задержка клавы в fl
Модератор: WWolf
F4DiS
задержка клавы в fl
11 май 2019, 19:26
железо
Host: HP-250-G5 Kernel: 4.15.0-20-generic x86_64 bits: 64 compiler: gcc
v: 7.3.0 Desktop: Xfce 4.12.3 Distro: Linux Mint 19.1 Tessa
base: Ubuntu 18.04 bionic
Type: Laptop System: HP product: HP 250 G5 Notebook PC
v: Type1ProductConfigId serial: <filter>
Mobo: HP model: 81F0 v: 63.38 serial: <filter> UEFI: Insyde v: F.21
date: 10/27/2016
ID-1: BAT1 charge: 40.7 Wh condition: 40.7/41.6 Wh (98%)
model: COMPAL PABAS0241231 status: Full
Topology: Dual Core model: Intel Core i3-5005U bits: 64 type: MT MCP
arch: Broadwell rev: 4 L2 cache: 3072 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 15963
Speed: 1478 MHz min/max: 500/1900 MHz Core speeds (MHz): 1: 1478 2: 1643
3: 1535 4: 1505
Device-1: Intel HD Graphics 5500 vendor: Hewlett-Packard driver: i915
v: kernel bus ID: 00:02.0
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430]
vendor: Hewlett-Packard driver: radeon v: kernel bus ID: 0d:00.0
Display: x11 server: X.Org 1.19.6 driver: ati,modesetting,radeon
unloaded: fbdev,vesa resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 5500 (Broadwell GT2)
v: 4.5 Mesa 18.2.8 direct render: Yes
Device-1: Intel Broadwell-U Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 00:03.0
Device-2: Intel Wildcat Point-LP High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 00:1b.0
Sound Server: ALSA v: k4.15.0-20-generic
vendor: Hewlett-Packard driver: r8169 v: 2.3LK-NAPI port: 5000
bus ID: 07:00.0
IF: enp7s0 state: down mac: <filter>
Device-2: Intel Wireless 3165 driver: iwlwifi v: kernel port: 4000
bus ID: 13:00.0
IF: wlp19s0 state: up mac: <filter>
Local Storage: total: 465.76 GiB used: 114.26 GiB (24.5%)
ID-1: /dev/sda vendor: Toshiba model: MQ01ABF050 size: 465.76 GiB
ID-1: / size: 24.74 GiB used: 21.96 GiB (88.8%) fs: ext4 dev: /dev/sda7
ID-2: swap-1 size: 8.74 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda6
System Temperatures: cpu: 44.5 C mobo: N/A gpu: radeon temp: 43 C
Processes: 204 Uptime: 2h 01m Memory: 3.77 GiB used: 2.11 GiB (56.1%)
inxi: 3.0.27
mint 19 x64. проблема в следующем: запускаю FL Studio (v12) а там с того момента пока я нажму на клавишу на клаве ноутбука (или внешней клаве или клавишу юсб синтезатора) и до момента пока пойдет звук проходит где то пол секунды. понимаю, конечно, что с таким железом да с таким совтом да еще и под эмулятором... но мне кажется что такого быть не должно. может смена ядра поможет, или вайн обновить/откатить, или либы доставить какие?
пс при вводе текста задержки замечено небыло но текста я особо и не вводил...
Решение F4DiS » 14 май 2019, 16:52
Проблема решена! установил размер аудио буфера buffer length в минимальное значение чтоб звук без треска был, лично у меня это 640 смп. по дефолту было 4096 и задержка 93мс, теперь всего 15 и играть уже можно. остаюсь на линуксе! юху! :yahoo:
Благодарил (а): 794 раза
задержка клавы в fl
11 май 2019, 19:44
F4DiS писал(а):
11 май 2019, 19:26
понимаю, конечно, что с таким совтом да еще и под эмулятором
В полне вероятно
Не смотрел в эту сторону https://lmms.io/
F4DiS
задержка клавы в fl
12 май 2019, 12:59
lmms класная штука, но даже если все необходимые функции я на ней найду, это займет оочень много времени. а на фл есть и куча туториалов и вообще это целая эко система, что бы это не значило. может ли помочь патч -ck например?
F4DiS
задержка клавы в fl
14 май 2019, 16:52
задержка клавы в fl
14 май 2019, 17:30
F4DiS писал(а):
14 май 2019, 16:52
you are welcome :redhat:
Вернуться в «Wine»
