Работает микрофон только когда подключены наушники(просто наушники через jack)
snap
06 май 2019, 22:42
Доброе время суток,купил ноут Trekstor Primebook P13, стояла Win10, микро и звук работал,поставил Linux Mint 19.1 Cinnamon x64, все работает кроме микро, он работает только когда в jack вставляешь наушники, без них не работает. Спасибо.
lspci -k
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers (rev 02)
Subsystem: Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers
Kernel driver in use: skl_uncore
00:02.0 VGA compatible controller: Intel Corporation Device 591e (rev 02)
Subsystem: Intel Corporation Device 591e
Kernel driver in use: i915
Kernel modules: i915
00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem (rev 02)
Subsystem: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem
Kernel driver in use: proc_thermal
Kernel modules: processor_thermal_device
00:07.0 Performance counters: Intel Corporation Device 1907 (rev 02)
Subsystem: Intel Corporation Device 2015
00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th Gen Core Processor Gaussian Mixture Model
Subsystem: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th Gen Core Processor Gaussian Mixture Model
00:14.0 USB controller: Intel Corporation Sunrise Point-LP USB 3.0 xHCI Controller (rev 21)
Subsystem: Intel Corporation Sunrise Point-LP USB 3.0 xHCI Controller
Kernel driver in use: xhci_hcd
00:14.2 Signal processing controller: Intel Corporation Sunrise Point-LP Thermal subsystem (rev 21)
Subsystem: Intel Corporation Sunrise Point-LP Thermal subsystem
Kernel driver in use: intel_pch_thermal
Kernel modules: intel_pch_thermal
00:15.0 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO I2C Controller #0 (rev 21)
Subsystem: Intel Corporation 100 Series PCH/Sunrise Point PCH I2C0 [Skylake/Kaby Lake LPSS I2C]
Kernel driver in use: intel-lpss
Kernel modules: intel_lpss_pci
00:15.1 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO I2C Controller #1 (rev 21)
Subsystem: Intel Corporation Sunrise Point-LP Serial IO I2C Controller
00:15.2 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO I2C Controller #2 (rev 21)
00:16.0 Communication controller: Intel Corporation Sunrise Point-LP CSME HECI #1 (rev 21)
Subsystem: Intel Corporation Sunrise Point-LP CSME HECI
Kernel driver in use: mei_me
Kernel modules: mei_me
00:17.0 SATA controller: Intel Corporation Sunrise Point-LP SATA Controller [AHCI mode] (rev 21)
Subsystem: Intel Corporation Sunrise Point-LP SATA Controller [AHCI mode]
Kernel driver in use: ahci
Kernel modules: ahci
00:1d.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #9 (rev f1)
Kernel driver in use: pcieport
00:1e.0 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO UART Controller #0 (rev 21)
Subsystem: Intel Corporation Sunrise Point-LP Serial IO UART Controller
00:1e.4 SD Host controller: Intel Corporation Device 9d2b (rev 21)
Subsystem: Intel Corporation Device 9d2b
Kernel driver in use: sdhci-pci
Kernel modules: sdhci_pci
00:1e.6 SD Host controller: Intel Corporation Sunrise Point-LP Secure Digital IO Controller (rev 21)
Subsystem: Intel Corporation Sunrise Point-LP Secure Digital IO Controller
00:1f.0 ISA bridge: Intel Corporation Sunrise Point-LP LPC Controller (rev 21)
Subsystem: Intel Corporation Sunrise Point-LP LPC Controller
00:1f.2 Memory controller: Intel Corporation Sunrise Point-LP PMC (rev 21)
Subsystem: Intel Corporation Sunrise Point-LP PMC
00:1f.3 Audio device: Intel Corporation Sunrise Point-LP HD Audio (rev 21)
Subsystem: Realtek Semiconductor Co., Ltd. Sunrise Point-LP HD Audio
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel, snd_soc_skl
00:1f.4 SMBus: Intel Corporation Sunrise Point-LP SMBus (rev 21)
Subsystem: Intel Corporation Sunrise Point-LP SMBus
Kernel modules: i2c_i801
01:00.0 Network controller: Intel Corporation Wireless 3165 (rev 79)
Subsystem: Intel Corporation Wireless 3165
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
Host: p13 Kernel: 5.1.0-050100-generic x86_64 bits: 64 compiler: gcc
v: 8.3.0 Desktop: Cinnamon 4.0.10 Distro: Linux Mint 19.1 Tessa
base: Ubuntu 18.04 bionic
Type: Laptop System: TrekStor product: PrimeBook P13 v: N/A
serial: <filter>
Mobo: TS_emdoor model: Kabylake_m3_V01 serial: <filter> UEFI: N/A
v: PSB132256-1_BIOS_V2.1.4 date: 04/10/2017
ID-1: BAT0 charge: 44.2 Wh condition: 47.0/47.0 Wh (100%)
model: Intel SR 1 SR Real Battery status: Charging
Topology: Dual Core model: Intel Core m3-7Y30 bits: 64 type: MT MCP
arch: Kaby Lake rev: 9 L2 cache: 4096 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 12864
Speed: 600 MHz min/max: 400/2600 MHz Core speeds (MHz): 1: 600 2: 600
3: 600 4: 600
Device-1: Intel driver: i915 v: kernel bus ID: 00:02.0
Display: x11 server: X.Org 1.19.6 driver: modesetting unloaded: fbdev,vesa
resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 615 (Kaby Lake GT2)
v: 4.5 Mesa 18.2.8 direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Realtek
Sound Server: ALSA v: k5.1.0-050100-generic
Device-1: Intel Wireless 3165 driver: iwlwifi v: kernel port: f040
bus ID: 01:00.0
Local Storage: total: 119.24 GiB used: 12.40 GiB (10.4%)
ID-1: /dev/sda vendor: Foresee model: 128GB SSD size: 119.24 GiB
ID-1: / size: 113.00 GiB used: 12.39 GiB (11.0%) fs: ext4 dev: /dev/sda4
ID-2: swap-1 size: 3.75 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda1
System Temperatures: cpu: 52.0 C mobo: N/A
Processes: 207 Uptime: 14m Memory: 3.77 GiB used: 1.30 GiB (34.4%)
inxi: 3.0.27
broken
Благодарил (а): 21 раз
07 май 2019, 08:14
Внесу свои 5.
У меня
00:16.0 Communication controller: Intel Corporation 8 Series/C220 Series Chipset Family MEI Controller #1 (rev 04)
	Subsystem: ASUSTeK Computer Inc. 8 Series/C220 Series Chipset Family MEI Controller
00:1b.0 Audio device: Intel Corporation 8 Series/C220 Series Chipset High Definition Audio Controller (rev 05)
	Subsystem: ASUSTeK Computer Inc. 8 Series/C220 Series Chipset High Definition Audio Controller
Я вижу явное отличие в используемых модулях, но сказать по этому поводу ничего не могу поскольку не знаю может ли это влиять. В любом случае информация лишней не бывает.
snap
07 май 2019, 13:46
Предлагаешь убить второй модуль? (snd_soc_skl)
07 май 2019, 13:48
Попробуй лучше pavucontrol.
snap
07 май 2019, 14:55
etamax писал(а):
07 май 2019, 13:48
Если было все так просто, я бы тему не создавал
snap
07 май 2019, 19:30
broken писал(а):
07 май 2019, 08:14
Внесу свои 5.
У меня
Не помогло, я отправил модуль в blacklist,ребутнул ноут, и все так же
Вернуться в «Звуковые карты»
