Перевёрнутое изображение при использовании веб камеры
Ctyx
Благодарил (а): 64 раза
04 май 2019, 18:47
Суть проблемы -- перевёрнутое изображение встроенной веб-камеры в Skype и Viber. Инфо о железе и системе:
Host: ctyx-pc Kernel: 4.9.0-9-amd64 x86_64 bits: 64 compiler: gcc v: 6.3.0
Desktop: Cinnamon 4.0.10 Distro: LMDE 3 Cindy base: Debian 9.3 stretch
Type: Laptop System: ASUSTeK product: K52Jc v: 1.0 serial: <filter>
Mobo: ASUSTeK model: K52Jc v: 1.0 serial: <filter>
BIOS: American Megatrends v: K52Jc.206 date: 03/29/2010
Topology: Dual Core model: Intel Core i3 M 350 bits: 64 type: MT MCP
arch: Nehalem rev: 2 L2 cache: 3072 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 18631
Speed: 933 MHz min/max: 933/2266 MHz Core speeds (MHz): 1: 933 2: 933
3: 933 4: 933
Device-1: Intel Core Processor Integrated Graphics vendor: ASUSTeK
Device-2: NVIDIA GT218M [GeForce 310M] vendor: ASUSTeK driver: N/A
bus ID: 01:00.0
Display: x11 server: X.Org 1.19.2 driver: modesetting unloaded: fbdev,vesa
resolution: 1366x768~60Hz
OpenGL: renderer: Mesa DRI Intel Ironlake Mobile v: 2.1 Mesa 13.0.6
Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: ASUSTeK
Sound Server: ALSA v: k4.9.0-9-amd64
Device-1: Qualcomm Atheros AR9285 Wireless Network Adapter
vendor: AzureWave AW-NE785 / AW-NE785H 802.11bgn driver: ath9k v: kernel
port: d000 bus ID: 03:00.0
IF: wls1 state: down mac: <filter>
Device-2: JMicron JMC250 PCI Express Gigabit Ethernet vendor: ASUSTeK
driver: jme v: 1.0.8 port: a000 bus ID: 04:00.5
IF: ens5f5 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 344.68 GiB used: 159.80 GiB (46.4%)
ID-1: /dev/sda vendor: Kingston model: SA400S37120G size: 111.79 GiB
ID-2: /dev/sdb vendor: Seagate model: ST9250315AS size: 232.89 GiB
ID-1: / size: 22.39 GiB used: 6.77 GiB (30.2%) fs: ext4 dev: /dev/sda3
ID-2: /home size: 28.71 GiB used: 1.28 GiB (4.4%) fs: ext4 dev: /dev/sda4
System Temperatures: cpu: 52.0 C mobo: N/A
Processes: 227 Uptime: 51m Memory: 5.63 GiB used: 1.49 GiB (26.5%)
Init: systemd runlevel: 5 Compilers: gcc: 6.3.0 Shell: bash v: 4.4.12
inxi: 3.0.32
при этом в проге Sheese изображение отображается нормально. Библиотека libv4l установлена. Решения из сети результата не принесли. Пробовал ставить v4l2ucp, в Sheese изображение переворачивается, в Skype и Viber -- без изменения, т.е. перевёрнутое. :dash2:
Решение symon2014 » 04 май 2019, 20:51
Exec=sh -c 'export LIBV4LCONTROL_FLAGS=2 && LD_PRELOAD=/usr/lib/x86_64-linux-gnu/libv4l/v4l1compat.so /opt/viber/Viber'
Note the integer value 2 for camera inversion.
Обратите внимание на целое значение 2 для инверсии камеры.
Viber а не viber и к тому же путь с /opt.
Griga211
Благодарил (а): 9 раз
04 май 2019, 19:08
А если камеру перевернуть? :-D
FreeStyler
Решено: 7
Благодарил (а): 772 раза
04 май 2019, 19:08
Ctyx, что за Sheese? Ши3а? :crazy:
deadmau5 - Harmonic Mix
Ctyx
04 май 2019, 19:11
чиииз ( :-D ).
Griga211
04 май 2019, 19:20
Скорми вебку vlc. Как там изображение?
Ctyx
04 май 2019, 19:24
Попробовал через vlc -- всё норм
Griga211
04 май 2019, 19:29
Ctyx, тогда это проблема именно вайбера, где то валялась старая вебка, сейчас поставлю вайбер и проверю
04 май 2019, 19:33
Ctyx
04 май 2019, 19:35
skype и viber ставил deb-пакетами с официальных сайтов, правка ярлыков запуска не помогла. Нашёл совет об установке 32-битной версии libv4l, но при попытке установки вылезло сообщение об удалении чуть не половины системы, том числе и корицы.... :hoho: корочь не стал я баловаться настолько... :smile:
Благодарил (а): 794 раза
04 май 2019, 19:35
Попробуй так запустить skype
LD_PRELOAD=/usr/lib/x86_64-linux-gnu/libv4l/v4l1compat.so skype
Ctyx
04 май 2019, 19:41
ctyx@ctyx-pc:~$ LD_PRELOAD=/usr/lib/x86_64-linux-gnu/libv4l/v4l1compat.so skype
skype: command not found
я это уже пробовал, там путь по-моему другой...
Ctyx
04 май 2019, 19:48
Ooooo!!! Заработало! Чуть подправил:
sudo LD_PRELOAD=/usr/lib/x86_64-linux-gnu/libv4l/v4l1compat.so skypeforlinux
Griga211
04 май 2019, 19:49
Griga211 писал(а):
04 май 2019, 19:29
Вы не поверите!)Я сейчас видел халка) :-D :-D :-D :crazy:
Но все таки он был как полагается, головой в верх)
04 май 2019, 19:51
sudo не надо
Ctyx
04 май 2019, 19:56
Со skype разобрались, СПАСИБО! А от с viber'ом пока так не прокат
ctyx@ctyx-pc:~$ LD_PRELOAD=/usr/lib/x86_64-linux-gnu/libv4l/v4l1compat.so viber
No command 'viber' found, did you mean:
Command 'biber' from package 'biber' (main)
viber: command not found
04 май 2019, 19:58
Ctyx, посмотри в ярлыке команду запуска
Ctyx
04 май 2019, 19:59
путь напомните, сорри пока что нуб :blush:
04 май 2019, 20:02
Жми в меню редактировать свойства , там смотри.
04 май 2019, 20:02
ПКМ на кнопку Меню, Настройка, Меню, Открыть редактор меню, найти там кнопку запуска viber, свойства
Ctyx
04 май 2019, 20:17
что-то viber не хочет. Может не так ярлык правлю?
[Desktop Entry]
Name=Viber
Comment=Viber VoIP and messenger
#Exec=/opt/viber/Viber %u
Exec=sh -c 'LD_PRELOAD=/usr/lib/x86_64-linux-gnu/libv4l/v4l1compat.so viber %U'
Icon=/usr/share/pixmaps/viber.png
Terminal=false
Type=Application
Categories=Network;InstantMessaging;P2P;
MimeType=x-scheme-handler/viber;
Вернуться в «Мультимедиа»
