- LM 19.1 x64
- Cinnamon
- System:
Host: normandy Kernel: 4.15.0-47-generic x86_64 bits: 64 compiler: gcc v: 7.3.0 Desktop: Cinnamon 4.0.10 Distro: Linux Mint 19.1 Tessa base: Ubuntu 18.04 bionic Machine: Type: Laptop System: ASUSTeK product: K42Dr v: 1.0 serial: <filter> Mobo: ASUSTeK model: K42Dr v: 1.0 serial: <filter> BIOS: American Megatrends v: K42Dr.209 date: 09/30/2010 Battery: ID-1: BAT0 charge: 19.3 Wh condition: 19.5/47.3 Wh (41%) model: ASUSTek K52F-44 status: Unknown CPU: Topology: Triple Core model: AMD Phenom II N830 bits: 64 type: MCP arch: K10 rev: 3 L2 cache: 1536 KiB flags: lm nx pae sse sse2 sse3 sse4a svm bogomips: 12599 Speed: 1500 MHz min/max: 800/2100 MHz Core speeds (MHz): 1: 1500 2: 800 3: 800 Graphics: Device-1: AMD Park [Mobility Radeon HD 5430/5450/5470] vendor: ASUSTeK driver: radeon v: kernel bus ID: 01:00.0 Display: x11 server: X.Org 1.19.6 driver: ati,radeon unloaded: fbdev,modesetting,vesa resolution: 1366x768~60Hz OpenGL: renderer: AMD CEDAR (DRM 2.50.0 / 4.15.0-47-generic LLVM 7.0.0) v: 3.3 Mesa 18.2.8 direct render: Yes Audio: Device-1: AMD SBx00 Azalia vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 00:14.2 Device-2: AMD Cedar HDMI Audio [Radeon HD 5400/6300/7300 Series] vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 01:00.1 Sound Server: ALSA v: k4.15.0-47-generic Network: Device-1: Qualcomm Atheros AR9285 Wireless Network Adapter vendor: AzureWave AW-NE785 / AW-NE785H 802.11bgn driver: ath9k v: kernel port: e000 bus ID: 04:00.0 IF: wlp4s0 state: up mac: <filter> Device-2: JMicron JMC250 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: jme v: 1.0.8 port: d000 bus ID: 05:00.5 IF: enp5s0f5 state: down mac: <filter> Drives: Local Storage: total: 465.76 GiB used: 35.03 GiB (7.5%) ID-1: /dev/sda vendor: Toshiba model: MQ01ABF050 size: 465.76 GiB Partition: ID-1: / size: 91.17 GiB used: 25.32 GiB (27.8%) fs: ext4 dev: /dev/sda5 ID-2: /home size: 362.11 GiB used: 9.71 GiB (2.7%) fs: ext4 dev: /dev/sda6 ID-3: swap-1 size: 3.72 GiB used: 468 KiB (0.0%) fs: swap dev: /dev/sda1 Sensors: System Temperatures: cpu: 66.5 C mobo: N/A gpu: radeon temp: 69 C Fan Speeds (RPM): N/A Info: Processes: 191 Uptime: 1d 4h 58m Memory: 3.85 GiB used: 2.27 GiB (58.8%) Init: systemd runlevel: 5 Compilers: gcc: 7.3.0 Shell: bash v: 4.4.19 inxi: 3.0.27
- У меня последний Linux Mint x64. Скачал с офф. сайта дистрибутив браузера тор. Разархивировал. Дважды кликаю на ярлык - ничего не происходит. Смотрю настройки ярлыка через через контектстное меню - галочка стоит как исполняемый файл. Смушает надпись в контектсном меню:
"sh -c '"$(dirname "$*")"/Browser/start-tor-browser --detach || ([ ! -x "$(dirname "$*")"/Browser/start-tor-browser ] && "$(dirname "$*")"/start-tor-browser --detach)' dummy %k"
Может из-за этого не запускается? Кто знает? Понятия не имею что здесь написано. Пару месяцев назад прошлая версия запускалась без проблем аналогично.
Не запускается браузер TOR
- Решено: 18
Так можно ведь PPA прописать и установить его как пакет: https://www.ubuntuupdates.org/ppa/tor?dist=bionic
Или по каким-то причинам нужен именно подписанный архив?
sergey@normandy:~$ gpg --keyserver keys.gnupg.net --recv 886DDD89
gpg: создан щит с ключами '/home/sergey/.gnupg/pubring.kbx'
gpg: сбой при получении с сервера ключей: Нет данных
sergey@normandy:~$ gpg --export A3C4F0F979CAA22CDBA8F512EE8CBC9E886DDD89 | sudo apt-key add -
gpg: Внимание: нечего экспортировать
gpg: не найдено данных формата OpenPGP.
sergey@normandy:~$ sudo sh -c 'echo "deb http://deb.torproject.org/torproject.org/ bionic main" >> /etc/apt/sources.list.d/tor.list'
sergey@normandy:~$ sudo add-apt-repository ppa:webupd8team/tor-browser
[sudo] пароль для sergey:
HTTP Error 404: Not Found
Не удаётся добавить PPA: «'Данный PPA не поддерживает bionic'».
Я смог запустить свой изначально разархивированный файл через командную сроку через символы ./
