по механической клавиатуре народные страдания
djsantehnik
Благодарил (а): 24 раза
11 апр 2019, 15:42
Модель CORSAIR K70 RGB
Все танцы ни к чему не привели, все делалось по описанию из кинохи https://www.youtube.com/watch?v=xfm2D15q4eE
Может кто чем запоможет
простыня inxi -Fxz
kostusa@kostusa-EB-7528:~$  inxi -Fxz
  Host: kostusa-EB-7528 Kernel: 4.15.0-20-generic i686 bits: 32
  compiler: gcc v: 7.3.0 Desktop: Cinnamon 4.0.8
  Type: Desktop Mobo: MICRO-STAR model: EB-7528 v: 1.0 serial: <filter>
  BIOS: American Megatrends v: 1.3 date: 08/06/2008
  Topology: Quad Core model: Intel Core2 Quad Q8200 bits: 64 type: MCP
  arch: Penryn rev: 7 L2 cache: 2048 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 ssse3 bogomips: 18729
  Speed: 2341 MHz min/max: N/A Core speeds (MHz): 1: 2341 2: 2337 3: 2337
  4: 2340
  Device-1: Intel 82G33/G31 Express Integrated Graphics
  vendor: Micro-Star MSI driver: i915 v: kernel bus ID: 00:02.0
  Display: x11 server: X.Org 1.19.6 driver: intel
  unloaded: fbdev,modesetting,vesa resolution: 1680x1050~60Hz
  OpenGL: renderer: Mesa DRI Intel G33 x86/MMX/SSE2 v: 1.4 Mesa 18.0.5
  vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 00:1b.0
  Sound Server: ALSA v: k4.15.0-20-generic
  vendor: Micro-Star MSI driver: r8169 v: 2.3LK-NAPI port: d800
  bus ID: 02:00.0
  IF: ens33 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-2: Realtek RTL8188EE Wireless Network Adapter driver: rtl8188ee
  v: kernel port: e800 bus ID: 03:00.0
  IF: wls35 state: up mac: <filter>
  Local Storage: total: 298.09 GiB used: 16.52 GiB (5.5%)
  ID-1: /dev/sda vendor: Samsung model: HD321HJ size: 298.09 GiB
  ID-1: / size: 18.21 GiB used: 9.73 GiB (53.4%) fs: ext4 dev: /dev/sda1
  ID-2: /home size: 274.08 GiB used: 6.79 GiB (2.5%) fs: ext4 dev: /dev/sda2
  System Temperatures: cpu: 51.0 C mobo: N/A
  Processes: 191 Uptime: 3m Memory: 2.95 GiB used: 410.7 MiB (13.6%)
  inxi: 3.0.27
простыня lsusb
kostusa@kostusa-EB-7528:~$ lsusb
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 003: ID 1b1c:1b38 Corsair
Bus 002 Device 002: ID 1532:0016 Razer USA, Ltd DeathAdder Mouse
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
простыня sudo dmesg
kostusa@kostusa-EB-7528:~$ sudo dmesg
[sudo] пароль для kostusa:
[    0.000000] Linux version 4.15.0-20-generic (buildd@lgw01-amd64-033) (gcc version 7.3.0 (Ubuntu 7.3.0-16ubuntu3)) #21-Ubuntu SMP Tue Apr 24 06:15:38 UTC 2018 (Ubuntu 4.15.0-20.21-generic 4.15.17)
[    0.000000] KERNEL supported cpus:
[    0.000000]   Intel GenuineIntel
[    0.000000]   AMD AuthenticAMD
[    0.000000]   NSC Geode by NSC
[    0.000000]   Cyrix CyrixInstead
[    0.000000]   Centaur CentaurHauls
[    0.000000]   Transmeta GenuineTMx86
[    0.000000]   Transmeta TransmetaCPU
[    0.000000]   UMC UMC UMC UMC
[    0.000000] x86/fpu: x87 FPU will use FXSAVE
[    0.000000] e820: BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009fbff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009fc00-0x000000000009ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000bf69ffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000bf6a0000-0x00000000bf6adfff] ACPI data
[    0.000000] BIOS-e820: [mem 0x00000000bf6ae000-0x00000000bf6effff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000bf6f0000-0x00000000bf6fdfff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fff80000-0x00000000ffffffff] reserved
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] random: fast init done
[    0.000000] SMBIOS 2.5 present.
[    0.000000] DMI: MICRO-STAR INTERNATIONAL CO.,LTD EB-7528/EB-7528, BIOS V1.3 08/06/2008
[    0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000000] e820: last_pfn = 0xbf6a0 max_arch_pfn = 0x1000000
[    0.000000] MTRR default type: uncachable
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
[    0.000000]   A0000-BFFFF uncachable
[    0.000000]   C0000-CBFFF write-protect
[    0.000000]   CC000-DFFFF uncachable
[    0.000000]   E0000-EFFFF write-through
[    0.000000]   F0000-FFFFF write-protect
[    0.000000] MTRR variable ranges enabled:
[    0.000000]   0 base 000000000 mask F80000000 write-back
[    0.000000]   1 base 080000000 mask FC0000000 write-back
[    0.000000]   2 base 0BF700000 mask FFFF00000 uncachable
[    0.000000]   3 base 0BF800000 mask FFF800000 uncachable
[    0.000000]   4 disabled
[    0.000000]   5 disabled
[    0.000000]   6 disabled
[    0.000000]   7 disabled
[    0.000000] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.000000] total RAM covered: 3063M
[    0.000000] Found optimal setting for mtrr clean up
[    0.000000]  gran_size: 64K 	chunk_size: 16M 	num_reg: 4  	lose cover RAM: 0G
[    0.000000] found SMP MP-table at [mem 0x000ff780-0x000ff78f] mapped at [(ptrval)]
[    0.000000] Scanning 1 areas for low memory corruption
[    0.000000] initial memory mapped: [mem 0x00000000-0x163fffff]
[    0.000000] Base memory trampoline at [(ptrval)] 9b000 size 16384
[    0.000000] BRK [0x15f8d000, 0x15f8dfff] PGTABLE
[    0.000000] BRK [0x15f8e000, 0x15f8efff] PGTABLE
[    0.000000] RAMDISK: [mem 0x318c7000-0x34c5afff]
[    0.000000] ACPI: Early table checksum verification disabled
[    0.000000] ACPI: RSDP 0x00000000000F9690 000014 (v00 ACPIAM)
[    0.000000] ACPI: RSDT 0x00000000BF6A0000 00003C (v01 EXC    HOME     20080806 MSFT 00000097)
[    0.000000] ACPI: FACP 0x00000000BF6A0200 000084 (v01 7528EB A7528200 20080806 MSFT 00000097)
[    0.000000] ACPI: DSDT 0x00000000BF6A05C0 0059EF (v01 A7528  A7528200 00000200 INTL 20051117)
[    0.000000] ACPI: FACS 0x00000000BF6AE000 000040
[    0.000000] ACPI: APIC 0x00000000BF6A0390 00006C (v01 7528EB A7528200 20080806 MSFT 00000097)
[    0.000000] ACPI: MCFG 0x00000000BF6A0400 00003C (v01 7528EB OEMMCFG  20080806 MSFT 00000097)
[    0.000000] ACPI: SLIC 0x00000000BF6A0440 000176 (v01 EXC    HOME     20080806 MSFT 00000097)
[    0.000000] ACPI: OEMB 0x00000000BF6AE040 000071 (v01 7528EB A7528200 20080806 MSFT 00000097)
[    0.000000] ACPI: GSCI 0x00000000BF6AE0C0 002024 (v01 7528EB GMCHSCI  20080806 MSFT 00000097)
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] 2174MB HIGHMEM available.
[    0.000000] 887MB LOWMEM available.
[    0.000000]   mapped low ram: 0 - 377fe000
[    0.000000]   low ram: 0 - 377fe000
[    0.000000] tsc: Fast TSC calibration using PIT
[    0.000000] BRK [0x15f8f000, 0x15f8ffff] PGTABLE
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.000000]   Normal   [mem 0x0000000001000000-0x00000000377fdfff]
[    0.000000]   HighMem  [mem 0x00000000377fe000-0x00000000bf69ffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000001000-0x000000000009efff]
[    0.000000]   node   0: [mem 0x0000000000100000-0x00000000bf69ffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x00000000bf69ffff]
[    0.000000] On node 0 totalpages: 783934
[    0.000000]   DMA zone: 40 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 3998 pages, LIFO batch:0
[    0.000000]   Normal zone: 2180 pages used for memmap
[    0.000000]   Normal zone: 223230 pages, LIFO batch:31
[    0.000000]   HighMem zone: 556706 pages, LIFO batch:31
[    0.000000] Reserved but unavailable: 98 pages
[    0.000000] Using APIC driver default
[    0.000000] Reserving Intel graphics memory at 0x00000000bf800000-0x00000000bfffffff
[    0.000000] ACPI: PM-Timer IO Port: 0x808
[    0.000000] IOAPIC[0]: apic_id 4, version 32, address 0xfec00000, GSI 0-23
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[    0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.000000] PM: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
[    0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000dffff]
[    0.000000] PM: Registered nosave memory: [mem 0x000e0000-0x000fffff]
[    0.000000] e820: [mem 0xc0000000-0xfedfffff] available for PCI devices
[    0.000000] Booting paravirtualized kernel on bare hardware
[    0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[    0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1
[    0.000000] percpu: Embedded 30 pages/cpu @(ptrval) s93068 r0 d29812 u122880
[    0.000000] pcpu-alloc: s93068 r0 d29812 u122880 alloc=30*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 781714
[    0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-20-generic root=UUID=a8da6411-326b-4c69-8671-6aefa945b591 ro quiet splash vt.handoff=1
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Initializing CPU#0
[    0.000000] Initializing HighMem for node 0 (000377fe:000bf6a0)
[    0.000000] Initializing Movable for node 0 (00000000:00000000)
[    0.000000] Memory: 3034916K/3135736K available (8795K kernel code, 890K rwdata, 3448K rodata, 1088K init, 848K bss, 100820K reserved, 0K cma-reserved, 2226824K highmem)
[    0.000000] virtual kernel memory layout:
                   fixmap  : 0xfff14000 - 0xfffff000   ( 940 kB)
                 cpu_entry : 0xffa00000 - 0xffb39000   (1252 kB)
                   pkmap   : 0xff800000 - 0xffa00000   (2048 kB)
                   vmalloc : 0xf7ffe000 - 0xff7fe000   ( 120 MB)
                   lowmem  : 0xc0000000 - 0xf77fe000   ( 887 MB)
                     .init : 0xd5ced000 - 0xd5dfd000   (1088 kB)
                     .data : 0xd5896c88 - 0xd5cd9980   (4363 kB)
                     .text : 0xd5000000 - 0xd5896c88   (8795 kB)
[    0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 37746 entries in 74 pages
[    0.000000] Hierarchical RCU implementation.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] 	Tasks RCU enabled.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 2304, nr_irqs: 456, preallocated irqs: 16
[    0.000000] CPU 0 irqstacks, hard=(ptrval) soft=(ptrval)
[    0.000000] vt handoff: transparent VT on vt#1
[    0.000000] Console: colour dummy device 80x25
[    0.000000] console [tty0] enabled
[    0.000000] allocated 3145728 bytes of page_ext
[    0.000000] ACPI: Core revision 20170831
[    0.000000] ACPI: 1 ACPI AML tables successfully acquired and loaded
[    0.000000] APIC: Switch to symmetric I/O mode setup
[    0.000000] Enabling APIC mode:  Flat.  Using 1 I/O APICs
[    0.000000] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.020000] tsc: Fast TSC calibration using PIT
[    0.024000] tsc: Detected 2341.135 MHz processor
[    0.024000] Calibrating delay loop (skipped), value calculated using timer frequency.. 4682.27 BogoMIPS (lpj=9364540)
[    0.024000] pid_max: default: 32768 minimum: 301
[    0.024000] Security Framework initialized
[    0.024000] Yama: becoming mindful.
[    0.024000] AppArmor: AppArmor initialized
[    0.024000] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.024000] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.024000] CPU: Physical Processor ID: 0
[    0.024000] CPU: Processor Core ID: 0
[    0.024000] mce: CPU supports 6 MCE banks
[    0.024000] CPU0: Thermal monitoring enabled (TM2)
[    0.024000] process: using mwait in idle threads
[    0.024000] Last level iTLB entries: 4KB 128, 2MB 4, 4MB 4
[    0.024000] Last level dTLB entries: 4KB 256, 2MB 0, 4MB 32, 1GB 0
[    0.024000] Spectre V2 : Mitigation: Full generic retpoline
[    0.024000] Spectre V2 : Spectre v2 mitigation: Filling RSB on context switch
[    0.024000] Freeing SMP alternatives memory: 36K
[    0.036000] smpboot: CPU0: Intel(R) Core(TM)2 Quad  CPU   Q8200  @ 2.33GHz (family: 0x6, model: 0x17, stepping: 0x7)
[    0.036000] Performance Events: PEBS fmt0+, Core2 events, Intel PMU driver.
[    0.036000] ... version:                2
[    0.036000] ... bit width:              40
[    0.036000] ... generic registers:      2
[    0.036000] ... value mask:             000000ffffffffff
[    0.036000] ... max period:             000000007fffffff
[    0.036000] ... fixed-purpose events:   3
[    0.036000] ... event mask:             0000000700000003
[    0.036000] Hierarchical SRCU implementation.
[    0.036000] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.036000] smp: Bringing up secondary CPUs ...
[    0.036000] CPU 1 irqstacks, hard=adbdca22 soft=764650ab
[    0.036000] x86: Booting SMP configuration:
[    0.036000] .... node  #0, CPUs:      #1
[    0.004000] Initializing CPU#1
[    0.036115] CPU 2 irqstacks, hard=a91c21e6 soft=66eaed1f
[    0.036117]  #2
[    0.004000] Initializing CPU#2
[    0.038418] CPU 3 irqstacks, hard=0d134233 soft=e92782d5
[    0.038418]  #3
[    0.004000] Initializing CPU#3
[    0.040099] smp: Brought up 1 node, 4 CPUs
[    0.040099] smpboot: Max logical packages: 1
[    0.040099] smpboot: Total of 4 processors activated (18729.08 BogoMIPS)
[    0.044127] devtmpfs: initialized
[    0.044387] evm: security.selinux
[    0.044388] evm: security.SMACK64
[    0.044389] evm: security.SMACK64EXEC
[    0.044390] evm: security.SMACK64TRANSMUTE
[    0.044390] evm: security.SMACK64MMAP
[    0.044391] evm: security.apparmor
[    0.044392] evm: security.ima
[    0.044393] evm: security.capability
[    0.044410] PM: Registering ACPI NVS region [mem 0xbf6ae000-0xbf6effff] (270336 bytes)
[    0.044410] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.044410] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.044410] pinctrl core: initialized pinctrl subsystem
[    0.044410] RTC time: 12:14:20, date: 04/11/19
[    0.044410] NET: Registered protocol family 16
[    0.044531] audit: initializing netlink subsys (disabled)
[    0.044538] audit: type=2000 audit(1554984860.044:1): state=initialized audit_enabled=0 res=1
[    0.044538] EISA bus registered
[    0.044538] cpuidle: using governor ladder
[    0.044538] cpuidle: using governor menu
[    0.044538] ACPI: bus type PCI registered
[    0.044538] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.044538] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[    0.044538] PCI: not using MMCONFIG
[    0.044772] PCI: PCI BIOS area is rw and x. Use pci=nobios if you want it NX.
[    0.044823] PCI: PCI BIOS revision 3.00 entry at 0xf0031, last bus=4
[    0.044824] PCI: Using configuration type 1 for base access
[    0.049000] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.049000] ACPI: Added _OSI(Module Device)
[    0.049000] ACPI: Added _OSI(Processor Device)
[    0.049000] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.049000] ACPI: Added _OSI(Processor Aggregator Device)
[    0.049000] ACPI: Executed 1 blocks of module-level executable AML code
[    0.049855] ACPI: Interpreter enabled
[    0.049894] ACPI: (supports S0 S1 S4 S5)
[    0.049896] ACPI: Using IOAPIC for interrupt routing
[    0.049929] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[    0.051413] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in ACPI motherboard resources
[    0.051414] PCI: Using MMCONFIG for extended config space
[    0.051424] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.051808] ACPI: GPE 0x1B active on init
[    0.052007] ACPI: Enabled 12 GPEs in block 00 to 1F
[    0.060274] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[    0.060279] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[    0.060565] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
[    0.060854] PCI host bridge to bus 0000:00
[    0.060857] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.060859] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.060861] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.060863] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000dffff window]
[    0.060865] pci_bus 0000:00: root bus resource [mem 0xbf700000-0xdfffffff window]
[    0.060867] pci_bus 0000:00: root bus resource [mem 0xf0000000-0xffffffff window]
[    0.060869] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.060880] pci 0000:00:00.0: [8086:29c0] type 00 class 0x060000
[    0.060995] pci 0000:00:02.0: [8086:29c2] type 00 class 0x030000
[    0.061005] pci 0000:00:02.0: reg 0x10: [mem 0xfe980000-0xfe9fffff]
[    0.061010] pci 0000:00:02.0: reg 0x14: [io  0xcc00-0xcc07]
[    0.061015] pci 0000:00:02.0: reg 0x18: [mem 0xd0000000-0xdfffffff pref]
[    0.061019] pci 0000:00:02.0: reg 0x1c: [mem 0xfe800000-0xfe8fffff]
[    0.061149] pci 0000:00:1b.0: [8086:27d8] type 00 class 0x040300
[    0.061168] pci 0000:00:1b.0: reg 0x10: [mem 0xfe978000-0xfe97bfff 64bit]
[    0.061234] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[    0.061330] pci 0000:00:1c.0: [8086:27d0] type 01 class 0x060400
[    0.061394] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.061497] pci 0000:00:1c.1: [8086:27d2] type 01 class 0x060400
[    0.061566] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[    0.061669] pci 0000:00:1c.3: [8086:27d6] type 01 class 0x060400
[    0.061738] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[    0.061841] pci 0000:00:1d.0: [8086:27c8] type 00 class 0x0c0300
[    0.061879] pci 0000:00:1d.0: reg 0x20: [io  0xc880-0xc89f]
[    0.061989] pci 0000:00:1d.1: [8086:27c9] type 00 class 0x0c0300
[    0.062027] pci 0000:00:1d.1: reg 0x20: [io  0xc800-0xc81f]
[    0.062137] pci 0000:00:1d.2: [8086:27ca] type 00 class 0x0c0300
[    0.062174] pci 0000:00:1d.2: reg 0x20: [io  0xc480-0xc49f]
[    0.062284] pci 0000:00:1d.3: [8086:27cb] type 00 class 0x0c0300
[    0.062322] pci 0000:00:1d.3: reg 0x20: [io  0xc400-0xc41f]
[    0.062436] pci 0000:00:1d.7: [8086:27cc] type 00 class 0x0c0320
[    0.062455] pci 0000:00:1d.7: reg 0x10: [mem 0xfe977c00-0xfe977fff]
[    0.062526] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[    0.062619] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[    0.062750] pci 0000:00:1f.0: [8086:27b8] type 00 class 0x060100
[    0.062829] pci 0000:00:1f.0: Force enabled HPET at 0xfed00000
[    0.062835] pci 0000:00:1f.0: quirk: [io  0x0800-0x087f] claimed by ICH6 ACPI/GPIO/TCO
[    0.062839] pci 0000:00:1f.0: quirk: [io  0x0480-0x04bf] claimed by ICH6 GPIO
[    0.062842] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0a00 (mask 00ff)
[    0.062845] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 2 PIO at 0a00 (mask 0017)
[    0.062848] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 3 PIO at 4700 (mask 00ff)
[    0.062952] pci 0000:00:1f.1: [8086:27df] type 00 class 0x01018a
[    0.062968] pci 0000:00:1f.1: reg 0x10: [io  0x0000-0x0007]
[    0.062975] pci 0000:00:1f.1: reg 0x14: [io  0x0000-0x0003]
[    0.062983] pci 0000:00:1f.1: reg 0x18: [io  0x08f0-0x08f7]
[    0.062991] pci 0000:00:1f.1: reg 0x1c: [io  0x08f8-0x08fb]
[    0.062999] pci 0000:00:1f.1: reg 0x20: [io  0xffa0-0xffaf]
[    0.063016] pci 0000:00:1f.1: legacy IDE quirk: reg 0x10: [io  0x01f0-0x01f7]
[    0.063017] pci 0000:00:1f.1: legacy IDE quirk: reg 0x14: [io  0x03f6]
[    0.063019] pci 0000:00:1f.1: legacy IDE quirk: reg 0x18: [io  0x0170-0x0177]
[    0.063021] pci 0000:00:1f.1: legacy IDE quirk: reg 0x1c: [io  0x0376]
[    0.063719] pci 0000:00:1f.2: [8086:27c0] type 00 class 0x01018f
[    0.063733] pci 0000:00:1f.2: reg 0x10: [io  0xc080-0xc087]
[    0.063740] pci 0000:00:1f.2: reg 0x14: [io  0xc000-0xc003]
[    0.063747] pci 0000:00:1f.2: reg 0x18: [io  0xbc00-0xbc07]
[    0.063754] pci 0000:00:1f.2: reg 0x1c: [io  0xb880-0xb883]
[    0.063761] pci 0000:00:1f.2: reg 0x20: [io  0xb800-0xb80f]
[    0.063793] pci 0000:00:1f.2: PME# supported from D3hot
[    0.063884] pci 0000:00:1f.3: [8086:27da] type 00 class 0x0c0500
[    0.063934] pci 0000:00:1f.3: reg 0x20: [io  0x0400-0x041f]
[    0.064082] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.064146] pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000
[    0.064173] pci 0000:02:00.0: reg 0x10: [io  0xd800-0xd8ff]
[    0.064199] pci 0000:02:00.0: reg 0x18: [mem 0xfdfff000-0xfdffffff 64bit pref]
[    0.064215] pci 0000:02:00.0: reg 0x20: [mem 0xfdfe0000-0xfdfeffff 64bit pref]
[    0.064226] pci 0000:02:00.0: reg 0x30: [mem 0xfeaf0000-0xfeafffff pref]
[    0.064303] pci 0000:02:00.0: supports D1 D2
[    0.064305] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.080021] pci 0000:00:1c.1: PCI bridge to [bus 02]
[    0.080025] pci 0000:00:1c.1:   bridge window [io  0xd000-0xdfff]
[    0.080028] pci 0000:00:1c.1:   bridge window [mem 0xfea00000-0xfeafffff]
[    0.080033] pci 0000:00:1c.1:   bridge window [mem 0xfdf00000-0xfdffffff 64bit pref]
[    0.080096] pci 0000:03:00.0: [10ec:8179] type 00 class 0x028000
[    0.080127] pci 0000:03:00.0: reg 0x10: [io  0xe800-0xe8ff]
[    0.080156] pci 0000:03:00.0: reg 0x18: [mem 0xfebfc000-0xfebfffff 64bit]
[    0.080262] pci 0000:03:00.0: supports D1 D2
[    0.080264] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.096022] pci 0000:00:1c.3: PCI bridge to [bus 03]
[    0.096026] pci 0000:00:1c.3:   bridge window [io  0xe000-0xefff]
[    0.096029] pci 0000:00:1c.3:   bridge window [mem 0xfeb00000-0xfebfffff]
[    0.096104] pci 0000:00:1e.0: PCI bridge to [bus 04] (subtractive decode)
[    0.096113] pci 0000:00:1e.0:   bridge window [io  0x0000-0x0cf7 window] (subtractive decode)
[    0.096114] pci 0000:00:1e.0:   bridge window [io  0x0d00-0xffff window] (subtractive decode)
[    0.096116] pci 0000:00:1e.0:   bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[    0.096118] pci 0000:00:1e.0:   bridge window [mem 0x000d0000-0x000dffff window] (subtractive decode)
[    0.096120] pci 0000:00:1e.0:   bridge window [mem 0xbf700000-0xdfffffff window] (subtractive decode)
[    0.096122] pci 0000:00:1e.0:   bridge window [mem 0xf0000000-0xffffffff window] (subtractive decode)
[    0.096140] pci_bus 0000:00: on NUMA node 0
[    0.097021] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 *10 11 12 14 15)
[    0.097097] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[    0.097167] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[    0.097236] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 *5 6 7 10 11 12 14 15)
[    0.097305] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[    0.097375] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[    0.097445] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[    0.097515] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 *10 11 12 14 15)
[    0.100003] SCSI subsystem initialized
[    0.100026] libata version 3.00 loaded.
[    0.100042] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[    0.100042] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.100042] pci 0000:00:02.0: vgaarb: bridge control possible
[    0.100042] vgaarb: loaded
[    0.100053] ACPI: bus type USB registered
[    0.100075] usbcore: registered new interface driver usbfs
[    0.100086] usbcore: registered new interface driver hub
[    0.100108] usbcore: registered new device driver usb
[    0.100173] EDAC MC: Ver: 3.0.0
[    0.100173] PCI: Using ACPI for IRQ routing
[    0.100173] PCI: pci_cache_line_size set to 64 bytes
[    0.100173] e820: reserve RAM buffer [mem 0x0009fc00-0x0009ffff]
[    0.100173] e820: reserve RAM buffer [mem 0xbf6a0000-0xbfffffff]
[    0.100234] NetLabel: Initializing
[    0.100235] NetLabel:  domain hash size = 128
[    0.100236] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.100251] NetLabel:  unlabeled traffic allowed by default
[    0.100277] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[    0.100277] hpet clockevent registered
[    0.100277] HPET: 3 timers in total, 0 timers will be used for per-cpu timer
[    0.100277] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[    0.100277] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[    0.104035] clocksource: Switched to clocksource hpet
[    0.121811] VFS: Disk quotas dquot_6.6.0
[    0.121838] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.121990] AppArmor: AppArmor Filesystem Enabled
[    0.122034] pnp: PnP ACPI init
[    0.122156] system 00:00: [mem 0xfed14000-0xfed19fff] has been reserved
[    0.122163] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.122248] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.122504] pnp 00:02: [dma 0 disabled]
[    0.122574] pnp 00:02: Plug and Play ACPI device, IDs PNP0501 (active)
[    0.122854] pnp 00:03: [dma 2]
[    0.122911] pnp 00:03: Plug and Play ACPI device, IDs PNP0700 (active)
[    0.123065] system 00:04: [io  0x04d0-0x04d1] has been reserved
[    0.123068] system 00:04: [io  0x0800-0x087f] has been reserved
[    0.123070] system 00:04: [io  0x0480-0x04bf] has been reserved
[    0.123073] system 00:04: [mem 0xfed1c000-0xfed1ffff] has been reserved
[    0.123075] system 00:04: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.123077] system 00:04: [mem 0xfed45000-0xfed89fff] has been reserved
[    0.123083] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.123203] system 00:05: [mem 0xffc00000-0xfff7ffff] has been reserved
[    0.123208] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.123345] system 00:06: [mem 0xfec00000-0xfec00fff] could not be reserved
[    0.123348] system 00:06: [mem 0xfee00000-0xfee00fff] has been reserved
[    0.123353] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.123533] system 00:07: [io  0x0a00-0x0adf] has been reserved
[    0.123535] system 00:07: [io  0x0ae0-0x0aef] has been reserved
[    0.123541] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.123777] pnp 00:08: [dma 0 disabled]
[    0.123874] pnp 00:08: Plug and Play ACPI device, IDs PNP0501 (active)
[    0.124192] pnp 00:09: [dma 0 disabled]
[    0.124311] pnp 00:09: Plug and Play ACPI device, IDs PNP0400 (active)
[    0.124402] system 00:0a: [mem 0xe0000000-0xefffffff] has been reserved
[    0.124407] system 00:0a: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.124618] system 00:0b: [mem 0x00000000-0x0009ffff] could not be reserved
[    0.124621] system 00:0b: [mem 0x000c0000-0x000cffff] could not be reserved
[    0.124623] system 00:0b: [mem 0x000e0000-0x000fffff] could not be reserved
[    0.124626] system 00:0b: [mem 0x00100000-0xbf6fffff] could not be reserved
[    0.124631] system 00:0b: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.124783] pnp: PnP ACPI: found 12 devices
[    0.124787] PnPBIOS: Disabled
[    0.163607] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.163622] pci 0000:00:1c.0: bridge window [io  0x1000-0x0fff] to [bus 01] add_size 1000
[    0.163626] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 01] add_size 200000 add_align 100000
[    0.163629] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff] to [bus 01] add_size 200000 add_align 100000
[    0.163642] pci 0000:00:1c.3: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03] add_size 200000 add_align 100000
[    0.163660] pci 0000:00:1c.0: BAR 14: assigned [mem 0xc0000000-0xc01fffff]
[    0.163667] pci 0000:00:1c.0: BAR 15: assigned [mem 0xc0200000-0xc03fffff 64bit pref]
[    0.163674] pci 0000:00:1c.3: BAR 15: assigned [mem 0xc0400000-0xc05fffff 64bit pref]
[    0.163677] pci 0000:00:1c.0: BAR 13: assigned [io  0x1000-0x1fff]
[    0.163680] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.163683] pci 0000:00:1c.0:   bridge window [io  0x1000-0x1fff]
[    0.163687] pci 0000:00:1c.0:   bridge window [mem 0xc0000000-0xc01fffff]
[    0.163690] pci 0000:00:1c.0:   bridge window [mem 0xc0200000-0xc03fffff 64bit pref]
[    0.163695] pci 0000:00:1c.1: PCI bridge to [bus 02]
[    0.163698] pci 0000:00:1c.1:   bridge window [io  0xd000-0xdfff]
[    0.163702] pci 0000:00:1c.1:   bridge window [mem 0xfea00000-0xfeafffff]
[    0.163705] pci 0000:00:1c.1:   bridge window [mem 0xfdf00000-0xfdffffff 64bit pref]
[    0.163710] pci 0000:00:1c.3: PCI bridge to [bus 03]
[    0.163712] pci 0000:00:1c.3:   bridge window [io  0xe000-0xefff]
[    0.163716] pci 0000:00:1c.3:   bridge window [mem 0xfeb00000-0xfebfffff]
[    0.163719] pci 0000:00:1c.3:   bridge window [mem 0xc0400000-0xc05fffff 64bit pref]
[    0.163725] pci 0000:00:1e.0: PCI bridge to [bus 04]
[    0.163734] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.163736] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.163738] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.163740] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000dffff window]
[    0.163741] pci_bus 0000:00: resource 8 [mem 0xbf700000-0xdfffffff window]
[    0.163743] pci_bus 0000:00: resource 9 [mem 0xf0000000-0xffffffff window]
[    0.163745] pci_bus 0000:01: resource 0 [io  0x1000-0x1fff]
[    0.163747] pci_bus 0000:01: resource 1 [mem 0xc0000000-0xc01fffff]
[    0.163749] pci_bus 0000:01: resource 2 [mem 0xc0200000-0xc03fffff 64bit pref]
[    0.163751] pci_bus 0000:02: resource 0 [io  0xd000-0xdfff]
[    0.163753] pci_bus 0000:02: resource 1 [mem 0xfea00000-0xfeafffff]
[    0.163754] pci_bus 0000:02: resource 2 [mem 0xfdf00000-0xfdffffff 64bit pref]
[    0.163756] pci_bus 0000:03: resource 0 [io  0xe000-0xefff]
[    0.163758] pci_bus 0000:03: resource 1 [mem 0xfeb00000-0xfebfffff]
[    0.163760] pci_bus 0000:03: resource 2 [mem 0xc0400000-0xc05fffff 64bit pref]
[    0.163762] pci_bus 0000:04: resource 4 [io  0x0000-0x0cf7 window]
[    0.163764] pci_bus 0000:04: resource 5 [io  0x0d00-0xffff window]
[    0.163766] pci_bus 0000:04: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.163768] pci_bus 0000:04: resource 7 [mem 0x000d0000-0x000dffff window]
[    0.163769] pci_bus 0000:04: resource 8 [mem 0xbf700000-0xdfffffff window]
[    0.163771] pci_bus 0000:04: resource 9 [mem 0xf0000000-0xffffffff window]
[    0.163856] NET: Registered protocol family 2
[    0.164078] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.164115] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.164152] TCP: Hash tables configured (established 8192 bind 8192)
[    0.164199] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.164208] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.164260] NET: Registered protocol family 1
[    0.164276] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.165020] PCI: CLS 32 bytes, default 64
[    0.165076] Unpacking initramfs...
[    1.242032] Freeing initrd memory: 52816K
[    1.242417] Scanning for low memory corruption every 60 seconds
[    1.243229] Initialise system trusted keyrings
[    1.243241] Key type blacklist registered
[    1.243345] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[    1.245257] zbud: loaded
[    1.245691] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.245970] fuse init (API version 7.26)
[    1.248612] Key type asymmetric registered
[    1.248613] Asymmetric key parser 'x509' registered
[    1.248632] bounce: pool size: 64 pages
[    1.248648] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    1.248698] io scheduler noop registered
[    1.248699] io scheduler deadline registered
[    1.248769] io scheduler cfq registered (default)
[    1.248984] pcieport 0000:00:1c.0: enabling device (0104 -> 0107)
[    1.249656] pcieport 0000:00:1c.0: Signaling PME with IRQ 24
[    1.249680] pcieport 0000:00:1c.1: Signaling PME with IRQ 25
[    1.249702] pcieport 0000:00:1c.3: Signaling PME with IRQ 26
[    1.249730] pciehp 0000:00:1c.0:pcie004: Slot #32 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl- LLActRep+
[    1.249773] pciehp 0000:00:1c.1:pcie004: Slot #33 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl- LLActRep+
[    1.249809] pciehp 0000:00:1c.3:pcie004: Slot #35 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl- LLActRep+
[    1.249909] vesafb: mode is 1280x1024x32, linelength=5120, pages=0
[    1.249911] vesafb: scrolling: redraw
[    1.249913] vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    1.249935] vesafb: framebuffer at 0xd0000000, mapped to 0x6e244727, using 5120k, total 5120k
[    1.250090] Console: switching to colour frame buffer device 160x64
[    1.250132] fb0: VESA VGA frame buffer device
[    1.250155] intel_idle: does not run on family 6 model 23
[    1.250258] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[    1.250272] ACPI: Power Button [PWRB]
[    1.250320] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[    1.250366] ACPI: Power Button [PWRF]
[    1.250765] isapnp: Scanning for PnP cards...
[    1.250858] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[    1.271297] 00:02: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[    1.291840] 00:08: ttyS1 at I/O 0x2f8 (irq = 3, base_baud = 115200) is a 16550A
[    1.294911] Linux agpgart interface v0.103
[    1.301786] loop: module loaded
[    1.301959] ata_piix 0000:00:1f.1: version 2.13
[    1.304176] scsi host0: ata_piix
[    1.304326] scsi host1: ata_piix
[    1.304379] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xffa0 irq 14
[    1.304381] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xffa8 irq 15
[    1.304482] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[    1.305702] scsi host2: ata_piix
[    1.305826] scsi host3: ata_piix
[    1.305878] ata3: SATA max UDMA/133 cmd 0xc080 ctl 0xc000 bmdma 0xb800 irq 19
[    1.305879] ata4: SATA max UDMA/133 cmd 0xbc00 ctl 0xb880 bmdma 0xb808 irq 19
[    1.305998] libphy: Fixed MDIO Bus: probed
[    1.306000] tun: Universal TUN/TAP device driver, 1.6
[    1.306060] PPP generic driver version 2.4.2
[    1.306126] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.306131] ehci-pci: EHCI PCI platform driver
[    1.306252] ehci-pci 0000:00:1d.7: EHCI Host Controller
[    1.306259] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 1
[    1.306271] ehci-pci 0000:00:1d.7: debug port 1
[    1.310188] ehci-pci 0000:00:1d.7: cache line size of 32 is not supported
[    1.310201] ehci-pci 0000:00:1d.7: irq 23, io mem 0xfe977c00
[    1.324029] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[    1.324095] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.324097] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.324099] usb usb1: Product: EHCI Host Controller
[    1.324100] usb usb1: Manufacturer: Linux 4.15.0-20-generic ehci_hcd
[    1.324102] usb usb1: SerialNumber: 0000:00:1d.7
[    1.324235] hub 1-0:1.0: USB hub found
[    1.324243] hub 1-0:1.0: 8 ports detected
[    1.324465] ehci-platform: EHCI generic platform driver
[    1.324476] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.324479] ohci-pci: OHCI PCI platform driver
[    1.324491] ohci-platform: OHCI generic platform driver
[    1.324501] uhci_hcd: USB Universal Host Controller Interface driver
[    1.324583] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[    1.324591] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[    1.324597] uhci_hcd 0000:00:1d.0: detected 2 ports
[    1.324614] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000c880
[    1.324665] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[    1.324667] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.324668] usb usb2: Product: UHCI Host Controller
[    1.324670] usb usb2: Manufacturer: Linux 4.15.0-20-generic uhci_hcd
[    1.324672] usb usb2: SerialNumber: 0000:00:1d.0
[    1.324793] hub 2-0:1.0: USB hub found
[    1.324800] hub 2-0:1.0: 2 ports detected
[    1.324981] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[    1.324986] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[    1.324992] uhci_hcd 0000:00:1d.1: detected 2 ports
[    1.325009] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000c800
[    1.325057] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[    1.325059] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.325061] usb usb3: Product: UHCI Host Controller
[    1.325063] usb usb3: Manufacturer: Linux 4.15.0-20-generic uhci_hcd
[    1.325064] usb usb3: SerialNumber: 0000:00:1d.1
[    1.325182] hub 3-0:1.0: USB hub found
[    1.325189] hub 3-0:1.0: 2 ports detected
[    1.325369] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[    1.325374] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[    1.325380] uhci_hcd 0000:00:1d.2: detected 2 ports
[    1.325404] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000c480
[    1.325452] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[    1.325454] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.325456] usb usb4: Product: UHCI Host Controller
[    1.325457] usb usb4: Manufacturer: Linux 4.15.0-20-generic uhci_hcd
[    1.325459] usb usb4: SerialNumber: 0000:00:1d.2
[    1.325578] hub 4-0:1.0: USB hub found
[    1.325585] hub 4-0:1.0: 2 ports detected
[    1.325766] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[    1.325774] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[    1.325779] uhci_hcd 0000:00:1d.3: detected 2 ports
[    1.325802] uhci_hcd 0000:00:1d.3: irq 16, io base 0x0000c400
[    1.325853] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[    1.325855] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.325856] usb usb5: Product: UHCI Host Controller
[    1.325858] usb usb5: Manufacturer: Linux 4.15.0-20-generic uhci_hcd
[    1.325860] usb usb5: SerialNumber: 0000:00:1d.3
[    1.325978] hub 5-0:1.0: USB hub found
[    1.325985] hub 5-0:1.0: 2 ports detected
[    1.326162] i8042: PNP: No PS/2 controller found.
[    1.326163] i8042: Probing ports directly.
[    1.328546] serio: i8042 KBD port at 0x60,0x64 irq 1
[    1.328550] serio: i8042 AUX port at 0x60,0x64 irq 12
[    1.328717] mousedev: PS/2 mouse device common for all mice
[    1.328917] rtc_cmos 00:01: RTC can wake from S4
[    1.329039] rtc_cmos 00:01: rtc core: registered rtc_cmos as rtc0
[    1.329061] rtc_cmos 00:01: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[    1.329072] i2c /dev entries driver
[    1.329168] device-mapper: uevent: version 1.0.3
[    1.329262] device-mapper: ioctl: 4.37.0-ioctl (2017-09-20) initialised: dm-devel@redhat.com
[    1.329287] platform eisa.0: Probing EISA bus 0
[    1.329289] platform eisa.0: EISA: Cannot allocate resource for mainboard
[    1.329291] platform eisa.0: Cannot allocate resource for EISA slot 1
[    1.329293] platform eisa.0: Cannot allocate resource for EISA slot 2
[    1.329295] platform eisa.0: Cannot allocate resource for EISA slot 3
[    1.329297] platform eisa.0: Cannot allocate resource for EISA slot 4
[    1.329298] platform eisa.0: Cannot allocate resource for EISA slot 5
[    1.329300] platform eisa.0: Cannot allocate resource for EISA slot 6
[    1.329302] platform eisa.0: Cannot allocate resource for EISA slot 7
[    1.329304] platform eisa.0: Cannot allocate resource for EISA slot 8
[    1.329305] platform eisa.0: EISA: Detected 0 cards
[    1.329310] cpufreq_nforce2: No nForce2 chipset
[    1.343213] ledtrig-cpu: registered to indicate activity on CPUs
[    1.343517] NET: Registered protocol family 10
[    1.348385] Segment Routing with IPv6
[    1.348410] NET: Registered protocol family 17
[    1.348468] Key type dns_resolver registered
[    1.388315] microcode: sig=0x10677, pf=0x10, revision=0x703
[    1.388370] microcode: Microcode Update Driver: v2.2.
[    1.388378] Using IPI No-Shortcut mode
[    1.388385] sched_clock: Marking stable (1388364582, 0)->(1478629620, -90265038)
[    1.388590] registered taskstats version 1
[    1.388601] Loading compiled-in X.509 certificates
[    1.394654] Loaded X.509 cert 'Build time autogenerated kernel key: 573dc39532f0c19c40a93e72c7ccf5ca0668369a'
[    1.394681] zswap: loaded using pool lzo/zbud
[    1.398853] Key type big_key registered
[    1.398858] Key type trusted registered
[    1.400888] Key type encrypted registered
[    1.400891] AppArmor: AppArmor sha1 policy hashing enabled
[    1.400894] ima: No TPM chip found, activating TPM-bypass! (rc=-19)
[    1.400920] evm: HMAC attrs: 0x1
[    1.401179]   Magic number: 15:253:228
[    1.401315] rtc_cmos 00:01: setting system clock to 2019-04-11 12:14:22 UTC (1554984862)
[    1.401441] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[    1.401442] EDD information not available.
[    1.504237] ata4.00: ATA-7: SAMSUNG HD321HJ, 1AC01118, max UDMA7
[    1.504239] ata4.00: 625142448 sectors, multi 16: LBA48 NCQ (depth 0/32)
[    1.528230] ata4.00: configured for UDMA/133
[    1.560774] isapnp: No Plug & Play device found
[    1.560966] scsi 3:0:0:0: Direct-Access     ATA      SAMSUNG HD321HJ  1118 PQ: 0 ANSI: 5
[    1.561181] sd 3:0:0:0: [sda] 625142448 512-byte logical blocks: (320 GB/298 GiB)
[    1.561188] sd 3:0:0:0: Attached scsi generic sg0 type 0
[    1.561197] sd 3:0:0:0: [sda] Write Protect is off
[    1.561199] sd 3:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    1.561223] sd 3:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.572264]  sda: sda1 sda2
[    1.572607] sd 3:0:0:0: [sda] Attached SCSI disk
[    1.574467] Freeing unused kernel memory: 1088K
[    1.574523] Write protecting the kernel text: 8796k
[    1.574638] Write protecting the kernel read-only data: 3472k
[    1.574639] NX-protecting the kernel data: 5540k
[    1.574789] ------------[ cut here ]------------
[    1.574793] x86/mm: Found insecure W+X mapping at address 6470a6d6/0xc00a0000
[    1.574802] WARNING: CPU: 0 PID: 1 at /build/linux-vfP2Zg/linux-4.15.0/arch/x86/mm/dump_pagetables.c:266 note_page+0x670/0x860
[    1.574803] Modules linked in:
[    1.574806] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.15.0-20-generic #21-Ubuntu
[    1.574810] Hardware name: MICRO-STAR INTERNATIONAL CO.,LTD EB-7528/EB-7528, BIOS V1.3 08/06/2008
[    1.574813] EIP: note_page+0x670/0x860
[    1.574814] EFLAGS: 00210282 CPU: 0
[    1.574815] EAX: 00000041 EBX: f140df44 ECX: 0000026f EDX: 00000000
[    1.574816] ESI: 80000000 EDI: 00000000 EBP: f140df10 ESP: f140dee4
[    1.574817]  DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068
[    1.574819] CR0: 80050033 CR2: 00000000 CR3: 15e09000 CR4: 000006f0
[    1.574820] Call Trace:
[    1.574826]  ptdump_walk_pgd_level_core+0x2ac/0x2e0
[    1.574830]  ptdump_walk_pgd_level_checkwx+0x18/0x20
[    1.574833]  mark_rodata_ro+0xf5/0x117
[    1.574837]  ? rest_init+0xa0/0xa0
[    1.574839]  kernel_init+0x2e/0xf0
[    1.574842]  ret_from_fork+0x2e/0x38
[    1.574844] Code: d5 e9 0c fb ff ff f7 c6 00 10 00 00 74 8c 68 2e f3 ad d5 e9 16 fe ff ff 52 52 68 dc f3 ad d5 c6 05 26 e4 ca d5 01 e8 e0 73 00 00 <0f> 0b 8b 53 0c 83 c4 0c e9 38 fa ff ff 50 6a 08 52 6a 08 68 de
[    1.574880] ---[ end trace d03d56b5bfae95d0 ]---
[    1.574955] x86/mm: Checked W+X mappings: FAILED, 96 W+X pages found.
[    1.684683] Floppy drive(s): fd0 is 1.44M
[    1.692219] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[    1.692726] r8169 0000:02:00.0 eth0: RTL8168c/8111c at 0xf799f567, 00:1d:92:d9:5c:91, XID 1c2000c0 IRQ 27
[    1.692728] r8169 0000:02:00.0 eth0: jumbo features [frames: 6128 bytes, tx checksumming: ko]
[    1.701276] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[    1.707887] FDC 0 is a post-1991 82077
[    1.725998] r8169 0000:02:00.0 ens33: renamed from eth0
[    1.786786] pci 0000:00:00.0: Intel G33 Chipset
[    1.786802] pci 0000:00:00.0: detected gtt size: 524288K total, 262144K mappable
[    1.787307] pci 0000:00:00.0: detected 8192K stolen memory
[    1.787374] [drm] Memory usable by graphics device = 512M
[    1.787379] checking generic (d0000000 500000) vs hw (d0000000 10000000)
[    1.787380] fb: switching to inteldrmfb from VESA VGA
[    1.787408] Console: switching to colour dummy device 80x25
[    1.787539] [drm] Replacing VGA console driver
[    1.793613] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    1.793614] [drm] Driver supports precise vblank timestamp query.
[    1.794181] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[    1.797490] [drm] RC6 disabled, disabling runtime PM support
[    1.797503] [drm] initialized overlay support
[    1.797732] [drm] Initialized i915 1.6.0 20171023 for 0000:00:02.0 on minor 0
[    1.864038] usb 2-1: new full-speed USB device number 2 using uhci_hcd
[    1.874076] fbcon: inteldrmfb (fb0) is primary device
[    1.874180] Console: switching to colour frame buffer device 210x65
[    1.874236] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[    2.067049] usb 2-1: New USB device found, idVendor=1532, idProduct=0016
[    2.067052] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.067054] usb 2-1: Product: Razer DeathAdder
[    2.067055] usb 2-1: Manufacturer: Razer
[    2.078836] hidraw: raw HID events driver (C) Jiri Kosina
[    2.088524] usbcore: registered new interface driver usbhid
[    2.088525] usbhid: USB HID core driver
[    2.094072] input: Razer Razer DeathAdder as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1:1.0/0003:1532:0016.0001/input/input5
[    2.094203] hid-generic 0003:1532:0016.0001: input,hidraw0: USB HID v1.11 Mouse [Razer Razer DeathAdder] on usb-0000:00:1d.0-1/input0
[    2.268030] tsc: Refined TSC clocksource calibration: 2341.133 MHz
[    2.268043] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x21befe00197, max_idle_ns: 440795315444 ns
[    3.112020] usb 2-2: new full-speed USB device number 3 using uhci_hcd
[    3.292135] clocksource: Switched to clocksource tsc
[    3.515048] usb 2-2: New USB device found, idVendor=1b1c, idProduct=1b38
[    3.515050] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    3.515052] usb 2-2: Product: Corsair Gaming K70 RGB RAPIDFIRE Keyboard
[    3.515053] usb 2-2: Manufacturer: Corsair
[    3.515055] usb 2-2: SerialNumber: 17043021AEB890E655B231C9F5001946
[    3.523909] input: Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard  as /devices/pci0000:00/0000:00:1d.0/usb2/2-2/2-2:1.0/0003:1B1C:1B38.0002/input/input6
[    3.523992] hid-generic 0003:1B1C:1B38.0002: input,hidraw1: USB HID v1.11 Keyboard [Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard ] on usb-0000:00:1d.0-2/input0
[    3.529896] input: Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard  as /devices/pci0000:00/0000:00:1d.0/usb2/2-2/2-2:1.1/0003:1B1C:1B38.0003/input/input7
[    3.530022] hid-generic 0003:1B1C:1B38.0003: input,hiddev0,hidraw2: USB HID v1.11 Keyboard [Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard ] on usb-0000:00:1d.0-2/input1
[    3.530092] usbhid 2-2:1.2: couldn't find an input interrupt endpoint
[    4.032023] raid6: mmxx1    gen()  2972 MB/s
[    4.080017] raid6: mmxx2    gen()  3313 MB/s
[    4.128032] raid6: sse1x1   gen()  1972 MB/s
[    4.176010] raid6: sse1x2   gen()  2534 MB/s
[    4.224010] raid6: sse2x1   gen()  3656 MB/s
[    4.272016] raid6: sse2x1   xor()  3939 MB/s
[    4.320025] raid6: sse2x2   gen()  4582 MB/s
[    4.368022] raid6: sse2x2   xor()  4722 MB/s
[    4.368023] raid6: using algorithm sse2x2 gen() 4582 MB/s
[    4.368024] raid6: .... xor() 4722 MB/s, rmw enabled
[    4.368025] raid6: using ssse3x1 recovery algorithm
[    4.380351] xor: measuring software checksum speed
[    4.420008]    pIII_sse  :  8241.000 MB/sec
[    4.460008]    prefetch64-sse:  9318.000 MB/sec
[    4.460009] xor: using function: prefetch64-sse (9318.000 MB/sec)
[    4.504170] Btrfs loaded, crc32c=crc32c-generic
[   17.180564] print_req_error: I/O error, dev fd0, sector 0
[   17.180569] floppy: error 10 while reading block 0
[   17.275866] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[   18.350271] ip_tables: (C) 2000-2006 Netfilter Core Team
[   18.422999] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[   18.440139] systemd[1]: Detected architecture x86.
[   18.447115] systemd[1]: Set hostname to <kostusa-EB-7528>.
[   19.371793] random: crng init done
[   20.080556] systemd[1]: Configuration file /usr/lib/systemd/system/ckb-daemon.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[   20.381746] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   20.381995] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   20.382017] systemd[1]: Reached target Remote File Systems.
[   20.382033] systemd[1]: Reached target User and Group Name Lookups.
[   20.382268] systemd[1]: Created slice User and Session Slice.
[   20.382467] systemd[1]: Created slice System Slice.
[   20.915793] lp: driver loaded but no devices found
[   20.978035] ppdev: user-space parallel port driver
[   20.979202] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[   21.029498] systemd-journald[347]: Received request to flush runtime journal from PID 1
[   21.147520] parport_pc 00:09: reported by Plug and Play ACPI
[   21.147591] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE]
[   21.169516] Adding 902668k swap on /swapfile.  Priority:-2 extents:4 across:927244k FS
[   21.248106] lp0: using parport0 (interrupt-driven).
[   28.364287] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[   28.432724] intel_rng: FWH not detected
[   28.441794] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   28.450531] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   28.484266] leds_ss4200: no LED devices found
[   28.544901] intel_powerclamp: No package C-state available
[   28.561000] rtl8188ee: rtl8188ee: FW Power Save off (module option)
[   28.561282] rtl8188ee: Using firmware rtlwifi/rtl8188efw.bin
[   28.589267] ieee80211 phy0: Selected rate control algorithm 'rtl_rc'
[   28.589623] rtlwifi: rtlwifi: wireless switch is on
[   28.628541] gpio_ich: GPIO from 462 to 511 on gpio_ich
[   28.634503] rtl8188ee 0000:03:00.0 wls35: renamed from wlan0
[   28.687387] snd_hda_intel 0000:00:1b.0: Applying patch firmware 'hda-jack-retask.fw'
[   28.983023] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC888: line_outs=2 (0x18/0x14/0x0/0x0/0x0) type:line
[   28.983027] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[   28.983029] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[   28.983031] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[   28.983032] snd_hda_codec_realtek hdaudioC0D0:    dig-out=0x1e/0x0
[   28.983034] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[   28.983036] snd_hda_codec_realtek hdaudioC0D0:      Mic=0x19
[   28.983038] snd_hda_codec_realtek hdaudioC0D0:      Line=0x1a
[   29.000643] input: HDA Intel Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[   29.000736] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[   29.000815] input: HDA Intel Line Out Front as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[   29.000895] input: HDA Intel Line Out Surround as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[   29.000969] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[   30.521564] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[   30.837134] audit: type=1400 audit(1554984891.930:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=640 comm="apparmor_parser"
[   30.837142] audit: type=1400 audit(1554984891.930:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=640 comm="apparmor_parser"
[   30.837145] audit: type=1400 audit(1554984891.930:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=640 comm="apparmor_parser"
[   30.838799] audit: type=1400 audit(1554984891.930:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-oopslash" pid=641 comm="apparmor_parser"
[   30.838844] audit: type=1400 audit(1554984891.930:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-senddoc" pid=642 comm="apparmor_parser"
[   30.838948] audit: type=1400 audit(1554984891.930:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/sbin/dhclient" pid=638 comm="apparmor_parser"
[   30.838951] audit: type=1400 audit(1554984891.930:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=638 comm="apparmor_parser"
[   30.838953] audit: type=1400 audit(1554984891.930:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-helper" pid=638 comm="apparmor_parser"
[   30.838956] audit: type=1400 audit(1554984891.930:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=638 comm="apparmor_parser"
[   30.839259] audit: type=1400 audit(1554984891.930:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/lightdm/lightdm-guest-session" pid=637 comm="apparmor_parser"
[   34.489066] IPv6: ADDRCONF(NETDEV_UP): ens33: link is not ready
[   34.505715] r8169 0000:02:00.0 ens33: link down
[   34.505718] r8169 0000:02:00.0 ens33: link down
[   34.505822] IPv6: ADDRCONF(NETDEV_UP): ens33: link is not ready
[   34.510521] IPv6: ADDRCONF(NETDEV_UP): wls35: link is not ready
[   34.968970] IPv6: ADDRCONF(NETDEV_UP): wls35: link is not ready
[   35.067887] IPv6: ADDRCONF(NETDEV_UP): wls35: link is not ready
[   36.527814] wls35: authenticate with 90:94:e4:b3:fa:46
[   36.537883] wls35: send auth to 90:94:e4:b3:fa:46 (try 1/3)
[   36.539359] wls35: authenticated
[   36.540027] wls35: associate with 90:94:e4:b3:fa:46 (try 1/3)
[   36.543198] wls35: RX AssocResp from 90:94:e4:b3:fa:46 (capab=0x431 status=0 aid=1)
[   36.543451] wls35: associated
[   36.935875] r8169 0000:02:00.0 ens33: link up
[   36.935886] IPv6: ADDRCONF(NETDEV_CHANGE): ens33: link becomes ready
[   37.568134] IPv6: ADDRCONF(NETDEV_CHANGE): wls35: link becomes ready
[   37.837874] vboxdrv: loading out-of-tree module taints kernel.
[   37.838178] vboxdrv: module verification failed: signature and/or required key missing - tainting kernel
[   37.844145] vboxdrv: Found 4 processor cores
[   37.844450] vboxdrv: fAsync=0 offMin=0x2ed offMax=0x1355
[   37.944624] vboxdrv: TSC mode is Synchronous, tentative frequency 2341132931 Hz
[   37.944626] vboxdrv: Successfully loaded version 5.2.18_Ubuntu (interface 0x00290001)
[   37.950592] VBoxNetFlt: Successfully started.
[   37.956174] VBoxNetAdp: Successfully started.
[   37.961937] VBoxPciLinuxInit
[   37.967590] vboxpci: IOMMU not found (not registered)
Решение rogoznik » 11 апр 2019, 17:23
djsantehnik, значит cmake нужно доставить
sudo apt install cmake
11 апр 2019, 15:43
djsantehnik, а вопрос то в чем?
djsantehnik
11 апр 2019, 15:46
подожди, я картинку вставлять учусь
О получилось - НО девайс коннектед (на синамоне и на fxce - одинаково все)
11 апр 2019, 15:52
А что должно быть разного? о_О
У вас клавиатура со светодиодами? Или в чем прикол? И причем тут механическая? о_О
11 апр 2019, 15:53
Как я понял ты брал тут https://github.com/ccMSC/ckb ?
А пробовал взять тут https://github.com/ckb-next/ckb-next ?
Просто по первой ссылке там обновлений не было уже 3 года
djsantehnik
11 апр 2019, 16:07
Dja писал(а):
11 апр 2019, 15:52
ну да цветастенькая с двумя юсб в металлическом корпусе, механическая для поиска страждущими с теми же симптомами
darkfenix, попробую
djsantehnik
11 апр 2019, 16:59
11 апр 2019, 15:53
darkfenix, попробовал
kostusa@kostusa-EB-7528:~/Загрузки/ckb-next-master$ ./quickinstall
./quickinstall: line 51: cmake: command not found
An error occurred,
press enter to exit.
djsantehnik
11 апр 2019, 17:04
да что ж тут так быслро редактирование гасят не успеваешь апосля красиво сделать - тот кусок
rm -rf build
cmake -H. -Bbuild -DCMAKE_BUILD_TYPE=Release -DSAFE_INSTALL=ON -DSAFE_UNINSTALL=ON
checkfail $?
# Find out how many cores the system has, for make
11 апр 2019, 17:09
sudo apt install build-essential libudev-dev qt5-default zlib1g-dev libappindicator-dev
Это делал?
djsantehnik
11 апр 2019, 17:21
ничего не изменилось в квикинсталле
kostusa@kostusa-EB-7528:~/Загрузки/ckb-next-master$ sudo apt install build-essential libudev-dev qt5-default zlib1g-dev libappindicator-dev
Попробуйте ещё раз.
Уже установлен пакет build-essential самой новой версии (12.4ubuntu1).
Уже установлен пакет zlib1g-dev самой новой версии (1:1.2.11.dfsg-0ubuntu2).
Уже установлен пакет libappindicator-dev самой новой версии (12.10.1+18.04.20180322.1-0ubuntu1).
Уже установлен пакет libudev-dev самой новой версии (237-3ubuntu10.19).
Уже установлен пакет qt5-default самой новой версии (5.9.5+dfsg-0ubuntu2).
Следующий пакет устанавливался автоматически и больше не требуется:
  libart-2.0-2 libbonobo2-0 libbonobo2-common libbonoboui2-0
  libbonoboui2-common libgconfmm-2.6-1v5 libglademm-2.4-1v5 libgnome-2-0
  libgnome-keyring-common libgnome-keyring0 libgnome2-common libgnomecanvas2-0
  libgnomecanvas2-common libgnomeui-0 libgnomeui-common libgnomevfs2-0
  libgnomevfs2-common liborbit-2-0 pulseaudio-module-gconf
  pulseaudio-module-zeroconf qastools-common
Для его удаления используйте «sudo apt autoremove».
Обновлено 0 пакетов, установлено 0 новых пакетов, для удаления отмечено 0 пакетов, и 308 пакетов не обновлено.
11 апр 2019, 17:23
djsantehnik
11 апр 2019, 17:33
уже сам полез на яшу выяснять что за смайк такой - вобщем после установки его завелась печка. Спасибо darkfenix, за поддержку
djsantehnik
11 апр 2019, 17:48
Дополнение о странностях - в терминале клава на русской раскладке два символа на нажатие пишет, на английской все нормально, В морде все нормально.
