Регулировка яркости экрана hp4535s в KDE Plasma 5
Олег
Благодарил (а): 3 раза
25 мар 2019, 17:52
Здравствуйте, форумчане! :smile: 1. ОС ЛМ 19.1, х64. 2. Синнамон, КДЕ (в будущем). 3. Данные компьютера и ос:
Host: oleg-hp Kernel: 4.15.0-46-generic x86_64 bits: 64 compiler: gcc
v: 7.3.0 Desktop: Cinnamon 4.0.9 Distro: Linux Mint 19.1 Tessa
base: Ubuntu 18.04 bionic
Type: Laptop System: Hewlett-Packard product: HP ProBook 4535s v: A0000402
serial: <filter>
Mobo: Hewlett-Packard model: 168B v: KBC Version 32.12 serial: <filter>
BIOS: Hewlett-Packard v: 68CPC Ver. F.02 date: 06/09/2011
Topology: Dual Core model: AMD E2-3000M APU with Radeon HD Graphics
bits: 64 type: MCP arch: Fusion L2 cache: 1024 KiB
flags: lm nx pae sse sse2 sse3 sse4a svm bogomips: 7187
Speed: 1037 MHz min/max: 800/1800 MHz Core speeds (MHz): 1: 950 2: 1076
Device-1: AMD Sumo [Radeon HD 6380G] vendor: Hewlett-Packard
driver: radeon v: kernel bus ID: 00:01.0
Device-2: AMD Seymour [Radeon HD 6400M/7400M Series] driver: radeon
v: kernel bus ID: 01:00.0
Display: x11 server: X.Org 1.19.6 driver: ati,radeon
unloaded: fbdev,modesetting,vesa resolution: 1366x768~60Hz
OpenGL: renderer: AMD SUMO2 (DRM 2.50.0 / 4.15.0-46-generic LLVM 7.0.0)
v: 3.3 Mesa 18.2.8 direct render: Yes
Device-1: AMD BeaverCreek HDMI Audio [Radeon HD 6500D and 6400G-6600G
series]
vendor: Hewlett-Packard ProBook 4535s driver: snd_hda_intel v: kernel
bus ID: 00:01.1
Device-2: AMD FCH Azalia vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel bus ID: 00:14.2
Sound Server: ALSA v: k4.15.0-46-generic
vendor: Hewlett-Packard driver: r8169 v: 2.3LK-NAPI port: 5000
bus ID: 02:00.0
Device-2: Qualcomm Atheros AR9285 Wireless Network Adapter
vendor: Hewlett-Packard driver: ath9k v: kernel port: 5000 bus ID: 04:00.0
Device-3: Atheros AR3011 Bluetooth type: USB driver: btusb bus ID: 4-5:3
Local Storage: total: 313.04 GiB used: 175.03 GiB (55.9%)
ID-1: /dev/sda vendor: Western Digital model: WD3200BEKT-60PVMT0
ID-2: /dev/sdb type: USB vendor: Transcend model: JetFlash Transcend 16GB
ID-1: / size: 43.93 GiB used: 26.00 GiB (59.2%) fs: ext4 dev: /dev/sda1
ID-2: /home size: 249.11 GiB used: 148.96 GiB (59.8%) fs: ext4
dev: /dev/sda5
System Temperatures: cpu: 46.0 C mobo: 25.0 C gpu: radeon temp: 45 C
Processes: 202 Uptime: 33m Memory: 5.30 GiB used: 1.58 GiB (29.8%)
inxi: 3.0.27
Хочу попросить совета-посказки, что наведет на путь истинный, а именно: настройка регулировки яркости экрана ноутбука hp 4535s. Вопрос здесь уже задавался здесь некогда (два года назад в этой теме: Регулировка яркости и тормоза плазмы в 18.1 (Пост Олег #14786)). Тогда мне помогли хорошие люди Регулировка яркости и тормоза плазмы в 18.1 (Пост Bill Williamson #14533), написали скрипты (приложеный архив) :hshake: . Я писал, что мало в чем разобался в линукс. Но по правде скать я не программист. Простой пользователь которому по душе линукс, но знаний по теме не очень много (делетант) :blush: . Даной ОС нача пользоваться не с первого раза. Вот не спервого раза пришел и тому, решил все таки пользоваться графическим окружением KDE Plasma 5. Немного гуглил, но толком не разорался куда положить скрипты и как их выполнять без sudo (куда положить файлы runscript и runscript.с), какую команду нужно записать на горячие клавиши для задействования скрипта?
scripts.7z
(2.44 КБ) 70 скачиваний
26 мар 2019, 09:34
А что, без sudo не срабатывает?
Олег
26 мар 2019, 13:07
Нет, без sudo не работет (приложеная картинка). Когда гуглил нашел, что для этого создется файл runscript. Но не разобался, что с ним делать. С sudo система тоже пишет, что "нет такого каталога", но яркость изменяяется.
26 мар 2019, 14:49
Олег, а что у тебя апплета батарейки не видно если ноут ? Может там ползунком яркость будет регулироваться. И Тему нужно создавать в Коричной, а не в Плазменной ветке.
26 мар 2019, 15:25
Олег, а redshift проблему не решит? Не яркость, но всё же... Кстати, а с яркостью что не так? Она меньше, чем нужна или больше? о.О
Олег
26 мар 2019, 18:10
Извините, не совмсем точно все объяснил. Апплета батарейки не отображает уже несколько лет. Батарейка есть, но не работает и комп ее уже перестал видеть. Изменяется яркость через апплет в виде солнышка/лапочки. Но это в Синнамоне. Хочу установить Плазму, там горячие клавиши работают и ползунок тоже. Но яркость екрана на максимуме и не изменяется. Redshift хорошая программа, ночью легче для глаз. Как писал в первом посте ребята тогда мне помогли написанием скрипта. Тогда испугался этого всего. Сейчас хочу разобраться как его применть: читал, что для того что-бы при выполении скрипта без запроса пароля для sudo и создается файл runscript. Только что с ним делать не знаю. Вот :dash2:
Вернуться в «KDE»
