Железо:
$ inxi -Fxz System: Host: sergei-N56VZ Kernel: 4.15.0-46-generic x86_64 bits: 64 compiler: gcc v: 7.3.0 Desktop: Xfce 4.12.3 Distro: Linux Mint 19.1 Tessa base: Ubuntu 18.04 bionic Machine: Type: Laptop System: ASUSTeK product: N56VZ v: 1.0 serial: <filter> Mobo: ASUSTeK model: N56VZ v: 1.0 serial: <filter> UEFI: American Megatrends v: N56VZ.217 date: 05/22/2013 Battery: ID-1: BAT0 charge: 32.4 Wh condition: 33.4/57.7 Wh (58%) model: ASUSTeK N56--52 status: Unknown CPU: Topology: Quad Core model: Intel Core i7-3630QM bits: 64 type: MT MCP arch: Ivy Bridge rev: 9 L2 cache: 6144 KiB flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 38312 Speed: 1328 MHz min/max: 1200/3400 MHz Core speeds (MHz): 1: 1371 2: 1378 3: 1496 4: 1561 5: 1441 6: 1395 7: 1619 8: 1217 Graphics: Device-1: Intel 3rd Gen Core processor Graphics vendor: ASUSTeK N56VZ driver: i915 v: kernel bus ID: 00:02.0 Device-2: NVIDIA GK107M [GeForce GT 650M] vendor: ASUSTeK N56VZ driver: nvidia v: 390.116 bus ID: 01:00.0 Display: x11 server: X.Org 1.19.6 driver: modesetting,nvidia unloaded: fbdev,nouveau,vesa resolution: 1920x1080~60Hz, 1920x1080~60Hz OpenGL: renderer: GeForce GT 650M/PCIe/SSE2 v: 4.6.0 NVIDIA 390.116 direct render: Yes Audio: Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: ASUSTeK N56VZ driver: snd_hda_intel v: kernel bus ID: 00:1b.0 Sound Server: ALSA v: k4.15.0-46-generic Network: Device-1: Intel Centrino Wireless-N 2230 driver: iwlwifi v: kernel port: e000 bus ID: 03:00.0 IF: wlp3s0 state: up mac: <filter> Device-2: Qualcomm Atheros AR8161 Gigabit Ethernet vendor: ASUSTeK N56VZ driver: alx v: kernel port: d000 bus ID: 04:00.0 IF: enp4s0 state: down mac: <filter> Drives: Local Storage: total: 1.03 TiB used: 362.13 GiB (34.5%) ID-1: /dev/sda vendor: OCZ model: AGILITY3 size: 119.24 GiB ID-2: /dev/sdb vendor: HGST (Hitachi) model: HTS541010B7E610 size: 931.51 GiB Partition: ID-1: / size: 115.38 GiB used: 17.36 GiB (15.0%) fs: ext4 dev: /dev/sda3 ID-2: /home size: 98.31 GiB used: 55.39 GiB (56.3%) fs: ext4 dev: /dev/sdb4 ID-3: swap-1 size: 1.27 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda2 Sensors: System Temperatures: cpu: 66.0 C mobo: N/A gpu: nvidia temp: 56 C Fan Speeds (RPM): cpu: 2800 Info: Processes: 259 Uptime: 12h 58m Memory: 7.68 GiB used: 2.38 GiB (31.0%) Init: systemd runlevel: 5 Compilers: gcc: 7.3.0 Shell: bash v: 4.4.19 inxi: 3.0.27
Прилагаю видео как это выглядит https://youtu.be/n05O4yPIe8U
Хотелось бы решить эту проблему.
