Unity Editor Linux Download Assistant
aldikiy
19 мар 2019, 14:00
Здравствуйте!
Скачал файл UnitySetup-2017.3.0b1 отсюда http://beta.unity3d.com/download/2ca68d ... nload.html
Какой программой его можно запустить?
Данные мои:
  Host: Alex Kernel: 4.15.0-20-generic x86_64 bits: 64 compiler: gcc
  v: 7.3.0 Desktop: Cinnamon 4.0.8 Distro: Linux Mint 19.1 Tessa
  base: Ubuntu 18.04 bionic
  Type: Laptop System: ASUSTeK product: N53TK v: 1.0 serial: <filter>
  Mobo: ASUSTeK model: N53TK v: 1.0 serial: <filter>
  BIOS: American Megatrends v: N53TK.205 date: 01/06/2012
  ID-1: BAT0 charge: 49.9 Wh condition: 50.9/48.4 Wh (105%)
  model: ASUSTek M50--22 status: Unknown
  Topology: Dual Core model: AMD A4-3305M APU with Radeon HD Graphics
  bits: 64 type: MCP arch: Fusion L2 cache: 1024 KiB
  flags: lm nx pae sse sse2 sse3 sse4a svm bogomips: 7586
  Speed: 804 MHz min/max: 800/1900 MHz Core speeds (MHz): 1: 804 2: 804
  Device-1: AMD Sumo [Radeon HD 6480G] vendor: ASUSTeK driver: radeon
  v: kernel bus ID: 00:01.0
  Device-2: AMD Thames [Radeon HD 7500M/7600M Series] driver: radeon
  v: kernel bus ID: 01:00.0
  Display: x11 server: X.Org 1.19.6 driver: ati,radeon
  unloaded: fbdev,modesetting,vesa resolution: 1024x768~60Hz, 1366x768~60Hz
  OpenGL: renderer: AMD SUMO2 (DRM 2.50.0 / 4.15.0-20-generic LLVM 6.0.0)
  v: 3.3 Mesa 18.0.5 direct render: Yes
  Device-1: AMD BeaverCreek HDMI Audio [Radeon HD 6500D and 6400G-6600G
  series]
  driver: snd_hda_intel v: kernel bus ID: 00:01.1
  Device-2: AMD FCH Azalia vendor: ASUSTeK driver: snd_hda_intel v: kernel
  bus ID: 00:14.2
  Sound Server: ALSA v: k4.15.0-20-generic
  Device-1: Qualcomm Atheros AR9285 Wireless Network Adapter
  vendor: AzureWave AW-NB037H 802.11bgn driver: ath9k v: kernel port: f150
  bus ID: 02:00.0
  Device-2: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet vendor: ASUSTeK
  driver: atl1c v: 1.0.1.1-NAPI port: d000 bus ID: 03:00.0
  Device-3: Atheros AR3011 Bluetooth type: USB driver: btusb bus ID: 4-5:3
  Local Storage: total: 465.76 GiB used: 11.34 GiB (2.4%)
  ID-1: /dev/sda vendor: Seagate model: ST9500420AS size: 465.76 GiB
  ID-1: / size: 213.53 GiB used: 11.34 GiB (5.3%) fs: ext4 dev: /dev/sda5
  System Temperatures: cpu: 43.6 C mobo: N/A gpu: radeon temp: 44 C
  Processes: 184 Uptime: 37m Memory: 3.34 GiB used: 1.60 GiB (47.8%)
  inxi: 3.0.27
Последний раз редактировалось пользователем 1 rogoznik; всего редактировалось раз: 19
Причина: BBCode
19 мар 2019, 14:53
aldikiy, дать файлу права на запуск в свойствах или через chmod, и запустить как исполняемый.
Например
19 мар 2019, 14:56
19 мар 2019, 19:04
aldikiy, научиться читать и изучить Панель форматирования текста в темах/ответах
Делаю последнее китайское предупреждение
Вернуться в «Мультимедиа»
