Опять куча WARNING'ов в журнале. Помогите разобраться?
StarMAUGLI
Решено: 19
Благодарил (а): 697 раз
04 мар 2019, 16:50
┌─ mugalem ~
└─ $ journalctl | grep WARNING | uniq -u
фев 25 12:32:44 mugalem-P35 colord[1475]: (colord:1475): Cd-WARNING **: failed to get session [pid 711]: Нет такого устройства или адреса
фев 25 12:32:47 mugalem-P35 org.freedesktop.systemd1[1625]: ** (process:1660): WARNING **: cgmanager method call org.linuxcontainers.cgmanager0_0.MovePidAbs failed: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: invalid request.  Use G_DBUS_DEBUG=message for more info.
фев 25 12:32:47 mugalem-P35 org.freedesktop.systemd1[1625]: ** (process:1660): WARNING **: cgmanager method call org.linuxcontainers.cgmanager0_0.GetValue failed: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: invalid request.  Use G_DBUS_DEBUG=message for more info.
фев 25 12:32:47 mugalem-P35 org.freedesktop.systemd1[1625]: ** (process:1660): WARNING **: cgmanager method call org.linuxcontainers.cgmanager0_0.SetValue failed: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: invalid request.  Use G_DBUS_DEBUG=message for more info.
фев 25 12:39:20 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 12:39:59 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 12:42:16 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 12:47:37 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 12:48:03 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 13:01:31 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 13:05:01 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 13:05:37 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 13:05:54 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 13:06:09 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 17:27:07 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 17:35:41 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 17:37:13 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 17:42:25 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 18:36:59 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 18:55:20 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 18:57:36 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 19:02:35 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 19:02:36 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 19:02:37 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 19:02:39 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 19:02:40 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 19:02:55 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 19:07:10 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 19:13:07 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 19:14:55 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 19:17:58 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 19:18:05 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 19:18:07 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 19:21:10 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: failed to coldplug unifying device: Attempt to read response from device timed out
фев 25 19:21:13 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 19:24:08 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 19:31:43 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 19:55:40 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 20:03:38 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 20:05:10 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 20:13:18 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 20:16:53 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 20:19:04 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 20:19:05 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 20:19:58 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 20:27:36 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4008.0004/power_supply/hidpp_battery_0
фев 25 20:32:39 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 20:55:02 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 21:00:22 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 21:07:26 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 25 23:59:19 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 00:00:33 mugalem-P35 colord[1475]: (colord:1475): Cd-WARNING **: failed to get session [pid 11311]: Нет такого устройства или адреса
фев 26 00:05:09 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 00:07:28 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 00:11:06 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 00:11:08 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 00:11:09 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 00:11:10 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 00:12:02 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 00:17:15 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 00:17:20 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 00:22:32 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 00:34:41 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 00:47:35 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 09:08:01 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 09:13:11 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 17:13:56 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 17:14:06 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 17:14:13 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 17:14:15 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 17:14:17 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 17:24:23 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 17:33:40 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 17:48:55 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 17:54:24 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 18:46:19 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 18:53:51 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 18:59:18 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 19:05:08 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 19:14:47 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 19:20:04 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 19:39:42 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 19:45:53 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 21:13:56 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 21:14:22 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 21:14:24 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 21:14:38 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 21:19:54 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 21:28:49 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 21:43:45 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 21:48:12 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 22:05:03 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 22:10:10 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 22:13:47 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 22:20:05 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 22:20:38 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 26 22:25:50 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 00:00:41 mugalem-P35 colord[1475]: (colord:1475): Cd-WARNING **: failed to get session [pid 22712]: Нет такого устройства или адреса
фев 27 00:41:40 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 00:41:46 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 00:41:49 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: failed to coldplug unifying device: Attempt to read response from device timed out
фев 27 00:41:49 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 00:46:23 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 00:51:26 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 00:51:31 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 13:02:25 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 13:07:34 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 13:13:54 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 13:19:07 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 13:28:18 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 13:33:52 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 14:11:56 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 14:13:11 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 14:20:16 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 14:25:02 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 14:32:26 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 14:36:28 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 14:45:15 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 15:42:52 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 15:50:13 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 15:56:29 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 16:08:24 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 16:08:40 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 16:08:41 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 16:12:09 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 16:19:47 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 16:26:03 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 16:26:13 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 16:26:14 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 16:26:15 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 16:42:55 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 16:42:59 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 16:44:35 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 16:46:47 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 16:46:48 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 16:46:49 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 16:46:50 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 16:48:59 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 16:49:28 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 16:54:58 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 16:54:59 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 16:58:02 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 16:58:07 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 16:58:37 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 16:58:38 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 16:58:41 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 16:58:56 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 17:21:01 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 18:04:26 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 18:12:19 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 18:14:06 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 18:23:53 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 18:27:20 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 18:36:04 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 18:44:02 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 18:48:58 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 18:56:19 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 18:56:20 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 18:56:26 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 18:56:27 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 18:56:28 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 18:56:29 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 18:56:31 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 18:56:38 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 18:58:25 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 19:06:17 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 20:00:52 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 20:06:06 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 20:18:19 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 20:23:37 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 20:33:33 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 20:33:41 mugalem-P35 org.freedesktop.systemd1[2455]: ** (process:2482): WARNING **: cgmanager method call org.linuxcontainers.cgmanager0_0.MovePidAbs failed: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: invalid request.  Use G_DBUS_DEBUG=message for more info.
фев 27 20:33:41 mugalem-P35 org.freedesktop.systemd1[2455]: ** (process:2482): WARNING **: cgmanager method call org.linuxcontainers.cgmanager0_0.GetValue failed: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: invalid request.  Use G_DBUS_DEBUG=message for more info.
фев 27 20:33:41 mugalem-P35 org.freedesktop.systemd1[2455]: ** (process:2482): WARNING **: cgmanager method call org.linuxcontainers.cgmanager0_0.SetValue failed: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: invalid request.  Use G_DBUS_DEBUG=message for more info.
фев 27 20:38:45 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 21:23:32 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 21:33:39 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 21:33:41 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 21:33:44 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 21:39:04 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 21:44:37 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 21:46:33 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 21:51:51 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 21:59:24 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 22:06:16 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 22:07:36 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 22:15:00 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 22:15:13 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 22:23:40 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 22:23:41 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 22:23:42 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 22:54:21 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 22:56:59 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 22:59:03 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 22:59:15 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 22:59:17 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 22:59:34 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 22:59:40 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 22:59:41 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 22:59:43 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 27 23:00:20 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 28 00:00:14 mugalem-P35 colord[1475]: (colord:1475): Cd-WARNING **: failed to get session [pid 26251]: Нет такого устройства или адреса
Есть большой блок, касающийся корзины. Я и в самом деле вчера ночью обнаружил, что у меня что-то лежит в корзине и почистил ее, особо не разбираясь. Вроде ничего там (в корзине) не менял - просто нажал "Очистить корзину" в Дольфине... и что он мне теперь пишет - не пойму?
А про другие варнинги тоже может кто чего знает? Как лечить?
(у меня комп старенький, любая ошибка превращается в тупняк и жуткие тормоза, поэтому приходится вылизывать)
UPD: лог не поместился под кат - ограничение на кол-во знаков... :sad:
Последний раз редактировалось пользователем 1 StarMAUGLI; всего редактировалось раз: 4
StarMAUGLI
Решено: 19
04 мар 2019, 16:51
То, что не поместилось
фев 28 00:59:57 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 28 01:00:20 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 28 01:40:49 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 28 01:40:54 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 28 01:40:59 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 28 01:41:03 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 28 01:41:08 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 28 01:50:41 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 28 01:52:07 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 28 01:54:44 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 28 01:55:50 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 28 02:00:17 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 28 02:05:22 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 28 02:13:03 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 28 02:13:08 mugalem-P35 org.freedesktop.systemd1[28343]: ** (process:28383): WARNING **: cgmanager method call org.linuxcontainers.cgmanager0_0.MovePidAbs failed: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: invalid request.  Use G_DBUS_DEBUG=message for more info.
фев 28 02:13:08 mugalem-P35 org.freedesktop.systemd1[28343]: ** (process:28383): WARNING **: cgmanager method call org.linuxcontainers.cgmanager0_0.GetValue failed: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: invalid request.  Use G_DBUS_DEBUG=message for more info.
фев 28 02:13:08 mugalem-P35 org.freedesktop.systemd1[28343]: ** (process:28383): WARNING **: cgmanager method call org.linuxcontainers.cgmanager0_0.SetValue failed: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: invalid request.  Use G_DBUS_DEBUG=message for more info.
фев 28 02:21:34 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 28 04:38:03 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 28 04:43:21 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 28 05:10:38 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 28 05:19:14 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 28 05:50:59 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 28 05:56:22 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 28 18:22:57 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 28 18:28:43 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 28 18:39:45 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 28 18:45:14 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 28 18:49:18 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
фев 28 19:15:46 mugalem-P35 org.freedesktop.systemd1[5650]: ** (process:5677): WARNING **: cgmanager method call org.linuxcontainers.cgmanager0_0.MovePidAbs failed: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: invalid request.  Use G_DBUS_DEBUG=message for more info.
фев 28 19:15:46 mugalem-P35 org.freedesktop.systemd1[5650]: ** (process:5677): WARNING **: cgmanager method call org.linuxcontainers.cgmanager0_0.GetValue failed: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: invalid request.  Use G_DBUS_DEBUG=message for more info.
фев 28 19:15:46 mugalem-P35 org.freedesktop.systemd1[5650]: ** (process:5677): WARNING **: cgmanager method call org.linuxcontainers.cgmanager0_0.SetValue failed: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: invalid request.  Use G_DBUS_DEBUG=message for more info.
фев 28 19:25:49 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 01 00:00:56 mugalem-P35 colord[1475]: (colord:1475): Cd-WARNING **: failed to get session [pid 11195]: Нет такого устройства или адреса
мар 01 05:11:03 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 01 05:16:16 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: failed to coldplug unifying device: timeout while reading response
мар 01 05:16:18 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 01 05:17:07 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 01 05:22:30 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 01 05:47:24 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 01 05:52:40 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 01 07:36:00 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 01 07:41:08 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 01 08:36:03 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 01 08:39:57 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 01 08:41:13 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 01 09:05:01 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 01 09:08:49 mugalem-P35 org.freedesktop.systemd1[19369]: ** (process:19402): WARNING **: cgmanager method call org.linuxcontainers.cgmanager0_0.MovePidAbs failed: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: invalid request.  Use G_DBUS_DEBUG=message for more info.
мар 01 09:08:49 mugalem-P35 org.freedesktop.systemd1[19369]: ** (process:19402): WARNING **: cgmanager method call org.linuxcontainers.cgmanager0_0.GetValue failed: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: invalid request.  Use G_DBUS_DEBUG=message for more info.
мар 01 09:08:49 mugalem-P35 org.freedesktop.systemd1[19369]: ** (process:19402): WARNING **: cgmanager method call org.linuxcontainers.cgmanager0_0.SetValue failed: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: invalid request.  Use G_DBUS_DEBUG=message for more info.
мар 01 09:13:52 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 01 16:31:21 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 01 16:55:06 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 01 17:00:37 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 01 17:31:53 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 01 17:31:56 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 01 17:32:02 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 01 17:32:06 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: failed to coldplug unifying device: Attempt to read response from device timed out
мар 01 17:32:06 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 01 18:36:06 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 01 18:39:52 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 01 18:43:54 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 01 22:45:09 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 01 22:48:25 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4008.0004/power_supply/hidpp_battery_0
мар 01 22:50:15 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 01 23:55:58 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 00:00:32 mugalem-P35 colord[1475]: (colord:1475): Cd-WARNING **: failed to get session [pid 28563]: Нет такого устройства или адреса
мар 02 00:01:05 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 08:26:57 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 08:37:31 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 08:53:53 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 09:00:03 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 09:18:11 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 09:23:26 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 09:26:20 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 09:31:54 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 09:41:27 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 09:46:35 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 09:47:20 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 09:52:43 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 12:22:51 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 12:22:57 mugalem-P35 org.freedesktop.systemd1[2558]: ** (process:2585): WARNING **: cgmanager method call org.linuxcontainers.cgmanager0_0.MovePidAbs failed: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: invalid request.  Use G_DBUS_DEBUG=message for more info.
мар 02 12:22:57 mugalem-P35 org.freedesktop.systemd1[2558]: ** (process:2585): WARNING **: cgmanager method call org.linuxcontainers.cgmanager0_0.GetValue failed: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: invalid request.  Use G_DBUS_DEBUG=message for more info.
мар 02 12:22:57 mugalem-P35 org.freedesktop.systemd1[2558]: ** (process:2585): WARNING **: cgmanager method call org.linuxcontainers.cgmanager0_0.SetValue failed: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: invalid request.  Use G_DBUS_DEBUG=message for more info.
мар 02 12:30:19 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 13:44:07 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 13:49:23 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 13:49:39 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 13:49:50 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 13:50:05 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 14:06:40 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 14:59:42 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 14:59:45 mugalem-P35 org.freedesktop.systemd1[6691]: ** (process:6725): WARNING **: cgmanager method call org.linuxcontainers.cgmanager0_0.MovePidAbs failed: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: invalid request.  Use G_DBUS_DEBUG=message for more info.
мар 02 14:59:45 mugalem-P35 org.freedesktop.systemd1[6691]: ** (process:6725): WARNING **: cgmanager method call org.linuxcontainers.cgmanager0_0.GetValue failed: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: invalid request.  Use G_DBUS_DEBUG=message for more info.
мар 02 14:59:45 mugalem-P35 org.freedesktop.systemd1[6691]: ** (process:6725): WARNING **: cgmanager method call org.linuxcontainers.cgmanager0_0.SetValue failed: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: invalid request.  Use G_DBUS_DEBUG=message for more info.
мар 02 15:04:50 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 15:10:49 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 15:14:20 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4008.0004/power_supply/hidpp_battery_0
мар 02 15:17:09 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 15:19:38 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4008.0004/power_supply/hidpp_battery_0
мар 02 15:19:43 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 15:24:55 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 15:32:53 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 15:38:39 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 15:46:44 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 16:04:47 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 16:08:23 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 16:13:33 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 16:17:01 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 16:23:05 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 16:30:12 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 16:39:31 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 16:45:14 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 17:03:05 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 18:57:55 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 19:17:48 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 19:21:59 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 19:27:25 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 19:28:04 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 19:34:15 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 19:44:03 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 19:51:53 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 19:57:39 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 20:34:07 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 20:56:29 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 22:01:00 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 22:46:49 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 22:47:12 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 23:00:16 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 23:00:20 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 23:05:58 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 23:05:59 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 02 23:29:01 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4008.0004/power_supply/hidpp_battery_0
мар 02 23:44:20 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 00:00:26 mugalem-P35 colord[1475]: (colord:1475): Cd-WARNING **: failed to get session [pid 12871]: Нет такого устройства или адреса
мар 03 00:01:37 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 00:01:52 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 00:02:43 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 00:02:44 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 00:02:51 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 00:04:27 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4008.0004/power_supply/hidpp_battery_0
мар 03 00:04:44 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 00:05:02 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4008.0004/power_supply/hidpp_battery_0
мар 03 04:51:15 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 05:05:11 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 05:06:50 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 05:27:51 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 05:37:27 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 05:42:04 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 05:42:07 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 05:46:38 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 05:46:40 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 05:46:41 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 05:46:43 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 05:46:47 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: failed to coldplug unifying device: Attempt to read response from device timed out
мар 03 05:46:49 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 05:46:50 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 05:47:17 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 06:04:40 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 06:04:52 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 06:17:04 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 06:17:58 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 06:18:04 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 06:18:10 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 06:18:11 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 06:18:17 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 06:18:19 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 06:18:21 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 06:18:27 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 06:18:28 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 06:19:41 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4008.0004/power_supply/hidpp_battery_0
мар 03 06:26:48 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 06:56:58 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 06:57:22 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 07:02:48 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 07:19:59 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 07:27:06 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 07:29:04 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 07:34:13 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 08:06:06 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 08:14:50 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 08:17:23 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 08:31:55 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 13:21:27 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 13:56:16 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 13:57:47 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 14:39:22 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 14:43:01 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 14:53:16 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 15:42:11 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 15:47:28 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 22:23:55 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 22:35:16 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4008.0004/power_supply/hidpp_battery_0
мар 03 22:39:49 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 22:43:34 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 22:48:39 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 22:51:58 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 23:11:01 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 23:11:03 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 23:11:12 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 23:20:45 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 23:39:07 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 23:46:15 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 03 23:51:23 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 04 00:00:38 mugalem-P35 colord[1475]: (colord:1475): Cd-WARNING **: failed to get session [pid 24888]: Нет такого устройства или адреса
мар 04 04:21:48 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 04 04:28:11 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 04 04:28:23 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 04 04:28:26 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 04 04:29:04 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 04 04:29:05 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 04 04:35:10 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 04 04:36:52 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **: *** Unsupported operation detected on trash directory
мар 04 04:36:52 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **:     A trash files/ directory should only have files linked or unlinked (via moves or deletes).  Some other operation has been detected on a file in the directory (eg: a file has been modified).  Likely, the data reported by the trash backend will now be inconsistent.
мар 04 04:36:52 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **:   dir: /home/mugalem/.local/share/Trash/files, file: _060618, type: 4
мар 04 04:36:52 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **:   dir: /home/mugalem/.local/share/Trash/files, file: _070618, type: 4
мар 04 04:36:53 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **: *** Unsupported operation detected on trash directory
мар 04 04:36:53 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **:   dir: /home/mugalem/.local/share/Trash/files, file: _100618, type: 4
мар 04 04:36:53 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **:   dir: /home/mugalem/.local/share/Trash/files, file: _110618, type: 4
мар 04 04:36:54 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **: *** Unsupported operation detected on trash directory
мар 04 04:36:54 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **:   dir: /home/mugalem/.local/share/Trash/files, file: _130618, type: 4
мар 04 04:36:55 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **: *** Unsupported operation detected on trash directory
мар 04 04:36:55 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **:   dir: /home/mugalem/.local/share/Trash/files, file: _150618, type: 4
мар 04 04:36:56 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **: *** Unsupported operation detected on trash directory
мар 04 04:36:56 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **:   dir: /home/mugalem/.local/share/Trash/files, file: _160618, type: 4
мар 04 04:36:56 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **:   dir: /home/mugalem/.local/share/Trash/files, file: _170618, type: 4
мар 04 04:36:57 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **: *** Unsupported operation detected on trash directory
мар 04 04:36:57 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **:   dir: /home/mugalem/.local/share/Trash/files, file: _190618, type: 4
мар 04 04:36:58 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **: *** Unsupported operation detected on trash directory
мар 04 04:36:58 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **:   dir: /home/mugalem/.local/share/Trash/files, file: _210618, type: 4
мар 04 04:36:58 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **:   dir: /home/mugalem/.local/share/Trash/files, file: _250618, type: 4
мар 04 04:37:00 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **: *** Unsupported operation detected on trash directory
мар 04 04:37:00 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **:   dir: /home/mugalem/.local/share/Trash/files, file: _290618, type: 4
мар 04 04:37:00 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **:   dir: /home/mugalem/.local/share/Trash/files, file: anydesk_4.0.1-1_amd64.deb, type: 4
мар 04 04:37:00 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **:   dir: /home/mugalem/.local/share/Trash/files, file: gtkfilechooser.ini, type: 4
мар 04 04:37:00 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **:   dir: /home/mugalem/.local/share/Trash/files, file: Jabra Storm User Manual_RU.pdf, type: 4
мар 04 04:37:00 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **:   dir: /home/mugalem/.local/share/Trash/files, file: organizationSout.xls, type: 4
мар 04 04:37:00 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **:   dir: /home/mugalem/.local/share/Trash/files, file: qmlcache (1), type: 4
мар 04 04:37:00 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **:   dir: /home/mugalem/.local/share/Trash/files, file: qmlcache, type: 4
мар 04 04:37:01 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **: *** Unsupported operation detected on trash directory
мар 04 04:37:01 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **:   dir: /home/mugalem/.local/share/Trash/files, file: qmlcache, type: 4
мар 04 04:37:01 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **:   dir: /home/mugalem/.local/share/Trash/files, file: settings.ini, type: 4
мар 04 04:37:01 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **:   dir: /home/mugalem/.local/share/Trash/files, file: А685 - Акт.xlsx, type: 4
мар 04 04:37:01 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **:   dir: /home/mugalem/.local/share/Trash/files, file: акт аренда транспорта.docx, type: 4
мар 04 04:37:01 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **:   dir: /home/mugalem/.local/share/Trash/files, file: Карточка предприятия GDC_рубли.doc, type: 4
мар 04 04:37:01 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **:   dir: /home/mugalem/.local/share/Trash/files, file: ПАМЯТКА ПО ДСВ 3.doc, type: 4
мар 04 04:37:01 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **:   dir: /home/mugalem/.local/share/Trash/files, file: Памятка по ДСВ.pdf, type: 4
мар 04 04:37:01 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **:   dir: /home/mugalem/.local/share/Trash/files, file: письмо-1.txt, type: 4
мар 04 04:37:01 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **:   dir: /home/mugalem/.local/share/Trash/files, file: письмо.txt, type: 4
мар 04 04:37:01 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **:   dir: /home/mugalem/.local/share/Trash/files, file: Сервисный лист 141480.docx, type: 4
мар 04 04:37:01 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **:   dir: /home/mugalem/.local/share/Trash/files, file: Счет на оплату № 236 от 30 ноября 2018%A0г-1.pdf, type: 4
мар 04 04:37:01 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **:   dir: /home/mugalem/.local/share/Trash/files, file: Счет на оплату № 236 от 30 ноября 2018%A0г.pdf, type: 4
мар 04 04:37:01 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **:   dir: /home/mugalem/.local/share/Trash/files, file: Счет № ГДКС001_041218 от 04.12.2018 для ООО ДЖИДИСИ СЕРВИСЕЗ_1.pdf, type: 4
мар 04 04:37:01 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **:   dir: /home/mugalem/.local/share/Trash/files, file: форма Соглашения с работодателем-1.doc, type: 4
мар 04 04:37:01 mugalem-P35 org.gtk.vfs.Daemon[6691]: ** (process:15374): WARNING **:   dir: /home/mugalem/.local/share/Trash/files, file: форма Соглашения с работодателем.doc, type: 4
мар 04 05:01:36 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 04 05:08:40 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 04 16:03:10 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 04 16:08:36 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 04 16:12:39 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 04 16:18:52 mugalem-P35 org.freedesktop.systemd1[32339]: ** (process:32373): WARNING **: cgmanager method call org.linuxcontainers.cgmanager0_0.MovePidAbs failed: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: invalid request.  Use G_DBUS_DEBUG=message for more info.
мар 04 16:18:52 mugalem-P35 org.freedesktop.systemd1[32339]: ** (process:32373): WARNING **: cgmanager method call org.linuxcontainers.cgmanager0_0.GetValue failed: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: invalid request.  Use G_DBUS_DEBUG=message for more info.
мар 04 16:18:52 mugalem-P35 org.freedesktop.systemd1[32339]: ** (process:32373): WARNING **: cgmanager method call org.linuxcontainers.cgmanager0_0.SetValue failed: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: invalid request.  Use G_DBUS_DEBUG=message for more info.
┌─ mugalem ~
Опять куча WARNING'ов в журнале. Помогите разобраться?
04 мар 2019, 17:29
StarMAUGLI писал(а):
04 мар 2019, 16:50
лог не поместился под кат - ограничение на кол-во знаков...
viewtopic.php?t=2609 или https://pastebin.com/
04 мар 2019, 18:11
StarMAUGLI,
Складывается впечатление что...
А беспроводная мышка используется?
StarMAUGLI
Решено: 19
Благодарил (а): 697 раз
04 мар 2019, 18:31
darkfenix, OK - учту
(век живи, век учись - дураком помрешь)
vir0id писал(а):
04 мар 2019, 18:11
да. у меня беспроводной комплект (клавиатура + мышь) от Логитеч
есть способы борьбы с этой напастью?
я хотел upowerd (и upower, который без d) вообще отключить (писал в консоли и stop и disable), но не получается: где-то всплывает systemd vendor preset (наверное от этого самого Логитеча? хотя я не помню, что бы как-то специально его настраивал/подключал) и принудительно включает оного демона :evil:
например vendor preset: enabled
┌─ mugalem ~
└─ $ s systemctl status upower
● upower.service - Daemon for power management
   Loaded: loaded (/lib/systemd/system/upower.service; disabled; vendor preset: enabled)
   Active: inactive (dead)
     Docs: man:upowerd(8)
мар 04 17:36:30 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000
мар 04 18:23:11 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000
мар 04 18:32:28 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000
мар 04 18:32:47 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000
мар 04 18:34:48 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000
мар 04 18:34:51 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000
мар 04 18:35:11 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000
мар 04 18:35:27 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000
мар 04 18:35:28 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000
мар 04 18:35:29 mugalem-P35 upowerd[1706]: (upowerd:1706): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000
lines 1-15/15 (END)
в upowerd я большого смысла не вижу: если батарейка сдохнет в клавиатуре или мышке, я и без индикатора в трее об этом узнаю... (ибо буковки нажиматься перестанут или курсор по монитору елозиться не будет)
...короче акромя дополнительной тупизны и без того полудохлого компа - никакой пользы от демона не наблюдаю
Последний раз редактировалось пользователем 2 StarMAUGLI; всего редактировалось раз: 4
04 мар 2019, 18:41
04 мар 2019, 18:31
Ну а если батарейки поменять на новые? Для интереса.
04 мар 2019, 18:44
04 мар 2019, 18:31
04 мар 2019, 18:31
Ну как бы... Есть увереность в том, что он не нужен системе?
StarMAUGLI
Решено: 19
04 мар 2019, 18:54
vir0id писал(а):
04 мар 2019, 18:41
На прошлой неделе пришел именно к этой мысли. И во избежание того, что у меня батарейки которые дома могли быть недостаточно свежими, специально сходил в магазин и купил. Заменил (хотя те, что были в мышке и в клаве померил тестером, - были еще не дохлые).
Лог на лицо. Никакого толку.
StarMAUGLI
Решено: 19
04 мар 2019, 19:00
vir0id писал(а):
04 мар 2019, 18:44
у меня встречный вопрос: а есть уверенность, что он нужен системе?
У меня же стационарный домашний комп, не ноутбук.
Спящими режимами я не пользуюсь. Скринсейверами тоже. Максимум, что делаю - так это гашение экрана, через 20 минут простоя (но и без этого вполне могу обойтись).
Управление питанием процессора и памяти? сколько они там за ночь пока я сплю намолотят?
А вот выход из всех этих сберегающих режимов - вечный гемор. То процессор не получает сигнал на выход из спящего режима, то память не активируется, то сетевая карта неожиданно (посреди соединения с удаленным компьютером) заснет, то юсби-устройство - уже успело заснуть и надо лезть в командную строку опрашивать юсби-устройства каким-нибудь lsusb. Задолбало!
Как по мне плюсов (для десктопа) не вижу, от слова "совсем" (, а для сервера так и подавно). В мобильных устройствах (ноутбуках, планшетах) - другое дело.
Разубедите меня. Может я чего не знаю?
Последний раз редактировалось пользователем 1 StarMAUGLI; всего редактировалось раз: 4
04 мар 2019, 19:04
StarMAUGLI, http://manpages.ubuntu.com/manpages/bio ... erd.8.html
upowerd provides the org.freedesktop.UPower service on the system message bus. Users or
administrators should never need to start this daemon as it will be automatically started
by dbus-daemon(1) whenever an application calls into the org.freedesktop.UPower service
StarMAUGLI
Решено: 19
04 мар 2019, 19:17
darkfenix, ээээ...
засунул в гуглопереводчик
upowerd предоставляет сервис org.freedesktop.UPower для шины системных сообщений. Пользователям или администраторам никогда не нужно запускать этот демон, так как он будет автоматически запускаться dbus-daemon (1) всякий раз, когда приложение вызывает сервис org.freedesktop.UPower.
и что это значит?
что мне его не отключить что ли?
кстати, если я выполняю systemctl status upowerd то он вроде как отключен...
...в отличие от systemctl status upower (без d), который сколько я его не выключаю - включается вопреки моим усилиям самостоятельно (очевидно кто-то где-то поставил "защиту от дурака"). Хрен с ним. Смирюсь. Я тот самый "дурак", против которого стоит защита.
Тогда, где тот "умник", который мне расскажет, как сделать, что бы этот сервис не долбил мне постоянно ошибками в шину, завешивая все и вся?
А journalctl всплывают ошибки как раз с upowerd. В общем - нихрена я этой логики не понимаю.
UPD: Сейчас отловил этот процесс в системном мониторе и кильнул его. И вроде система не умерла на месте. Только боюсь после перезагрузки он опять появится.
UPD2: Даже перезагружаться не потребовалось. Прошло пара минут и сам появился.
04 мар 2019, 19:19
StarMAUGLI, UPower
StarMAUGLI
Решено: 19
04 мар 2019, 19:41
04 мар 2019, 19:19
UPower
Хм.
Предположил, что это из-за индикатора в трее (который рядом с часами). Выключил его средствами кде.
Еще раз отключил сервис stop/disable/daemon-reload
Перезагрузился
┌─ mugalem ~
└─ $ journalctl | grep WARNING | uniq -u
мар 04 19:32:41 mugalem-P35 colord[1015]: (colord:1015): Cd-WARNING **: failed to get session [pid 676]: Нет такого устройства или адреса
мар 04 19:32:44 mugalem-P35 org.freedesktop.systemd1[1163]: ** (process:1196): WARNING **: cgmanager method call org.linuxcontainers.cgmanager0_0.MovePidAbs failed: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: invalid request.  Use G_DBUS_DEBUG=message for more info.
мар 04 19:32:44 mugalem-P35 org.freedesktop.systemd1[1163]: ** (process:1196): WARNING **: cgmanager method call org.linuxcontainers.cgmanager0_0.GetValue failed: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: invalid request.  Use G_DBUS_DEBUG=message for more info.
мар 04 19:32:44 mugalem-P35 org.freedesktop.systemd1[1163]: ** (process:1196): WARNING **: cgmanager method call org.linuxcontainers.cgmanager0_0.SetValue failed: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: invalid request.  Use G_DBUS_DEBUG=message for more info.
┌─ mugalem ~
Ну так это совсем другое дело. С этим уже можно жить. 4-5 строк вместо двух экранов, которые в форум не лезут...
Ну то есть их тоже желательно было бы пофиксить...
upowerd в системном мониторе в списке процессов присутствует, но в лог, вроде, пока не гадит...
Но неужели из-за индикатора батареек? вот тебе и кде :sad:
Или это затишье перед бурей?
StarMAUGLI
Решено: 19
05 мар 2019, 01:25
Нет!
Похоже я преждевременно обрадовался:
┌─ mugalem ~
└─ $ !501
мар 04 19:38:23 mugalem-P35 upowerd[1246]: (upowerd:1246): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 04 19:41:34 mugalem-P35 upowerd[1246]: (upowerd:1246): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 04 19:41:36 mugalem-P35 upowerd[1246]: (upowerd:1246): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 04 19:41:37 mugalem-P35 upowerd[1246]: (upowerd:1246): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 04 19:41:43 mugalem-P35 upowerd[1246]: (upowerd:1246): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 04 19:47:03 mugalem-P35 upowerd[1246]: (upowerd:1246): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 04 19:47:08 mugalem-P35 upowerd[1246]: (upowerd:1246): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 04 19:47:10 mugalem-P35 upowerd[1246]: (upowerd:1246): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 04 19:47:33 mugalem-P35 upowerd[1246]: (upowerd:1246): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 04 19:47:35 mugalem-P35 upowerd[1246]: (upowerd:1246): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4008.0004/power_supply/hidpp_battery_0
мар 04 19:54:04 mugalem-P35 upowerd[1246]: (upowerd:1246): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 04 19:54:06 mugalem-P35 upowerd[1246]: (upowerd:1246): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 04 19:54:25 mugalem-P35 upowerd[1246]: (upowerd:1246): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 04 20:00:05 mugalem-P35 upowerd[1246]: (upowerd:1246): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 04 20:00:08 mugalem-P35 upowerd[1246]: (upowerd:1246): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 04 20:05:42 mugalem-P35 upowerd[1246]: (upowerd:1246): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 04 20:07:11 mugalem-P35 upowerd[1246]: (upowerd:1246): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 04 20:12:15 mugalem-P35 upowerd[1246]: (upowerd:1246): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 04 20:12:21 mugalem-P35 upowerd[1246]: (upowerd:1246): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 04 20:14:13 mugalem-P35 upowerd[1246]: (upowerd:1246): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 04 20:14:14 mugalem-P35 upowerd[1246]: (upowerd:1246): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 04 20:21:16 mugalem-P35 upowerd[1246]: (upowerd:1246): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 05 00:00:36 mugalem-P35 colord[1015]: (colord:1015): Cd-WARNING **: failed to get session [pid 5959]: Нет такого устройства или адреса
мар 05 00:10:52 mugalem-P35 upowerd[1246]: (upowerd:1246): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 05 00:11:10 mugalem-P35 upowerd[1246]: (upowerd:1246): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 05 00:11:12 mugalem-P35 upowerd[1246]: (upowerd:1246): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 05 00:11:41 mugalem-P35 upowerd[1246]: (upowerd:1246): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 05 00:18:09 mugalem-P35 upowerd[1246]: (upowerd:1246): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 05 00:32:24 mugalem-P35 upowerd[1246]: (upowerd:1246): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 05 01:15:57 mugalem-P35 upowerd[1246]: (upowerd:1246): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 05 01:16:48 mugalem-P35 upowerd[1246]: (upowerd:1246): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 05 01:18:56 mugalem-P35 upowerd[1246]: (upowerd:1246): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
мар 05 01:19:53 mugalem-P35 upowerd[1246]: (upowerd:1246): UPower-Linux-WARNING **: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/power_supply/hidpp_battery_1
┌─ mugalem ~
Закономерности не вижу :dash2:
Почему, например, с 20:21 до 00:00 - почти 4 часа все работало нормально и варнингов не было? Что изменилось?
а это статусы проблемных сервисов
┌─ mugalem ~
└─ $ !490
[sudo] пароль для mugalem:
   Active: active (running) since Пн 2019-03-04 19:33:08 MSK; 5h 51min ago
 Main PID: 1246 (upowerd)
   CGroup: /system.slice/upower.service
           └─1246 /usr/lib/upower/upowerd
┌─ mugalem ~
└─ $ s systemctl status upowerd
● upowerd.service
   Loaded: not-found (Reason: No such file or directory)
┌─ mugalem ~
Как отключить vendor preset: enabled?
darkfenix, я так и не нашел в предложенных вами ссылках подсказки как можно справиться с этой напастью. Может есть еще какие-то мысли? :dash2:
05 мар 2019, 05:09
StarMAUGLI, ну... А если скажем отключить от порта мышку и клавиатуру? Как система себя поведет?
StarMAUGLI
Решено: 19
15 мар 2019, 15:07
в папке /etc/UPower/ нашел конфиг UPower.conf следующего содержания
# Only the system vendor should modify this file, ordinary users
# should not have to change anything.
[UPower]
# Enable the Watts Up Pro device.
# The Watts Up Pro contains a generic FTDI USB device without a specific
# vendor and product ID. When we probe for WUP devices, we can cause
# the user to get a perplexing "Device or resource busy" error when
# attempting to use their non-WUP device.
# The generic FTDI device is known to also be used on:
# - Sparkfun FT232 breakout board
# - Parallax Propeller
# default=false
EnableWattsUpPro=false
# Don't poll the kernel for battery level changes.
# Some hardware will send us battery level changes through
# events, rather than us having to poll for it. This option
# allows disabling polling for hardware that sends out events.
# default=false
NoPollBatteries=false
# Do we ignore the lid state
# Some laptops are broken. The lid state is either inverted, or stuck
# on or off. We can't do much to fix these problems, but this is a way
# for users to make the laptop panel vanish, a state that might be used
# by a couple of user-space daemons. On Linux systems, see also
# logind.conf(5).
# default=false
IgnoreLid=false
# Policy for warnings and action based on battery levels
# Whether battery percentage based policy should be used. The default
# is to use the time left, change to true to use the percentage, which
# should work around broken firmwares. It is also more reliable than
# the time left (frantically saving all your files is going to use more
# battery than letting it rest for example).
# default=true
UsePercentageForPolicy=true
# When UsePercentageForPolicy is true, the levels at which UPower will
# consider the battery low, critical, or take action for the critical
# battery level.
# This will also be used for batteries which don't have time information
# such as that of peripherals.
# If any value is invalid, or not in descending order, the defaults
# will be used.
# Defaults:
# PercentageLow=10
# PercentageCritical=3
# PercentageAction=2
PercentageLow=10
PercentageAction=2
# When UsePercentageForPolicy is false, the time remaining at which UPower
# will consider the battery low, critical, or take action for the critical
# battery level.
# will be used.
# Defaults:
# TimeLow=1200
# TimeCritical=300
# TimeAction=120
TimeLow=1200
TimeCritical=300
TimeAction=120
# The action to take when "TimeAction" or "PercentageAction" above has been
# reached for the batteries (UPS or laptop batteries) supplying the computer
# Possible values are:
# PowerOff
# Hibernate
# HybridSleep
# If HybridSleep isn't available, Hibernate will be used
# If Hibernate isn't available, PowerOff will be used
CriticalPowerAction=HybridSleep
при переводе гуглопереводчиком у меня получилось следующее
# Только файл системы должен изменять этот файл, обычные пользователи не должны ничего менять.
[UPower]
# Включите устройство Watts Up Pro.
# Watts Up Pro содержит стандартное USB-устройство FTDI без конкретного поставщика и идентификатора продукта. Когда мы проверяем устройства WUP, мы можем заставить пользователя получить сбивающую с толку ошибку «Устройство или ресурс заняты» при попытке использовать свое устройство не-WUP.
# Известно, что универсальное устройство FTDI также используется для:
# - Доска объявлений Sparkfun FT232
# - Параллакс Пропеллер
# default = false
EnableWattsUpPro = ложь
# Не опрашивать ядро ​​на предмет изменения уровня заряда батареи.
# Некоторое оборудование будет отправлять нам изменения уровня заряда батареи посредством событий, а не нам, когда нам нужно будет это делать. Эта опция позволяет отключить опрос оборудования, которое отправляет события.
# default = false
NoPollBatteries = ложь
# Мы игнорируем состояние крышки
# Некоторые ноутбуки сломаны. Состояние крышки либо перевернуто, либо заблокировано, либо включено. Мы не можем сделать много, чтобы решить эти проблемы, но это способ для пользователей заставить панель ноутбука исчезать, состояние, которое может использоваться парой демонов пользовательского пространства. В системах Linux см. Также logind.conf (5).
# default = false
IgnoreLid = ложь
# Политика для предупреждений и действий на основе уровня заряда батареи
# Следует ли использовать политику, основанную на проценте батареи. По умолчанию используется оставшееся время, измените значение на true, чтобы использовать процент, который должен работать вокруг сломанных прошивок. Это также более надежно, чем оставшееся время (неистовое сохранение всех ваших файлов потребует больше батареи, чем, например, оставит их отдыхать).
# default = true
UsePercentageForPolicy = верно
# Когда UsePercentageForPolicy имеет значение true, уровни, на которых UPower будет считать низкий или критический уровень заряда батареи, или предпринимают действия для критического уровня заряда батареи.
# Это также будет использоваться для батарей, которые не имеют информации о времени, например, о периферийных устройствах.
# Если какое-либо значение недопустимо или не в порядке убывания, будут использоваться значения по умолчанию.
# По умолчанию:
# PercentageLow = 10
# PercentageCritical = 3
# PercentageAction = 2
PercentageLow = 10
# Когда UsePercentageForPolicy имеет значение false, оставшееся время, в течение которого UPower будет считать низкий уровень заряда батареи, критическое или предпринять действия для критического уровня заряда батареи.
## Если какое-либо значение недопустимо или не в порядке убывания, будут использоваться значения по умолчанию.
## Значения по умолчанию:
# TimeLow = 1200
# TimeCritical = 300
# TimeAction = 120
TimeLow = 1200
TimeCritical = 300
TimeAction = 120
# Действие, которое необходимо выполнить, когда «TimeAction» или «PercentageAction», указанные выше, достигнуты для батарей (батарей ИБП или ноутбука), поставляющих компьютер.
# Возможные значения:
# Выключение
# Спящий
# HybridSleep
# Если HybridSleep недоступен, будет использован Hibernate
# Если Hibernate недоступен, будет использоваться PowerOff
CriticalPowerAction = HybridSleep
Перевод не очень внятный... :sad:
что за параметр Watts Up Pro я так и не понял ни в английском ни в русском варианте...
Подскажите как лучше настроить?
...в конфигурационном файле есть два параметра
1. NoPollBatteries и
2. UsePercentageForPolicy
2.1. и в случае если этот (2) параметр true/false, вытекащие дополнительные PercentageLow = 10, PercentageCritical = 3, PercentageAction = 2 или TimeLow = 1200, TimeCritical = 300, TimeAction = 120
(я бы хотел по максимуму отключить эти опросы батарей на десктопе... особенно опросы мышки и клавиатуры... но у меня некоторые сомнения, какой параметр отвечает именно за них? а какой за батареи, скажем, ноутбуков?)
ну и
3. Параметр CriticalPowerAction=HybridSleep я хочу перевести в режим PowerOff (ни Hibernate, ни HybridSleep я на десктопе не использую). Может есть возражающие соображения?
15 мар 2019, 16:47
15 мар 2019, 15:07
Чтобы ничего не опрашивало. У тебя не ноут, и очевидно нет продвинутого УПСа. Потому что это относится к системе питания ПК, а не к батарейкам мышей и клавиатур.
StarMAUGLI
Решено: 19
15 мар 2019, 18:01
15 мар 2019, 15:07
...в конфигурационном файле есть два [ключевых, в моем случае,] параметра
т.е. первый параметр
EnableWattsUpPro=false - я не трогаю, следующий
NoPollBatteries я перевожу в состояние true
IgnoreLid=false - опять не трогаю
Что делать с параметрами которые уже включены? (ориентируясь на мои задачи: отключение всего, что можно в этом демоне по максимуму)
UsePercentageForPolicy=true - я не понимаю, что это за полиси такая? и почему при переводе ее в false спустя два модуля этого же конфига я читаю
# When UsePercentageForPolicy is false, ...
что, для нее тоже требуется настройка? Она что, до конца не выключается что ли? Или я что-то в этом гуглопереводе не догоняю?
Следующие два модуля конфига - это следствия настройки предыдущего параметра:
PercentageLow=10
PercentageAction=2
и
TimeLow=1200
TimeCritical=300
TimeAction=120
и последний параметр этого конфига я изменяю на
CriticalPowerAction=PowerOff
15 мар 2019, 19:10
15 мар 2019, 18:01
Да.
15 мар 2019, 18:01
Да. Не опрашивать батарейки.
15 мар 2019, 18:01
Это реагировать или нет на закрытие крышки ноута. Да, игнорировать. Или у тебя на десктопе есть крышка как на ноуте и есть датчик освещённости?
15 мар 2019, 18:01
Использовать или нет политику %% уровня заряда-разряда? Нет. Нет у тебя на десктопе батарейки для его питания.
Остальное просто закомментировать.
15 мар 2019, 18:01
Это что делать при критическом уровне заряда батарейки, которой у тебя нет.
И вообще в начале установили, что не хрен батарейки опрашивать.
