добавить в ярлык Google Chrome "DRI_PRIME=1"
Black$@6er
19 фев 2019, 19:43
здравствуйте. Как мне добавить в ярлык Google Chroma, находящийся в главном меню, команду DRI_PRIME=1.
  Host: blacksaber-SATELLITE-L755D Kernel: 4.15.0-45-generic x86_64 bits: 64
  compiler: gcc v: 7.3.0 Desktop: Cinnamon 4.0.9
  Type: Laptop System: TOSHIBA product: SATELLITE L755D v: PSK36E-00E00MRU
  serial: <filter>
  Mobo: AMD model: Torpedo serial: <filter> BIOS: Insyde v: 2.10
  date: 06/28/2012
  Topology: Quad Core model: AMD A6-3400M APU with Radeon HD Graphics
  bits: 64 type: MCP arch: Fusion L2 cache: 4096 KiB
  flags: lm nx pae sse sse2 sse3 sse4a svm bogomips: 11179
  Speed: 800 MHz min/max: 800/1400 MHz Core speeds (MHz): 1: 816 2: 805
  3: 853 4: 804
  Device-1: AMD BeaverCreek [Radeon HD 6520G]
  vendor: Toshiba America Info Systems driver: radeon v: kernel
  bus ID: 00:01.0
  Device-2: AMD Seymour [Radeon HD 6400M/7400M Series] driver: radeon
  v: kernel bus ID: 01:00.0
  Display: x11 server: X.Org 1.19.6 driver: ati,radeon
  unloaded: fbdev,modesetting,vesa resolution: 1366x768~60Hz
  OpenGL: renderer: AMD SUMO (DRM 2.50.0 / 4.15.0-45-generic LLVM 7.0.0)
  v: 3.3 Mesa 18.2.2 direct render: Yes
  Device-1: AMD BeaverCreek HDMI Audio [Radeon HD 6500D and 6400G-6600G
  series]
  driver: snd_hda_intel v: kernel bus ID: 00:01.1
  Device-2: AMD FCH Azalia vendor: Toshiba America Info Systems
  driver: snd_hda_intel v: kernel bus ID: 00:14.2
  Sound Server: ALSA v: k4.15.0-45-generic
  Device-1: Qualcomm Atheros AR8152 v2.0 Fast Ethernet
  vendor: Toshiba America Info Systems driver: atl1c v: 1.0.1.1-NAPI
  port: 3000 bus ID: 02:00.0
  Device-2: Realtek RTL8188CE 802.11b/g/n WiFi Adapter driver: rtl8192ce
  v: kernel port: 2000 bus ID: 03:00.0
  Local Storage: total: 473.44 GiB used: 43.65 GiB (9.2%)
  ID-1: /dev/sda vendor: Western Digital model: WD5000BPKX-22HPJT0
  ID-2: /dev/sdb type: USB vendor: Generic model: Flash Disk size: 7.68 GiB
  ID-1: / size: 454.02 GiB used: 38.00 GiB (8.4%) fs: ext4 dev: /dev/dm-0
  ID-2: swap-1 size: 3.47 GiB used: 268 KiB (0.0%) fs: swap dev: /dev/dm-1
  System Temperatures: cpu: 55.8 C mobo: N/A gpu: radeon temp: 56 C
  Processes: 225 Uptime: 1h 03m Memory: 3.34 GiB used: 1.64 GiB (49.1%)
  inxi: 3.0.27
Решено: 129
Благодарил (а): 776 раз
20 фев 2019, 07:37
Black$@6er,
20 фев 2019, 09:08
darkfenix, ты хочешь сказать, что ТС знает как переключаются карты АМД, но не знает как отредактировать команду запуска в Меню?
Хотя.., что спросили, на то и ответили.
Вернуться в «Видеокарты»
