Linux Mint 19.1 Ждущий режим Помогите
putnik113
Благодарил (а): 15 раз
02 фев 2019, 09:37
Host: olga Kernel: 4.18.0-14-generic x86_64 bits: 64 compiler: gcc
v: 7.3.0 Desktop: Cinnamon 4.0.9 Distro: Linux Mint 19.1 Tessa
base: Ubuntu 18.04 bionic
Type: Desktop Mobo: MSI model: 770-G45 (MS-7599) v: 2.0 serial: <filter>
BIOS: American Megatrends v: 10.9 date: 08/30/2013
Topology: Dual Core model: AMD Phenom II X2 570 bits: 64 type: MCP
arch: K10 rev: 3 L2 cache: 1024 KiB
flags: lm nx pae sse sse2 sse3 sse4a svm bogomips: 14001
Speed: 800 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 800 2: 800
Device-1: AMD Juniper XT [Radeon HD 5770] vendor: PC Partner Limited
driver: radeon v: kernel bus ID: 01:00.0
Display: x11 server: X.Org 1.19.6 driver: ati,radeon
unloaded: fbdev,modesetting,vesa resolution: 1680x1050~60Hz
OpenGL: renderer: AMD JUNIPER (DRM 2.50.0 / 4.18.0-14-generic LLVM 6.0.0)
v: 3.3 Mesa 18.0.5 direct render: Yes
Device-1: AMD SBx00 Azalia vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus ID: 00:14.2
Device-2: AMD Juniper HDMI Audio [Radeon HD 5700 Series]
vendor: PC Partner Limited driver: snd_hda_intel v: kernel bus ID: 01:00.1
Sound Server: ALSA v: k4.18.0-14-generic
Device-1: Qualcomm Atheros AR8131 Gigabit Ethernet vendor: Micro-Star MSI
driver: atl1c v: 1.0.1.1-NAPI port: e800 bus ID: 02:00.0
Local Storage: total: 997.89 GiB used: 29.89 GiB (3.0%)
ID-1: /dev/sda vendor: Toshiba model: HDWD110 size: 931.51 GiB
ID-2: /dev/sdb vendor: Samsung model: SP0411N size: 37.31 GiB
ID-3: /dev/sdc type: USB vendor: SanDisk model: Cruzer Glide 3.0
ID-1: / size: 36.01 GiB used: 7.11 GiB (19.8%) fs: ext4 dev: /dev/sdb5
ID-2: /boot size: 453.0 MiB used: 149.5 MiB (33.0%) fs: ext4
dev: /dev/sdb1
ID-3: /home size: 912.14 GiB used: 15.11 GiB (1.7%) fs: ext4
dev: /dev/sda5
ID-4: swap-1 size: 3.81 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda1
System Temperatures: cpu: 30.1 C mobo: N/A gpu: radeon temp: 45 C
Processes: 191 Uptime: 22m Memory: 3.85 GiB used: 730.9 MiB (18.5%)
inxi: 3.0.27
При включении ждущего режима, изображение пропадает, но все вентиляторы продолжают работать.
При попытке выйти из него по нажатию мыши или клавиатуры, реакция ноль.
При нажатии кнопки питание на системнеке, изображение появляется, но все в артефактах.
Вернутся к нормальному состоянию помогает перезагрузка.
overjoyed1987
02 фев 2019, 17:19
Такая же точно проблема. lenovo ideapad 330 arr. linux-mint. еще и видюха не работает, нагрузка на процессор сумасшедшая amd ryzen 3 (vega)
ГУРУ на помощь!
putnik113
03 фев 2019, 18:43
overjoyed1987 писал(а):
02 фев 2019, 17:19
ГУРУ на помощь!
Уважаемый выход пока один, перейти на LMDE3. Там это более менее работает.
