янв 25 13:51:46 oleg-HP-ProBook-430-G5 NetworkManager[1244]: <info> [1548406306.4706] audit: op="connection-activate" uuid="2c9c47b4-0d58-4b16-a70c-36e4df844340" name="Omks" pid=16449 uid=1000 result="success" янв 25 13:51:46 oleg-HP-ProBook-430-G5 NetworkManager[1244]: <info> [1548406306.4792] vpn-connection[0x55f1120b86e0,2c9c47b4-0d58-4b16-a70c-36e4df844340,"Omks",0]: Started the VPN service, PID 16468 янв 25 13:51:46 oleg-HP-ProBook-430-G5 NetworkManager[1244]: <info> [1548406306.4900] vpn-connection[0x55f1120b86e0,2c9c47b4-0d58-4b16-a70c-36e4df844340,"Omks",0]: Saw the service appear; activating connection янв 25 13:51:46 oleg-HP-ProBook-430-G5 NetworkManager[1244]: <info> [1548406306.5864] vpn-connection[0x55f1120b86e0,2c9c47b4-0d58-4b16-a70c-36e4df844340,"Omks",0]: VPN connection: (ConnectInteractive) reply received янв 25 13:51:46 oleg-HP-ProBook-430-G5 NetworkManager[1244]: <info> [1548406306.7118] vpn-connection[0x55f1120b86e0,2c9c47b4-0d58-4b16-a70c-36e4df844340,"Omks",0]: VPN plugin: state changed: starting (3) янв 25 13:51:46 oleg-HP-ProBook-430-G5 pppd[16475]: Plugin /usr/lib/pppd/2.4.7/nm-pptp-pppd-plugin.so loaded. янв 25 13:51:46 oleg-HP-ProBook-430-G5 NetworkManager[1244]: Plugin /usr/lib/pppd/2.4.7/nm-pptp-pppd-plugin.so loaded. янв 25 13:51:46 oleg-HP-ProBook-430-G5 pppd[16475]: pppd 2.4.7 started by root, uid 0 янв 25 13:51:46 oleg-HP-ProBook-430-G5 pppd[16475]: Using interface ppp0 янв 25 13:51:46 oleg-HP-ProBook-430-G5 NetworkManager[1244]: Using interface ppp0 янв 25 13:51:46 oleg-HP-ProBook-430-G5 NetworkManager[1244]: Connect: ppp0 <--> /dev/pts/3 янв 25 13:51:46 oleg-HP-ProBook-430-G5 pppd[16475]: Connect: ppp0 <--> /dev/pts/3 янв 25 13:51:46 oleg-HP-ProBook-430-G5 NetworkManager[1244]: <info> [1548406306.7336] manager: (ppp0): new Ppp device (/org/freedesktop/NetworkManager/Devices/30) янв 25 13:51:46 oleg-HP-ProBook-430-G5 systemd-udevd[16479]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable. янв 25 13:51:46 oleg-HP-ProBook-430-G5 pptp[16480]: nm-pptp-service-16468 log[main:pptp.c:353]: The synchronous pptp option is NOT activated янв 25 13:51:46 oleg-HP-ProBook-430-G5 NetworkManager[1244]: <info> [1548406306.7560] devices added (path: /sys/devices/virtual/net/ppp0, iface: ppp0) янв 25 13:51:46 oleg-HP-ProBook-430-G5 NetworkManager[1244]: <info> [1548406306.7560] device added (path: /sys/devices/virtual/net/ppp0, iface: ppp0): no ifupdown configuration found. янв 25 13:51:46 oleg-HP-ProBook-430-G5 pptp[16492]: nm-pptp-service-16468 log[ctrlp_rep:pptp_ctrl.c:259]: Sent control packet type is 1 'Start-Control-Connection-Request' янв 25 13:51:46 oleg-HP-ProBook-430-G5 pptp[16492]: nm-pptp-service-16468 log[ctrlp_disp:pptp_ctrl.c:781]: Received Start Control Connection Reply янв 25 13:51:46 oleg-HP-ProBook-430-G5 pptp[16492]: nm-pptp-service-16468 log[ctrlp_disp:pptp_ctrl.c:815]: Client connection established. янв 25 13:51:47 oleg-HP-ProBook-430-G5 pptp[16492]: nm-pptp-service-16468 log[ctrlp_rep:pptp_ctrl.c:259]: Sent control packet type is 7 'Outgoing-Call-Request' янв 25 13:51:47 oleg-HP-ProBook-430-G5 pptp[16492]: nm-pptp-service-16468 log[ctrlp_disp:pptp_ctrl.c:900]: Received Outgoing Call Reply. янв 25 13:51:47 oleg-HP-ProBook-430-G5 pptp[16492]: nm-pptp-service-16468 log[ctrlp_disp:pptp_ctrl.c:939]: Outgoing call established (call ID 64948, peer's call ID 23941). янв 25 13:51:59 oleg-HP-ProBook-430-G5 fctsched[951]: cat: ошибка записи: Обрыв канала янв 25 13:51:59 oleg-HP-ProBook-430-G5 fctsched[951]: No LSB modules are available. янв 25 13:52:07 oleg-HP-ProBook-430-G5 pptp[16492]: nm-pptp-service-16468 log[ctrlp_disp:pptp_ctrl.c:977]: Call disconnect notification received (call id 23941) янв 25 13:52:07 oleg-HP-ProBook-430-G5 pptp[16492]: nm-pptp-service-16468 log[ctrlp_error:pptp_ctrl.c:207]: Result code is 3 'Administrative Shutdown'. Error code is 0, Cause code is 0 янв 25 13:52:07 oleg-HP-ProBook-430-G5 NetworkManager[1244]: Modem hangup янв 25 13:52:07 oleg-HP-ProBook-430-G5 NetworkManager[1244]: Connection terminated. янв 25 13:52:07 oleg-HP-ProBook-430-G5 pptp[16492]: nm-pptp-service-16468 log[call_callback:pptp_callmgr.c:84]: Closing connection (call state) янв 25 13:52:07 oleg-HP-ProBook-430-G5 pppd[16475]: Modem hangup янв 25 13:52:07 oleg-HP-ProBook-430-G5 pppd[16475]: Connection terminated. янв 25 13:52:07 oleg-HP-ProBook-430-G5 NetworkManager[1244]: <warn> [1548406327.8505] vpn-connection[0x55f1120b86e0,2c9c47b4-0d58-4b16-a70c-36e4df844340,"Omks",0]: VPN plugin: failed: connect-failed (1) янв 25 13:52:07 oleg-HP-ProBook-430-G5 NetworkManager[1244]: <info> [1548406327.8507] vpn-connection[0x55f1120b86e0,2c9c47b4-0d58-4b16-a70c-36e4df844340,"Omks",0]: VPN plugin: state changed: stopping (5) янв 25 13:52:07 oleg-HP-ProBook-430-G5 NetworkManager[1244]: <info> [1548406327.8598] devices removed (path: /sys/devices/virtual/net/ppp0, iface: ppp0) янв 25 13:52:07 oleg-HP-ProBook-430-G5 NetworkManager[1244]: <info> [1548406327.8642] vpn-connection[0x55f1120b86e0,2c9c47b4-0d58-4b16-a70c-36e4df844340,"Omks",0]: VPN service disappeared янв 25 13:52:07 oleg-HP-ProBook-430-G5 pppd[16475]: Exit. янв 25 13:52:19 oleg-HP-ProBook-430-G5 fctsched[951]: cat: ошибка записи: Обрыв канала янв 25 13:52:19 oleg-HP-ProBook-430-G5 fctsched[951]: No LSB modules are available.
Перестало работать подключение к VPN
Всем привет! Сразу прошу строго не судить, я в linux новичек, но мне бы очень хотелось постичь эту замечательную ось. Суть проблемы вот в чем: я настроил vpn-подключение (pptp). Изначально все работало нормально, но однажды перестало подключаться. Со стороны vpn-шлюза никаких проблем нет, так как с других компов подключение проходит нормально. Помогите пожалуйста разобраться с проблемой и понять причины, чтобы больше не порождать подобных постов)))
Последний раз редактировалось пользователем 1 Dja; всего редактировалось раз: 25
Причина: spoil
Причина: spoil
Подключение пересоздать я пробовал, но результат остался тем же
