При прокрутке страниц в браузере изображение плавает
scorpionhitech
Благодарил (а): 2 раза
11 янв 2019, 01:03
Всем доброго времени суток. Есть комп с такими параметрами, под спойлером 1
  Host: uliy-mate Kernel: 4.15.0-43-generic x86_64 bits: 64 compiler: gcc
  v: 7.3.0 Desktop: MATE 1.20.1 Distro: Linux Mint 19.1 Tessa
  base: Ubuntu 18.04 bionic
  Type: Desktop Mobo: ASUSTeK model: P8H77-M LE v: Rev X.0x serial: <filter>
  UEFI: American Megatrends v: 1501 date: 06/20/2014
  Topology: Dual Core model: Intel Pentium G620 bits: 64 type: MCP
  arch: Sandy Bridge rev: 7 L2 cache: 3072 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 10376
  Speed: 2592 MHz min/max: 1600/2600 MHz Core speeds (MHz): 1: 2454 2: 2256
  vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0
  Display: x11 server: X.Org 1.19.6 driver: modesetting unloaded: fbdev,vesa
  resolution: 1920x1080~60Hz
  OpenGL: renderer: Mesa DRI Intel Sandybridge Desktop v: 3.3 Mesa 18.0.5
  Device-1: Intel 7 Series/C216 Family High Definition Audio
  vendor: ASUSTeK ASUS P8Z77-V LX driver: snd_hda_intel v: kernel
  bus ID: 00:1b.0
  Device-2: Logitech type: USB driver: snd-usb-audio,uvcvideo bus ID: 3-2:2
  Sound Server: ALSA v: k4.15.0-43-generic
  vendor: ASUSTeK P8 series driver: r8169 v: 2.3LK-NAPI port: e000
  bus ID: 03:00.0
  Local Storage: total: 1.80 TiB used: 34.58 GiB (1.9%)
  ID-1: /dev/sda vendor: Western Digital model: WD10EZEX-08WN4A0
  ID-2: /dev/sdb vendor: Western Digital model: WD1600AAJS-00PSA0
  ID-3: /dev/sdc vendor: Hitachi model: HDT725032VLA360 size: 298.09 GiB
  ID-4: /dev/sdd vendor: Western Digital model: WD5000AZRX-00A8LB0
  ID-1: / size: 91.17 GiB used: 28.06 GiB (30.8%) fs: ext4 dev: /dev/sda2
  ID-2: /home size: 100.23 GiB used: 6.52 GiB (6.5%) fs: ext4 dev: /dev/sda4
  ID-3: swap-1 size: 4.66 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda1
  System Temperatures: cpu: 29.8 C mobo: 27.8 C
  Fan Speeds (RPM): cpu: 0
  Processes: 184 Uptime: 10m Memory: 3.73 GiB used: 1.64 GiB (44.1%)
  inxi: 3.0.27
и есть интегрированое видео Intel HD GRAPHICS под спойлером 2
Проблема следующая - при прокрутке сайтов в браузере наблюдается как будто изображение плавает. По экрану проходит полоса по диагонали. На статичном такого нет. Насколько я понимаю, что то связано с обновлением экрана. А вот как это исправить?
Благодарил (а): 1233 раза
11 янв 2019, 01:53
У меня всегда так было на всех Linux осях. Горизонтальная полоска в центре экрана. Я думал так и должно быть и не обращал внимания. Теперь задумался. :joke:
Griga211
Благодарил (а): 9 раз
11 янв 2019, 05:14
Тиринг что ли? Как правило это лечится.
abulaev2008
Благодарил (а): 24 раза
11 янв 2019, 11:04
hellonet писал(а):
11 янв 2019, 01:53
Теперь задумался
Тоже было такое, почему-то только в Mate (Mint и Ubunta).
11 янв 2019, 16:09
abulaev2008 писал(а):
11 янв 2019, 11:04
Я всегда себе только Mate и ставлю. Другие не воспринимаю.
11 янв 2019, 17:23
11 янв 2019, 11:04
Завязано на compositing manager - в мате это marco. Если поменять на альтернативный, например compton - часто уже этого бывает достаточно. Но compton может вызывать другие косяки, потому по умолчанию его не ставят.
kutalgin
Благодарил (а): 12 раз
11 янв 2019, 17:42
Ещё это может решится установкой приопиретарных драйверов.
Ишимбайский
11 янв 2019, 20:09
kutalgin писал(а):
11 янв 2019, 17:42
На intel?
Kurum
Благодарил (а): 193 раза
11 янв 2019, 22:12
hellonet писал(а):
11 янв 2019, 01:53
:lol: :lol: :lol:
Linux - это свобода... :tux:
Текущая:
KDE Neon 5.2x
Предыдущая:
Linux Mint 19.1 Cinnamon
Железо:
Благодарил (а): 26 раз
12 янв 2019, 01:07
Гуглить тиринг linux amd, или nvidia, или intel.
Пробовать разные конфиги в /usr/share/X11/xorg.conf.d/
Скажем, у меня на прежнем слабом железе AMD 5450 на матэ вылез жуткий тиринг (на циннамоне при этом просто подтупливало видео). Добавил в конфиг строчку
Option "TearFree" "on"
и тиринг пропал.
Потом сменил видюху на гораздо более мощную, и все было хорошо, пока не обновился до 19.1. На циннамоне видео стало слегка подтормаживать, потерялась плавность на сложных сценах 1080р.
Убрал строчку, стало плавно.
(при экспериментах перезапускать гуй не забываем, service lightdm restart или тупо перезагрузить комп).
12 янв 2019, 01:21
027 писал(а):
12 янв 2019, 01:07
Загрузился сейчас в матэ, посмотрел. Тиринг заметен на одном видео футбола, запись 1080p в формате TimeShift. Очень сложные сцены, панорамирование общего плана стадиона с десятками тысяч мелких контрастных деталей. Тиринг не жуткий, но заметный. А на 1080р с природой, средней степени сложности — испарения гейзеров, или там забег медведя по ручью крупным планом (мелкие брызги по всему полю) — там ничо так, ни таринга, ни подергиваний.
12 янв 2019, 02:00
Kurum писал(а):
11 янв 2019, 22:12
hellonet писал(а): ↑Вчера, 05:53
У меня, видимо и не тиринг, как его описывают, а просто небольшое расплытие изображения на горизонтальной линии (не более полусантиметра толщиной) по центру экрана и только во время движения окна сайта колёсиком мыши. Мне абсолютно не мешает. Все фильмы: обычные, HD, FullHD, Blu ray и другие идут абсолютно без искажений.
12 янв 2019, 02:01
hellonet писал(а):
12 янв 2019, 02:00
сдвиг? это и есть тиринг
12 янв 2019, 03:15
Примерно происходит выпадение с 1 строчку размером.
scorpionhitech
13 янв 2019, 12:17
Что бьі систему не переустанавливать , поставил cinnamon на мате. Так назьіваемьій тиринг пропал, но многие настройки cinnamon панели не работают. Не охота ость переустанавливать, но наверное придется.
13 янв 2019, 14:38
scorpionhitech, Не обязательно. можно создать нового пользователя, и там каши в конфигах двух рабочих столов не будет. Перенести туда все свои остальные файлы и настройки будет делом техники.
scorpionhitech
13 янв 2019, 19:20
zuzabrik писал(а):
13 янв 2019, 14:38
разобрался. Нужно было один компонент доустановить и всё заработало.
14 янв 2019, 12:41
scorpionhitech, какой?
scorpionhitech
14 янв 2019, 23:22
Dja писал(а):
14 янв 2019, 12:41
если не ошибаюсь, mint-meta-cinnamon
15 янв 2019, 07:58
scorpionhitech, у вас mate. mint-meta-cinnamon там ни одним местом
Вернуться в «Видеокарты»
