После очередной перезагрузки система не запустилась
putnik113
Благодарил (а): 15 раз
28 дек 2018, 10:03
dom@dom:~$ inxi -Fxz
  Host: dom Kernel: 4.18.0-13-generic x86_64 bits: 64 compiler: gcc v: 7.3.0
  Desktop: Cinnamon 4.0.8 Distro: Linux Mint 19.1 Tessa
  base: Ubuntu 18.04 bionic
  Type: Desktop System: Gigabyte product: N/A v: N/A serial: <filter>
  Mobo: Gigabyte model: 970-GAMING v: x.x serial: <filter>
  BIOS: American Megatrends v: F2 date: 04/06/2016
  Topology: Quad Core model: AMD FX-4330 bits: 64 type: MCP arch: Bulldozer
  L2 cache: 2048 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
  bogomips: 32146
  Speed: 1889 MHz min/max: 1400/4000 MHz Core speeds (MHz): 1: 2008 2: 1989
  3: 2544 4: 2740
  Device-1: AMD Tahiti XT [Radeon HD 7970/8970 OEM / R9 280X]
  vendor: Gigabyte driver: radeon v: kernel bus ID: 01:00.0
  Display: x11 server: X.Org 1.19.6 driver: ati,radeon
  OpenGL: renderer: AMD TAHITI (DRM 2.50.0 / 4.18.0-13-generic LLVM 6.0.0)
  v: 4.5 Mesa 18.0.5 direct render: Yes
  Device-1: AMD SBx00 Azalia vendor: Gigabyte driver: snd_hda_intel
  v: kernel bus ID: 00:14.2
  Device-2: AMD Tahiti HDMI Audio [Radeon HD 7870 XT / 7950/7970]
  vendor: Gigabyte driver: snd_hda_intel v: kernel bus ID: 01:00.1
  Sound Server: ALSA v: k4.18.0-13-generic
  Device-1: Qualcomm Atheros Killer E2400 Gigabit Ethernet vendor: Gigabyte
  driver: alx v: kernel port: d000 bus ID: 04:00.0
  Local Storage: total: 931.51 GiB used: 24.78 GiB (2.7%)
  ID-1: /dev/sda vendor: Seagate model: ST1000DM003-1SB10C size: 931.51 GiB
  ID-1: / size: 186.74 GiB used: 7.16 GiB (3.8%) fs: ext4 dev: /dev/sda6
  ID-2: /boot size: 461.0 MiB used: 148.9 MiB (32.3%) fs: ext2
  dev: /dev/sda1
  ID-3: /home size: 720.18 GiB used: 17.47 GiB (2.4%) fs: ext4
  dev: /dev/sda7
  ID-4: swap-1 size: 7.63 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda5
  System Temperatures: cpu: 35.0 C mobo: 32.0 C gpu: radeon temp: 46 C
  Fan Speeds (RPM): cpu: 913 fan-2: 1318 fan-3: 1757 fan-4: 0 fan-5: 0
  Voltages: 12v: N/A 5v: N/A 3.3v: N/A vbat: 3.12
  Processes: 205 Uptime: 21m Memory: 7.75 GiB used: 1.19 GiB (15.4%)
  inxi: 3.0.27
dom@dom:~$
После очередной перезагрузки система не загрузилась.
download/file.php?mode=view&id=9903
Так как / и home на разных дисках, я сразу переутановил систему. Но не тут то было, ошибка выскочила вновь. Так как остался не тронутым диск home, я заподозрил в ошибке настройки которые на нем остались.
Пришлось сносить и home. После этого все загрузилось. Кто подскажет что за хрень была, что бы в будущем такого избежать?
Дополню: ядро на тот момент стояло 4.19.11
Последний раз редактировалось пользователем 1 putnik113; всего редактировалось раз: 28
Благодарил (а): 794 раза
28 дек 2018, 10:15
putnik113 писал(а):
28 дек 2018, 10:03
Никто, потому как логов уже не посмотреть
putnik113
28 дек 2018, 10:17
А как и где в таких случаях смотреть и сохранять эти логи?
28 дек 2018, 10:25
putnik113 писал(а):
28 дек 2018, 10:17
Прям на твоем скриншоте экрана написано где искать логи, достаточно прочитать.
Я не думаю что проблема в /home была, для этого нет никаких предпосылок. Система ругается на видеокарту (неверная сигнатура) и usb порты.
Гугленье по названию ошибки выдает в основном сайты майнеров, которые тыкают по 6 видях, ты не майнер случаем? :-D
putnik113 писал(а):
28 дек 2018, 10:03
Если подозреваешь ядро, сделай так чтобы при загрузке появлялось меню GRUB и оставь дефолтное, которое идет при установке. Накатив новое оно появится в меню GRUB наравне со старым, и ты сможешь выбрать с каким ядром грузить систему.
putnik113
28 дек 2018, 12:46
Но система загрузилась только после очистки (форматирования) диска home. Вот в чем заковырка.
28 дек 2018, 14:42
putnik113 писал(а):
28 дек 2018, 12:46
Правила логики говорят: после этого - не означает "в следствие этого". Вероятность конечно присутствует. Но не более.
Благодарил (а): 212 раз
28 дек 2018, 16:50
putnik113 писал(а):
28 дек 2018, 10:03
А яндекс говорит что видеокарта не определяется (не считывается сигнатура) из-за того что карта перепрошитая. Ну вот например.. https://www.linux.org.ru/forum/linux-hardware/14022928
Майнеры кстати того же мнения.. :-D
putnik113
28 дек 2018, 17:00
Видюха R9 280x два биоса. Один я запорол. Майнинг, не и не пахнет.
Видеокарта была в ремонте. Жарили проц. Сколько протянет, сказали не известно.
Может эта инфа поможет?
28 дек 2018, 17:22
putnik113, там по ссылке и решение - "Залить в видюху нормальную прошивку"
putnik113
28 дек 2018, 19:41
Вы случайно не из латышких стрелков? В видюхе ДВА биоса
После форматирования и переустановки ВСЁ работает
ЗАЧЕМ что то прошивать?
29 дек 2018, 06:12
putnik113 писал(а):
28 дек 2018, 19:41
Дело хозяйское, я говорю о том, что проблема на уровне железа, а не софтовая
