LM 19.1 Tessa x86_64
inxi -Fxz:
Machine: Type: Desktop Mobo: ASRock model: ZH77 Pro3 serial: <filter> BIOS: American Megatrends v: P1.00
date: 07/23/2012
CPU: Topology: Dual Core model: Intel Core i3-2120 bits: 64 type: MT MCP arch: Sandy Bridge rev: 7
L2 cache: 3072 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 26339
Speed: 1596 MHz min/max: 1600/3300 MHz Core speeds (MHz): 1: 1596 2: 1596 3: 1596 4: 1596
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Bonaire XTX [Radeon R7 260X/360] vendor: Gigabyte
driver: radeon v: kernel bus ID: 01:00.0
Display: x11 server: X.Org 1.19.6 driver: ati,radeon unloaded: fbdev,modesetting,vesa
resolution: 1920x1080~60Hz
OpenGL: renderer: AMD BONAIRE (DRM 2.50.0 / 4.15.0-43-generic LLVM 6.0.0) v: 4.5 Mesa 18.0.5
Audio: Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: ASRock driver: snd_hda_intel
v: kernel bus ID: 00:1b.0
Device-2: Advanced Micro Devices [AMD/ATI] Tobago HDMI Audio [Radeon R7 360 / R9 360 OEM]
vendor: Gigabyte driver: snd_hda_intel v: kernel bus ID: 01:00.1
Sound Server: ALSA v: k4.15.0-43-generic
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASRock driver: r8169
v: 2.3LK-NAPI port: d000 bus ID: 05:00.0
IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives: Local Storage: total: 1.93 TiB used: 656.36 GiB (33.2%)
ID-1: /dev/sda vendor: Western Digital model: WD10EZEX-00KUWA0 size: 931.51 GiB
ID-2: /dev/sdb vendor: Kingston model: SA400S37120G size: 111.79 GiB
ID-3: /dev/sdc type: USB vendor: Western Digital model: WD My Passport 074A size: 931.51 GiB
Partition: ID-1: / size: 45.58 GiB used: 7.05 GiB (15.5%) fs: ext4 dev: /dev/sdb1
ID-2: /home size: 63.70 GiB used: 8.91 GiB (14.0%) fs: ext4 dev: /dev/sdb2
ID-3: swap-1 size: 3.81 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/dm-0
Sensors: System Temperatures: cpu: 47.0 C mobo: N/A gpu: radeon temp: 45 C
Info: Processes: 219 Uptime: 1h 53m Memory: 7.75 GiB used: 2.56 GiB (33.0%) Init: systemd runlevel: 5
Compilers: gcc: 7.3.0 Shell: bash v: 4.4.19 inxi: 3.0.27
Ведь вместо 40-libsane.rules во всех системах я вижу только 60-libsane1.rules, кстати вот его содержание(может я не туда скопипастил?)
# udev rules file for supported USB and SCSI devices
# For the list of supported USB devices see /usr/lib/udev/hwdb.d/20-sane.hwdb
# The SCSI device support is very basic and includes only
# scanners that mark themselves as type "scanner" or
# SCSI-scanners from HP and other vendors that are entitled "processor"
# but are treated accordingly.
# If your SCSI scanner isn't listed below, you can add it to a new rules
# file under /etc/udev/rules.d/.
# If your scanner is supported by some external backend (brother, epkowa,
# hpaio, etc) please ask the author of the backend to provide proper
# device detection support for your OS
# If the scanner is supported by sane-backends, please mail the entry to
# the sane-devel mailing list (sane-devel@lists.alioth.debian.org).
ACTION!="add", GOTO="libsane_rules_end"
# The following rule will disable USB autosuspend for the device
ENV{DEVTYPE}=="usb_device", ENV{libsane_matched}=="yes", TEST=="power/control", ATTR{power/control}="on"
SUBSYSTEMS=="scsi", GOTO="libsane_scsi_rules_begin"
LABEL="libsane_scsi_rules_begin"
KERNEL!="sg[0-9]*", GOTO="libsane_rules_end"
# Generic: SCSI device type 6 indicates a scanner
ATTRS{type}=="6", ENV{libsane_matched}="yes"
# Some scanners advertise themselves as SCSI device type 3
# Wildcard: for some Epson SCSI scanners
ATTRS{type}=="3", ATTRS{vendor}=="EPSON", ATTRS{model}=="SCANNER*", ENV{libsane_matched}="yes"
# Epson Expression 800 | Epson Expression 800
ATTRS{type}=="3", ATTRS{vendor}=="EPSON", ATTRS{model}=="Expression800", ENV{libsane_matched}="yes"
# Epson Perfection 2450 | Epson GT-9700F | Epson Perfection 2450 PHOTO
ATTRS{type}=="3", ATTRS{vendor}=="EPSON", ATTRS{model}=="GT-9700", ENV{libsane_matched}="yes"
# Epson Perfection 3200 | Epson GT-9800F | Epson Perfection 3200 PHOTO
ATTRS{type}=="3", ATTRS{vendor}=="EPSON", ATTRS{model}=="GT-9800", ENV{libsane_matched}="yes"
# Epson GT-X900 | Epson Perfection V700 Photo | Epson Perfection V750 Photo
ATTRS{type}=="3", ATTRS{vendor}=="EPSON", ATTRS{model}=="GT-X900", ENV{libsane_matched}="yes"
# Epson Perfection 636S | Epson Perfection 1200S | Epson Perfection 1200S
ATTRS{type}=="3", ATTRS{vendor}=="EPSON", ATTRS{model}=="Perfection1200", ENV{libsane_matched}="yes"
# Epson Perfection 636 | Epson Perfection 636S
ATTRS{type}=="3", ATTRS{vendor}=="EPSON", ATTRS{model}=="Perfection636", ENV{libsane_matched}="yes"
# Hewlett-Packard ScanJet 4p
ATTRS{type}=="3", ATTRS{vendor}=="HP", ATTRS{model}=="C1130A", ENV{libsane_matched}="yes"
# Hewlett-Packard ScanJet IIc
ATTRS{type}=="3", ATTRS{vendor}=="HP", ATTRS{model}=="C1750A", ENV{libsane_matched}="yes"
# Hewlett-Packard ScanJet IIp
ATTRS{type}=="3", ATTRS{vendor}=="HP", ATTRS{model}=="C1790A", ENV{libsane_matched}="yes"
# Hewlett-Packard ScanJet IIcx
ATTRS{type}=="3", ATTRS{vendor}=="HP", ATTRS{model}=="C2500A", ENV{libsane_matched}="yes"
# Hewlett-Packard ScanJet 4c
ATTRS{type}=="3", ATTRS{vendor}=="HP", ATTRS{model}=="C2520A", ENV{libsane_matched}="yes"
# Hewlett-Packard ScanJet 5p
ATTRS{type}=="3", ATTRS{vendor}=="HP", ATTRS{model}=="C5110A", ENV{libsane_matched}="yes"
# Hewlett-Packard ScanJet 6200C
ATTRS{type}=="3", ATTRS{vendor}=="HP", ATTRS{model}=="C6270A", ENV{libsane_matched}="yes"
# Hewlett-Packard ScanJet 6300C
ATTRS{type}=="3", ATTRS{vendor}=="HP", ATTRS{model}=="C7670A", ENV{libsane_matched}="yes"
# Panasonic MFS scanners
ATTRS{idVendor}=="04da", ENV{libsane_matched}="yes"
LABEL="libsane_rules_end"
UPD:
На всякий случай lsusb его видит вот так: lsusb
Bus 002 Device 003: ID 04da:0f0b Panasonic (Matsushita)
