Не обновляется кэш в апплетах и темах
lelik86
24 дек 2018, 03:44
LM 19.1 x64 Cinnamon. Не обновляется кэш именно в темах и апплетах.
inxi
~$ inxi -Fxz
Host: Aspire Kernel: 4.15.0-43-generic x86_64 bits: 64 compiler: gcc
v: 7.3.0 Desktop: Cinnamon 4.0.8 Distro: Linux Mint 19.1 Tessa
base: Ubuntu 18.04 bionic
Type: Laptop System: Acer product: Aspire 4920 v: 0100 serial: <filter>
Mobo: Acer model: Tahoe v: Rev serial: <filter> BIOS: Phoenix v: 1.20
date: 02/01/2008
Topology: Dual Core model: Intel Core2 Duo T5550 bits: 64 type: MCP
arch: Core Merom rev: D L2 cache: 2048 KiB
flags: lm nx pae sse sse2 sse3 ssse3 bogomips: 7315
Speed: 1250 MHz min/max: 1000/1833 MHz Core speeds (MHz): 1: 1106 2: 1097
Device-1: AMD RV610/M74 [Mobility Radeon HD 2400 XT]
vendor: Acer Incorporated ALI driver: radeon v: kernel bus ID: 01:00.0
Display: x11 server: X.Org 1.19.6 driver: ati,radeon
unloaded: fbdev,modesetting,vesa resolution: 1280x800~60Hz
OpenGL: renderer: AMD RV610 (DRM 2.50.0 / 4.15.0-43-generic LLVM 6.0.0)
v: 3.3 Mesa 18.0.5 direct render: Yes
Device-1: Intel 82801H HD Audio vendor: Acer Incorporated ALI
Sound Server: ALSA v: k4.15.0-43-generic
Device-1: Broadcom Limited NetLink BCM5787M Gigabit Ethernet PCI Express
vendor: Acer Incorporated ALI driver: tg3 v: 3.137 port: 2000
bus ID: 02:00.0
Device-2: Intel PRO/Wireless 4965 AG or AGN [Kedron] Network
driver: iwl4965 v: in-tree: port: 2000 bus ID: 04:00.0
IF: wlp4s0 state: down mac: <filter>
IF-ID-1: ppp0 state: unknown speed: N/A duplex: N/A mac: N/A
Local Storage: total: 111.79 GiB used: 78.98 GiB (70.7%)
ID-1: /dev/sda vendor: Fujitsu model: MHY2120BH size: 111.79 GiB
ID-1: / size: 109.53 GiB used: 78.98 GiB (72.1%) fs: ext4 dev: /dev/sda1
System Temperatures: cpu: 60.0 C mobo: 59.0 C gpu: radeon temp: 54 C
Processes: 180 Uptime: 44m Memory: 3.85 GiB used: 1.12 GiB (29.0%)
inxi: 3.0.27
Вот скрин В 19.0 все работало.
Менеджер обновлений и Менеджер программ работают нормально.
Подскажите пожалуйста в чем проблема.
24 дек 2018, 06:12
Такая же беда
inxi -S
System:    Host: darkfenix Kernel: 4.15.0-43-generic x86_64 bits: 64 Desktop: Cinnamon 4.0.8 Distro: Linux Mint 19.1 Tessa
Ара Магеддон
Решено: 18
Благодарил (а): 37 раз
24 дек 2018, 06:48
УМВР. Скорее всего, действительно нужно было повторить через некоторое время.
24 дек 2018, 09:12
Ара Магеддон писал(а):
24 дек 2018, 06:48
Действительно, заработало :hoho:
lelik86
24 дек 2018, 09:18
Проверяю регулярно,не работает. Может из терминала как то можно сделать?
lelik86
24 дек 2018, 09:39
С соседского WiFi все заработало. Тему можно закрыть
lelik86
24 дек 2018, 09:40
lelik86 писал(а):
24 дек 2018, 03:44
inxi
~$ inxi -Fxz
date: 02/01/2008
bus ID: 02:00.0
inxi: 3.0.27
24 дек 2018, 21:19
lelik86,
Просьба изображения постить либо перетаскиванием в окно написания сообщения на форуме либо прямым линком (оканчиваться должно на расширение файла), заключенным в тег [img]ссылка.png[/img]
