error while loading shared libraries: libtcmalloc_minimal.so.4
Xiomon
Благодарил (а): 2 раза
15 дек 2018, 09:39
Linux Mint 18.3 x64
error while loading shared libraries: libtcmalloc_minimal.so.4: cannot open shared object file: No such file or directory
Как решить проблему?
System:    Host: ggggg-X555LD Kernel: 4.10.0-38-generic x86_64 (64 bit gcc: 5.4.0)
           Desktop: Cinnamon 3.6.7 (Gtk 3.18.9) Distro: Linux Mint 18.3 Sylvia
Machine:   System: ASUSTeK (portable) product: X555LD v: 1.0
           Mobo: ASUSTeK model: X555LD v: 1.0
           Bios: American Megatrends v: X555LD.310 date: 08/14/2014
CPU:       Dual core Intel Core i7-4510U (-HT-MCP-) cache: 4096 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 10376
           clock speeds: max: 3100 MHz 1: 1281 MHz 2: 1461 MHz 3: 1333 MHz
           4: 1287 MHz
Graphics:  Card-1: Intel Haswell-ULT Integrated Graphics Controller
           bus-ID: 00:02.0
           Card-2: NVIDIA GF117M [GeForce 610M/710M/810M/820M / GT 620M/625M/630M/720M]
           bus-ID: 04:00.0
           Display Server: X.Org 1.18.4 driver: nvidia
           Resolution: 1366x768@60.00hz
           GLX Renderer: GeForce 820M/PCIe/SSE2
           GLX Version: 4.6.0 NVIDIA 390.77 Direct Rendering: Yes
Audio:     Card-1 Intel 8 Series HD Audio Controller
           Card-2 Intel Haswell-ULT HD Audio Controller
           driver: snd_hda_intel bus-ID: 00:03.0
           Sound: Advanced Linux Sound Architecture v: k4.10.0-38-generic
Network:   Card-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
           driver: r8169 v: 2.3LK-NAPI port: e000 bus-ID: 02:00.0
           Card-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
           driver: ath9k bus-ID: 03:00.0
Drives:    HDD Total Size: 1000.2GB (36.1% used)
           ID-1: /dev/sda model: ST1000LM024_HN size: 1000.2GB temp: 31C
Partition: ID-1: / size: 110G used: 26G (25%) fs: ext4 dev: /dev/sda1
           ID-2: /home size: 459G used: 309G (71%) fs: ext4 dev: /dev/sda5
           ID-3: swap-1 size: 2.00GB used: 0.00GB (0%) fs: swap dev: /dev/sda6
Sensors:   System Temperatures: cpu: 57.5C mobo: N/A gpu: 0.0:61C
           Fan Speeds (in rpm): cpu: 3500
Info:      Processes: 281 Uptime: 13 min Memory: 2070.2/5849.4MB
Последний раз редактировалось пользователем 1 rogoznik; всего редактировалось раз: 15
Причина: так лучше :)
15 дек 2018, 10:25
Xiomon, а что за проблема то? Текст ошибки мы увидели, но этого мало.
15 дек 2018, 10:43
15 дек 2018, 10:25
+1 хотелось бы грязных подробностей, в каком случае выскакивает это сообщение
поиск в гугле отсылает в основном на проблемы с запуском игр, приведу один из ответов.
Игра требует 32-битную версию библиотеки, так что если вы запускаете ее на 64-битной системе, и не имеете 32-битной библиотеки, вы должны запустить
и затем установить с :i386 suffix:
sudo apt install libtcmalloc-minimal4:i386
colonel
Решено: 21
15 дек 2018, 12:21
и чего юзеры такие ленивые ни прочитать не хотят что в "ошибке" написано
"ошибка загрузки общих библиотек: libtcmalloc_minimal.so.4: не удается открыть общий объектный файл: нет такого файла или каталога
ни в поиск тупо забить эту ошибку и посмотреть ... ТЫЦ>>>>
вторая же ссылка -> Ошибка error while loading shared libraries >>> (скорее поможет для общего понимания )
а там и 3 и 4 и...
Сейчас этот форум просматривают: Yandex [Bot] и 2 гостя
