Очень долгая загрузка ядра в LM 19
Anatoly 86
09 ноя 2018, 13:37
desktop:~$ inxi -Fxz
System: Host: user-desktop Kernel: 4.15.0-38-generic x86_64
bits: 64 gcc: 7.3.0
Desktop: Cinnamon 3.8.9 (Gtk 3.22.30-1ubuntu1)
Distro: Linux Mint 19 Tara
Machine: Device: desktop Mobo: ASRock model: 890GX Extreme3 serial: N/A
BIOS: American Megatrends v: P3.10 date: 12/06/2011
CPU: Quad core AMD Phenom II X4 955 (-MCP-)
arch: K10 rev.3 cache: 2048 KB
flags: (lm nx sse sse2 sse3 sse4a svm) bmips: 28857
clock speeds: max: 3600 MHz 1: 2100 MHz 2: 800 MHz 3: 2100 MHz
4: 2100 MHz
Graphics: Card: Advanced Micro Devices [AMD/ATI] Barts PRO [Radeon HD 6850]
bus-ID: 04:00.0
drivers: ati,radeon (unloaded: modesetting,fbdev,vesa)
Resolution: 1920x1080@60.00hz
OpenGL: renderer: AMD BARTS (DRM 2.50.0 / 4.15.0-38-generic, LLVM 6.0.0)
version: 3.3 Mesa 18.0.5 Direct Render: Yes
Audio: Card-1 Advanced Micro Devices [AMD/ATI] Barts HDMI Audio [Radeon HD 6790/6850/6870 / 7720 OEM]
driver: snd_hda_intel bus-ID: 04:00.1
Card-2 Advanced Micro Devices [AMD/ATI] SBx00 Azalia (Intel HDA)
Card-3 Cubeternet driver: USB Audio usb-ID: 001-003
Sound: Advanced Linux Sound Architecture v: k4.15.0-38-generic
Network: Card-1: Realtek RTL8111/8168/8411 PCIE Gigabit Ethernet Controller
driver: r8169 v: 2.3LK-NAPI port: c800 bus-ID: 02:00.0
Card-2: Realtek RTL8192CU 802.11n WLAN Adapter
driver: rtl8192cu usb-ID: 001-002
IF: wlxc04a001b383b state: N/A mac: N/A
Drives: HDD Total Size: 1064.2GB (1.6% used)
ID-1: /dev/sda model: ST31000528AS size: 1000.2GB
ID-2: /dev/sdb model: T size: 64.0GB
Partition: ID-1: / size: 60G used: 17G (29%) fs: btrfs dev: /dev/sdb1
ID-2: /home size: 60G used: 17G (29%) fs: btrfs dev: /dev/sdb1
Sensors: System Temperatures: cpu: 37.0C mobo: 38.0C gpu: 44.0
Fan Speeds (in rpm): cpu: N/A fan-1: 0 fan-2: 1205 fan-3: 0
Info: Processes: 232 Uptime: 47 min Memory: 1689.4/3944.4MB
09 ноя 2018, 13:39
Anatoly 86, насколько долгая, почему именно ядра?
дополни сперва вводную чтоль. :rus3:
09 ноя 2018, 13:39
Anatoly 86, поздравляем :)
09 ноя 2018, 13:41
Anatoly 86, и как ты это определил?
Тут нет телепатов.
Вывод
systemd-analyze
и
systemd-analyze blame
в студию
Anatoly 86
09 ноя 2018, 13:43
systemd-analyze plot > slow_boot.svg -15м ядро
Anatoly 86
09 ноя 2018, 13:43
desktop:~$ systemd-analyze blame
          6.212s NetworkManager-wait-online.service
          1.131s keyboard-setup.service
           580ms dev-sdb1.device
           424ms udisks2.service
           407ms NetworkManager.service
           299ms systemd-journal-flush.service
           282ms networkd-dispatcher.service
           270ms upower.service
           256ms ubuntu-system-adjustments.service
           250ms systemd-logind.service
           229ms minidlna.service
           199ms thermald.service
           174ms systemd-udevd.service
           166ms systemd-resolved.service
           162ms ModemManager.service
           160ms accounts-daemon.service
           158ms grub-common.service
           149ms gpu-manager.service
           140ms nmbd.service
           134ms systemd-timesyncd.service
           119ms wpa_supplicant.service
            81ms systemd-modules-load.service
            81ms lightdm.service
            78ms lvm2-monitor.service
            76ms plymouth-quit-wait.service
            70ms smbd.service
            68ms systemd-udev-trigger.service
            63ms systemd-journald.service
            63ms apparmor.service
            57ms dns-clean.service
            57ms home.mount
            53ms systemd-rfkill.service
            50ms avahi-daemon.service
            49ms speech-dispatcher.service
            43ms packagekit.service
            41ms polkit.service
            41ms systemd-tmpfiles-setup.service
            40ms plymouth-start.service
            40ms networking.service
            39ms rsyslog.service
            38ms apport.service
            37ms lm-sensors.service
            37ms systemd-sysctl.service
            37ms user@1000.service
            34ms systemd-remount-fs.service
            30ms systemd-tmpfiles-setup-dev.service
            30ms kmod-static-nodes.service
            27ms systemd-fsck@dev-disk-by\x2duuid-5cae6705\x2d8f98\x2d48de\x2dbe
            27ms dev-mqueue.mount
            24ms pppd-dns.service
            23ms sys-kernel-debug.mount
            21ms dev-hugepages.mount
            19ms geoclue.service
            18ms systemd-tmpfiles-clean.service
            17ms hddtemp.service
            15ms ureadahead-stop.service
            14ms plymouth-read-write.service
            14ms colord.service
            13ms systemd-random-seed.service
            12ms ufw.service
            11ms blk-availability.service
            10ms kerneloops.service
            10ms alsa-restore.service
             6ms systemd-update-utmp.service
             5ms systemd-update-utmp-runlevel.service
             4ms console-setup.service
             3ms systemd-user-sessions.service
             3ms rtkit-daemon.service
             3ms sys-kernel-config.mount
             2ms setvtrgb.service
             2ms openvpn.service
             2ms sys-fs-fuse-connections.mount
lines 50-72/72 (END)
 ! Сообщение из: darkfenix
Просьба ознакомиться Панель форматирования текста в темах/ответах
09 ноя 2018, 13:50
Anatoly 86 писал(а):
09 ноя 2018, 13:43
Это что?
09 ноя 2018, 13:56
Anatoly 86, сделай лучше hw-probe там хоть увидим что происходит при загрузке.
09 ноя 2018, 14:18
Anatoly 86, многочисленные таймауты на свопфайл
[FAILED] Failed to activate swap /swapfile.
See 'systemctl status swapfile.swap' for details.
[DEPEND] Dependency failed for Swap.
закомментируй его пока в fstab и перезагрузись
Anatoly 86
09 ноя 2018, 14:20
# / was on /dev/sdb1 during installation
UUID=5cae6705-8f98-48de-beb4-93978a57a861 / btrfs defaults,subvol=@ 0 1
# /home was on /dev/sdb1 during installation
UUID=5cae6705-8f98-48de-beb4-93978a57a861 /home btrfs defaults,subvol=@home 0 2
09 ноя 2018, 14:20
btrfs и swap файл? вы серьёзно?*
09 ноя 2018, 14:20
09 ноя 2018, 14:18
У него btrfs, а на нее нельзя swap-файл. Вот и вся разгадка
09 ноя 2018, 14:22
darkfenix, Ага, уже тоже увидел) все так.
Но в фстаб его не вижу, откуда он монтируется тут
09 ноя 2018, 14:24
Chocobo, я его и в fstab не увидел :blink2:
09 ноя 2018, 14:27
darkfenix, в dmesg вижу только про zswap запись, но она одинарная. оно подгружается там а не активируется.
Куда ж он потерялся)
Anatoly 86
09 ноя 2018, 14:31
Установка с swap или без ничего не меняет.
09 ноя 2018, 14:32
Anatoly 86, давай пойдем от первичного описания ошибки, система плохого не посоветует)
А именно:
09 ноя 2018, 14:41
Или даже нефиг туда смотреть, давай сразу маскировать ненужный элемент нафиг.
sudo systemctl mask swapfile.swap
Anatoly 86
09 ноя 2018, 14:45
/swapfile none swap sw 0 0
