Тачпад
Iroshino
Тачпад
23 окт 2018, 20:49
1. LM 18.2 x64
2. xfce
3.
System: Host: iroshino-Inspiron-5565 Kernel: 4.8.0-53-generic x86_64 (64 bit gcc: 5.4.0)
Desktop: Xfce 4.12.3 (Gtk 2.24.28) Distro: Linux Mint 18.2 Sonya
Machine: System: Dell product: Inspiron 5565 v: 1.0.2
Mobo: Dell model: 0M42GH v: A00
Bios: Dell v: 1.0.2 date: 07/20/2016
CPU: Dual core AMD A6-9200 RADEON R4 5 COMPUTE CORES 2C+3G (-MCP-) cache: 2048 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm) bmips: 7984
clock speeds: max: 2000 MHz 1: 1800 MHz 2: 1600 MHz
Graphics: Card-1: Advanced Micro Devices [AMD/ATI] Device 98e4
bus-ID: 00:01.0
Card-2: Advanced Micro Devices [AMD/ATI] Jet PRO [Radeon R5 M230]
bus-ID: 01:00.0
Display Server: X.Org 1.18.4 drivers: ati,radeon (unloaded: fbdev,vesa,amdgpu)
Resolution: 1366x768@60.00hz
GLX Renderer: Gallium 0.4 on AMD STONEY (DRM 3.3.0 / 4.8.0-53-generic, LLVM 3.8.0)
GLX Version: 3.0 Mesa 12.0.6 Direct Rendering: Yes
Audio: Card-1 Advanced Micro Devices [AMD] Device 157a
driver: snd_hda_intel bus-ID: 00:09.2
Card-2 Advanced Micro Devices [AMD/ATI] Device 15b3
driver: snd_hda_intel bus-ID: 00:01.1
Network: Card-1: Realtek RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
driver: r8169 v: 2.3LK-NAPI port: 2000 bus-ID: 02:00.0
Card-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
driver: ath9k bus-ID: 03:00.0
Card-3: Atheros usb-ID: 002-003
IF: null-if-id state: N/A speed: N/A duplex: N/A mac: N/A
Drives: HDD Total Size: 500.1GB (2.0% used)
ID-1: /dev/sda model: TOSHIBA_MQ01ABF0 size: 500.1GB
Partition: ID-1: / size: 134G used: 5.7G (5%) fs: ext4 dev: /dev/sda6
ID-2: swap-1 size: 4.17GB used: 0.00GB (0%) fs: swap dev: /dev/sda7
Sensors: System Temperatures: cpu: N/A mobo: N/A gpu: N/A,0.0
Fan Speeds (in rpm): cpu: 3700
Info: Processes: 204 Uptime: 3 min Memory: 685.2/3894.1MB
4. Здравствуйте. Решил попробовать linux впервые. Установил Linux mint 18.2 xcfe 64bit на ноут. Впервые - это значит ни разу им не пользовался. Проблема такая, спустя минут 15-30 после использования перестает работать тачпад. Т.е. вроде все норм, а потом бац, и стрелка как вкопанная. Клавиатура работает, я могу двигаться по меню стрелками, что-то напечатать, но тачпад молчит, ни кнопки на нем, ни стрелка. Как это исправить? Я просто понятия не имею с чего начать. В гугле не нашел, или просто плохо искал. Заранее спасибо.
Последний раз редактировалось пользователем 2 Iroshino; всего редактировалось раз: 23
Тачпад
23 окт 2018, 20:56
Iroshino писал(а):
23 окт 2018, 20:49
впервые
Это конечно здорово. Но ведь читать-то научили уже давно. Поэтому внимательно читаем что написано в красном поле вверху страницы.
Iroshino
Тачпад
23 окт 2018, 21:52
Поправил немного
Тачпад
23 окт 2018, 23:58
Iroshino, в первую очередь стоит проверить логи dmesg и journalctl, на те временные отрезки когда он отваливается.
Ну и ядрышко с 4.8 обновить пора бы
StarMAUGLI
Решено: 19
Благодарил (а): 697 раз
Тачпад
24 окт 2018, 00:50
Iroshino писал(а):
23 окт 2018, 21:52
Поправил немного
молодец
Chocobo, Мне кажется ты слишком сложно ему объясняешь. Новичок, все-таки.
Iroshino, Мышка-то у тебя есть пока тач-пад починишь?
После установки первое обновление уже делал?
Менеджер обновлений представляешь где находится?
Тачпад
24 окт 2018, 06:19
Iroshino, вопрос не по теме почему именно версия 18.2 и откуда брал образ?
С твоим процессором можно ставить 19 версию. Ну или если так хочется 18 то 18.3. Ну и ядро бы обязательно обновить, как уже выше сказали
Тачпад
24 окт 2018, 14:10
24 окт 2018, 06:19
Можно, но нужно начать с 17, потому что - https://www.amd.com/ru/support/graphics ... on-r5-m230
Конкретно про тач - нужен выхлоп xinput.
Тачпад
24 окт 2018, 14:15
StarMAUGLI писал(а):
24 окт 2018, 00:50
Новичок, все-таки.
Новичок в линукс не обязательно не знает каким концом мышку держать.
с inxi ТС справился, остальное не сильно сложней. Если возникнут сложности - то где-то распишем и подробней.
Iroshino
Тачпад
24 окт 2018, 22:22
Спасибо огромное за советы. Ночью обновился, проблема вроде пропала, если снова будет, гляну логи. Почему 18.2? Скачивал 19, при загрузке системы через флэшку, полносьтю зависал, успевал только выбрать язык при установке. Образ делал через rufus 3.3, затем пробовал более старыми версиями, пробовал unetbootin. Одно и тоже. 18,2 просто на глаз быстрее попался. Для тестирования и знакомства с системой думаю и эта версия пойдет. Не понял зачем нужен xinput, или имеешь ввиду когда перестает работать? Буду ждать, когда отвалится тачпад, самому интересно из-за чего это было.
Подскажите заодно, до какого ядра обновляться?
Еще раз всем спасибо за ответы и советы, простите если много написал не по теме
StarMAUGLI
Решено: 19
Тачпад
25 окт 2018, 01:08
Iroshino писал(а):
24 окт 2018, 22:22
разбирали недавно по ядру для 18.3
где взять информацию по ядру?
получилось, что либо 4.4 LTS (поддержка Торвальдса), либо 4.15 (поддержка Убунты).
Не думаю, что у тебя в 18.2 - сильно отличается.
Кто тебе больше нравится в качестве поддержки, того и бери.
Если же хочешь все-таки эксперементнуть и поставить более новое ядро. То установи утилиту ukuu и с ее помощью можешь получить самые новые ядра. Правда, как поведет в них твоя видеокарта Radeon R5 M230, я не знаю. Посмотри совет и ссылку от Unborn, может там есть ответ на твой вопрос.
Я слышал, краем уха, что с ATI/AMD были какие-то проблемы, но у меня nvidia - поэтому не вникал.
Может кто еще по-подробнее на этот счет подскажет.
Или погугли.
У нас на форуме тоже обсуждалось Установка видеодрайвера AMD Сatalyst (fglrx) в Linux Mint 18.X
не знаю точно ли в твою это тему ли... полистай, подумай
Тачпад
26 окт 2018, 12:01
Iroshino, тач видно - Dell076B:00 06CB:7E92 Touchpad
Может поможет - http://ubuntu.fliplinux.com/dell-inspiron-7347.html
Вообще то Делловские ноуты должны с Убунту и производными нормально работать.
