Включение/Выключение телевизора по HDMI
06 окт 2018, 15:11
Вообщем... дано:
Вот такой вот ноутбук:
System:    Host: Lenovo Kernel: 4.15.0-20-generic x86_64 bits: 64 gcc: 7.3.0 Console: tty 0
           Distro: Linux Mint 19 Tara
Machine:   Device: laptop System: LENOVO product: 80XW v: Lenovo ideapad 320-17AST serial: <filter>
           Mobo: LENOVO model: LNVNB161216 v: SDK0J40700WIN serial: <filter>
           UEFI: LENOVO v: 5PCN19WW date: 11/29/2017
Battery    BAT0: charge: 29.6 Wh 99.2% condition: 29.8/30.0 Wh (99%) model: LGC L16L2PB2 status: N/A
CPU:       Dual core AMD A6-9220 RADEON R4 5 COMPUTE CORES 2C+3G (-MCP-) arch: Excavator rev.0 cache: 2048 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm) bmips: 9980
           clock speeds: max: 2500 MHz 1: 1794 MHz 2: 1910 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Device 98e4 bus-ID: 00:01.0
           Display Server: X.org 1.19.6 drivers: ati,amdgpu (unloaded: modesetting,fbdev,vesa,radeon)
           tty size: 125x32 Advanced Data: N/A for root out of X
Audio:     Card-1 Advanced Micro Devices [AMD] Device 157a driver: snd_hda_intel bus-ID: 00:09.2
           Card-2 Advanced Micro Devices [AMD/ATI] Device 15b3 driver: snd_hda_intel bus-ID: 00:01.1
           Sound: Advanced Linux Sound Architecture v: k4.15.0-20-generic
Network:   Card-1: Realtek RTL8821AE 802.11ac PCIe Wireless Network Adapter
           driver: rtl8821ae port: 2000 bus-ID: 01:00.0
           Card-2: Realtek RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
           driver: r8169 v: 2.3LK-NAPI port: 1000 bus-ID: 02:00.0
Drives:    HDD Total Size: 1000.2GB (1.5% used)
           ID-1: /dev/sda model: ST1000LM035 size: 1000.2GB temp: 30C
Partition: ID-1: / size: 165G used: 5.6G (4%) fs: ext4 dev: /dev/sda2
           ID-2: /home size: 743G used: 507M (1%) fs: ext4 dev: /dev/sda4
           ID-3: swap-1 size: 8.81GB used: 0.00GB (0%) fs: swap dev: /dev/sda3
Sensors:   System Temperatures: cpu: No active sensors found. Have you configured your sensors yet? mobo: N/A gpu: 43.0
Info:      Processes: 182 Uptime: 6 min Memory: 819.2/3817.2MB Init: systemd runlevel: 5 Gcc sys: 7.3.0
           Client: Shell (sudo) inxi: 2.3.56
Подключённый к телевизору Sony KDL-40P3000 по HDMI. Есть ребёнок, которого трудновато уложить спать.
SSH тунель ноутбуку-ноутбук
Задача: Найти способ выключения/включения телевизора через HDMI порт по SSH тунелю. Если это вообще возможно? Даже не знаю куда капнуть, с чего начать.
06 окт 2018, 15:41
vir0id, Умную розетку наверн проще под такие цели :)
06 окт 2018, 15:43
06 окт 2018, 15:41
Ну как вариант. Но пока её дождёшься... к тому же чёрт её знает.... как выключишь, так и спалишь свой телек нафик.
06 окт 2018, 15:57
vir0id писал(а):
06 окт 2018, 15:11
Насколько я знаю, это принципиально невозможно. HDMI не имеет управляющего канала/протокола для управления самим устройством.
Но некоторые телевизоры умеют сами выключаться, при обнаружении пропавшего сигнала на входе hdmi (т.е. выключении плеера или компьютера) - это у них в настройках задается как себя вести. Если нету - увы.
06 окт 2018, 16:03
06 окт 2018, 15:57
Да, он умеет выключаться при отсутствии сигнала, так же, как и включаться при появлении. Но... я хотел добиться, что бы телек вёл себя также, при работе в TV режиме. Но под моим контролем.
Ну вот нарыл такую технологию как HDMI CEC
Но я так понимаю, для его настройки нужно, что бы телек имел выход в сеть, т.е был Smarth. А на моём к сожалению его нету.
Выходит что облом?
06 окт 2018, 16:12
Посмотрел, погуглил - это новенькое расширение появилось, всего в прошлом году официально. Я кстати не в курсе был - спасибо. Но это именно расширение, и хотя выхода в сеть как я понял не нужно, но тут нужна поддержка этого расширения стандарта как со стороны телевизора так и того, что к нему подключено. И с поддержкой оного у десктопного/ноутбучного железа все пока печально. Вроде-бы где-то что-то иногда бывает но очень редко. И работает криво. Это, разумеется по тому, что удалось нагуглить сейчас.
И самих линуксовых плееров вроде бы XBMC/Kodi имеет поддержку.
abulaev2008
Благодарил (а): 24 раза
06 окт 2018, 16:23
1й вариант установить на ноутбук что то типа родительского контроля.
2й удаленное управление по сети, опять же на ноут поставить. Хотя это просто выкл. Есть программы как бы. ( в винде точно есть)
3й - самый жестокий: удлинитель с выключателем около себя - вкл и выкл.
Не знаю, я выключаю комп у сына и для контроля еще кнопочку сзади на системном блоке. Еще не разу не сообразил: а почему компутер не работает. Хотя не раз вместе с ним и разбирал, и чистил, память менял и т.д.
Ну и если есть USB на телеке, попробовать что-то типа приставки Андроид подсоединить (будет СМАРТ). Да, Лучше в эту сторону подумать.
abulaev2008
06 окт 2018, 16:30
abulaev2008 писал(а):
06 окт 2018, 16:23
Вот например Медиаплеер NEXBOX A95X 2Gb+16Gb
06 окт 2018, 16:31
06 окт 2018, 16:23
В том-то и дело, что комп вырубить - не проблема. А вот телек... в TV режиме... удалённо выключить - проблема. :sad:
Этож надо задницу с дивана поднять и малого наругать.... Ну как бы... можно ставить таймер с пульта, но... - каменный век
06 окт 2018, 16:33
06 окт 2018, 16:30
Зачем? У меня комп по тому же hdmi подключен. Это тот же "смарт" что и приставка, даже круче
06 окт 2018, 18:44
06 окт 2018, 16:23
Я бы такому не радовался. Т.к. это либо нехватка умения применять логику и отсутствие наблюдательности, либо хитрость - т.е. все он знает, но вам не показывает. :) Хотя, если он у вас гуманитарий по натуре, и младше 5-6 лет, то это еще объяснимо. А так, дети очень наблюдательны, и легко впитывают подобные навыки. Если вы с ним вместе компьютер разбирали - наверняка должен был сообразить/заметить.
Вернуться в «Мультимедиа»
