System: Host: Whowka Kernel: 4.15.0-32-generic x86_64 bits: 64 gcc: 7.3.0 Desktop: MATE 1.20.1 (Gtk 3.22.30-1ubuntu1) Distro: Linux Mint 19 Tara Machine: Device: desktop Mobo: Gigabyte model: G41M-ES2L v: x.x serial: N/A BIOS: Award v: F6 date: 11/04/2009 CPU: Quad core Intel Core2 Quad Q9400 (-MCP-) arch: Penryn rev.10 cache: 3072 KB flags: (lm nx sse sse2 sse3 sse4_1 ssse3 vmx) bmips: 21332 clock speeds: max: 2667 MHz 1: 1999 MHz 2: 2142 MHz 3: 2096 MHz 4: 1999 MHz Graphics: Card: NVIDIA G86 [GeForce 8500 GT] bus-ID: 01:00.0 Display Server: x11 (X.Org 1.19.6 ) drivers: nvidia (unloaded: modesetting,fbdev,vesa,nouveau) Resolution: 1280x1024@60.02hz OpenGL: renderer: N/A version: N/A Direct Render: N/A Audio: Card Intel NM10/ICH7 Family High Def. Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0 Sound: Advanced Linux Sound Architecture v: k4.15.0-32-generic Network: Card-1: Realtek RTL8111/8168/8411 PCIE Gigabit Ethernet Controller driver: r8169 v: 2.3LK-NAPI port: d000 bus-ID: 03:00.0 IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter> Card-2: Ralink RT3060 Wireless 802.11n 1T/1R driver: rt2800pci v: 2.3.0 bus-ID: 04:01.0 IF: wlp4s1 state: down mac: <filter> Drives: HDD Total Size: 450.2GB (26.4% used) ID-1: /dev/sda model: WDC_WD1600JB size: 160.0GB ID-2: /dev/sdc model: ST3250312AS size: 250.1GB ID-3: /dev/sdb model: SAMSUNG_SP0411N size: 40.1GB Partition: ID-1: / size: 28G used: 8.1G (31%) fs: ext4 dev: /dev/sda5 ID-2: /home size: 53G used: 15G (30%) fs: ext4 dev: /dev/sda6 ID-3: swap-1 size: 3.00GB used: 0.00GB (0%) fs: swap dev: /dev/sda1 RAID: No RAID devices: /proc/mdstat, md_mod kernel module present Sensors: System Temperatures: cpu: 42.0C mobo: N/A gpu: 0.0:50C Fan Speeds (in rpm): cpu: 1584 mobo: 6026 Info: Processes: 178 Uptime: 7:47 Memory: 1689.1/3944.0MB Init: systemd runlevel: 5 Gcc sys: 7.3.0 Client: Shell (bash 4.4.191) inxi: 2.3.56
Сеть и обновление ядра
Автор темы - Сообщения: 1899
- Решено: 13
Столкнулся с проблемой: после обновления ядра в linux mint 19 Mate х64 через раз подключается сеть. Поиск не подсказал решения даже на 15-й странице... Я, конечно, понимаю, что 19-й ещё маленький, но может где-то чё-то подправить в файлах можно? Всё-таки частенько проскакивают удачные попытки... Или ждать свежего ядра?
Решение
Whowka, вообще попробуй загрузиться с ядром, на котором сеть нормально работала.
Попробуй понизить версию ядра до 4.4. С твоим железом не стоит больше брать. Посмотри в менеджере обновлений Вид->обновление ядра. Или через UKUU
- Решено: 15
Возможно это их-за dkms, который не полноценно собрал драйвер для нового ядра. Можно попытаться обновить dkms или послушать darkfenix,
У меня порой пропадала сетка с новым ядром, но автоматом переподключалася. Пробем с роутером не наблюдал. Так что... у меня есть снования предпологать что это из-за dkms. Кстати.. у меня, раньше, была ситуация, когда что-то типа modprobe выгружало модуль из ядра по не понятной причине. После чего обновил ядро и получил фиговую пересборку от dkms. Но далее, обновив на еще более новое ядро, я получил нормальную работу драйвера
Последний раз редактировалось пользователем 2 vir0id; всего редактировалось раз: 1
- Решено: 217
Уточни еще момент, сеть это - LAN/WLAN/PPP/L2tP/ и т.д. ?
т.е. чинить хотим определение самого линка, или соединение уже по конкретным протоколам?)
- Решено: 13
Chocobo, LAN, как я понимаю... Через роутер кабелем.
Последний раз редактировалось пользователем 1 Whowka; всего редактировалось раз: 1
- Решено: 217
Whowka, ну сетевой адаптер-то вполне себе ходовой.
У меня такой же)
И от ядер разнообразных не шатало никогда обычно.
может более капризным к физической среде стал? Ну и попробуй задействовать networkd вместо NM, если у тебя dhcp или статика
У меня такой же)
▶ inxi -SN
System: Host: desktop Kernel: 4.18.3-041803-generic x86_64 bits: 64 Desktop: Cinnamon 3.8.9
Network: Card: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller driver: r8169
- Решено: 13
darkfenix, что сейчас постоянно и делаю. Просто в менеджере обновлений висит уведомление... Не аккуратненько как-то...
- Решено: 217
Whowka, у меня тут 34-е установлено как раз, из 4.15 еще осталось - попробую пожалуй в него бутнуться пару раз проверить)
- Решено: 13
Chocobo, Так через раз-то соединялось... Иногда сходу, иногда через пару минут, а иногда кружок в трее крутился до перезагрузки со старым ядром...
- Решено: 15
Я не знаю. Может быть, а может и нет. Но если у тебя на старом язре всё нормально работало, то... стоит прислушаться и откатить ядро. К тому же тут нету ничего зазорного делать откат на старое и проверенное, нежели новое и через-жопу-рабочее. Мы так все делали не раз
- Решено: 15
А dkms какой версии-то? Просто... есть такая особенность у ядер - выходить скорее чем сборщик. А со старым сборщиком не все они работают. А если и работают, то хреном об касяк
[vir0id]
19:12:04
~ $ uname -a
Linux vir0id 4.15.0-34-generic #37-Ubuntu SMP Mon Aug 27 15:21:48 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
[vir0id]
19:12:29
~ $ sudo apt-cache policy dkms
dkms:
Установлен: 2.3-3ubuntu9.2
Кандидат: 2.3-3ubuntu9.2
Таблица версий:
*** 2.3-3ubuntu9.2 500
500 http://ubuntu.koyanet.lv/ubuntu bionic-updates/main amd64 Packages
500 http://ubuntu.koyanet.lv/ubuntu bionic-updates/main i386 Packages
100 /var/lib/dpkg/status
2.3-3ubuntu9 500
500 http://ubuntu.koyanet.lv/ubuntu bionic/main amd64 Packages
500 http://ubuntu.koyanet.lv/ubuntu bionic/main i386 Packages
- Решено: 217
Ну это может NM мозгоклюйствует. поищи логи че он там делает когда проблема.
journalctl -u NetworkManager
Примерный норм выхлоп будет выглядеть так:
июн 02 11:03:16 desktop systemd[1]: Starting Network Manager...
июн 02 11:03:16 desktop NetworkManager[720]: <info> [1527926596.8460] NetworkManager (version 1.10.6) is starting... (for the first time)
июн 02 11:03:16 desktop NetworkManager[720]: <info> [1527926596.8465] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 10-dns-resolved.conf, 20-connectivity-ubuntu.conf, no-mac-addr-change.conf) (run:
июн 02 11:03:16 desktop NetworkManager[720]: <info> [1527926596.8574] manager[0x55cda49a9060]: monitoring kernel firmware directory '/lib/firmware'.
июн 02 11:03:16 desktop NetworkManager[720]: <info> [1527926596.8574] monitoring ifupdown state file '/run/network/ifstate'.
июн 02 11:03:16 desktop NetworkManager[720]: <info> [1527926596.9745] hostname: hostname: using hostnamed
июн 02 11:03:16 desktop NetworkManager[720]: <info> [1527926596.9746] hostname: hostname changed from (none) to "desktop"
июн 02 11:03:16 desktop NetworkManager[720]: <info> [1527926596.9749] dns-mgr[0x55cda49c5940]: init: dns=systemd-resolved, rc-manager=symlink, plugin=systemd-resolved
июн 02 11:03:16 desktop NetworkManager[720]: <info> [1527926596.9753] manager[0x55cda49a9060]: rfkill: WiFi hardware radio set enabled
июн 02 11:03:16 desktop NetworkManager[720]: <info> [1527926596.9754] manager[0x55cda49a9060]: rfkill: WWAN hardware radio set enabled
июн 02 11:03:16 desktop systemd[1]: Started Network Manager.
июн 02 11:03:16 desktop NetworkManager[720]: <info> [1527926596.9984] init!
июн 02 11:03:16 desktop NetworkManager[720]: <info> [1527926596.9986] interface-parser: parsing file /etc/network/interfaces
июн 02 11:03:16 desktop NetworkManager[720]: <info> [1527926596.9986] interface-parser: finished parsing file /etc/network/interfaces
июн 02 11:03:16 desktop NetworkManager[720]: <info> [1527926596.9986] management mode: unmanaged
июн 02 11:03:16 desktop NetworkManager[720]: <info> [1527926596.9990] devices added (path: /sys/devices/pci0000:00/0000:00:1c.5/0000:03:00.0/net/enp3s0, iface: enp3s0)
июн 02 11:03:16 desktop NetworkManager[720]: <info> [1527926596.9991] device added (path: /sys/devices/pci0000:00/0000:00:1c.5/0000:03:00.0/net/enp3s0, iface: enp3s0): no ifupdown configuration found.
июн 02 11:03:16 desktop NetworkManager[720]: <info> [1527926596.9991] devices added (path: /sys/devices/virtual/net/lo, iface: lo)
июн 02 11:03:16 desktop NetworkManager[720]: <info> [1527926596.9991] device added (path: /sys/devices/virtual/net/lo, iface: lo): no ifupdown configuration found.
июн 02 11:03:16 desktop NetworkManager[720]: <info> [1527926596.9991] end _init.
июн 02 11:03:16 desktop NetworkManager[720]: <info> [1527926596.9991] settings: loaded plugin ifupdown: (C) 2008 Canonical Ltd. To report bugs please use the NetworkManager mailing list. (/usr/lib/x86_64-linux
июн 02 11:03:16 desktop NetworkManager[720]: <info> [1527926596.9992] settings: loaded plugin keyfile: (c) 2007 - 2016 Red Hat, Inc. To report bugs please use the NetworkManager mailing list.
июн 02 11:03:16 desktop NetworkManager[720]: <info> [1527926596.9992] (-1533137728) ... get_connections.
июн 02 11:03:16 desktop NetworkManager[720]: <info> [1527926596.9992] (-1533137728) ... get_connections (managed=false): return empty list.
июн 02 11:03:16 desktop NetworkManager[720]: <info> [1527926596.9995] get unmanaged devices count: 0
июн 02 11:03:16 desktop NetworkManager[720]: <info> [1527926596.9995] manager: rfkill: WiFi enabled by radio killswitch; enabled by state file
июн 02 11:03:16 desktop NetworkManager[720]: <info> [1527926596.9996] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
июн 02 11:03:16 desktop NetworkManager[720]: <info> [1527926596.9996] manager: Networking is enabled by state file
июн 02 11:03:16 desktop NetworkManager[720]: <info> [1527926596.9998] dhcp-init: Using DHCP client 'dhclient'
июн 02 11:03:17 desktop NetworkManager[720]: <info> [1527926597.0006] Loaded device plugin: NMBondDeviceFactory (internal)
июн 02 11:03:17 desktop NetworkManager[720]: <info> [1527926597.0006] Loaded device plugin: NMBridgeDeviceFactory (internal)
июн 02 11:03:17 desktop NetworkManager[720]: <info> [1527926597.0006] Loaded device plugin: NMDummyDeviceFactory (internal)
июн 02 11:03:17 desktop NetworkManager[720]: <info> [1527926597.0006] Loaded device plugin: NMEthernetDeviceFactory (internal)
июн 02 11:03:17 desktop NetworkManager[720]: <info> [1527926597.0007] Loaded device plugin: NMInfinibandDeviceFactory (internal)
июн 02 11:03:17 desktop NetworkManager[720]: <info> [1527926597.0007] Loaded device plugin: NMIPTunnelDeviceFactory (internal)
июн 02 11:03:17 desktop NetworkManager[720]: <info> [1527926597.0007] Loaded device plugin: NMMacsecDeviceFactory (internal)
июн 02 11:03:17 desktop NetworkManager[720]: <info> [1527926597.0007] Loaded device plugin: NMMacvlanDeviceFactory (internal)
июн 02 11:03:17 desktop NetworkManager[720]: <info> [1527926597.0007] Loaded device plugin: NMPppDeviceFactory (internal)
июн 02 11:03:17 desktop NetworkManager[720]: <info> [1527926597.0008] Loaded device plugin: NMTunDeviceFactory (internal)
июн 02 11:03:17 desktop NetworkManager[720]: <info> [1527926597.0008] Loaded device plugin: NMVethDeviceFactory (internal)
июн 02 11:03:17 desktop NetworkManager[720]: <info> [1527926597.0008] Loaded device plugin: NMVlanDeviceFactory (internal)
июн 02 11:03:17 desktop NetworkManager[720]: <info> [1527926597.0008] Loaded device plugin: NMVxlanDeviceFactory (internal)
июн 02 11:03:17 desktop NetworkManager[720]: <info> [1527926597.0033] Loaded device plugin: NMWwanFactory (/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-device-plugin-wwan.so)
июн 02 11:03:17 desktop NetworkManager[720]: <info> [1527926597.0053] Loaded device plugin: NMWifiFactory (/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-device-plugin-wifi.so)
июн 02 11:03:17 desktop NetworkManager[720]: <info> [1527926597.0066] Loaded device plugin: NMAtmManager (/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-device-plugin-adsl.so)
июн 02 11:03:17 desktop NetworkManager[720]: <info> [1527926597.0092] Loaded device plugin: NMTeamFactory (/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-device-plugin-team.so)
июн 02 11:03:17 desktop NetworkManager[720]: <info> [1527926597.0125] Loaded device plugin: NMBluezManager (/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-device-plugin-bluetooth.so)
июн 02 11:03:17 desktop NetworkManager[720]: <info> [1527926597.0138] device (lo): carrier: link connected
июн 02 11:03:17 desktop NetworkManager[720]: <info> [1527926597.0144] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1)
июн 02 11:03:17 desktop NetworkManager[720]: <info> [1527926597.0153] manager: (enp3s0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
июн 02 11:03:17 desktop NetworkManager[720]: <info> [1527926597.0170] keyfile: add connection in-memory (c238b948-5779-36ba-881e-1399bc4539cb,"Проводное соединение 1")
июн 02 11:03:17 desktop NetworkManager[720]: <info> [1527926597.0173] settings: (enp3s0): created default wired connection 'Проводное соединение 1'
июн 02 11:03:17 desktop NetworkManager[720]: <info> [1527926597.0180] device (enp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
июн 02 11:03:17 desktop NetworkManager[720]: <info> [1527926597.1451] modem-manager: ModemManager available
июн 02 11:03:18 desktop NetworkManager[720]: <info> [1527926598.7165] device (enp3s0): carrier: link connected
июн 02 11:03:18 desktop NetworkManager[720]: <info> [1527926598.7173] device (enp3s0): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
июн 02 11:03:18 desktop NetworkManager[720]: <info> [1527926598.7179] policy: auto-activating connection 'Проводное соединение 1'
июн 02 11:03:18 desktop NetworkManager[720]: <info> [1527926598.7188] device (enp3s0): Activation: starting connection 'Проводное соединение 1' (c238b948-5779-36ba-881e-1399bc4539cb)
июн 02 11:03:18 desktop NetworkManager[720]: <info> [1527926598.7191] device (enp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
июн 02 11:03:18 desktop NetworkManager[720]: <info> [1527926598.7192] manager: NetworkManager state is now CONNECTING
июн 02 11:03:18 desktop NetworkManager[720]: <info> [1527926598.7196] device (enp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
июн 02 11:03:18 desktop NetworkManager[720]: <info> [1527926598.7201] device (enp3s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
июн 02 11:03:18 desktop NetworkManager[720]: <info> [1527926598.7208] dhcp4 (enp3s0): activation: beginning transaction (timeout in 45 seconds)
июн 02 11:03:18 desktop NetworkManager[720]: <info> [1527926598.7236] dhcp4 (enp3s0): dhclient started with pid 964
июн 02 11:03:18 desktop dhclient[964]: DHCPDISCOVER on enp3s0 to 255.255.255.255 port 67 interval 3 (xid=0xf1597875)
июн 02 11:03:19 desktop dhclient[964]: DHCPREQUEST of 192.168.0.105 on enp3s0 to 255.255.255.255 port 67 (xid=0x757859f1)
июн 02 11:03:19 desktop dhclient[964]: DHCPOFFER of 192.168.0.105 from 192.168.0.1
июн 02 11:03:19 desktop dhclient[964]: DHCPACK of 192.168.0.105 from 192.168.0.1
июн 02 11:03:19 desktop NetworkManager[720]: <info> [1527926599.2491] dhcp4 (enp3s0): address 192.168.0.105
июн 02 11:03:19 desktop NetworkManager[720]: <info> [1527926599.2491] dhcp4 (enp3s0): plen 24 (255.255.255.0)
июн 02 11:03:19 desktop NetworkManager[720]: <info> [1527926599.2491] dhcp4 (enp3s0): gateway 192.168.0.1
июн 02 11:03:19 desktop NetworkManager[720]: <info> [1527926599.2492] dhcp4 (enp3s0): lease time 7200
июн 02 11:03:19 desktop NetworkManager[720]: <info> [1527926599.2492] dhcp4 (enp3s0): nameserver '192.168.0.1'
июн 02 11:03:19 desktop NetworkManager[720]: <info> [1527926599.2492] dhcp4 (enp3s0): state changed unknown -> bound
июн 02 11:03:19 desktop NetworkManager[720]: <info> [1527926599.2510] device (enp3s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
июн 02 11:03:19 desktop NetworkManager[720]: <info> [1527926599.2520] device (enp3s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
июн 02 11:03:19 desktop NetworkManager[720]: <info> [1527926599.2523] device (enp3s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
июн 02 11:03:19 desktop NetworkManager[720]: <info> [1527926599.2526] manager: NetworkManager state is now CONNECTED_LOCAL
июн 02 11:03:19 desktop NetworkManager[720]: <info> [1527926599.2538] manager: NetworkManager state is now CONNECTED_SITE
июн 02 11:03:19 desktop NetworkManager[720]: <info> [1527926599.2540] policy: set 'Проводное соединение 1' (enp3s0) as default for IPv4 routing and DNS
июн 02 11:03:19 desktop NetworkManager[720]: <info> [1527926599.2544] device (enp3s0): Activation: successful, device activated.
июн 02 11:03:19 desktop NetworkManager[720]: <info> [1527926599.2552] manager: startup complete
июн 02 11:03:19 desktop dhclient[964]: bound to 192.168.0.105 -- renewal in 2821 seconds.
У себя за несколько ребутов не поймал твоей беды, пакетики бегают штатно)
- Решено: 13
vir0id,
Таблица версий:
500 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 Packages
500 http://archive.ubuntu.com/ubuntu bionic-updates/main i386 Packages
2.3-3ubuntu9 500
500 http://archive.ubuntu.com/ubuntu bionic/main amd64 Packages
500 http://archive.ubuntu.com/ubuntu bionic/main i386 Packages
Таблица версий:
2.3-3ubuntu9 500
- Решено: 15
Whowka, тогда точно не dkms. У меня всё ок, с теми же версиями. Значит что-то другое. Chocobo, подкинул вариант с NM. Покидай логи, которые он предоставил для примера
