$ inxi -Fxz System: Host: lm100918de Kernel: 4.9.0-8-amd64 x86_64 (64 bit gcc: 6.3.0) Desktop: Cinnamon 3.8.9 (Gtk 3.22.11-1) Distro: LMDE 3 (cindy) Machine: Device: desktop Mobo: ASUSTeK model: P8H61-M LX v: Rev x.0x UEFI: American Megatrends v: 4601 date: 09/18/2013 CPU: Dual core Intel Core i3-3250 (-HT-MCP-) cache: 3072 KB flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 13967 clock speeds: max: 3500 MHz 1: 2571 MHz 2: 2498 MHz 3: 2558 MHz 4: 2468 MHz Graphics: Card: NVIDIA GF116 [GeForce GTS 450 Rev. 2] bus-ID: 01:00.0 Display Server: X.Org 1.19.2 drivers: nouveau (unloaded: modesetting,fbdev,vesa) Resolution: 1280x1024@60.02hz GLX Renderer: Gallium 0.4 on NVCF GLX Version: 3.0 Mesa 13.0.6 Direct Rendering: Yes Audio: Card-1 NVIDIA GF116 High Definition Audio Controller driver: snd_hda_intel bus-ID: 01:00.1 Card-2 Intel 6 Series/C200 Series Family High Definition Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0 Sound: Advanced Linux Sound Architecture v: k4.9.0-8-amd64 Network: Card: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller driver: r8169 v: 2.3LK-NAPI port: d000 bus-ID: 03:00.0 IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter> Drives: HDD Total Size: 500.1GB (5.5% used) ID-1: /dev/sda model: Hitachi_HDT72105 size: 500.1GB Partition: ID-1: / size: 30G used: 5.2G (19%) fs: ext4 dev: /dev/sda5 ID-2: /home size: 66G used: 13G (21%) fs: ext4 dev: /dev/sda7 ID-3: swap-1 size: 8.59GB used: 0.00GB (0%) fs: swap dev: /dev/sda6 Sensors: System Temperatures: cpu: 29.8C mobo: 27.8C gpu: 39.0 Fan Speeds (in rpm): cpu: 0 Info: Processes: 201 Uptime: 50 min Memory: 1693.4/7952.9MB Init: systemd runlevel: 5 Gcc sys: 6.3.0 Client: Shell (bash 4.4.121) inxi: 2.3.5
Установка драйвера Nvidia в LMDE 3 (Cinnamon x64)
Уважаемые подскажите как правильно установить драйвер для видеокарты Nvidia в LMDE 3 (Cinnamon x64)? В LinuxMint 18-19 для этого юзал "Менеджер драйверов", так что проблем не возникало, в LMDE 3 "Менеджера драйверов" нет. Вот прошу помощи дабы не запороть новенькую систему. Видеокарта: Nvidia GeForce GTS 450
BadBird, к сожалению это немного не то. Там про kdeneon, а он как и минт основан на ubuntu.
Ну как? Получилось?
У меня не хочет работать((
После перезагрузки Cinnamon говорит, что ушел в резервный режим и просит перезагрузить его, но бестолку.
nvidia-settings после ее установки и запуска просит выполнить nvidia-xconfig и перезапустить x-server.
После выполнения sudo nvidia-xconfig перезагружаюсь и усё... графика не стартует.
Здравствуй первый телетайп и Timeshift --restore))
Ситуация 1 в 1, если дебиановскую репу не подключать и ставить имеющийся драйвер nvidia-driver (Version: 384.130-1)
UPD: карточка GT 635M
sudo nano /etc/apt/sources.list
\\содержимое_НАЧАЛО
#/etc/apt/sources.list
deb http://deb.debian.org/debian stretch-backports main contrib non-free
\\содержимое_КОНЕЦ
sudo apt-get install linux-headers-$(uname -r|sed 's/[^-]*-[^-]*-//')
sudo apt-get update
sudo apt-get install -t stretch-backports nvidia-driver
sudo reboot
С ноября так ответа и не поступило?
К вам люди обращаются, а вы им ссылки, это что форум, я сам могу сказать тому кто мне говорит что и как, проявили интерес будьте добры дать подобающий ответ!
- Решено: 20
Дак мы к ним и относимся как к людям, и предполагаем что они способны прочитать информацию по ссылкеVasiliy Terkin писал(а): ↑14 янв 2019, 14:11К вам люди обращаются, а вы им ссылки, это что форум, я сам могу сказать тому кто мне говорит что и как, проявили интерес будьте добры дать подобающий ответ!
Касательно предпоследнего поста могу еще пару ссылок дать для карты GT 635M
https://www.nvidia.ru/Download/driverRe ... /137439/ru
http://us.download.nvidia.com/XFree86/L ... index.html
Поставил через МП вроде на первый взгляд и работает но что-то не так, тиринг присутствует и икс конфииг не могу создать через программу нвидиа сервер х, файл не сохраняется, какие есть соображения?
Vasiliy Terkin, У большинства ubuntu-подобных так, и кажись это от родоначальника тянется. Ни конфиг автоматом не создать, и тиринг если проявился, автоматом не вывести. Только руками. Я в минте (mate) делал так:
1. запускаем nvidia-settings, делаем настройки, но главное, когда оно сохраняет эти настройки, то сохраняет как раз в формате xorg.conf. Но прямо на нужное место в etc сохранить не получится - прав не хватит. А от root запускать этот конфигуратор не стоит. Потому сохраняем настройки где-то себе в каталог, а потом переносим в /etc/X11...
2. Чтобы избавится от тиринга нужно добавить/исправить вот примерно такую строчку в секцию Screen:
Это все можно оформить как отдельный файл в xorg.conf.d, но в убунтоподобных оно работает коряво и непредсказуемо. В LMDE - не знаю, не пробовал.
"Option "metamodes" "nvidia-auto-select +0+0 { ForceCompositionPipeline = On }""
. Но следует иметь в виду что подобная строчка часто уже есть, и тогда надо не вторую добавлять, а именно первую править. Чтобы добавить "{ ForceCompositionPipeline = On }".Это все можно оформить как отдельный файл в xorg.conf.d, но в убунтоподобных оно работает коряво и непредсказуемо. В LMDE - не знаю, не пробовал.
Создал файл xorg.conf, сохранил в дк и перенёс в etc/x11/, так как без рута не перенесёшь в эту папку то рутанул и получил бок на выходе, пришлось удалять!
- Решено: 3
Также, после установки драйвера Нвидео вообще ОС переставил. И греется сильно и глючит. И хрен удалиш без проблем.
Nouveau по умолчанию лучше.
Проприаритетный переставил, всё работает нормально, !!!!
