AMD Radeon 520 driver LM19x64
dza
Благодарил (а): 2 раза
16 сен 2018, 21:03
здравствуйте!
ОС Linux mint 19 x64
не могу поставить драйвера на видеокарту AMD Radeon 520 driver
System:    Host: user-HP-Laptop-15-bs1xx Kernel: 4.15.0-20-generic x86_64
           bits: 64 gcc: 7.3.0
           Desktop: Cinnamon 3.8.9 (Gtk 3.22.30-1ubuntu1)
           Distro: Linux Mint 19 Tara
Machine:   Device: laptop System: HP product: HP Laptop 15-bs1xx v: Type1ProductConfigId serial: N/A
           Mobo: HP model: 832B v: 23.47 serial: N/A
           UEFI [Legacy]: Insyde v: F.33 date: 12/08/2017
Battery    BAT1: charge: 41.2 Wh 100.0% condition: 41.2/41.6 Wh (99%)
           model: Hewlett-Packard PABAS0241231 status: Full
CPU:       Quad core Intel Core i5-8250U (-MT-MCP-)
           arch: Kaby Lake rev.10 cache: 6144 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 14400
           clock speeds: max: 3400 MHz 1: 800 MHz 2: 800 MHz 3: 800 MHz
           4: 800 MHz 5: 800 MHz 6: 800 MHz 7: 800 MHz 8: 800 MHz
Graphics:  Card-1: Intel UHD Graphics 620 bus-ID: 00:02.0
           Card-2: Advanced Micro Devices [AMD/ATI] Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430]
           bus-ID: 01:00.0
           drivers: modesetting,ati,radeon (unloaded: fbdev,vesa)
           Resolution: 1366x768@60.00hz, 1366x768@59.79hz
           OpenGL: renderer: Mesa DRI Intel UHD Graphics 620 (Kabylake GT2)
           version: 4.5 Mesa 18.0.5 Direct Render: Yes
Audio:     Card Intel Sunrise Point-LP HD Audio
           driver: snd_hda_intel bus-ID: 00:1f.3
           Sound: Advanced Linux Sound Architecture v: k4.15.0-20-generic
Network:   Card-1: Realtek RTL8111/8168/8411 PCIE Gigabit Ethernet Controller
           driver: r8169 v: 2.3LK-NAPI port: 3000 bus-ID: 02:00.0
           IF: eno1 state: down mac: <filter>
           Card-2: Intel Wireless 7265 driver: iwlwifi bus-ID: 03:00.0
Drives:    HDD Total Size: 1000.2GB (3.5% used)
           ID-1: /dev/sda model: TOSHIBA_MQ01ABD1 size: 1000.2GB
Partition: ID-1: / size: 197G used: 18G (10%) fs: ext4 dev: /dev/sda6
           ID-2: swap-1 size: 16.78GB used: 0.00GB (0%)
           fs: swap dev: /dev/dm-0
Sensors:   System Temperatures: cpu: 50.0C mobo: 27.8C gpu: 40.0
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 263 Uptime: 3:54 Memory: 1654.9/3861.7MB
пробовал с сайта AMD установить AMDGPU-PRO пишет не поддерживаемая ОС
16 сен 2018, 21:11
Тут не столько ОС, сколько адаптер будет неподдерживаемым.
dza писал(а):
16 сен 2018, 21:03
это GCN1.0 или 1.1
https://www.notebook-center.ru/video_726.html
AMD Radeon 520 использует старую архитектуру, представленную в Radeon R5 M230 в 2014 году, а также в M330/M430/M440/M445.
Поэтому amdgpu-pro на ней не взлетит. Можно включить свободный модуль amdgpu всемто radeon
dza
16 сен 2018, 21:14
как включить свободный модуль amdgpu
На Win10 карта определялась как Radeon 520
На win 7 не ставились драйвера Intel UHD 620 и карта ADM Radeon определялась как стандартный VGA адаптор
В linux я чайник! Прошу рассказать подробнее что делать.
16 сен 2018, 23:12
dza
17 сен 2018, 07:03
Посмотрел ссылку, мне как начинающему не понятно как править grub. Можете разьяснить как?
17 сен 2018, 07:10
dza, там же все написано
01 июл 2018, 15:53
нужно добавить к строке загрузки grub (/etc/default/grub) следующие параметры в строку GRUB_CMDLINE_LINUX=""
modprobe.blacklist=radeon radeon.cik_support=0 amdgpu.cik_support=1
Cохранить файл.
Открываешь файл sudo xed /etc/default/grub. Находишь в нем строку GRUB_CMDLINE_LINUX="". Приводишь ее к виду GRUB_CMDLINE_LINUX="modprobe.blacklist=radeon radeon.cik_support=0 amdgpu.cik_support=1". Сохраняешь файл. Обновляешь груб sudo update-grub.
dza
17 сен 2018, 07:59
Я же написал что новичек :dash2: :smile:
Благодарю за помощь буду пробовать
dza
17 сен 2018, 16:28
после правки grub параметры системы
bits: 64 gcc: 7.3.0
bus-ID: 01:00.0
ID-1: /dev/sda model: TOSHIBA_MQ01ABD1 size: 1000.2GB temp: 31C
Sensors: System Temperatures: cpu: 29.8C mobo: 27.8C gpu: 34.0
Info: Processes: 268 Uptime: 7 min Memory: 1336.1/3861.7MB
игры запускаться так и не хотят. Через стим не устанавливаются выдает ошибку при обновлении произошла ошибка ( серверы с данными не доступны)
Основная идея игры типа World of Tanks
17 сен 2018, 16:31
dza писал(а):
17 сен 2018, 16:28
Ничего не изменилось пока, перезагружался?
dza писал(а):
17 сен 2018, 16:28
Ну а данные по сети - это и не к видеорайверу вопрос обычно)
dza
17 сен 2018, 16:43
перезагрузился
bus-ID: 01:00.0
так проблема появилась после установки win7, ни одна игра не устанавливается. По этому и решил установить Linux. И на нем проблема осталась
dza
17 сен 2018, 17:29
после установки Steam
выдает такую ошибку
Error in POL_Wine
Похоже, Wine прервала работу.
Если Ваша программа работает, просто не обращайте внимания на это сообщение.
dza
17 сен 2018, 22:41
всем спасибо! Думаю видюха AMD не запустится, т.к. дров нет
