Konsole вылетает
genghaev
Благодарил (а): 8 раз
Konsole вылетает
Сообщение genghaev » 08 сен 2018, 12:19
Доброго времени )
Где-то всплывала проблема c постоянным вылетанием konsole, случайно не решилось это? Уже просто достало в KDE, кто нибудь может быть поможет?
System:    Host: genghaev-P5KC Kernel: 4.15.12-041512-generic x86_64 bits: 64 compiler: gcc v: 7.2.0
           Desktop: KDE Plasma 5.8.9 tk: Qt 5.6.1 Distro: Linux Mint 18.3 Sylvia
Machine:   Type: Desktop Mobo: ASUSTeK model: P5KC v: Rev 1.xx serial: <filter> BIOS: American Megatrends
           v: 1203 date: 06/25/2008
Battery:   Device-1: hidpp_battery_0 model: Logitech M310 charge: Normal status: Discharging
           Device-2: hidpp_battery_1 model: Logitech Unifying Device. Wireless PID:2011 charge: High
           status: Discharging
CPU:       Topology: Dual Core model: Intel Core2 Duo E8500 bits: 64 type: MCP arch: Penryn rev: A
           L2 cache: 6144 KiB
           flags: lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx bogomips: 12689
           Speed: 3172 MHz min/max: 1998/3163 MHz Core speeds (MHz): 1: 3172 2: 3172
Graphics:  Card-1: NVIDIA GK106 [GeForce GTX 650 Ti] driver: nvidia v: 390.87 bus ID: 01:00.0
           Display: x11 server: X.Org 1.18.4 driver: nvidia unloaded: fbdev,modesetting,nouveau,vesa
           resolution: 1920x1080~60Hz
           OpenGL: renderer: GeForce GTX 650 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 390.87 direct render: Yes
Audio:     Card-1: NVIDIA GK106 HDMI Audio driver: snd_hda_intel v: kernel bus ID: 01:00.1
           Card-2: Creative Labs CA0106 Soundblaster driver: snd_ca0106 v: kernel bus ID: 05:02.0
           Card-3: KYE Systems (Mouse Systems) Genius iSlim 2000AF V2 type: USB driver: uvcvideo,snd-usb-audio
           bus ID: 1:2
           Sound Server: ALSA v: k4.15.12-041512-generic
Network:   Card-1: Qualcomm Atheros Attansic L1 Gigabit Ethernet driver: atl1 v: 2.1.3 port: N/A
           bus ID: 02:00.0
           IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives:    HDD Total Size: 6.42 TiB used: 4.50 TiB (70.1%)
           ID-1: /dev/sda vendor: OCZ model: AGILITY2 size: 55.90 GiB
           ID-2: /dev/sdb vendor: Western Digital model: WD20EARX-00PASB0 size: 1.82 TiB
           ID-3: /dev/sdc vendor: Western Digital model: WD20EZRX-00D8PB0 size: 1.82 TiB
           ID-4: /dev/sdd vendor: Western Digital model: WD30EZRX-00DC0B0 size: 2.73 TiB
Partition: ID-1: / size: 47.02 GiB used: 22.40 GiB (47.6%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 8.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda5
Sensors:   System Temperatures: cpu: 58.0 C mobo: 41.0 C gpu: nvidia temp: 41 C
           Fan Speeds (RPM): cpu: 1188 psu: 0 case-1: 649 case-2: 1180 gpu: nvidia fan: 10%
Info:      Processes: 224 Uptime: 18m Memory: 7.79 GiB used: 2.29 GiB (29.4%) Init: systemd runlevel: 5
           Compilers: gcc: 5.4.0 Shell: fish v: 2.7.1-1426-g0e6cc13d inxi: 3.0.12
Забыл сказать: ядра менял, видюхи менял, переменял и перепробовал все, один черт - вылетает (
Благодарил (а): 1378 раз
Konsole вылетает
Сообщение Dja » 08 сен 2018, 12:27
Для пятокед это нормально Re: Релиз Linux Mint 18 KDE (Пост Dja #845)
StarMAUGLI
Решено: 19
Благодарил (а): 716 раз
Konsole вылетает
Сообщение StarMAUGLI » 08 сен 2018, 12:28
У меня КДЕ.
Не сталкивался.
Из идей:
1. Запустить консоль и набрать в ней команду konsole. Если повезет 50х50 то вылетит та консоль, которая запущена из консоли, а в первой консоли можно будет увидеть ошибку. :crazy: (согласен - метод через ...опу, но вдруг сработает)
2. Найти соответствующий пакет в Synaptik'е (по поиску легко найдется) и переустановить его.
Последний раз редактировалось пользователем 2 StarMAUGLI; всего редактировалось раз: 8
Konsole вылетает
Сообщение Dja » 08 сен 2018, 12:30
StarMAUGLI писал(а):
08 сен 2018, 12:28
Минт ли у тебя, не говоря уж о версии оного)
genghaev писал(а):
08 сен 2018, 12:19
StarMAUGLI
Решено: 19
Konsole вылетает
Сообщение StarMAUGLI » 08 сен 2018, 12:33
Dja писал(а):
08 сен 2018, 12:30
Сорри. Прошляпил. Подправил чутка.
Последний раз редактировалось пользователем 1 StarMAUGLI; всего редактировалось раз: 8
genghaev
Konsole вылетает
Сообщение genghaev » 08 сен 2018, 12:34
Запустил консоль, сейчас дождусь вылета и выхлоп сюда закину
как назло будет работать
Konsole вылетает
Сообщение Dja » 08 сен 2018, 12:41
genghaev писал(а):
08 сен 2018, 12:34
Принцип присутствия :magic:
genghaev
Konsole вылетает
Сообщение genghaev » 08 сен 2018, 12:54
Процесс: konsole PID: 3689 Сигнал завершения: Segmentation fault (11) Время: 08.09.18 19:53:50
Konsole вылетает
Сообщение Dja » 08 сен 2018, 12:56
Я бы поставил минта с 4-ми кедами и уже его обновил бы, но пятокеды фу. Как были жидкими, так видимо и остались. В принципе ничего удивительного. Их выпилили и забили на них.
genghaev
Konsole вылетает
Сообщение genghaev » 08 сен 2018, 12:56
иногда такая же фигна вылетает c xwin
задумываюсь перейти на ксубунту,, но тоже c кедами )
genghaev
Konsole вылетает
Сообщение genghaev » 08 сен 2018, 13:05
Dja, посоветуй что нибудь нормаьный терминал, gnome (ну нафиг его), под qt - ну хз, главное что бы не вылетал )
Благодарил (а): 802 раза
Konsole вылетает
Сообщение rogoznik » 08 сен 2018, 13:12
genghaev писал(а):
08 сен 2018, 13:05
Вот https://github.com/lxqt/qterminal
Konsole вылетает
Сообщение Dja » 08 сен 2018, 13:13
genghaev, я не тулкитофоб, поэтому в кедах юзал gimp, в крысе kopete.
xfce4-terminal ни разу не падал на моей памяти
StarMAUGLI
Решено: 19
Konsole вылетает
Сообщение StarMAUGLI » 08 сен 2018, 13:20
genghaev писал(а):
08 сен 2018, 12:54
Segmentation fault
Если интересно почитать про эту ошибку "вообще", то
https://habr.com/company/nixsolutions/blog/277759/
по-моему, все-таки стоит попробовать просто переустановить пакет
Также, по моему, как раз Dja предлагал ставить другой планировщик памяти. Может быть это будет не плохим выходом?
genghaev
Konsole вылетает
Сообщение genghaev » 08 сен 2018, 13:25
Dja писал(а):
08 сен 2018, 13:13
xfce4-terminal
не, я не крысяшник, не не,не не )
genghaev
Konsole вылетает
Сообщение genghaev » 08 сен 2018, 13:27
08 сен 2018, 13:20
Если интересно почитать про эту ошибку, то
не, все мы это проходили на третьем курсе автомаки и вычислительной техники )
StarMAUGLI
Решено: 19
Konsole вылетает
Сообщение StarMAUGLI » 08 сен 2018, 13:30
genghaev писал(а):
08 сен 2018, 13:27
Везет. :thumbs:
Когда я учился, то у нас такого курса в принципе не было. :write:
Теперь приходится брать крохи знаний где придется.
genghaev
Konsole вылетает
Сообщение genghaev » 08 сен 2018, 13:33
ну дак почему консоль то выетает?
08 сен 2018, 13:30
такая же фигня
StarMAUGLI
Решено: 19
Konsole вылетает
Сообщение StarMAUGLI » 08 сен 2018, 13:52
genghaev писал(а):
08 сен 2018, 13:33
ну дак
genghaev писал(а):
08 сен 2018, 12:54
Segmentation fault
ошибка сегментации памяти, на сколько я понимаю. Проблема которая может как быть связана с установленным пакетом, так и не быть с ним связана вовсе. Т.е. проблема может проявиться на каких-то других задачах (просто ты на нее пока что не обращал внимания, допустим из-за того, что другие задачи подверженные ошибке используешь реже по сравнению с консолью).
Как наиболее простой путь, проверки (диагностики) я уже предложил просто переустановить пакет. Если ошибка уйдет, то и слава богу. Значит она была связана с пакетом и исправлена.
Если не поможет, то придется копать дальше и глубже (и не факт, что смена терминала/консоли тебе поможет в этом случае).
Например,
- просмотреть логи в journalctl дабы получить дополнительную информацию
- или заменить планировщик памяти на более новый и прогрессивный (но еще не используемый в LM по умолчанию) аналог.
genghaev
Konsole вылетает
Сообщение genghaev » 08 сен 2018, 14:08
08 сен 2018, 13:52
планки менял, все менял - память , винчестера менял, кернели менял, драйвера менял видео, даже переставлял карты планки, все менял - один черt konsole error
Вернуться в «KDE»
