Система не видит Card Reader
G.A.P
Благодарил (а): 11 раз
03 сен 2018, 23:32
Ноут HP, установлен минт 19 корица.
Вставляю SDшку в картридер и... тишина! :blink2: При этом она живая и прекрасно читается юсбишным картридером на этом же ноуте :yes:
В консоли ничего не видно.
lsusb
Bus 001 Device 003: ID 0bda:b009 Realtek Semiconductor Corp.
Bus 001 Device 002: ID 0438:7900 Advanced Micro Devices, Inc.
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 002: ID 05c8:0233 Cheng Uei Precision Industry Co., Ltd (Foxlink)
lspci -v
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 1576
	Subsystem: Hewlett-Packard Company Device 8331
	Flags: bus master, fast devsel, latency 0
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Device 1577
	Flags: bus master, fast devsel, latency 0, IRQ 24
	Capabilities: <access denied>
00:01.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Device 98e4 (rev da) (prog-if 00 [VGA controller])
	Flags: bus master, fast devsel, latency 0, IRQ 37
	Memory at e0000000 (64-bit, prefetchable) [size=256M]
	Memory at f0800000 (64-bit, prefetchable) [size=8M]
	I/O ports at 5000 [size=256]
	Memory at f0500000 (32-bit, non-prefetchable) [size=256K]
	Expansion ROM at 000c0000 [disabled] [size=128K]
	Kernel driver in use: amdgpu
	Kernel modules: amdgpu
00:01.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Device 15b3
	Flags: bus master, fast devsel, latency 0, IRQ 41
	Memory at f0560000 (64-bit, non-prefetchable) [size=16K]
	Kernel driver in use: snd_hda_intel
	Kernel modules: snd_hda_intel
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 157b
	Flags: fast devsel
00:02.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 157c (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 26
	Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
	I/O behind bridge: 00004000-00004fff
	Memory behind bridge: f0400000-f04fffff
	Prefetchable memory behind bridge: 00000000d0000000-00000000dfffffff
	Kernel driver in use: pcieport
	Kernel modules: shpchp
00:02.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 157c (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 27
	Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
	I/O behind bridge: 00003000-00003fff
	Memory behind bridge: f0300000-f03fffff
00:02.4 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 157c (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 28
	Bus: primary=00, secondary=03, subordinate=05, sec-latency=0
	I/O behind bridge: 00002000-00002fff
	Memory behind bridge: f1000000-f10fffff
	Prefetchable memory behind bridge: 00000000f0000000-00000000f00fffff
00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 157b
	Flags: fast devsel
00:08.0 Encryption controller: Advanced Micro Devices, Inc. [AMD] Device 1578
	Memory at f0540000 (64-bit, prefetchable) [size=128K]
	Memory at f0200000 (32-bit, non-prefetchable) [size=1M]
	Memory at f056f000 (32-bit, non-prefetchable) [size=4K]
	Memory at f056a000 (32-bit, non-prefetchable) [size=8K]
00:09.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 157d
	Flags: fast devsel
00:09.2 Audio device: Advanced Micro Devices, Inc. [AMD] Device 157a
	Flags: bus master, fast devsel, latency 0, IRQ 42
	Memory at f0564000 (32-bit, non-prefetchable) [size=16K]
00:10.0 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB XHCI Controller (rev 20) (prog-if 30 [XHCI])
	Subsystem: Hewlett-Packard Company FCH USB XHCI Controller
	Flags: bus master, fast devsel, latency 0, IRQ 18
	Memory at f0568000 (64-bit, non-prefetchable) [size=8K]
	Kernel driver in use: xhci_hcd
00:11.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 4b) (prog-if 01 [AHCI 1.0])
	Subsystem: Hewlett-Packard Company FCH SATA Controller [AHCI mode]
	Flags: bus master, 66MHz, medium devsel, latency 64, IRQ 19
	I/O ports at 5118 [size=8]
	I/O ports at 5124 [size=4]
	I/O ports at 5110 [size=8]
	I/O ports at 5120 [size=4]
	I/O ports at 5100 [size=16]
	Memory at f056c000 (32-bit, non-prefetchable) [size=1K]
	Kernel driver in use: ahci
	Kernel modules: ahci
00:12.0 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB EHCI Controller (rev 49) (prog-if 20 [EHCI])
	Subsystem: Hewlett-Packard Company FCH USB EHCI Controller
	Flags: bus master, 66MHz, medium devsel, latency 32, IRQ 18
	Memory at f056d000 (32-bit, non-prefetchable) [size=256]
	Kernel driver in use: ehci-pci
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 4b)
	Subsystem: Hewlett-Packard Company FCH SMBus Controller
	Flags: 66MHz, medium devsel
	Kernel driver in use: piix4_smbus
	Kernel modules: i2c_piix4, sp5100_tco
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 11)
	Subsystem: Hewlett-Packard Company FCH LPC Bridge
	Flags: bus master, 66MHz, medium devsel, latency 0
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 15b0
	Flags: fast devsel
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 15b1
	Flags: fast devsel
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 15b2
	Flags: fast devsel
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 15b3
	Flags: fast devsel
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 15b4
	Flags: fast devsel
	Kernel driver in use: fam15h_power
	Kernel modules: fam15h_power
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 15b5
	Flags: fast devsel
01:00.0 Display controller: Advanced Micro Devices, Inc. [AMD/ATI] Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430] (rev ff) (prog-if ff)
	!!! Unknown header type 7f
	Kernel driver in use: radeon
	Kernel modules: radeon, amdgpu
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
	Subsystem: Hewlett-Packard Company RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
	Flags: bus master, fast devsel, latency 0, IRQ 34
	I/O ports at 3000 [size=256]
	Memory at f0304000 (64-bit, non-prefetchable) [size=4K]
	Memory at f0300000 (64-bit, non-prefetchable) [size=16K]
	Kernel driver in use: r8169
	Kernel modules: r8169
03:00.0 Network controller: Realtek Semiconductor Co., Ltd. Device d723
	Subsystem: Hewlett-Packard Company Device 8319
	Flags: bus master, fast devsel, latency 0, IRQ 39
	I/O ports at 2000 [size=256]
	Memory at f1000000 (64-bit, non-prefetchable) [size=64K]
	Kernel driver in use: rtl8723de
	Kernel modules: 8723de
Вылечил таким шаманским методом:
sudo apt-get install --reinstall udisks2
Перезагружаемся и пользуемся картридером :thumbs:
Win10Pro + AMD
G.A.P
01 окт 2018, 19:24
G.A.P писал(а):
03 сен 2018, 23:32
После установки этого ядра и модулей Kernel: 4.15.0-34-generic x86_64 bits картридер работает без шаманств :smile:
Win10Pro + AMD
G.A.P
30 дек 2018, 12:43
После чистой установки минт 19.1 корица, картридер пашет сразу :thumbs:
Win10Pro + AMD
