leafpad /var/log/syslog
=-Inspiron-N5010 systemd[1]: Starting Disk Manager...
Sep 2 08:39:57 vika-Inspiron-N5010 gpu-manager[871]: /etc/modprobe.d is not a file
Sep 2 08:39:57 vika-Inspiron-N5010 systemd[1]: Starting Snappy daemon...
Sep 2 08:39:57 vika-Inspiron-N5010 systemd[1]: Starting LSB: Record successful boot for GRUB...
Sep 2 08:39:57 vika-Inspiron-N5010 ModemManager[866]: <info> ModemManager (version 1.6.8) starting in system bus...
Sep 2 08:39:57 vika-Inspiron-N5010 systemd[1]: Starting Dispatcher daemon for systemd-networkd...
Sep 2 08:39:57 vika-Inspiron-N5010 systemd[1]: Starting Thermal Daemon Service...
Sep 2 08:39:57 vika-Inspiron-N5010 systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
Sep 2 08:39:57 vika-Inspiron-N5010 systemd[1]: Starting Login Service...
Sep 2 08:39:57 vika-Inspiron-N5010 systemd[1]: Started System Logging Service.
Sep 2 08:39:57 vika-Inspiron-N5010 udisksd[873]: udisks daemon version 2.7.6 starting
Sep 2 08:39:57 vika-Inspiron-N5010 gpu-manager[871]: Error: can't open /lib/modules/4.15.0-33-generic/updates/dkms
Sep 2 08:39:57 vika-Inspiron-N5010 dbus-daemon[861]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service' requested by ':1.3' (uid=0 pid=866 comm="/usr/sbin/ModemManager " label="unconfined")
Sep 2 08:39:57 vika-Inspiron-N5010 systemd[1]: Started Restore /etc/resolv.conf if the system crashed before the ppp link was shut down.
vika@vika-Inspiron-N5010:~$ inxi -Fxz
System: Host: vika-Inspiron-N5010 Kernel: 4.15.0-33-generic x86_64
bits: 64 gcc: 7.3.0
Desktop: Cinnamon 3.8.8 (Gtk 3.22.30-1ubuntu1)
Distro: Linux Mint 19 Tara
Machine: Device: portable System: Dell product: Inspiron N5010 v: A15 serial: N/A
Mobo: Dell model: 0YXXJJ v: A15 serial: N/A
BIOS: Dell v: A15 date: 07/19/2011
CPU: Dual core Intel Core i3 M 370 (-MT-MCP-)
arch: Nehalem rev.5 cache: 3072 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 9599
clock speeds: max: 2394 MHz 1: 1377 MHz 2: 1516 MHz 3: 1465 MHz
4: 1604 MHz
Graphics: Card: Advanced Micro Devices [AMD/ATI] Madison [Mobility Radeon HD 5650/5750 / 6530M/6550M]
bus-ID: 01:00.0
drivers: ati,radeon (unloaded: modesetting,fbdev,vesa)
Resolution: 1366x768@60.06hz
OpenGL: renderer: AMD REDWOOD (DRM 2.50.0 / 4.15.0-33-generic, LLVM 6.0.0)
version: 3.3 Mesa 18.0.5 Direct Render: Yes
Audio: Card-1 Advanced Micro Devices [AMD/ATI] Redwood HDMI Audio [Radeon HD 5000 Series]
Card-2 Intel 5 Series/3400 Series High Def. Audio
Sound: Advanced Linux Sound Architecture v: k4.15.0-33-generic
Network: Card-1: Broadcom Limited BCM4312 802.11b/g LP-PHY
driver: wl bus-ID: 12:00.0
IF: wlp18s0 state: down mac: <filter>
Card-2: Realtek RTL8101/2/6E PCIE Fast/Gigabit Ethernet controller
driver: r8169 v: 2.3LK-NAPI port: d000 bus-ID: 13:00.0
IF: enp19s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives: HDD Total Size: 560.1GB (13.0% used)
ID-1: /dev/sda model: KINGSTON_SVP200S size: 60.0GB
ID-2: /dev/sdb model: WDC_WD5000BEVT size: 500.1GB
Partition: ID-1: / size: 55G used: 26G (49%) fs: ext4 dev: /dev/sda1
Sensors: System Temperatures: cpu: 53.0C mobo: N/A gpu: 53.5
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 244 Uptime: 2:08 Memory: 2100.8/3810.2MB
bits: 64 gcc: 7.3.0
4: 1604 MHz
bus-ID: 01:00.0
