PCIe Bus error severity=Corrected много-много строк
21 авг 2018, 02:45
Взял ноут
System:    Host: dja-work Kernel: 4.13.0-43-generic x86_64 (64 bit gcc: 5.4.0) Desktop: Xfce 4.12.3 (Gtk 2.24.28)
Machine:   System: ASUSTeK (portable) product: X541UVK v: 1.0
           Mobo: ASUSTeK model: X541UVK v: 1.0 Bios: American Megatrends v: X541UVK.308 date: 01/30/2018
CPU:       Dual core Intel Core i3-6006U (-HT-MCP-) cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 7968
           clock speeds: max: 2000 MHz 1: 1669 MHz 2: 1569 MHz 3: 1663 MHz 4: 1503 MHz
Graphics:  Card-1: Intel Sky Lake Integrated Graphics bus-ID: 00:02.0
           Card-2: NVIDIA Device 134f bus-ID: 01:00.0
           Display Server: X.Org 1.18.4 driver: nvidia Resolution: 1920x1080@60.05hz
           GLX Renderer: GeForce 920MX/PCIe/SSE2 GLX Version: 4.5.0 NVIDIA 384.130 Direct Rendering: Yes
Audio:     Card Intel Sunrise Point-LP HD Audio driver: snd_hda_intel bus-ID: 00:1f.3
           Sound: Advanced Linux Sound Architecture v: k4.13.0-43-generic
Network:   Card-1: Realtek RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
           driver: r8169 v: 2.3LK-NAPI port: d000 bus-ID: 02:00.2
           IF: enp2s0f2 state: down mac: <filter>
           Card-2: Realtek RTL8723BE PCIe Wireless Network Adapter driver: rtl8723be port: c000 bus-ID: 03:00.0
Drives:    HDD Total Size: 1000.2GB (42.5% used) ID-1: /dev/sda model: ST1000LM035 size: 1000.2GB
Partition: ID-1: / size: 50G used: 24G (50%) fs: ext4 dev: /dev/sda2
           ID-2: /home size: 30G used: 3.7G (13%) fs: ext4 dev: /dev/sda3
           ID-3: swap-1 size: 9.66GB used: 0.00GB (0%) fs: swap dev: /dev/sda4
Sensors:   System Temperatures: cpu: 45.0C mobo: N/A gpu: 0.0:43C
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 247 Uptime: 22 min Memory: 1985.1/7858.9MB Init: systemd runlevel: 5 Gcc sys: 5.4.0
Всё бы ничего. Но при загрузке и выключении много таких строк
Помогло в /etc/default/grub
# /boot/grub/grub.cfg.
#   info -f grub -n 'Simple configuration'
GRUB_DEFAULT=0
GRUB_HIDDEN_TIMEOUT=0
GRUB_HIDDEN_TIMEOUT_QUIET=true
GRUB_TIMEOUT=10
#GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
GRUB_CMDLINE_LINUX_DEFAULT="pci=nomsi"
GRUB_CMDLINE_LINUX=""
#GRUB_TERMINAL=console
#GRUB_GFXMODE=640x480
#GRUB_DISABLE_LINUX_UUID=true
#GRUB_DISABLE_RECOVERY="true"
#GRUB_INIT_TUNE="480 440 1"
После изменений не забываем про
sudo upgrae-grub
Есть еще вариант
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash pci=noaer"
но не пробовал, поскольку помог первый. С ждуном еще не баловался. Если что отпишусь позже.
Нагуглить помог di_mok
Решение Unborn » 22 авг 2018, 22:15
Dja писал(а):
22 авг 2018, 22:00
И это только маленький кусочек
Понятно, что маленький. Ошибки давай. Что у тебя там на 1с.5? Вывод - lspci -tv
21 авг 2018, 19:21
Dja, pci=nomsi, pci=noaer зачем тогда новое железо покупал? У тебя инфа о скорректированных ошибках. Мог бы вообще её не увидеть. Обычно отключают вывод таких сообщений для уже готового, собранного ядра. В каких-нибудь альфа, бета версиях дистров такое увидишь.
А ты взял и на хер отключил возможность использования многоядерности, многопоточности для работы с прерываниями.
В принципе можно вообще на одно ядро ЦП обработку прерываний повесить. Так когда-то на серверах делали, когда ЦП одноядерные были.
Хотя бы загуглил - Message Signaled Interrupts
А то залез назад на пальму, всё, решил вопрос с жильем. И про ядро 4.13 уже забыли. Попробуй крайнюю версию 4.4
По железу бы 4.9 LTS или 4.14 LTS использовать. ОС в УЕФИ. Кстати у АСУС УЕФИ от АМИ и самые путные. Это не Н20+свои велосипеды у остальных вендоров.
21 авг 2018, 20:16
Unborn, система то в уефи. А про обнову ядра как-то и не подумал. Да и железо то не вот тебе новое. Попробую конечно ядра поудалять и поставить поновее.
Кстати именно 4.9 и 4.14 отсутствуют
21 авг 2018, 20:27
Dja, убунтовцы прошли их стороной...поставь ukuu и из нее накати ядрышки
21 авг 2018, 20:47
довольно странно иметь на борту утилиту, которую и запускаю только для ядра, но при этом качать стороннюю :-D
21 авг 2018, 20:59
Ничто не мешает тебе скачать и установить руками http://kernel.ubuntu.com/~kernel-ppa/mainline/
21 авг 2018, 21:37
В итоге 4.4 как и 4.15 - можно вечно смотреть на бегущие строки. 4.14 - хотя бы грузится как 4.13 после выплеска нескольких десятков строк.
Счас гляну 4.9
Их и так уже солить можно
-rw-------  1 root root  7407392 окт 10  2017 vmlinuz-4.10.0-38-generic
-rw-------  1 root root  7407392 ноя  9  2017 vmlinuz-4.10.0-40-generic
-rw-------  1 root root  7406720 дек  4  2017 vmlinuz-4.10.0-42-generic
-rw-------  1 root root  7669648 янв 10  2018 vmlinuz-4.13.0-26-generic
-rw-------  1 root root  7671376 янв 25  2018 vmlinuz-4.13.0-32-generic
-rw-------  1 root root  7711632 мар  7 21:23 vmlinuz-4.13.0-37-generic
-rw-------  1 root root  7712208 мар 14 22:49 vmlinuz-4.13.0-38-generic
-rw-------  1 root root  7711664 май  3 16:07 vmlinuz-4.13.0-41-generic
-rw-------  1 root root  7713296 май 17 18:33 vmlinuz-4.13.0-43-generic
-rw-------  1 root root  7923472 ноя 12  2017 vmlinuz-4.14.0-041400-generic
-rw-------  1 root root  8101272 авг  6 20:23 vmlinuz-4.15.0-30-generic
-rw-------  1 root root  7159744 авг 10 14:20 vmlinuz-4.4.0-133-generic
-rw-r--r--  1 root root  7065648 янв 25  2017 vmlinuz-4.4.0-53-generic
-rw-------  1 root root  7310848 июн 27  2017 vmlinuz-4.8.0-58-generic
4.14 4.9 ошибочки
dpkg: зависимости пакетов не позволяют настроить пакет linux-headers-4.9.122-0409122-generic:
 linux-headers-4.9.122-0409122-generic зависит от libssl1.1 (>= 1.1.0), однако:
  Пакет libssl1.1 не установлен.
Пошел искать пакет :tux:
UPD нашел пакет. Качнул. Поставил. Ядро 4.9 встало, но на загрузку влияет негативно. Можно вечно ждать окончания загрузки с бегущими тысячами строк. 4.14.65 тоже встало, хоть и агрилось с ошибками. Тоже грузит вечно.
Самое противное что эти строки мешают юзать ждуна :hoho:
Благодарил (а): 212 раз
21 авг 2018, 23:19
Dja писал(а):
21 авг 2018, 20:47
Политка убунты такая. Мне вот тоже до сих пор странно, на ядре 4.15 почему-то только убунтовые дистры
А для того чтоб ядрами поиграть ukuu удобный вариант (для новой железяки последние ядра попробуй)
StarMAUGLI
Решено: 19
Благодарил (а): 697 раз
22 авг 2018, 00:15
Dja, А что показывает lspci
что это вообще за зверь такой 0000:00:1c.5 ?
22 авг 2018, 09:18
Dja, попробуй свеженькие ядра 4.17, 4.18
IaroslavB
Благодарил (а): 199 раз
22 авг 2018, 10:24
StarMAUGLI, lspci = команда List(Ls) + то, что будем выводить : некий вывод(зависит от дефолтных атрибутов команды) с Pci(Peripheral Components Interconnect) шины - подсистема, соединяющая множество периферийных устройств(мышь,клавиатура и т.д.) для передачи по единому каналу информацию дальше, если я правильно понимаю, как правило, до материнской платы.
А цифры те - это порт шины pci, да поправят меня знающие, если это не так.
Acer Aspire E5-575G-55J7
□ LM 18.3 KDE Plasma 5.8.9 based on Kernel[ 4.15.0-15 ]×86_64.
■ Intel Core i5=7200u
■ NVIDIA GeForce GTX 950M
Audio card: ●Intel device 9d71
Network cards:● Qualcomm Atheros dev. 0042 + ●Realtek RTL8111/8168/8411
22 авг 2018, 12:31
darkfenix, да всякие пробовал. Эти "свежие ядра" вообще одни простыни выдают без возможности попасть в графику либо ждать минут по 10. Сейчас вообще графика из inxi пропала :-D чую меня эти ядра не полечат, а покалечат. Надо наверно вернуться к решению и попробовать ждуна ) Если работать будет - пофиг на эти выхлопы. Меньше видишь крепче спишь :-D
22 авг 2018, 12:42
Еще и хромиум перестал запускаться
dja-laptop ~ $ chromium-browser
Using PPAPI flash.
--disable-new-tab-first-run --enable-user-scripts --ppapi-flash-path=/usr/lib/adobe-flashplugin/libpepflashplayer.so --ppapi-flash-version=
[7706:7706:0822/124012.722612:ERROR:process_singleton_posix.cc(1035)] Failed to create socket directory.
[7706:7706:0822/124012.722769:ERROR:chrome_browser_main.cc(1713)] Failed to create a ProcessSingleton for your profile directory. This means that running multiple instances would start multiple browser processes rather than opening a new window in the existing process. Aborting now to avoid profile corruption.
dja-laptop ~ $
Весело
22 авг 2018, 12:50
Dja, Что-то с профилем случилось, вот он и не запускается
StarMAUGLI
Решено: 19
22 авг 2018, 13:27
IaroslavB писал(а):
22 авг 2018, 10:24
на моем компе это выглядит так
┌─ mugalem ~
└─ $ lspci
00:00.0 Host bridge: Intel Corporation 82G33/G31/P35/P31 Express DRAM Controller (rev 02)
00:01.0 PCI bridge: Intel Corporation 82G33/G31/P35/P31 Express PCI Express Root Port (rev 02)
00:1a.0 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #4 (rev 02)
00:1a.1 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #5 (rev 02)
00:1a.2 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #6 (rev 02)
00:1a.7 USB controller: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #2 (rev 02)
00:1b.0 Audio device: Intel Corporation 82801I (ICH9 Family) HD Audio Controller (rev 02)
00:1c.0 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 1 (rev 02)
00:1c.4 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 5 (rev 02)
00:1c.5 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 6 (rev 02)
00:1d.0 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #1 (rev 02)
00:1d.1 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #2 (rev 02)
00:1d.2 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #3 (rev 02)
00:1d.7 USB controller: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #1 (rev 02)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev 92)
00:1f.0 ISA bridge: Intel Corporation 82801IR (ICH9R) LPC Interface Controller (rev 02)
00:1f.2 IDE interface: Intel Corporation 82801IR/IO/IH (ICH9R/DO/DH) 4 port SATA Controller [IDE mode] (rev 02)
00:1f.3 SMBus: Intel Corporation 82801I (ICH9 Family) SMBus Controller (rev 02)
00:1f.5 IDE interface: Intel Corporation 82801I (ICH9 Family) 2 port SATA Controller [IDE mode] (rev 02)
01:00.0 VGA compatible controller: NVIDIA Corporation GK106 [GeForce GTX 650 Ti] (rev a1)
01:00.1 Audio device: NVIDIA Corporation GK106 HDMI Audio Controller (rev a1)
03:00.0 SATA controller: JMicron Technology Corp. JMB361 AHCI/IDE (rev 02)
03:00.1 IDE interface: JMicron Technology Corp. JMB361 AHCI/IDE (rev 02)
04:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 0
05:01.0 FireWire (IEEE 1394): Texas Instruments TSB43AB22A IEEE-1394a-2000 Controller (PHY/Link) [iOHCI-Lynx]
┌─ mugalem ~
т.е. на этом номере у меня 00:1c.5 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 6 (rev 02)
но у него-то на ноуте наверняка другой набор логики (чем на моем допотопном старье) не ICH9, значит там может быть и не PCI Express - поэтому и спросил - нужно же знать про что гуглить. Любопытно же.
Тем более, что это не тот PCI Express, что идет на видео-карту, а тот, что идет на всякую мелочь, типа звука или сетевух.
22 авг 2018, 13:56
всё это может быть результатом клонирования системы :) Попробую поставить именно на него. Посмотрю что выйдет.
22 авг 2018, 15:09
Dja писал(а):
22 авг 2018, 13:56
Так если ты с одной аппаратной конфигурации перенес на другую, то что ты ещё удивляешься? Это закономерное явление. Как говносборку-бэкап чей-нибудь на каком-нибудь десктопном железе сделанном воткнуть себе на ноут и удивляться, что это там не работает вай-фай, если у говносборщика и вафли то не было.
И если ядро будет уже с патчем против последних Мельдауна и Спектра, то и драйвер Нвидиа должен быть с 3-мя цифрами после точки. Если ядро не патченое, то лучше с 2-мя.
22 авг 2018, 16:11
22 авг 2018, 12:50
Места на корне нет :-D вот система и в шоке, собственно как и я :-D с 30 гигов увеличил до 50 и тех не хватило... Куда 20 гигов ушло... по ходу на эти логи :-D
Unborn, ну я же ставил линух на флешку и флешка прекрасно запускалась на других машинах.
22 авг 2018, 17:13
Поставил с нуля LM 18.3
Всё равно эти строки ))) Стало быть клонирование не виновато.
StarMAUGLI писал(а):
22 авг 2018, 00:15
показывает lspci
00:00.0 Host bridge: Intel Corporation Sky Lake Host Bridge/DRAM Registers (rev 08)
00:02.0 VGA compatible controller: Intel Corporation Sky Lake Integrated Graphics (rev 07)
00:04.0 Signal processing controller: Intel Corporation Skylake Processor Thermal Subsystem (rev 08)
00:14.0 USB controller: Intel Corporation Sunrise Point-LP USB 3.0 xHCI Controller (rev 21)
00:14.2 Signal processing controller: Intel Corporation Sunrise Point-LP Thermal subsystem (rev 21)
00:15.0 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO I2C Controller (rev 21)
00:15.1 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO I2C Controller (rev 21)
00:16.0 Communication controller: Intel Corporation Sunrise Point-LP CSME HECI (rev 21)
00:17.0 SATA controller: Intel Corporation Sunrise Point-LP SATA Controller [AHCI mode] (rev 21)
00:1c.0 PCI bridge: Intel Corporation Device 9d10 (rev f1)
00:1c.4 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port (rev f1)
00:1c.5 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port (rev f1)
00:1f.0 ISA bridge: Intel Corporation Sunrise Point-LP LPC Controller (rev 21)
00:1f.2 Memory controller: Intel Corporation Sunrise Point-LP PMC (rev 21)
00:1f.3 Audio device: Intel Corporation Sunrise Point-LP HD Audio (rev 21)
00:1f.4 SMBus: Intel Corporation Sunrise Point-LP SMBus (rev 21)
01:00.0 3D controller: NVIDIA Corporation Device 134f (rev a2)
02:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5286 PCI Express Card Reader (rev 01)
02:00.2 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller (rev 06)
03:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8723BE PCIe Wireless Network Adapter
StarMAUGLI
Решено: 19
22 авг 2018, 18:11
Dja писал(а):
22 авг 2018, 17:13
Странно. На 00:1c.4 точно такой же стоит, а ошибок нет.
Ты уверен, что проблема программная, а не железная?
Может стоит разобрать ноут и посмотреть в порт на предмет загнутых лепестков, перекошенных шлейфов, подгоревших деталек или металлического/токопроводящего мусора? Контактики там флейцем промести, ластиком почистить? Или даже пылесосом пожужжать?
Сейчас этот форум просматривают: нет зарегистрированных пользователей и 25 гостей
