Linux Mint Cinnamon no BT
ChekvEEs
18 авг 2018, 18:37
Версия ОС: LM 19 x64 Cinnamon
Система:
System:    Host: PC Kernel: 4.15.0-32-generic x86_64 bits: 64 gcc: 7.3.0
           Desktop: Cinnamon 3.8.8 (Gtk 3.22.30-1ubuntu1)
           Distro: Linux Mint 19 Tara
Machine:   Device: laptop System: Acer product: Extensa 2511G v: V3.72 serial: N/A
           Mobo: Acer model: ZORO_BH v: Type2 - A01 Board Version serial: N/A
           UEFI [Legacy]: Insyde v: V1.31 date: 09/25/2015
Battery    BAT1: charge: 29.6 Wh 100.0% condition: 29.6/37.0 Wh (80%)
           model: SANYO AL15A32 status: Full
CPU:       Dual core Intel Core i3-4005U (-MT-MCP-)
           arch: Haswell rev.1 cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 6800
           clock speeds: max: 1600 MHz 1: 1081 MHz 2: 1127 MHz 3: 1102 MHz
           4: 939 MHz
Graphics:  Card-1: Intel Haswell-ULT Integrated Graphics Controller
           bus-ID: 00:02.0
           Card-2: NVIDIA GM108M [GeForce 940M] bus-ID: 04:00.0
           drivers: modesetting,nvidia (unloaded: fbdev,vesa,nouveau)
           Resolution: 1366x768@60.00hz
           OpenGL: renderer: GeForce 940M/PCIe/SSE2
           version: 4.6.0 NVIDIA 390.48 Direct Render: Yes
Audio:     Card-1 Intel 8 Series HD Audio Controller
           Card-2 Intel Haswell-ULT HD Audio Controller
           driver: snd_hda_intel bus-ID: 00:03.0
           Sound: Advanced Linux Sound Architecture v: k4.15.0-32-generic
Network:   Card-1: Realtek RTL8111/8168/8411 PCIE Gigabit Ethernet Controller
           driver: r8169 v: 2.3LK-NAPI port: 4000 bus-ID: 02:00.0
           Card-2: Broadcom Limited BCM43142 802.11b/g/n bus-ID: 03:00.0
           IF: N/A state: N/A mac: N/A
Drives:    HDD Total Size: 500.1GB (4.1% used)
           ID-1: /dev/sda model: ST500LT012 size: 500.1GB
           ID-2: /dev/mmcblk0 model: N/A size: 4.0GB
Partition: ID-1: / size: 19G used: 15G (84%) fs: ext4 dev: /dev/sda6
           ID-2: /home size: 19G used: 918M (6%) fs: ext4 dev: /dev/sda8
           ID-3: swap-1 size: 4.00GB used: 0.00GB (0%)
           fs: swap dev: /dev/dm-0
Sensors:   System Temperatures: cpu: 54.0C mobo: N/A gpu: 0.0:52C
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 216 Uptime: 23 min Memory: 1941.1/3871.6MB
Суть: Вечер добрый, думаю о переходе на LinuxMint полностью, сегодня установил как 2 ОС 1я Win 8.1, вроде все окей но обнаружил что я не могу подключить бт, начал копатся обнаружил что сис-ма не видит адаптер бт, не знаю как решить проблему прошу помощи!
Последний раз редактировалось пользователем 1 ChekvEEs; всего редактировалось раз: 18
18 авг 2018, 19:01
Покажи вывод rfkill list
ChekvEEs
18 авг 2018, 19:48
1: acer-wireless: Wireless LAN
	Soft blocked: yes
	Hard blocked: no
18 авг 2018, 19:54
Хм...это все?
Попробуй кнопкой включения wifi поиграться. Показывает что у тебя wifi выключен.
1-ое нажатие должен wifi включиться.
2-ое нажатие должен bluetooth включиться.
После каждого раза смотри работает ли BT или нет. Проверяй что в программе из трея и что показывает rfkill list
ChekvEEs
18 авг 2018, 19:58
Прошелся почти по всем гугшли как включить бт на клавиатуре, у меня это сочетание fn+f3 но ничего не происходит результат такой же как и выше код
21 авг 2018, 20:40
ChekvEEs писал(а):
18 авг 2018, 19:58
Сначала драйвер установи для BCM43142. Он в Менеджере драйверов есть.
Для блютуз нужна фирмварь. Её у Убунту, Минт нет. Поэтому - https://help.ubuntu.ru/wiki/broadcom_bluetooth
ChekvEEs
22 авг 2018, 07:39
2 файла только в менеджере драиверов(см скрин)
ChekvEEs
22 авг 2018, 08:18
+ драивера в ссылках все на винду, а нужного файла там нет так что хз
ChekvEEs
22 авг 2018, 08:59
Команды:
usb-devices, lsusb
Не показывают бт
22 авг 2018, 09:33
ChekvEEs, дай выводы
dmesg | grep -i bluetooth
usb-devices | awk '/0bda/' RS=
А что значит lsusb не показывает блутуз? Дай вывод
Последний раз редактировалось пользователем 2 vir0id; всего редактировалось раз: 22
ChekvEEs
22 авг 2018, 09:35
darik@kif:~$ dmesg | grep -i bluetooth
[   15.578059] Bluetooth: Core ver 2.22
[   15.578083] Bluetooth: HCI device and connection manager initialized
[   15.578088] Bluetooth: HCI socket layer initialized
[   15.578091] Bluetooth: L2CAP socket layer initialized
[   15.578099] Bluetooth: SCO socket layer initialized
[   15.740269] Bluetooth: hci0: sending frame failed (-19)
[   17.756136] Bluetooth: hci0: command 0x1001 tx timeout
[   20.930501] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   20.930503] Bluetooth: BNEP filters: protocol multicast
[   20.930507] Bluetooth: BNEP socket layer initialized
[   25.820144] Bluetooth: hci0: BCM: Reading local version info failed (-110)
darik@kif:~$ usb-devices | awk '/0bda/' RS=
T:  Bus=02 Lev=01 Prnt=01 Port=07 Cnt=04 Dev#= 10 Spd=480 MxCh= 0
D:  Ver= 2.00 Cls=ff(vend.) Sub=ff Prot=ff MxPS=64 #Cfgs=  1
P:  Vendor=0bda ProdID=0129 Rev=39.60
S:  Manufacturer=Generic
S:  Product=USB2.0-CRW
S:  SerialNumber=20100201396000000
C:  #Ifs= 1 Cfg#= 1 Atr=a0 MxPwr=500mA
I:  If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=06 Prot=50 Driver=rtsx_usb
22 авг 2018, 09:38
ChekvEEs, попробуй так
sudo hciconfig hci0 up
ChekvEEs
22 авг 2018, 09:38
Can't get device info: No such device
22 авг 2018, 09:42
ChekvEEs,
lspci -v -s 03:00.0
по id на шине вывод в студию тоже
ChekvEEs
22 авг 2018, 09:43
darik@kif:~$ lspci -v -s 03:00.0
03:00.0 Network controller: Broadcom Limited BCM43142 802.11b/g/n (rev 01)
	Subsystem: Lite-On Communications Inc BCM43142 802.11b/g/n
	Flags: bus master, fast devsel, latency 0, IRQ 19
	Memory at b3400000 (64-bit, non-prefetchable) [size=32K]
	Capabilities: <access denied>
	Kernel driver in use: wl
	Kernel modules: wl
22 авг 2018, 09:52
ChekvEEs, ну да, видимо в том драйвере не собран синезуб, почему-то... Чё-то разрабы прикалолсись. В этом посте #6 примерно то, что нужно делать. Качнуть виндовый зип пакет и...
потанцевать с бубном
ChekvEEs
22 авг 2018, 09:54
Ладно плевать кароче, еще надо с звуком разбиратся (нет звука в наушниках), спасибо за попытку!)
22 авг 2018, 11:12
vir0id писал(а):
22 авг 2018, 09:52
У меня такая же карта. Всё работает. Один раз сделал, файлик на полку. Кстати, в Арч пакетом давно сделали.
Бродком традиционно на Линукс кладет, вот и проблемы. Само железо годное.
ChekvEEs
22 авг 2018, 11:27
Лично я не нашел споосба а все что пробовал не поомгло так что забил на это
22 авг 2018, 11:45
Unborn писал(а):
22 авг 2018, 11:12
vir0id писал(а):
22 авг 2018, 09:52
Да, согласен что кладут.
