медленная загрузка
bompas
медленная загрузка
16 авг 2018, 21:57
LM19 x64.
System:    Host: Tower Kernel: 4.15.0-32-generic x86_64 bits: 64 gcc: 7.3.0
           Desktop: Cinnamon 3.8.8 (Gtk 3.22.30-1ubuntu1) Distro: Linux Mint 19 Tara
Machine:   Device: desktop Mobo: ASUSTeK model: Z170-A v: Rev 1.xx serial: N/A UEFI: American Megatrends v: 3703 date: 12/27/2017
CPU:       Quad core Intel Core i5-6500 (-MCP-) arch: Skylake-S rev.3 cache: 6144 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 25536
           clock speeds: max: 3600 MHz 1: 800 MHz 2: 800 MHz 3: 800 MHz 4: 800 MHz
Graphics:  Card: Intel HD Graphics 530 bus-ID: 00:02.0
           Display Server: x11 (X.Org 1.19.6 ) drivers: modesetting (unloaded: fbdev,vesa)
           Resolution: 1680x1050@59.88hz
           OpenGL: renderer: Mesa DRI Intel HD Graphics 530 (Skylake GT2)
           version: 4.5 Mesa 18.0.5 Direct Render: Yes
Audio:     Card Intel Sunrise Point-H HD Audio driver: snd_hda_intel bus-ID: 00:1f.3
           Sound: Advanced Linux Sound Architecture v: k4.15.0-32-generic
Network:   Card-1: Intel Ethernet Connection (2) I219-V driver: e1000e v: 3.2.6-k bus-ID: 00:1f.6
           IF: enp0s31f6 state: down mac: <filter>
           Card-2: D-Link System DGE-528T Gigabit Ethernet Adapter
           driver: r8169 v: 2.3LK-NAPI port: e000 bus-ID: 04:00.0
           Card-3: Realtek RTL8812AE 802.11ac PCIe Wireless Network Adapter driver: rtl8821ae bus-ID: 05:00.0
           IF: wlp5s0 state: down mac: <filter>
Drives:    HDD Total Size: 2120.4GB (41.6% used)
           ID-1: /dev/nvme0n1 model: Force_MP500 size: 120.0GB
           ID-2: /dev/sda model: WDC_WD1003FZEX size: 1000.2GB
           ID-3: /dev/sdb model: WDC_WD10PURX size: 1000.2GB
Partition: ID-1: / size: 30G used: 7.2G (26%) fs: ext4 dev: /dev/nvme0n1p1
           ID-2: /home size: 917G used: 805G (93%) fs: ext4 dev: /dev/sdb1
           ID-3: swap-1 size: 10.74GB used: 0.00GB (0%) fs: swap dev: /dev/dm-0
Sensors:   System Temperatures: cpu: 31.0C mobo: N/A
           Fan Speeds (in rpm): cpu: 0
Info:      Processes: 214 Uptime: 34 min Memory: 2049.7/15845.5MB Init: systemd runlevel: 5 Gcc sys: 7.3.0
systemd-analyze
Startup finished in 9.097s (firmware) + 2.566s (loader) + 35.590s (kernel) + 8.897s (userspace) = 56.151s
graphical.target reached after 8.873s in userspace
          7.729s NetworkManager-wait-online.service
           736ms alsa-restore.service
           726ms user@1000.service
           389ms keyboard-setup.service
           307ms systemd-logind.service
           239ms systemd-cryptsetup@cryptswap1.service
           214ms dev-nvme0n1p1.device
           206ms udisks2.service
           201ms lightdm.service
           200ms plymouth-quit-wait.service
           161ms NetworkManager.service
           155ms systemd-fsck@dev-disk-by\x2duuid-8e574c1b\x2dd052\x2d41d2\x2dadf8\x2deae9e95a97fa.service
           124ms systemd-timesyncd.service
           123ms systemd-resolved.service
           118ms systemd-fsck@dev-disk-by\x2duuid-D4CF\x2d50A4.service
           102ms ubuntu-system-adjustments.service
            79ms networkd-dispatcher.service
            69ms ModemManager.service
            62ms systemd-journal-flush.service
            59ms systemd-udev-trigger.service
            58ms packagekit.service
            55ms accounts-daemon.service
            50ms apport.service
            49ms virtualbox.service
            49ms lvm2-monitor.service
            45ms upower.service
            42ms speech-dispatcher.service
            42ms systemd-rfkill.service
            41ms systemd-journald.service
            37ms grub-common.service
            37ms apparmor.service
            35ms colord.service
            34ms home.mount
            32ms lm-sensors.service
            32ms wpa_supplicant.service
            30ms rsyslog.service
            30ms thermald.service
подскажите где о проблеме почитать??
медленная загрузка
16 авг 2018, 22:17
Полистай тут. Благо всего 4 страницы.
Проблемы с запуском нетбука (Пост Ivan 85 #57642)
bompas
медленная загрузка
16 авг 2018, 22:54
откатил ядро назад 4.15.0-20 . то же самое. 35 секунд на загрузку это не вариант. на убунте 1604 за 5сек все грузилось.
warning
Решено: 7
Благодарил (а): 161 раз
медленная загрузка
16 авг 2018, 23:10
bompas писал(а):
16 авг 2018, 21:57
отключил?
думается можно еще выжать из загрузки пару секунд там-сям
hw-probe: тыц!
warning
Решено: 7
медленная загрузка
16 авг 2018, 23:15
hw-probe: тыц!
Благодарил (а): 1737 раз
медленная загрузка
16 авг 2018, 23:16
случается долгая загрузка на 18.3, при этом если по логу загрузки стопорится рандомно, но тыкнув любую клавишу загрузка продолжается моментально...
при этом в анализе fsck проскакивают... неправильно размонтирование я так понимаю на рэйде аппаратном...
у тебя тоже рэйд?
медленная загрузка
17 авг 2018, 00:15
bompas писал(а):
16 авг 2018, 22:54
Там еще в топике было чета по поводу накопления энтропии и как в этом помочь линуксу.
WARNING писал(а):
16 авг 2018, 23:10
у него ядрище 35 сек грузится, вот что явно ненормально.
bompas
медленная загрузка
17 авг 2018, 00:34
притом лет 5 сидел на убунте. вчера поставил минт. процессор сами видите, не самый слабый. и 35 сек только ядро. :cray2:
bompas
медленная загрузка
17 авг 2018, 09:58
при загрузке на этой строке самый тормоз. как узнать что это за устройство?
медленная загрузка
17 авг 2018, 10:32
bompas писал(а):
16 авг 2018, 22:54
Сказки. У вас не SSD чтоб мечтать об этом
bompas
медленная загрузка
17 авг 2018, 11:39
systemd-analyze
Startup finished in 9.088s (firmware) + 3.114s (loader) + 3.678s (kernel) + 7.445s (userspace) = 23.327s
graphical.target reached after 7.426s in userspace
кажется лед тронулся. убрал проверку Btrfs
https://askubuntu.com/questions/1034359 ... nt/1034952
bompas
медленная загрузка
17 авг 2018, 11:41
и у меня именно SSD
медленная загрузка
17 авг 2018, 16:13
bompas писал(а):
17 авг 2018, 11:41
у меня именно SSD
В каком месте?
bompas писал(а):
16 авг 2018, 21:57
А учитывая
bompas писал(а):
16 авг 2018, 21:57
Мы видим, что на ssd (если /dev/nvme0n1p1 - ssd) только корень. Хомяк же и своп монтируются с hdd. Т.е. правильнее сказать у вас ssd+два hdd, которые участвуют в загрузке. Вот если бы все эти составляющие были на ssd, то было бы правильно сказано что у вас ssd. Но это не совсем так.
Сейчас этот форум просматривают: PetalBot[Bot] и 1 гость
