Mint 19 tara. Не стабильно работают шАры в Thunar. Ну, и вообще, - SAMBA !!!
hitkliv
Благодарил (а): 7 раз
03 авг 2018, 08:31
Здравствуйте!
OS: Mint 19 tara
Kernel: x86_64 Linux 4.15.0-24-generic
DE: XFCE
WM: Xfwm4
CPU: AMD FX-8370 Eight-Core @ 8x 4GHz
GPU: GeForce GTX 950
$ cat /etc/samba/smb.conf
#[global]
#### Debugging/Accounting ####
	dos charset = cp866
	unix charset = utf8
	workgroup = WORKGROUP
;	realm = WORKGROUP
	netbios name = <host>
	server string = %h
;	wins server = 127.0.0.1
	wins support = true
	interfaces = 192.168.x.y/24 enp3s0
;	bind interfaces only = true
;	nbt client socket address = 192.168.x.y
	hosts allow = 192.168.x.0/24
;	auth methods = guest, sam_ignoredomain
;	ntlm auth = yes
;	map to guest = Bad User
	map to guest = Bad Password
	log file = /var/log/samba/log.%m
	max log size = 1024
	max xmit = 65536
#   syslog only = no
;	syslog = 0
	unix extensions = No
	deadtime = 15
;	socket options = IPTOS_LOWDELAY TCP_NODELAY SO_SNDBUF=65536 SO_RCVBUF=65536 SO_KEEPALIVE
	panic action = /usr/share/samba/panic-action %d
	winbind enum groups = yes
	winbind enum users = yes
; управление доменом
	domain master = true
	server role = standalone server
	local master = true
	os level = 65
	preferred master = auto
	name resolve order =  wins, bcast, host, lmhosts
;	client ipc min protocol = NT1
;	client ipc max protocol = SMB3_10
;	client min protocol = NT1
;	client max protocol = SMB3_10
	client max protocol = NT1
;	nt status support = yes
	inherit permissions = yes
	security = user
	guest account = smbguest
	username map = /etc/samba/smbusers
	usershare allow guests = yes
	guest ok = yes
[Public]
	comment = Public
	path = /home/user/Общедоступные/
	writeable = yes
	browsable = yes
	guest ok = no
	dns proxy = no
;	log file = /var/log/samba/log.%m
;	max log size = 1000
;	syslog = 0
;	panic action = /usr/share/samba/panic-action %d
;	server role = standalone server
;	obey pam restrictions = yes
	unix password sync = yes
	passwd program = /usr/bin/passwd %u
	passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccessfully* .
	pam password change = yes
	map to guest = bad user
	valid users = hitkliv, guest, smbguest, eugene, Гость
[Folder]
	comment = Public
	path = /mnt/disk/Folder/
	writeable = yes
	browsable = yes
	guest ok = no
	dns proxy = no
;	syslog = 0
	valid users = user, guest, smbguest, user1
[printers]
	comment = All Printers
	browseable = no
	path = /var/spool/samba
	printable = yes
	create mask = 0700
[print$]
	comment = Printer Drivers
	path = /var/lib/samba/printers
	writeable = yes
	valid users = user, root, smbguest
$ apt list --installed | grep samba
python-samba/bionic,now 2:4.7.6+dfsg~ubuntu-0ubuntu2 amd64 [установлен, автоматически]
samba/bionic,now 2:4.7.6+dfsg~ubuntu-0ubuntu2 amd64 [установлен]
samba-common/bionic,bionic,now 2:4.7.6+dfsg~ubuntu-0ubuntu2 all [установлен, автоматически]
samba-common-bin/bionic,now 2:4.7.6+dfsg~ubuntu-0ubuntu2 amd64 [установлен, автоматически]
samba-dsdb-modules/bionic,now 2:4.7.6+dfsg~ubuntu-0ubuntu2 amd64 [установлен, автоматически]
samba-libs/bionic,now 2:4.7.6+dfsg~ubuntu-0ubuntu2 amd64 [установлен, автоматически]
samba-testsuite/bionic,now 2:4.7.6+dfsg~ubuntu-0ubuntu2 amd64 [установлен]
samba-vfs-modules/bionic,now 2:4.7.6+dfsg~ubuntu-0ubuntu2 amd64 [установлен, автоматически]
$ apt list --installed | grep gvfs
gvfs/bionic-updates,now 1.36.1-0ubuntu1.1 i386 [установлен]
gvfs-backends/bionic-updates,now 1.36.1-0ubuntu1.1 amd64 [установлен]
gvfs-bin/bionic-updates,now 1.36.1-0ubuntu1.1 amd64 [установлен]
gvfs-common/bionic-updates,bionic-updates,now 1.36.1-0ubuntu1.1 all [установлен]
gvfs-daemons/bionic-updates,now 1.36.1-0ubuntu1.1 amd64 [установлен]
gvfs-fuse/bionic-updates,now 1.36.1-0ubuntu1.1 amd64 [установлен]
gvfs-libs/bionic-updates,now 1.36.1-0ubuntu1.1 amd64 [установлен]
Thunar 1.6.15
Из сетки, с любой Windows-станции (7,XP,10), шАры Linux видны. В линукс, в Thunar, отображается сеть и станции. Причем сам Linux, - дважды :dash2: .
При попытке обратиться к одной ссылке, получаем:
Не удалось получить список доступных на сервере ресурсов: Недопустимый аргумент.
При попытке, обратиться к другой - нормальные шАры.
Диагностика:
И с Windows-станциями, та-же беда...
При обращении из Thunar:
К Win-XP, - без проблем.
К Win-7, - Не удалось получить список доступных на сервере ресурсов: Недопустимый аргумент.
Из консоли:
то так:
$ smbclient -L WIN7
protocol negotiation failed: NT_STATUS_CONNECTION_RESET
то, тут-же, - так:
$ smbclient -L WIN7
Enter WORKGROUP\user's password:
	Sharename       Type      Comment
	ADMIN$          Disk      Удаленный Admin
	C$              Disk      Стандартный общий ресурс
	D$              Disk      Стандартный общий ресурс
	E$              Disk      Общий ресурс по умолчанию
	IPC$            IPC       Удаленный IPC
	Music           Disk
	Public          Disk
	Users           Disk
Reconnecting with SMB1 for workgroup listing.
	Server               Comment
	Workgroup            Master
WORKGROUP
	\\XP32      		VM_XP
		\\VSBA-XP32\Документы
		\\VSBA-XP32\Принтер 	Microsoft Office Document Image Writer
		\\VSBA-XP32\C$             	Стандартный общий ресурс
		\\VSBA-XP32\ADMIN$         	Удаленный Admin
		\\VSBA-XP32\Принтер2	ElcomPDF
		\\VSBA-XP32\SharedDocs
		\\VSBA-XP32\print$         	Драйверы принтеров
		\\VSBA-XP32\IPC$           	Удаленный IPC
	\\LINUX-PC        		Linux-PC
		\\LINUX-PC\IPC$           	IPC Service (Linux-PC)
		\\LINUX-PC\print$         	Printer Drivers
		\\LINUX-PC\Folder       	Public
		\\LINUX-PC\Public         	Public
	\\WIN7
Что с этим SAMBA не так?
Пожалуйста, помогите разобраться!!!
"Зри в корень!"
Козьма Петрович Прутков.
hitkliv
03 авг 2018, 08:39
Ну, и еще вот:
$ apt list --installed | grep glib
gir1.2-dbusmenu-glib-0.4/bionic,now 16.04.1+18.04.20171206-0ubuntu1 amd64 [установлен]
gir1.2-glib-2.0/bionic,now 1.56.1-1 amd64 [установлен]
gir1.2-packagekitglib-1.0/bionic,now 1.1.9-1ubuntu2 amd64 [установлен]
gir1.2-upowerglib-1.0/bionic,now 0.99.7-2 amd64 [установлен]
glib-networking/bionic,now 2.56.0-1 amd64 [установлен]
glib-networking-common/bionic,bionic,now 2.56.0-1 all [установлен]
glib-networking-services/bionic,now 2.56.0-1 amd64 [установлен]
libaccounts-glib0/bionic,now 1.23+17.04.20161104-0ubuntu1 amd64 [установлен]
libappstream-glib8/bionic,now 0.7.7-2 amd64 [установлен]
libavahi-glib1/bionic,now 0.7-3.1ubuntu1 amd64 [установлен]
libcglib-java/bionic,bionic,now 3.2.6-2 all [установлен, автоматически]
libdbus-glib-1-2/bionic,now 0.110-2 amd64 [установлен]
libdbus-glib2.0-cil/bionic,bionic,now 0.6.0-1build1 all [установлен]
libdbusmenu-glib4/bionic,now 16.04.1+18.04.20171206-0ubuntu1 amd64 [установлен]
libgeocode-glib0/bionic,now 3.25.4.1-4 amd64 [установлен]
libglib-object-introspection-perl/bionic,now 0.044-2 amd64 [установлен, автоматически]
libglib-perl/bionic,now 3:1.326-1build1 amd64 [установлен]
libglib2.0-0/bionic,now 2.56.1-2ubuntu1 amd64 [установлен]
libglib2.0-bin/bionic,now 2.56.1-2ubuntu1 amd64 [установлен]
libglib2.0-cil/bionic,now 2.12.40-2 amd64 [установлен]
libglib2.0-data/bionic,bionic,now 2.56.1-2ubuntu1 all [установлен]
libglib2.0-dev/bionic,now 2.56.1-2ubuntu1 amd64 [установлен]
libglib2.0-dev-bin/bionic,now 2.56.1-2ubuntu1 amd64 [установлен, автоматически]
libglibmm-2.4-1v5/bionic,now 2.56.0-1 amd64 [установлен]
libjson-glib-1.0-0/bionic,now 1.4.2-3 amd64 [установлен]
libjson-glib-1.0-common/bionic,bionic,now 1.4.2-3 all [установлен]
libmbim-glib4/bionic,now 1.14.2-2.1ubuntu1 amd64 [установлен]
libmm-glib0/bionic,now 1.6.8-2ubuntu1 amd64 [установлен]
libnm-glib-vpn1/bionic,now 1.10.6-2ubuntu1 amd64 [установлен]
libnm-glib4/bionic,now 1.10.6-2ubuntu1 amd64 [установлен]
libpackagekit-glib2-16/now 0.8.17-4ubuntu6~gcc5.4ubuntu1.2 amd64 [установлен, локальный]
libpackagekit-glib2-18/bionic,now 1.1.9-1ubuntu2 amd64 [установлен, автоматически]
libpoppler-glib8/bionic-updates,bionic-security,now 0.62.0-2ubuntu2.1 amd64 [установлен]
libpulse-mainloop-glib0/bionic-updates,now 1:11.1-1ubuntu7.1 i386 [установлен]
libqmi-glib1/now 1.12.6-1 amd64 [установлен, локальный]
libqmi-glib5/bionic,now 1.18.0-3ubuntu1 amd64 [установлен, автоматически]
libtelepathy-glib0/bionic,now 0.24.1-2 amd64 [установлен]
libupower-glib3/bionic,now 0.99.7-2 amd64 [установлен]
"Зри в корень!"
03 авг 2018, 10:39
hitkliv, а что значит секция?
	local master = true
	os level = 65
	security = user
	guest ok = yes
Bill Williamson
Решено: 34
Благодарил (а): 288 раз
03 авг 2018, 10:55
hitkliv писал(а):
03 авг 2018, 08:31
Открывается ли, если прописать полный путь c ip-адресом до расшаренной директорий в Windows 7?
Последний раз редактировалось пользователем 1 Bill Williamson; всего редактировалось раз: 3
03 авг 2018, 11:00
03 авг 2018, 11:03
-I|--ip-address IP-address
IP address is the address of the server to connect to. It should be specified in standard "a.b.c.d" notation.
Normally the client would attempt to locate a named SMB/CIFS server by looking it up via the NetBIOS name resolution mechanism described above in the name
resolve order parameter above. Using this parameter will force the client to assume that the server is on the machine with the specified IP address and the
NetBIOS name component of the resource being connected to will be ignored.
There is no default for this parameter. If not supplied, it will be determined automatically by the client as described above.
Как юзать? Не догнал.
hitkliv
03 авг 2018, 17:36
Dja писал(а):
03 авг 2018, 10:39
	local master = true
	os level = 65
	security = user
	guest ok = yes
"Управление доменом", это не секция, это комментарий.
Если бы это была секция, было бы написано - [управление доменом]
"Зри в корень!"
hitkliv
03 авг 2018, 17:50
Bill Williamson писал(а):
03 авг 2018, 10:55
hitkliv писал(а):
03 авг 2018, 08:31
Да, с IP подключается...
smb://192.168.2.3/, шАры видно
:magic:
$ nmblookup -A 192.168.2.3
Looking up status of 192.168.2.3
WIN7 <20> - M <ACTIVE>
WIN7 <00> - M <ACTIVE>
WORKGROUP <00> - <GROUP> M <ACTIVE>
"Зри в корень!"
hitkliv
03 авг 2018, 18:20
di_mok писал(а):
03 авг 2018, 11:00
hitkliv, попробуй Mint 19 и изменения в Samba File Sharing [Перевод]
$ sudo service smbd status
smbd.service - Samba SMB Daemon
Loaded: loaded (/lib/systemd/system/smbd.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2018-08-03 13:03:06 +08; 10h ago
Docs: man:smbd(8)
man:samba(7)
man:smb.conf(5)
Main PID: 13389 (smbd)
Status: "smbd: ready to serve connections..."
Tasks: 10 (limit: 4915)
CGroup: /system.slice/smbd.service
├─12594 /usr/sbin/smbd --foreground --no-process-group
├─12600 /usr/sbin/smbd --foreground --no-process-group
├─12714 /usr/sbin/smbd --foreground --no-process-group
├─13059 /usr/sbin/smbd --foreground --no-process-group
├─13389 /usr/sbin/smbd --foreground --no-process-group
├─13409 /usr/sbin/smbd --foreground --no-process-group
├─13410 /usr/sbin/smbd --foreground --no-process-group
├─13413 /usr/sbin/smbd --foreground --no-process-group
├─14289 /usr/sbin/smbd --foreground --no-process-group
└─14290 /usr/sbin/smbd --foreground --no-process-group
авг 03 23:05:38 Home-PC smbd[14290]: [2018/08/03 23:05:38.492323, 0] ../lib/param/loadparm.c:1862(lpcfg_do_service_parameter)
авг 03 23:05:38 Home-PC smbd[14290]: Global parameter passwd program found in service section!
авг 03 23:05:38 Home-PC smbd[14290]: [2018/08/03 23:05:38.492345, 0] ../lib/param/loadparm.c:1862(lpcfg_do_service_parameter)
авг 03 23:05:38 Home-PC smbd[14290]: Global parameter passwd chat found in service section!
авг 03 23:05:38 Home-PC smbd[14290]: [2018/08/03 23:05:38.492365, 0] ../lib/param/loadparm.c:1862(lpcfg_do_service_parameter)
авг 03 23:05:38 Home-PC smbd[14290]: Global parameter pam password change found in service section!
авг 03 23:05:38 Home-PC smbd[14290]: [2018/08/03 23:05:38.492384, 0] ../lib/param/loadparm.c:1862(lpcfg_do_service_parameter)
авг 03 23:05:38 Home-PC smbd[14290]: Global parameter map to guest found in service section!
авг 03 23:05:38 Home-PC smbd[14290]: [2018/08/03 23:05:38.492406, 0] ../lib/param/loadparm.c:1862(lpcfg_do_service_parameter)
авг 03 23:05:38 Home-PC smbd[14290]: Global parameter usershare allow guests found in service section!
$ sudo service nmbd status
● nmbd.service - Samba NMB Daemon
Loaded: loaded (/lib/systemd/system/nmbd.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2018-08-03 10:43:57 +08; 12h ago
Docs: man:nmbd(8)
man:samba(7)
man:smb.conf(5)
Main PID: 2235 (nmbd)
Status: "nmbd: ready to serve connections..."
Tasks: 2 (limit: 4915)
CGroup: /system.slice/nmbd.service
├─2235 /usr/sbin/nmbd --foreground --no-process-group
└─2545 /usr/sbin/nmbd --foreground --no-process-group
авг 03 10:44:12 Home-PC nmbd[2235]:
авг 03 10:44:12 Home-PC nmbd[2235]: Samba server LINUX-PC is now a domain master browser for workgroup WORKGROUP on subnet 192.168.2.4
авг 03 10:44:12 Home-PC nmbd[2235]: *****
авг 03 10:44:20 Home-PC nmbd[2235]: [2018/08/03 10:44:20.034571, 0] ../source3/nmbd/nmbd_become_lmb.c:397(become_local_master_stage2)
авг 03 10:44:20 Home-PC nmbd[2235]: *****
авг 03 10:44:20 Home-PC nmbd[2235]: Samba name server LINUX-PC is now a local master browser for workgroup WORKGROUP on subnet 192.168.2.4
client max protocol = NT1 - был прописан до создания "Темы"
порт 5353 в брэндмауэрах Windows 7 открыт
"Зри в корень!"
hitkliv
03 авг 2018, 18:24
$ sudo nbtscan 192.168.2.0/24
Doing NBT name scan for addresses from 192.168.2.0/24
IP address NetBIOS Name Server User MAC address
192.168.2.0 Sendto failed: Permission denied
192.168.2.4 LINUX-PC <server> HOME-PC 00:00:00:00:00:00
192.168.2.5 XP32_PC <server> <unknown> xx:xx:xx:xx:xx:xx
192.168.2.3 WIN7 <server> <unknown> xx:xx:xx:xx:xx:xx
192.168.2.255 Sendto failed: Permission denied
"Зри в корень!"
03 авг 2018, 18:27
hitkliv писал(а):
03 авг 2018, 18:24
192.168.2.255
255 вроде как адрес для широковещательных пакетов, которые идут всем и отбрасываются обычно всеми
hitkliv
03 авг 2018, 18:34
Иногда, "Под настроение", Виндовая станция, может пару-тройку раз, запросить пароль.... :hoho:
"Зри в корень!"
03 авг 2018, 18:36
А вы пробовали писать в саппорт Microsoft?
hitkliv
03 авг 2018, 18:48
в логах, везде такая последовательность повторяется
log.192.168.2.3 (WIN7)
[2018/08/03 16:52:51.276598, 0] ../lib/param/loadparm.c:1862(lpcfg_do_service_parameter)
"Зри в корень!"
hitkliv
03 авг 2018, 19:31
zuzabrik писал(а):
03 авг 2018, 18:36
А поможет? :joke:
"Зри в корень!"
Благодарил (а): 54 раза
03 авг 2018, 19:47
hitkliv писал(а):
03 авг 2018, 18:20
Возможный корень проблемы с обращением из линукса к семерке. После прошлогодних патчей на "петю" с компанией, Win7 вообще не принимает обращений по протоколу SMB1. А вот XP - принимает, т.к. другого не умеет.
Bill Williamson
Решено: 34
03 авг 2018, 22:28
hitkliv писал(а):
03 авг 2018, 17:50
Это хорошо - работать можно. Дальше можно попробовать подключиться с Windows на Windows, потом пройтись по всем настройкам в Windows 7: антивирус, брандмауэр, локальные политики... Где-то еще советуют убрать Гостя в тех же локальных политиках.
hitkliv
05 авг 2018, 21:09
Снес все нафиг! С purge...
cifs-utils*
fusesmb*
gvfs-backends*
libnss-winbind*
libsmbclient*
pyneighborhood*
python-samba*
samba-common*
samba common-bin*
samba-libs*
samba-testsuite*
smbc*
smbclient*
smbnetfs*
winbind*
xmms2-plugin-smb*
xmms2-core
gvfs:i386*
gvfs*
gvfs-bin*
gvfs-common*
gvfs-daemons*
gvfs-fuse*
gvfs-libs*
gvfs-libs:i386*
И снова накатил в такой последовательности:
$ sudo apt-get install gvfs
gvfs
gvfs-common
gvfs-daemons
gvfs-libs
$ sudo apt-get install gvfs-fuse
gvfs-fuse
$ sudo apt-get install gvfs-backends
gvfs-backends
libsmbclient
samba-libs
$ sudo apt-get install winbind
python-samba
samba-common
samba-common-bin
winbind
Предлагаемые (не ставил):
python-gpgme
heimdal-clients
libnss-winbind
libpam-winbind
$ sudo apt-get install samba
samba libcephfs2 samba-dsdb-modules samba-vfs-modules
Предлагаемые(не ставил):
bind9 bind9utils ctdb ldb-tools smbldap-tools
При установке, samba выругалась не по русски:
Samba is not being run as an AD Domain Controller, masking samba-ad-dc.service.
Please ignore the following error about deb-systemd-helper not finding samba-ad-dc.service.
Created symlink /etc/systemd/system/multi-user.target.wants/nmbd.service → /lib/systemd/system/nmbd.service.
Failed to preset unit: Unit file /etc/systemd/system/samba-ad-dc.service is masked.
/usr/bin/deb-systemd-helper: error: systemctl preset failed on samba-ad-dc.service: No such file or directory
Created symlink /etc/systemd/system/multi-user.target.wants/smbd.service → /lib/systemd/system/smbd.service.
Ну, и в итоге,
#[global]
dos charset = cp866
unix charset = utf8
; realm = WORKGROUP
netbios name = Linux-PC
server string = %h
wins support = true
interfaces = 192.168.2.4/24 enp3s0
; nbt client socket address = 192.168.2.4
hosts allow = 192.168.2.0/24
; ntlm auth = yes
; null passwords = yes
; map to guest = Bad Password
max log size = 1024
max xmit = 65536
# syslog only = no
; syslog = 0
deadtime = 15
local master = true
os level = 65
security = user
guest ok = yes
[Public]
comment = Public
writeable = yes
browsable = yes
guest ok = no
dns proxy = no
valid users =user, guest, smbguest, user1, Гость
[Folder]
comment = Public
path = /mnt/DATA/Folder/
writeable = yes
browsable = yes
guest ok = no
dns proxy = no
[printers]
browseable = no
printable = yes
create mask = 0700
[print$]
writeable = yes
$ cat /etc/samba/smbusers
user = user
user1 = user1
smbguest = smbguest
nobody = nobody
И че-то все заработало!!! Станции все видны... И 7 и XP и Linux.... И шАры везде монтируются!!!
Ни чего, так и не понял... Но, работает!!!
:magic: :magic: :magic:
"Зри в корень!"
Вернуться в «Работа с сетью»
Сейчас этот форум просматривают: нет зарегистрированных пользователей и 33 гостя
