Kernel: 4.15.0-29-generic x86_64 bits: 64 gcc: 7.3.0 Desktop: MATE 1.20.1 (Gtk 2.24.32) Distro: Linux Mint 19 Tara Machine: Device: laptop System: Acer product: Aspire 5742Z v: V1.19 serial: <filter> Mobo: Acer model: Aspire 5742Z v: V1.19 serial: N/A BIOS: Acer v: V1.19 date: 04/01/2011 Battery BAT0: charge: 31.0 Wh 100.0% condition: 31.0/47.5 Wh (65%) model: SANYO Li_Ion_4000mA status: Full CPU: Dual core Intel Pentium P6200 (-MCP-) arch: Nehalem rev.5 cache: 3072 KB flags: (lm nx sse sse2 sse3 ssse3) bmips: 8512 clock speeds: max: 2133 MHz 1: 1014 MHz 2: 950 MHz Graphics: Card: Intel Core Processor Integrated Graphics Controller bus-ID: 00:02.0 Display Server: X.Org 1.19.6 drivers: modesetting (unloaded: fbdev,vesa) Resolution: 1366x768@60.01hz OpenGL: renderer: Mesa DRI Intel Ironlake Mobile version: 2.1 Mesa 18.0.5 Direct Render: Yes Audio: Card Intel 5 Series/3400 Series High Def. Audio driver: snd_hda_intel bus-ID: 00:1b.0 Sound: Advanced Linux Sound Architecture v: k4.15.0-29-generic Network: Card-1: Broadcom Limited NetLink BCM57780 Gigabit Ethernet PCIe driver: tg3 v: 3.137 bus-ID: 01:00.0 IF: enp1s0 state: down mac: <filter> Card-2: Qualcomm Atheros AR9285 Wireless Network Adapter (PCI-Express) driver: ath9k bus-ID: 02:00.0 IF: wlp2s0 state: up mac: <filter> Drives: HDD Total Size: 320.1GB (23.4% used) ID-1: /dev/sda model: WDC_WD3200BPVT size: 320.1GB temp: 38C Partition: ID-1: / size: 290G used: 66G (24%) fs: ext4 dev: /dev/dm-0 ID-2: /boot size: 472M used: 335M (75%) fs: ext2 dev: /dev/sda1 ID-3: swap-1 size: 3.95GB used: 0.60GB (15%) fs: swap dev: /dev/dm-1 RAID: No RAID devices: /proc/mdstat, md_mod kernel module present Sensors: System Temperatures: cpu: 47.0C mobo: N/A Fan Speeds (in rpm): cpu: N/A Info: Processes: 212 Uptime: 13:26 Memory: 2214.1/3619.5MB Init: systemd runlevel: 5 Gcc sys: 7.3.0 Client: Shell (bash 4.4.191) inxi: 2.3.56
Bitmask для Linux
Автор темы - Сообщения: 150
Bitmask для Linux
LM 19 MATE x64
не получается установить данную программу, подскажите в чём затык, взял отсюда
- Решено: 20
Bitmask для Linux
ЛМ 19 собран на базе Убунту 18.04, которого нет в списке.
Можешь попробовать "установить из архива" как описано в самом низу страницы.
Вообще не помешало бы описание того как ты пытаешься установить и что при этом пишет в терминале.
Bitmask для Linux
скачиваю архив 64-битную версию (Bitmask-linux64-latest.tar.gz) - распаковываю туда же где архив- захожу в папку ( bitmask-0.10.2) там две папки и три файла, выбираю файл bitsmak и кликаю на него, но нет реакции
- Решено: 20
Bitmask для Linux
Проверь что файл имеет права на исполнение.
Чтобы сделать это в терминале открой его (Ctrl+Alt+T)
перейди в нужную папку (cd ~/имятвоейпапки) где имятвоейпапки это имя твоей папки где лежит распакованный архив в твоей домашней директории.
проверь права доступа (ls -Al)
- Решено: 20
Bitmask для Linux
а на саму прогу в папке? должно быть -rwxr-xr-x
если с правами на файл все ок перейди в нужную папку где лежит прога
cd /путь/до/проги
и запусти ее
./bitmask
все что вывалит в терминал покажи тут, если проге чета не по вкусу она начнет ругаться в терминал.
Bitmask для Linux
права на исполнение есть, не получается дальше Загрузки прописать, говорит нет такого, папка лежит в Загрузки/программы/bitmask -0.10.2/bitmask
- Решено: 20
Bitmask для Linux
cd ~/Загрузки/программы/bitmask-0.10.2
./bitmask
- Решено: 20
Bitmask для Linux
Отредактировал свой пост выше. у тебя там после bitmaks стоял пробел перед тире. отсюда возможно проблемы с тем что не понимает куда ты хочешь попасть. пробел или убери в названии папки (если он конечно есть) или экранируй таким образом:
cd ~/Загрузки/программы/bitmask\ -0.10.2
Bitmask для Linux
[+] launching bitmaskd...
Another twistd server is running, PID 32412
This could either be a previously started instance of your application or a
different application entirely. To start a new one, either run it in some other
directory, or use the --pidfile and --logfile parameters to avoid clashes.
ERROR: No authentication token found!
- Решено: 20
Bitmask для Linux
Приложение жалуется что одна из копий уже запущена. Посмотри в трее не висит ли иконка твоего приложения.
Можешь прбить приложение по тому номеру что дал тебе жалующийся экземпляр. Для этого просто набери в консоли
kill 32412
Это прикончит процесс с этим номером, на который жалуется тот что ты пытаешься запустить. И пробуй запускать снова.
kill 32412
- Решено: 20
Bitmask для Linux
Опять же показывай выхлоп терминала. При всем уважении я не хочу там еще и регистрироваться ради проверки работоспособности
Bitmask для Linux
/usr/lib/x86_64-linux-gnu/gstreamer1.0/gstreamer-1.0/gst-plugin-scanner: symbol lookup error: /usr/lib/x86_64-linux-gnu/gstreamer1.0/gstreamer-1.0/gst-plugin-scanner: undefined symbol: _gst_executable_path
(bitmask:20199): GStreamer-WARNING **: External plugin loader failed. This most likely means that the plugin loader helper binary was not found or could not be run. You might need to set the GST_PLUGIN_SCANNER environment variable if your setup is unusual. This should normally not be required though.
(bitmask:20199): GStreamer-WARNING **: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstaudiomixmatrix.so': /usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstaudiomixmatrix.so: undefined symbol: gst_param_spec_array
(bitmask:20199): GStreamer-WARNING **: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstopenglmixers.so': /usr/lib/x86_64-linux-gnu/libgstbadvideo-1.0.so.0: undefined symbol: gst_aggregator_pad_pop_buffer
(bitmask:20199): GStreamer-WARNING **: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstlibav.so': /home/ramazan/Загрузки/программы/bitmask-0.10.2/lib/libz.so.1: version `ZLIB_1.2.9' not found (required by /usr/lib/x86_64-linux-gnu/libpng16.so.16)
(bitmask:20199): GStreamer-WARNING **: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgsthls.so': /usr/lib/x86_64-linux-gnu/libgstadaptivedemux-1.0.so.0: undefined symbol: gst_message_parse_error_details
(bitmask:20199): GStreamer-WARNING **: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstaudiomixer.so': /usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstaudiomixer.so: undefined symbol: gst_audio_aggregator_convert_pad_get_type
Ошибка сегментирования (стек памяти сброшен на диск)
- Решено: 20
Bitmask для Linux
Есть подозрение что это связано с нехваткой пакетов libqt5gstreamer-1.0-0 и libqtgstreamer-1.0-0
В консоли набери команду:
sudo apt-get install libqt5gstreamer libqtgstreamer
Если все установится, пробуй еще раз запускать свое приложение и если будут пробелмы снова показывай выхлоп консоли.
- Решено: 216
Bitmask для Linux
r33, есть он там,
▶ apt policy libqt5gstreamer-1.0-0
libqt5gstreamer-1.0-0:
Установлен: (отсутствует)
Кандидат: 1.2.0-5
Таблица версий:
1.2.0-5 500
500 http://mirror.logol.ru/ubuntu bionic/universe amd64 Packages
Bitmask для Linux
я и не спорю, это мне терминал говорит, что не найден, хотя пишет, что установленChocobo писал(а): ↑03 авг 2018, 05:46r33, есть он там,libqt5gstreamer-1.0-0
)Код: Выделить всё
▶ apt policy libqt5gstreamer-1.0-0 libqt5gstreamer-1.0-0: Установлен: (отсутствует) Кандидат: 1.2.0-5 Таблица версий: 1.2.0-5 500 500 http://mirror.logol.ru/ubuntu bionic/universe amd64 Packages
Установлен: 1.2.0-5
Кандидат: 1.2.0-5
Таблица версий:
*** 1.2.0-5 500
500 http://archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
100 /var/lib/dpkg/status
ramazan@ramazan-Aspire-5742Z ~ $ sudo apt-get install libqt5gstreamer
[sudo] пароль для ramazan:
E: Не удалось найти пакет libqt5gstreamer
Установлен: 1.2.0-5
Кандидат: 1.2.0-5
Таблица версий:
*** 1.2.0-5 500
