System: Host: ramazan-Aspire-5742Z Kernel: 4.15.0-24-generic x86_64 bits: 64 gcc: 7.3.0 Desktop: MATE 1.20.1 (Gtk 2.24.32) Distro: Linux Mint 19 Tara Machine: Device: laptop System: Acer product: Aspire 5742Z v: V1.19 serial: N/A Mobo: Acer model: Aspire 5742Z v: V1.19 serial: N/A BIOS: Acer v: V1.19 date: 04/01/2011 Battery BAT0: charge: 31.4 Wh 100.0% condition: 31.4/47.5 Wh (66%) model: SANYO Li_Ion_4000mA status: Full CPU: Dual core Intel Pentium P6200 (-MCP-) arch: Nehalem rev.5 cache: 3072 KB flags: (lm nx sse sse2 sse3 ssse3) bmips: 8511 clock speeds: max: 2133 MHz 1: 1015 MHz 2: 949 MHz Graphics: Card: Intel Core Processor Integrated Graphics Controller bus-ID: 00:02.0 Display Server: x11 (X.Org 1.19.6 ) drivers: modesetting (unloaded: fbdev,vesa) Resolution: 1366x768@60.01hz OpenGL: renderer: N/A version: N/A Direct Render: N/A Audio: Card Intel 5 Series/3400 Series High Def. Audio driver: snd_hda_intel bus-ID: 00:1b.0 Sound: Advanced Linux Sound Architecture v: k4.15.0-24-generic Network: Card-1: Broadcom Limited NetLink BCM57780 Gigabit Ethernet PCIe driver: tg3 v: 3.137 bus-ID: 01:00.0 IF: enp1s0 state: down mac: <filter> Card-2: Qualcomm Atheros AR9285 Wireless Network Adapter (PCI-Express) driver: ath9k bus-ID: 02:00.0 IF: wlp2s0 state: up mac: <filter> Drives: HDD Total Size: 320.1GB (27.1% used) ID-1: /dev/sda model: WDC_WD3200BPVT size: 320.1GB Partition: ID-1: / size: 290G used: 77G (29%) fs: ext4 dev: /dev/dm-0 ID-2: /boot size: 472M used: 265M (60%) fs: ext2 dev: /dev/sda1 ID-3: swap-1 size: 3.95GB used: 0.00GB (0%) fs: swap dev: /dev/dm-1 RAID: No RAID devices: /proc/mdstat, md_mod kernel module present Sensors: System Temperatures: cpu: 47.0C mobo: N/A Fan Speeds (in rpm): cpu: N/A Info: Processes: 189 Uptime: 5:34 Memory: 2350.8/3619.5MB Init: systemd runlevel: 5 Gcc sys: 7.3.0 Client: Shell (bash 4.4.191) inxi: 2.3.56 ramazan@ramazan-Aspire-5742Z ~ $
Репозитории
Автор темы - Сообщения: 150
Репозитории
LM 19 MATE x64 Не удаётся добавить PPA: «'Данный PPA не поддерживает bionic'».
Решение
Не надо. Если уж очень хочется - можно попробовать вытащить отдельно пакеты руками, и ставить через dpkg, отдельно. А пытаться системе насильно впихнуть левые ppa/репозитории - хороший способ устроить пакетную кашу, и доиграться до полной переустановки всего.
Репозитории
Репозитории
здравствуйте я по то муже вопросу что выше был указан Не удаётся добавить PPA: «'Данный PPA не поддерживает bionic
Я ночевок пользуюсь Линуксом 1 неделю. Пытаюсь установить программы для системы такие как PSENSOR и grub customizer но не чего не получается выдает ошибку. Как быть? Или есть вариант установить как то эти программы по другому. Подскажите пожалуйста. Только пишите так чтобы было понятно полному профану тоесть мне.
Репозитории
PSENSOR: https://gitlab.com/jeanfi/psensor
Установка grub customizer: https://losst.ru/ustanovka-grub-customi ... untu-18-04
Репозитории
Зачем добавлять PPA? Он в официальном хранилище находится. Насчет Grub Customizer, читайте тут. Удачи.
Репозитории
AlexelA, Большое спс AlexelA ты очень помог. Я вот только не понял, а почему у меня нечего не получалось все дело в ядре? Просто я хочу понять сам linux
Репозитории
Нет, не в ядре. Фигурально выражаясь, ты пытался детали от мерседеса ставить на тойоту.
Дистрибутив - это не только ядро, но и определенные версии библиотек, которые нужны друг-другу и программам тоже. В ppa и прочих репозиториях, программы собирают и кладут в расчете на определенное окружение этих компонентов, которое, собственно и является дистрибутивом.
- Решено: 17
Репозитории
Вот ещё 2 книжки в архивах и в ссылках на скачивание
https://cloud.mail.ru/public/8Cen/WfxFw8PMR
https://cloud.mail.ru/public/JdcX/qeHK6TWzD
- Вложения
- А.В. Федорчук Linux Mint и его Cinnamon.tar.gz
- (435.18 КБ) 96 скачиваний
- А.В. Федорчук Linux Mint и его Cinnamon.rar
- (435.15 КБ) 88 скачиваний
