LinuxMint 19 и видеокарта Intel HD Graphics 520
28 июн 2018, 18:59
Вот поставив LinuxMint 19 стал наблюдать такое
inxi -G
Graphics:  Card: Intel HD Graphics 520
           Display Server: x11 (X.Org 1.19.6 ) drivers: modesetting (unloaded: fbdev,vesa)
           Resolution: 1366x768@60.01hz
           OpenGL: renderer: Mesa DRI Intel HD Graphics 520 (Skylake GT2) version: 4.5 Mesa 18.0.0-rc5
Вот так это выглядело на 18.3
Graphics:  Card: Intel Sky Lake Integrated Graphics bus-ID: 00:02.0
           GLX Renderer: Mesa DRI Intel HD Graphics 520 (Skylake GT2)
           GLX Version: 3.0 Mesa 17.2.8 Direct Rendering: Yes
Вопрос: почему drivers: modesetting и как сделать чтоб таки был драйвер intel?
System:    Host: darkfenix Kernel: 4.15.0-23-generic x86_64 bits: 64 gcc: 7.3.0
           Desktop: Cinnamon 3.8.6 (Gtk 3.22.30-1ubuntu1) Distro: Linux Mint 19 Tara
Machine:   Device: laptop System: Acer product: Aspire V3-372 v: V1.12 serial: N/A
           Mobo: Acer model: Aspire V3-372 v: V1.12 serial: N/A UEFI: Insyde v: V1.12 date: 02/23/2017
Battery    BAT0: charge: 45.5 Wh 100.0% condition: 45.5/48.9 Wh (93%) model: LGC AC14B8K status: Discharging
CPU:       Dual core Intel Core i5-6200U (-MT-MCP-) arch: Skylake rev.3 cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 9600
           clock speeds: max: 2800 MHz 1: 500 MHz 2: 500 MHz 3: 500 MHz 4: 500 MHz
Graphics:  Card: Intel HD Graphics 520 bus-ID: 00:02.0
           version: 4.5 Mesa 18.0.0-rc5 Direct Render: Yes
Audio:     Card Intel Sunrise Point-LP HD Audio driver: snd_hda_intel bus-ID: 00:1f.3
           Sound: Advanced Linux Sound Architecture v: k4.15.0-23-generic
Network:   Card-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
           driver: r8169 v: 2.3LK-NAPI port: 3000 bus-ID: 02:00.0
           Card-2: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter driver: ath10k_pci bus-ID: 03:00.0
Drives:    HDD Total Size: 1000.2GB (26.4% used)
           ID-1: /dev/sda model: WDC_WD10SPCX size: 1000.2GB
Partition: ID-1: / size: 48G used: 6.4G (14%) fs: ext4 dev: /dev/sda3
           ID-2: /home size: 481G used: 225G (50%) fs: ext4 dev: /dev/sda4
           ID-3: swap-1 size: 16.78GB used: 0.00GB (0%) fs: swap dev: /dev/sda2
Sensors:   System Temperatures: cpu: 57.0C mobo: 51.0C
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 203 Uptime: 10 min Memory: 1763.4/7872.8MB Init: systemd runlevel: 5 Gcc sys: 7.3.0
           Client: Shell (zsh 5.4.2) inxi: 2.3.56
aulon
Благодарил (а): 37 раз
28 июн 2018, 19:01
Не пойму, в чём разница
$ inxi -G
Resolution: 1920x1080@60.01hz
Выпуск Linux Mint 20 Ulyana 64-разрядный MATE 1.24.0
Процессор Intel® Core™ i3-6006U CPU @ 2.00GHz × 4 Память 7,6 GiB
aulon
28 июн 2018, 19:02
А, вроде врубился. Нужно чтобы именно Intel было?
28 июн 2018, 19:03
aulon писал(а):
28 июн 2018, 19:02
да
aulon
28 июн 2018, 19:04
Ну шестерёнки нормально крутятся, не похоже на vesa.
28 июн 2018, 19:05
darkfenix, в lspci -k что скажет касаемо модулей активных и доступных под VGA адаптер?
aulon
28 июн 2018, 19:06
$ lspci -k
00:00.0 Host bridge: Intel Corporation Skylake Host Bridge/DRAM Registers (rev 08)
Subsystem: Acer Incorporated [ALI] Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Host Bridge/DRAM Registers
Kernel driver in use: skl_uncore
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 520 (rev 07)
Subsystem: Acer Incorporated [ALI] Skylake GT2 [HD Graphics 520]
Kernel driver in use: i915
Kernel modules: i915
28 июн 2018, 19:09
00:14.0 USB controller: Intel Corporation Sunrise Point-LP USB 3.0 xHCI Controller (rev 21)
	Subsystem: Acer Incorporated [ALI] Sunrise Point-LP USB 3.0 xHCI Controller
	Kernel driver in use: xhci_hcd
00:14.2 Signal processing controller: Intel Corporation Sunrise Point-LP Thermal subsystem (rev 21)
	Subsystem: Acer Incorporated [ALI] Sunrise Point-LP Thermal subsystem
	Kernel driver in use: intel_pch_thermal
	Kernel modules: intel_pch_thermal
00:15.0 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO I2C Controller #0 (rev 21)
	Subsystem: Acer Incorporated [ALI] Sunrise Point-LP Serial IO I2C Controller
	Kernel driver in use: intel-lpss
	Kernel modules: intel_lpss_pci
00:15.1 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO I2C Controller #1 (rev 21)
00:16.0 Communication controller: Intel Corporation Sunrise Point-LP CSME HECI #1 (rev 21)
	Subsystem: Acer Incorporated [ALI] Sunrise Point-LP CSME HECI
	Kernel driver in use: mei_me
	Kernel modules: mei_me
00:17.0 SATA controller: Intel Corporation Sunrise Point-LP SATA Controller [AHCI mode] (rev 21)
	Subsystem: Acer Incorporated [ALI] Sunrise Point-LP SATA Controller [AHCI mode]
	Kernel driver in use: ahci
	Kernel modules: ahci
00:1c.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port (rev f1)
	Kernel driver in use: pcieport
	Kernel modules: shpchp
00:1c.4 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #5 (rev f1)
00:1c.5 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #6 (rev f1)
00:1f.0 ISA bridge: Intel Corporation Sunrise Point-LP LPC Controller (rev 21)
	Subsystem: Acer Incorporated [ALI] Sunrise Point-LP LPC Controller
00:1f.2 Memory controller: Intel Corporation Sunrise Point-LP PMC (rev 21)
	Subsystem: Acer Incorporated [ALI] Sunrise Point-LP PMC
00:1f.3 Audio device: Intel Corporation Sunrise Point-LP HD Audio (rev 21)
	Subsystem: Acer Incorporated [ALI] Sunrise Point-LP HD Audio
	Kernel driver in use: snd_hda_intel
	Kernel modules: snd_hda_intel, snd_soc_skl
00:1f.4 SMBus: Intel Corporation Sunrise Point-LP SMBus (rev 21)
	Subsystem: Acer Incorporated [ALI] Sunrise Point-LP SMBus
	Kernel modules: i2c_i801
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
	Subsystem: Acer Incorporated [ALI] RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
	Kernel driver in use: r8169
	Kernel modules: r8169
03:00.0 Network controller: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter (rev 32)
	Subsystem: Foxconn International, Inc. QCA6174 802.11ac Wireless Network Adapter
	Kernel driver in use: ath10k_pci
	Kernel modules: ath10k_pci
Вижу только это
aulon
28 июн 2018, 19:10
Ну так i915 всегда и было, уже много лет. Это и есть драйвер интел.
28 июн 2018, 19:13
darkfenix, ченть сменилось в логике самой inxi или значения того поля которое она хватала.
Засвети пробу или отдельно лог Xorg - там явно видно что подцепилось при старте иксов.
28 июн 2018, 19:18
28 июн 2018, 19:23
И сам пакет, кстати - xorg-driver-video-intel установлен?)
28 июн 2018, 19:26
28 июн 2018, 19:23
Такого пакета нету в репах. Но есть пакет xserver-xorg-video-intel и он установлен
28 июн 2018, 19:29
На 18.3 у себя наблюдаю прост такую вот последовательность для интелов
[     4.408] (II) LoadModule: "intel"
[     4.408] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[     4.411] (II) Module intel: vendor="X.Org Foundation"
[     4.411]    compiled for 1.18.4, module version = 2.99.917
[     4.411]    Module class: X.Org Video Driver
[     4.411]    ABI class: X.Org Video Driver, version 20.0
[     4.411] (II) LoadModule: "modesetting"
[     4.411] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[     4.411] (II) Module modesetting: vendor="X.Org Foundation"
[     4.411]    compiled for 1.18.4, module version = 1.18.4
и собсно принадлежность файлика:
htpc@htpc ~ $ dpkg -S /usr/lib/xorg/modules/drivers/intel_drv.so
xserver-xorg-video-intel: /usr/lib/xorg/modules/drivers/intel_drv.so
У тебя чуть иначе, он нигде пока не нарисовался, intel_drv.so
28 июн 2018, 19:26
Да, я не тот копирнул)
Давай тогда посмотрим что у него внутри чтоль, где ж эта .so-шка)
28 июн 2018, 19:34
28 июн 2018, 19:29
где ж эта .so-шка
Вот она
ls -1a /usr/lib/xorg/modules/drivers/
amdgpu_drv.so
ati_drv.so
fbdev_drv.so
intel_drv.so
modesetting_drv.so
nouveau_drv.so
qxl_drv.so
radeon_drv.so
vesa_drv.so
vmware_drv.so
Ну и принадлежность
28 июн 2018, 19:51
darkfenix, Вот пока че нашел
https://wiki.archlinux.org/index.php/intel_graphics
Note: Some (Debian & Ubuntu, Fedora, KDE) recommend not installing the xf86-video-intel driver, and instead falling back on the modesetting driver for fourth generation and newer GPUs
А четвертое поколение и выше - это начиная с
List of Intel graphics processing units: Fourth generation
28 июн 2018, 20:17
28 июн 2018, 19:51
Свою нашел в 9 поколении.
Из арчивики переходами наткнулся вот на такой тест.
Так что думаю можно оставить все как есть - все норм работает. Просто странно было увидеть что-то другое вместо привычного intel
Вот еще что нашел 1 и 2. Похоже было ожидаемо что мы увидим использование modesetting вместо intel
28 июн 2018, 21:00
28 июн 2018, 20:17
Вот еще что нашел 1
Ну да, статья спустя три месяца после 16.04, следовательно в 18-й минт попасть не успело,
убунтоиды могли видеть в последующих промежуточных выпусках, а нас настигло уже на базе нового лтс под 19-й релиз)
29 июн 2018, 06:01
Думаю на этом можно тему закрыть. Выяснили что все это значит и как с этим жить.
Закрываю. :close:
Вернуться в «Видеокарты»
