Не работает блютуз acer2511g LM 18.3 x64 Cinnamon
zews81
12 июн 2018, 13:31
Не работает блютуз acer2511g один в один как в этой теме https://toster.ru/q/426196
System:    Host: dima-Extensa-2511G Kernel: 4.13.0-43-generic x86_64 (64 bit gcc: 5.4.0)
           Desktop: Cinnamon 3.6.7 (Gtk 3.18.9-1ubuntu3.3) Distro: Linux Mint 18.3 Sylvia
Machine:   System: Acer product: Extensa 2511G v: V3.72
           Mobo: Acer model: BA50_BH v: Type2 - A01 Board Version Bios: Insyde v: V1.37 date: 02/16/2016
CPU:       Dual core Intel Core i3-5005U (-HT-MCP-) cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 8000
           clock speeds: max: 1900 MHz 1: 973 MHz 2: 1117 MHz 3: 913 MHz 4: 1146 MHz
Graphics:  Card-1: Intel Broadwell-U Integrated Graphics bus-ID: 00:02.0
           Card-2: NVIDIA GM108M [GeForce 940M] bus-ID: 04:00.0
           Display Server: X.Org 1.18.4 drivers: intel (unloaded: fbdev,vesa) Resolution: 1366x768@60.00hz
           GLX Renderer: Mesa DRI Intel HD Graphics 5500 (Broadwell GT2)
           GLX Version: 3.0 Mesa 17.2.8 Direct Rendering: Yes
Audio:     Card-1 Intel Wildcat Point-LP High Definition Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0
           Card-2 Intel Broadwell-U Audio Controller driver: snd_hda_intel bus-ID: 00:03.0
           Sound: Advanced Linux Sound Architecture v: k4.13.0-43-generic
Network:   Card-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
           driver: r8169 v: 2.3LK-NAPI port: 4000 bus-ID: 02:00.0
           Card-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter driver: ath9k bus-ID: 03:00.0
Drives:    HDD Total Size: 628.1GB (17.6% used) ID-1: /dev/sda model: ADATA_SP900 size: 128.0GB
           ID-2: /dev/sdb model: WDC_WD5000LPCX size: 500.1GB
Partition: ID-1: / size: 36G used: 12G (35%) fs: ext4 dev: /dev/sda5
           ID-2: /home size: 92G used: 85G (98%) fs: ext4 dev: /dev/sdb3
           ID-3: swap-1 size: 7.00GB used: 0.00GB (0%) fs: swap dev: /dev/sdb2
Sensors:   System Temperatures: cpu: 46.0C mobo: N/A
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 255 Uptime: 3:20 Memory: 3250.6/11923.7MB Init: systemd runlevel: 5 Gcc sys: 5.4.0
Последний раз редактировалось пользователем 2 Dja; всего редактировалось раз: 13
Причина: BB-codes
zews81
12 июн 2018, 13:33
Помогите добрые люди))) А то мышкой приходится пользоваться через свисток :blush:
zews81
12 июн 2018, 16:16
13 июн 2018, 11:36
zews81 писал(а):
12 июн 2018, 13:33
А можно как-то иначе мышкой пользоваться?
zews81
13 июн 2018, 12:29
:blush:
Последний раз редактировалось пользователем 1 zews81; всего редактировалось раз: 13
zews81
13 июн 2018, 12:31
Dja писал(а):
13 июн 2018, 11:36
zews81 писал(а):
12 июн 2018, 13:33
У меня мышка Xiaomi может работать как через вайфай свисток, так и через блютуз. На вин 10 встроенный блютуз работает с коробки и без нареканий, а на линукс (deepen 15.5, ubuntu 16.04 и 18.04, дебиан, линукс минт 18.4, пробовал на бэтке то-же самое), что то совсем его не видно. Ну и хотелось бы освободить усб разьем, который теперь постоянно занят свистком))
13 июн 2018, 12:36
она у вас есть
Полагаю надо обратиться к мануалу и глянуть как ее задействовать. Т.е. видимо как блютус-гарнитуру - нажать заветные кнопки, зайти в манеджер блю-устройств и там и там сделать какие-то действия и будет счастье.
13 июн 2018, 12:44
Dja писал(а):
13 июн 2018, 12:36
она у вас есть
Это как раз свисток от мышки
13 июн 2018, 12:46
А чего тогда не в режиме working?
darkfenix, судя по https://linux-hardware.org/index.php?pr ... g=boot.log вообще получается что блютус либо отсутствует либо отключен механически.
zews81
13 июн 2018, 13:38
Второй осью стоит WIN 10 перезагружаюсь в нее, блютуз работает без нареканий. Заходим в линукс "Адаптеры блютуз не обнаружены".
zews81
13 июн 2018, 13:46
Dja писал(а):
13 июн 2018, 12:46
Ну отсутствовать он не может, на 10 ке же работает. Грешил на UEFI может он, что не корректно передает? Перешел на MBR в Live режиме и - песня таже поет она же. Блютуз адаптеры не обнаружены.
13 июн 2018, 13:48
zews81, т.е. таки он так и пишет, что не обнаружено?
zews81
13 июн 2018, 13:51
Ну да так и пишет
zews81
13 июн 2018, 13:55
Dja писал(а):
13 июн 2018, 13:48
Ну да так и пишет
13 июн 2018, 13:55
а в настройках что?
zews81
13 июн 2018, 13:59
Извиняюсь Dja, , но почему то не могу вам сразу ответить цитатой, только после сообщения появляется такая возможность.
13 июн 2018, 14:01
А в менеджере драйверов что? И видит ли его VirtualBox?
zews81
13 июн 2018, 14:05
Виртуал бокс его тоже не видит, а в менеджере все норм, не установленных устройств не обнаружено
13 июн 2018, 14:47
zews81 писал(а):
13 июн 2018, 14:05
А как вы это поняли?
zews81
13 июн 2018, 15:09
Запускаю в виртуалке ту же убунту 18.04 ну и там то же самое, что и в линукс минт. Сейчас запускал через ливе манджару, у него по умолчанию адаптер выключен, включаю блютуз, тоже не работает.
