Wifi Broadcom bcm4322
Gremlins
01 июн 2018, 16:57
Здравствуйте, столкнулся с проблемой немогу настроить wifi bcm4322, пробовал все что есть в гугле, вроде бы sta должны автоматом заводится, ан нет ничего не получается может кто подскажет куда копать?
mint@mint ~ $ lspci | grep Broadcom
01:00.0 Network controller: Broadcom Corporation BCM4322 802.11a/b/g/n Wireless LAN Controller (rev 01)
mint@mint ~ $ lspci -vnn | grep 14e4
01:00.0 Network controller [0280]: Broadcom Corporation BCM4322 802.11a/b/g/n Wireless LAN Controller [14e4:432b] (rev 01)
mint@mint ~ $ lspci -nnk | grep -iA2 net
	Subsystem: Dell Wireless 1510 Wireless-N WLAN Mini-Card [1028:000d]
	Kernel driver in use: b43-pci-bridge
02:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller [10ec:8136] (rev 05)
	DeviceName: Realtek PCIe FE Family Controller
	Subsystem: Hewlett-Packard Company RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller [103c:183f]
	Kernel driver in use: r8169
	Kernel modules: r8169
mint@mint ~ $ dmesg | grep b43
[   18.322701] b43-phy0: Broadcom 4322 WLAN found (core revision 16)
[   18.366508] b43-phy0: Found PHY: Analog 8, Type 4 (N), Revision 4
[   18.366535] b43-phy0: Found Radio: Manuf 0x17F, ID 0x2056, Revision 3, Version 0
[   18.386040] b43 ssb0:0: Direct firmware load for b43/ucode16_mimo.fw failed with error -2
[   18.386058] b43 ssb0:0: Direct firmware load for b43/ucode16_mimo.fw failed with error -2
[   18.386080] b43 ssb0:0: Direct firmware load for b43-open/ucode16_mimo.fw failed with error -2
[   18.386092] b43 ssb0:0: Direct firmware load for b43-open/ucode16_mimo.fw failed with error -2
[   18.386093] b43-phy0 ERROR: Firmware file "b43/ucode16_mimo.fw" not found
[   18.386096] b43-phy0 ERROR: Firmware file "b43-open/ucode16_mimo.fw" not found
[   18.386097] b43-phy0 ERROR: You must go to http://wireless.kernel.org/en/users/Drivers/b43#devicefirmware and download the correct firmware for this driver version. Please carefully read all instructions on this website.
mint mint # inxi -Fxz
System:    Host: mint Kernel: 4.10.0-38-generic x86_64 (64 bit gcc: 5.4.0)
           Desktop: Cinnamon 3.6.6 (Gtk 3.18.9-1ubuntu3.3)
Machine:   System: Hewlett-Packard (portable) product: HP Pavilion g6 Notebook PC v: 0884110000385910000610100
           Mobo: Hewlett-Packard model: 183F v: 56.32
           Bios: Insyde v: F.26 date: 06/03/2014
CPU:       Dual core Intel Core i5-3210M (-HT-MCP-) cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 9976
           clock speeds: max: 3100 MHz 1: 2239 MHz 2: 1256 MHz 3: 3066 MHz
           4: 2620 MHz
Graphics:  Card: Intel 3rd Gen Core processor Graphics Controller
           bus-ID: 00:02.0
           Display Server: X.org 1.18.4 drivers: intel (unloaded: fbdev,vesa)
           tty size: 80x24 Advanced Data: N/A for root
Audio:     Card Intel 7 Series/C210 Series Family High Definition Audio Controller
           Sound: Advanced Linux Sound Architecture v: k4.10.0-38-generic
Network:   Card-1: Broadcom BCM4322 802.11a/b/g/n Wireless LAN Controller
           driver: b43-pci-bridge bus-ID: 01:00.0
           IF: N/A state: N/A mac: N/A
           Card-2: Realtek RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
           driver: r8169 v: 2.3LK-NAPI port: 3000 bus-ID: 02:00.0
Drives:    HDD Total Size: 328.1GB (2.7% used)
           ID-1: /dev/sda model: ST320LM001_HN size: 320.1GB temp: 38C
           ID-2: USB /dev/sdb model: Transcend_8GB size: 8.0GB temp: 0C
Sensors:   System Temperatures: cpu: 47.0C mobo: N/A
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 200 Uptime: 16 min Memory: 958.9/5863.9MB
Решение Gremlins » 11 июн 2018, 23:06
Я нашел причину того что вайфай не устанавливался, оказывается все дело в моем биосе для hp, всем спасибо за участие и помощь
Последний раз редактировалось пользователем 3 rogoznik; всего редактировалось раз: 1
Причина: BBcode
01 июн 2018, 17:14
Gremlins писал(а):
01 июн 2018, 16:57
Вниз.
Внимательно читаем что написано в красном поле вверху страницы и дополняем тему
Gremlins
01 июн 2018, 18:19
LM 18.3 x64 Cinnamon
01 июн 2018, 18:27
А в чём заключается
Gremlins писал(а):
01 июн 2018, 16:57
немогу настроить
Gremlins
01 июн 2018, 18:29
не видит сети, и на ноутбуке не могу переключится с авиарежима в нормальный, перепробывал все что нашел в гугле, вайфай не поднимается
01 июн 2018, 18:35
Gremlins
01 июн 2018, 18:36
darkfenix, Пробовал, не работает
Gremlins
01 июн 2018, 18:37
darkfenix, и через диспетчер драйверов и через терминал, все бесполезно
01 июн 2018, 18:45
Почитай это
01 июн 2018, 18:58
Берём совковую лопату и копаем сюда.
http://help.ubuntu.ru/wiki/broadcom
Gremlins
01 июн 2018, 19:06
А я тут подумал, а может быть конфликт из за того что биос не поддерживает эту карту или конфликтует с ней?
01 июн 2018, 19:32
Gremlins писал(а):
01 июн 2018, 19:06
Чёй то? Не отдельно же вставлял вафлю в железку. Должна работать.
Gremlins
02 июн 2018, 07:12
etamax, Вообще то отдельно, я покупал ее с другой целью, то что хотел сделал, ну а карта так и осталась в ноуте
02 июн 2018, 07:43
Gremlins писал(а):
02 июн 2018, 07:12
Вообще то драйвер нужно для модели карты устанавливать, а не как ты - наобум - может заработает. Если железка не в белом списке вендора, то может и не работать.
Для 14e4:432d нужен bcmwl-kernel-source. Он в менеджере драйверов есть. Только сначала удали b43.
bcmwl-kernel-source - это сам по себе старый проприетарный драйвер, может не ахти работать. Есть дебианская реализация - пакет broadcom-sta, даже dkms есть.
Gremlins
02 июн 2018, 16:35
Unborn, Я эти все варианты перепробовал, бесполезно, а на счет белого списка я покупал для hackintosh вайфай этот и он нормально работал, а в линухе засада какая то :sad: :sad: :sad:
broken
Благодарил (а): 21 раз
03 июн 2018, 23:23
Gremlins писал(а):
02 июн 2018, 16:35
hack
не поминай всуе сабж :hoho: Линух никак не связан с хакерством. Вот и отказывается работать с хакерской примочкой.
04 июн 2018, 00:45
broken писал(а):
03 июн 2018, 23:23
:-D :cray2: :dash2: Ну, офигеть теперь. :)
Вы хоть историю этой системы знаете? А первоначальный смысл слова "хакер"? Поинтересуйтесь однако. :) Линукс был изначально создан хакером для хакеров. В том самом, не искаженном смысле.
broken
04 июн 2018, 09:00
slant, задача операционной системы (любой, а не только linux) - помогать взаимодействовать человеку с программным обеспечением, а никак не подставлять. И если раньше хакер - это было хорошо, то сейчас хакер - это взломщик, противозаконник.
Gremlins
11 июн 2018, 23:06
