Ошибка при добавлении репозитория
dav1d
Благодарил (а): 2 раза
20 май 2018, 14:12
LM 18.3 cinnamon x64,
CPU~Dual core AMD A4-3300M APU with Radeon HD Graphics (-MCP-) speed~1900 MHz (max) Kernel~4.10.0-38-generic x86_64 Up~4:36 Mem~1815.1/3426.0MB HDD~320.1GB(19.2% used) Procs~198 Client~Shell inxi~2.2.35
dav1d@pc ~ $ inxi -Fxz
System: Host: pc Kernel: 4.10.0-38-generic x86_64 (64 bit gcc: 5.4.0)
Machine: Mobo: SAMSUNG model: 305E4A/305E4A v: 00TJ
Bios: American Megatrends v: 00TJ.ME22.20120511.SKK date: 05/11/2012
CPU: Dual core AMD A4-3300M APU with Radeon HD Graphics (-MCP-) cache: 2048 KB
flags: (lm nx sse sse2 sse3 sse4a svm) bmips: 7586
clock speeds: max: 1900 MHz 1: 1900 MHz 2: 1600 MHz
Graphics: Card-1: Advanced Micro Devices [AMD/ATI] Sumo [Radeon HD 6480G]
bus-ID: 00:01.0
Card-2: Advanced Micro Devices [AMD/ATI] Seymour [Radeon HD 6400M/7400M Series]
bus-ID: 02:00.0
Resolution: 1366x768@60.05hz
GLX Renderer: AMD SUMO (DRM 2.49.0 / 4.10.0-38-generic, LLVM 6.0.0)
GLX Version: 3.1 Mesa 18.2.0-devel Direct Rendering: Yes
Audio: Card-1 Advanced Micro Devices [AMD] FCH Azalia Controller
Card-2 Advanced Micro Devices [AMD/ATI] BeaverCreek HDMI Audio [Radeon HD 6500D and 6400G-6600G series]
driver: snd_hda_intel bus-ID: 00:01.1
Sound: Advanced Linux Sound Architecture v: k4.10.0-38-generic
driver: r8169 v: 2.3LK-NAPI port: d000 bus-ID: 03:00.0
Card-2: Qualcomm Atheros AR9485 Wireless Network Adapter
driver: ath9k bus-ID: 05:00.0
IF: wlp5s0 state: up mac: <filter>
Drives: HDD Total Size: 320.1GB (19.2% used)
ID-1: /dev/sda model: WDC_WD3200BPVT size: 320.1GB
Partition: ID-1: / size: 290G used: 54G (20%) fs: ext4 dev: /dev/sda1
ID-2: swap-1 size: 3.74GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
Sensors: System Temperatures: cpu: 56.1C mobo: N/A gpu: N/A,56.0
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 198 Uptime: 4:36 Memory: 1818.7/3426.0MB
Производил установку из этого топика:viewtopic.php?t=397, скриншот 1- все команды выполнены успешно, скриншот 2 и 3 - ошибка в консоли.
2
20 май 2018, 14:54
dav1d, покажи вывод cat /etc/apt/sources.list
dav1d
20 май 2018, 15:02
#deb cdrom:[Linux Mint 18.3 _Sylvia_ - Release amd64 20171124]/ xenial contrib main non-free
wget --quiet repo/xenial/lmcomru-pubkey
sudo apt-key add lmcomru-pubkey
20 май 2018, 15:18
Теперь открой этот файл sudo xed /etc/apt/sources.list и удали последние 4 строчки. А потом внимательно по инструкции добавляй репозитории.
dav1d
20 май 2018, 15:32
Удалил, добавил заново, теперь там 1 строчка, как и должно быть, но в консоли ошибка:
dav1d@pc ~ $ sudo apt-key add lmcomru-pubkey
[sudo] пароль для dav1d:
OK
dav1d@pc ~ $ apt update
E: Неизвестный тип «wget» в строке 3 в списке источников /etc/apt/sources.list
E: Не читается перечень источников.
root
Благодарил (а): 268 раз
20 май 2018, 15:36
dav1d, строки с wget-ами удалите все из файла /etc/apt/sources.list
Вы не готовы! :pc2:
dav1d
20 май 2018, 15:44
Спасибо, получилось. Выполняю второй шаг (2. Приведение версий xorg), лог консоли:
dav1d@pc ~ $ apt install xserver-xorg-core=2:1.17.3-2ubuntu4 xserver-common=2:1.17.3-2ubuntu4 xserver-xorg-input-evdev=1:2.9.2-1ubuntu1 xserver-xorg-input-synaptics=1.8.2-1ubuntu2 xserver-xorg-input-vmmouse=1:13.1.0-1ubuntu1 xserver-xorg-input-wacom=1:0.32.0-0ubuntu2 xserver-xorg-video-intel=2:2.99.917+git20160218-1ubuntu2 xserver-xorg-video-radeon=1:7.6.1-1ubuntu1 lib32gcc1 libc6 libc6-dbg libc6-i386
E: Версия «2:1.17.3-2ubuntu4» для «xserver-xorg-core» не найдена
E: Версия «2:1.17.3-2ubuntu4» для «xserver-common» не найдена
E: Версия «1:2.9.2-1ubuntu1» для «xserver-xorg-input-evdev» не найдена
E: Версия «1.8.2-1ubuntu2» для «xserver-xorg-input-synaptics» не найдена
E: Версия «1:13.1.0-1ubuntu1» для «xserver-xorg-input-vmmouse» не найдена
E: Версия «1:0.32.0-0ubuntu2» для «xserver-xorg-input-wacom» не найдена
E: Версия «2:2.99.917+git20160218-1ubuntu2» для «xserver-xorg-video-intel» не найдена
E: Версия «1:7.6.1-1ubuntu1» для «xserver-xorg-video-radeon» не найдена
20 май 2018, 15:53
Потому что репозиторий не добавился.
Когда копируешь что-то - копируй аккуратно. Не нужно копироваться сразу все. Там нужно делать по порядку.
1. echo "deb https://linuxmint.com.ru/repo/xenial/ /" | sudo tee -a /etc/apt/sources.list
2. wget --quiet https://linuxmint.com.ru/repo/xenial/lmcomru-pubkey; sudo apt-key add lmcomru-pubkey
3. apt update
И будет счастье
dav1d
20 май 2018, 16:13
Верно, я выполнил эти команды - все прошло успешно. Нужно отдельно вводить эти команды? apt install xserver-xorg-core=2:1.17.3-2ubuntu4 , xserver-common=2:1.17.3-2ubuntu4 , xserver-xorg-input-evdev=1:2.9.2-1ubuntu1 и тд по списку? Я не вижу разделений между ними , поэтому скопировал всё сразу, спасибо за пояснение*
dav1d
20 май 2018, 16:38
Вот ввел одну команду, лог:
Попробуйте ещё раз.
21 май 2018, 15:09
dav1d, inxi -r после этой ошибки покажи.
Единстенный вариант, что репозиторий так и не добавил, т.к. пакеты там все на месте
dav1d
22 май 2018, 04:36
inxi -r
Repos:     Active apt sources in file: /etc/apt/sources.list.d/official-package-repositories.list
           deb http://packages.linuxmint.com sylvia main upstream import backport #id:linuxmint_main
           deb http://archive.ubuntu.com/ubuntu xenial main restricted universe multiverse
           deb http://archive.ubuntu.com/ubuntu xenial-updates main restricted universe multiverse
           deb http://archive.ubuntu.com/ubuntu xenial-backports main restricted universe multiverse
           deb http://security.ubuntu.com/ubuntu/ xenial-security main restricted universe multiverse
           deb http://archive.canonical.com/ubuntu/ xenial partner
           Active apt sources in file: /etc/apt/sources.list.d/oibaf-graphics-drivers-xenial.list
           deb http://ppa.launchpad.net/oibaf/graphics-drivers/ubuntu xenial main
           deb-src http://ppa.launchpad.net/oibaf/graphics-drivers/ubuntu xenial main
           Active apt sources in file: /etc/apt/sources.list.d/opera-stable.list
           deb https://deb.opera.com/opera-stable/ stable non-free #Opera Browser (final releases)
           Active apt sources in file: /etc/apt/sources.list.d/opera.list
           deb http://deb.opera.com/opera/ stable non-free #Opera Browser (final releases)
           Active apt sources in file: /etc/apt/sources.list.d/yandex-browser-beta.list
           deb [arch=amd64] http://repo.yandex.ru/yandex-browser/deb beta main
 ! Сообщение из: darkfenix
Читаем внимательно Панель форматирования текста в темах/ответах
Последний раз редактировалось пользователем 1 rogoznik; всего редактировалось раз: 22
Причина: BBCode
22 май 2018, 05:27
В репе версия 2.1.19 , а 2.1.17 в местной копилке.
22 май 2018, 05:57
dav1d писал(а):
22 май 2018, 04:36
inxi -r
У тебя в файле /etc/apt/sources.list отсутствует строчка с репозиторием. Я же тебе уже писал Ошибка при добавлении репозитория (Пост darkfenix #52275) порядок действий чтоб добавить репозиторий.
22 май 2018, 06:43
Что-то мне подсказывает.... (ктулху наверное)... Что это не последняя беда, которая вскоре, у ТС, будет связана с этой темкой. :-D :-D :-D
22 май 2018, 10:58
vir0id писал(а):
22 май 2018, 06:43
Ну Ктулху или там Крылатый медведь с сиськами, или еще кто-нибудь, но то, что у ТС графический стек из -
и как дальше будет происходить установка старых иксов - удачно или не удачно, посмотрим.
А по железу - АМД А4 3300М, с производительностью как у Коре 2 Дуо, - установить Минт 17.3 и фглрх из Менеджера драйверов. Да и ОС желательно х32 из-за ЦП.
22 май 2018, 16:21
Unborn писал(а):
22 май 2018, 10:58
Ага, самый логичный вариант.
Вернуться в «Видеокарты»
