Не запускается комп и вылетает ошибка
Avas
28 мар 2018, 08:05
initctl: Не удается подключиться к Upstart: Failed to connect to socket /com/ubuntu/upstart: В соединении отказано
syndaemon: процесс не найден
/etc/mdm/Xsession: Beginning session setup...
dbus-update-activation-environment: setting DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/1000/bus
dbus-update-activation-environment: setting DISPLAY=:0
dbus-update-activation-environment: setting XAUTHORITY=/home/cyka/.Xauthority
localuser:cyka being added to access control list
dbus-update-activation-environment: setting USER=cyka
dbus-update-activation-environment: setting HOME=/home/cyka
dbus-update-activation-environment: setting MDM_LANG=ru_RU.UTF-8
dbus-update-activation-environment: setting XDG_SESSION_COOKIE=5ab3c275b7304ed3b8aeef9ffcc37eb4-1522178128.730272-1704903907
dbus-update-activation-environment: setting DESKTOP_SESSION=cinnamon
dbus-update-activation-environment: setting GTK_MODULES=gail:atk-bridge
dbus-update-activation-environment: setting QT_LINUX_ACCESSIBILITY_ALWAYS_ON=1
dbus-update-activation-environment: setting GDM_XSERVER_LOCATION=local
dbus-update-activation-environment: setting MDMSESSION=cinnamon
dbus-update-activation-environment: setting MANDATORY_PATH=/usr/share/gconf/cinnamon.mandatory.path
dbus-update-activation-environment: setting IM_CONFIG_PHASE=1
dbus-update-activation-environment: setting LOGNAME=cyka
dbus-update-activation-environment: setting DEFAULTS_PATH=/usr/share/gconf/cinnamon.default.path
dbus-update-activation-environment: setting USERNAME=cyka
dbus-update-activation-environment: setting WINDOWPATH=9
dbus-update-activation-environment: setting PATH=/home/cyka/bin:/home/cyka/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
dbus-update-activation-environment: setting XDG_RUNTIME_DIR=/run/user/1000
dbus-update-activation-environment: setting LANG=ru_RU.UTF-8
dbus-update-activation-environment: setting XDG_SESSION_DESKTOP=cinnamon
dbus-update-activation-environment: setting SHELL=/bin/bash
dbus-update-activation-environment: setting GDMSESSION=cinnamon
dbus-update-activation-environment: setting QT_ACCESSIBILITY=1
dbus-update-activation-environment: setting PWD=/home/cyka
dbus-update-activation-environment: setting XDG_DATA_DIRS=/usr/share/cinnamon:/usr/share/gnome:/usr/local/share:/usr/share:/var/lib/snapd/desktop:/var/lib/snapd/desktop:/home/cyka/snap/anbox/common/app-data
dbus-update-activation-environment: setting XDG_CONFIG_DIRS=/etc/xdg/xdg-cinnamon:/etc/xdg
dbus-update-activation-environment: setting MDM_XSERVER_LOCATION=local
Решение Obamacyborg1975 » 28 мар 2018, 16:48
Думаю, нужно переключится на другое tty и удалить пакеты, связанные с virtualbox
sudo apt-get remove virtualbox*
Последний раз редактировалось пользователем 1 rogoznik; всего редактировалось раз: 28
Причина: BBCode
28 мар 2018, 10:17
Avas, Это обновки похоже на этот раз
https://forums.linuxmint.com/viewtopic. ... 7&t=266431
Удали пакеты гостевок виртуалбокса:
apt remove virtualbox-guest*
28 мар 2018, 10:45
Avas писал(а):
28 мар 2018, 08:05
USERNAME=cyka
Интересный логин :acute:
Avas
28 мар 2018, 12:59
darkfenix, ты лучше помоги с проблемой !!!
28 мар 2018, 13:00
Avas, ты проделал что тебе сказали в #2?
Avas
28 мар 2018, 15:32
Хе удаленно доступа нету
Благодарил (а): 128 раз
28 мар 2018, 16:48
28 мар 2018, 17:34
Avas писал(а):
28 мар 2018, 15:32
Вот это к чему было?
Avas
28 мар 2018, 18:06
удалил и все заработало
28 мар 2018, 18:12
Avas писал(а):
28 мар 2018, 18:06
Очень информативно. Что хоть удалил?
Avas
28 мар 2018, 19:09
darkfenix,
28 мар 2018, 19:10
Отлично. Проблема решена. Тему закрываю. :close:
Сейчас этот форум просматривают: Google [Bot] и 4 гостя
