System: Host: stepan-Lenovo-ideapad-110-15IBR Kernel: 4.10.0-38-generic x86_64 (64 bit gcc: 5.4.0) Desktop: Cinnamon 3.6.7 (Gtk 3.18.9-1ubuntu3.3) Distro: Linux Mint 18.3 Sylvia Machine: System: LENOVO (portable) product: 80T7 v: Lenovo ideapad 110-15IBR Mobo: LENOVO model: 00RD15IPG076 v: SDK0J40679 WIN Bios: LENOVO v: 1GCN23WW date: 09/05/2017 CPU: Quad core Intel Pentium N3710 (-MCP-) cache: 1024 KB flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 12800 clock speeds: max: 2560 MHz 1: 1198 MHz 2: 1587 MHz 3: 808 MHz 4: 965 MHz Graphics: Card: Intel Device 22b1 bus-ID: 00:02.0 Display Server: X.Org 1.18.4 drivers: intel (unloaded: fbdev,vesa) Resolution: 1366x768@59.97hz GLX Renderer: Mesa DRI Intel HD Graphics 405 (Braswell) GLX Version: 3.0 Mesa 17.0.7 Direct Rendering: Yes Audio: Card Intel Device 2284 driver: snd_hda_intel bus-ID: 00:1b.0 Sound: Advanced Linux Sound Architecture v: k4.10.0-38-generic Network: Card-1: Qualcomm Atheros Device 0042 driver: ath10k_pci bus-ID: 02:00.0 IF: wlp2s0 state: up speed: N/A duplex: N/A mac: <filter> Card-2: Realtek RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller driver: r8169 v: 2.3LK-NAPI port: 1000 bus-ID: 03:00.0 IF: enp3s0 state: down mac: <filter> Card-3: Atheros usb-ID: 001-004 IF: null-if-id state: N/A speed: N/A duplex: N/A mac: N/A Drives: HDD Total Size: 1000.2GB (1.1% used) ID-1: /dev/sda model: ST1000LM024_HN size: 1000.2GB Partition: ID-1: / size: 28G used: 5.6G (22%) fs: ext4 dev: /dev/sda9 ID-2: /home size: 556G used: 304M (1%) fs: ext4 dev: /dev/sda10 ID-3: swap-1 size: 4.72GB used: 0.00GB (0%) fs: swap dev: /dev/sda8 RAID: No RAID devices: /proc/mdstat, md_mod kernel module present Sensors: System Temperatures: cpu: 52.0C mobo: N/A Fan Speeds (in rpm): cpu: N/A Info: Processes: 198 Uptime: 13 min Memory: 898.7/3862.8MB Init: systemd runlevel: 5 Gcc sys: 5.4.0 Client: Shell (bash 4.3.481) inxi: 2.2.35
Не работают края тачпада. LM 18.3 Cinnamon
Автор темы - Сообщения: 73
Ну вот не работает по сантиметру с правого и левого края. Вот так:
На остальных дистрибутивах все нормально.
Забавно, раньше не обращал внимания, но у меня то-же самое
di_mok, если водить по краям вверх и вниз или от края к середине. У вас также? Какое у вас DE и дистрибутив?
- Решено: 7
У меня вроде с этим проблем нет.. Может миллиметров пять и "глухие", но точно не сантиметр. Во всяком случае, неудобств не испытываю вовсе. Mint 18.3 Xfce
WARNING, ну да, чуть перегнул палку. Даже если 5 мм это заметно, когда активно пользуешься тачпадом, как я
Dja, мышки есть, аж две, просто чувствуешь дискомфорт, когда что-то не работает
- Решено: 7
дык и я им активно пользуюсь. Но ,как сказал уже ранее, не испытываю никаких неудобств..Да и 5 мм - чисто субъективно, может это нормальная мертвая зона у всех тачев?
Ради интереса опробовал на WIn10, все также, самый край неактивен. Думаю таки это по умолчанию у всех тачей..
Да. Но прокрутку я привык делать двумя пальцами по центру, поэтому не замечал.
LM 18.3 Cinnamon
WARNING, Windows 10, Rosa, Xubuntu - в них работает вся поверхность тачпада
Поставьте в настройках тачпада прокрутку по краям. У меня тоже было как у вас, но вот теперь заработало. Хотя если бы не тема, я бы об этом никогда не узнал, что по боковым граням тач не работает с установками по умолчанию
Хотя, как то странно. Если стоит прокрутка авто, то края не работают, если же провести от середины к краю то работают. Если стоит прокрутка по краям, работает только прокрутка (не курсор мыши), и только справа. Наверно разрабы Корицы что-то курили
Сейчас езжу на Linux Mint 18.3 Sylvia - Cinnamon (64-bit). Прежние машины Debian 8 Jessie, Debian 7 Wheezy, Debian 6 Squeeze, Linux Mint 11 Katya, Ubuntu 10.10 Maverick Meerkat, Ubuntu 10.04 Lucid Lynx
