xeon E5430 имеет FSB 1333 при штатной частоте 2.66 но на FSB 1066 он выдаст всего 2.12ГГЦ (4ядра 12мб кэш 45нм техпроцесс)
сейчас стоит core2duo E6700 2.66ГГЦ (2 ядра 4мб кэш 65нм техпроцесс)
idea@cat ~ $ inxi -Fxz
System: Host: cat Kernel: 4.8.0-53-generic x86_64 (64 bit gcc: 5.4.0)
Desktop: Xfce 4.12.3 (Gtk 2.24.28) Distro: Linux Mint 18.2 Sonya
Machine: Mobo: ASUSTeK model: P5B-V v: Rev 1.xx
Bios: American Megatrends v: 1211 date: 10/15/2008
CPU: Dual core Intel Core2 6700 (-MCP-) cache: 4096 KB
flags: (lm nx sse sse2 sse3 ssse3 vmx) bmips: 10666
clock speeds: max: 2660 MHz 1: 2128 MHz 2: 2128 MHz
Graphics: Card: Advanced Micro Devices [AMD/ATI] RV620 LE [Radeon HD 3450]
bus-ID: 01:00.0
Resolution: 1280x1024@60.02hz, 1920x1080@60.34hz
GLX Renderer: Gallium 0.4 on AMD RV620 (DRM 2.46.0 / 4.8.0-53-generic, LLVM 3.8.0)
GLX Version: 3.0 Mesa 12.0.6 Direct Rendering: Yes
Audio: Card-1 Intel 82801H (ICH8 Family) HD Audio Controller
Card-2 Advanced Micro Devices [AMD/ATI] RV620 HDMI Audio [Radeon HD 3400 Series]
Network: Card-1: Marvell 88E8001 Gigabit Ethernet Controller
driver: skge v: 1.14 port: b800 bus-ID: 04:04.0
IF: enp4s4 state: down mac: <filter>
Card-2: Atheros AR9271 802.11n driver: ath9k_htc usb-ID: 002-002
IF: wlx8416f914a44d state: N/A mac: N/A
Drives: HDD Total Size: 1000.2GB (51.1% used)
ID-1: /dev/sda model: WDC_WD5000LPLX size: 500.1GB
ID-2: /dev/sdb model: ST3500418AS size: 500.1GB
Partition: ID-1: / size: 37G used: 20G (57%) fs: ext4 dev: /dev/sdb2
ID-2: swap-1 size: 10.00GB used: 0.09GB (1%) fs: swap dev: /dev/sdb5
Sensors: System Temperatures: cpu: 39.5C mobo: 38.0C gpu: 51.0
Fan Speeds (in rpm): cpu: 1654 psu: 0 sys-1: 479 sys-2: 13235 sys-3: 2743
Info: Processes: 202 Uptime: 1 day Memory: 2288.6/3886.6MB
