Помогите подключить картридер
_DS_
Благодарил (а): 12 раз
26 фев 2018, 22:55
System: Host: dsnout Kernel: 4.10.0-38-generic x86_64 (64 bit gcc: 5.4.0)
Machine: System: Sony (portable) product: VPCEB1M1R v: C6048RGS
Mobo: Sony model: VAIO
Bios: American Megatrends v: R0300Y8 date: 07/20/2010
CPU: Dual core Intel Core i3 M 330 (-HT-MCP-) cache: 3072 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 8512
clock speeds: max: 2133 MHz 1: 1733 MHz 2: 1066 MHz 3: 1599 MHz
4: 1066 MHz
Graphics: Card: Advanced Micro Devices [AMD/ATI] Madison [Mobility Radeon HD 5650/5750 / 6530M/6550M]
bus-ID: 01:00.0
Display Server: X.Org 1.17.3 driver: fglrx
Resolution: 1366x768@59.94hz
GLX Renderer: AMD Mobility Radeon HD 5000 Series
GLX Version: 4.5.13416 - CPC 15.302 Direct Rendering: Yes
Audio: Card-1 Intel 5 Series/3400 Series High Definition Audio
Card-2 Advanced Micro Devices [AMD/ATI] Redwood HDMI Audio [Radeon HD 5000 Series]
Sound: Advanced Linux Sound Architecture v: k4.10.0-38-generic
Network: Card-1: Qualcomm Atheros AR9285 Wireless Network Adapter (PCI-Express)
driver: ath9k bus-ID: 02:00.0
Card-2: Marvell Yukon Optima 88E8059 [PCIe Gigabit Ethernet Controller with AVB]
driver: sky2 v: 1.30 port: a000 bus-ID: 04:00.0
Drives: HDD Total Size: 320.1GB (25.4% used)
ID-1: /dev/sda model: WDC_WD3200BEVT size: 320.1GB
Partition: ID-1: / size: 19G used: 1.9G (11%) fs: ext4 dev: /dev/sda3
ID-2: /usr size: 45G used: 5.5G (13%) fs: ext4 dev: /dev/sda6
ID-3: /boot size: 454M used: 65M (16%) fs: ext4 dev: /dev/sda2
ID-4: /home size: 210G used: 68G (34%) fs: ext4 dev: /dev/sda5
ID-5: swap-1 size: 1.07GB used: 0.00GB (0%) fs: swap dev: /dev/sda1
Sensors: System Temperatures: cpu: 50.0C mobo: 50.0C gpu: 54.50C
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 199 Uptime: 30 min Memory: 1379.6/3805.6MB
Уважаемые форумчане помогите пожалуйста подключить картридер.
26 фев 2018, 23:30
_DS_, ещё lsusb
_DS_
26 фев 2018, 23:56
Bus 002 Device 003: ID 09da:054f A4Tech Co., Ltd.
Bus 002 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
27 фев 2018, 00:38
_DS_, а это со вставленной карточкой?
Впервые заметил, что без карточки кардридера не видно
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 004: ID 2232:1029 Silicon Motion WebCam SC-13HDL11939N
Bus 001 Device 003: ID 062a:4101 Creative Labs Wireless Keyboard/Mouse
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 010: ID 058f:6366 Alcor Micro Corp. Multi Flash Reader
_DS_
27 фев 2018, 00:42
Особой разницы не видно. :-(
Filin
Благодарил (а): 55 раз
27 фев 2018, 06:53
Мало кто обращает внимание на проблемы недостатка питания картридера. Проблема идёт если южный мост на материнке подгорает. Элементарно прекращается подача питания на карты памяти. Ремонт дорогостоящий получается но можно использовать картридер с внешним источником питания. Для не разбирающихся - к обычному картридеру прикладывется блок питания ну типа как зарядка к вашему телефону. Он как раз восполняет роль инвалида южного моста.
27 фев 2018, 07:52
_DS_ писал(а):
27 фев 2018, 00:42
И не должно быть видно, потому что ридер не usb, a pci. Повставляй и вынимай карточки, посмотри dmesg.
Ну и общую инфу -
dmesg | grep -i  sdhc
lsmod | egrep -i "sd|mmc|ricoh"
27 фев 2018, 08:54
Unborn, почему PCI-то?
27 фев 2018, 09:02
А хотя верно, у них Realtek на PCIE болтается
27 фев 2018, 10:01
di_mok писал(а):
27 фев 2018, 08:54
почему PCI-то?
Вендор так решил. Сони, Делл используют Ricoh на pci. В принципе он должен работать, по hw-probe у ТС ридер детектирован и драйвер sdhci_pci загружен.
_DS_
27 фев 2018, 10:52
[ 6.640806] sdhci: Secure Digital Host Controller Interface driver
[ 6.640807] sdhci: Copyright(c) Pierre Ossman
[ 6.644444] sdhci-pci 0000:03:00.0: SDHCI controller found [1180:e822] (rev 0)
[ 6.644677] sdhci-pci 0000:03:00.0: Will use DMA mode even though HW doesn't fully claim to support it.
[ 6.645903] mmc0: SDHCI controller on PCI [0000:03:00.0] using DMA
[ 6.645953] sdhci-pci 0000:03:00.4: SDHCI controller found [1180:e822] (rev 0)
[ 6.646189] sdhci-pci 0000:03:00.4: Will use DMA mode even though HW doesn't fully claim to support it.
[ 6.647344] mmc1: SDHCI controller on PCI [0000:03:00.4] using DMA
sdhci_pci 28672 0
sdhci 45056 1 sdhci_pci
_DS_
27 фев 2018, 10:54
Это вроде как необходимо к встроенному устройству внешнее питание подать?
_DS_
27 фев 2018, 11:03
тоже со вставленной флеш
[ 1494.251032] sdhci-pci 0000:03:00.4: Will use DMA mode even though HW doesn't fully claim to support it.
[ 1495.430558] sdhci-pci 0000:03:00.4: Will use DMA mode even though HW doesn't fully claim to support it.
[ 1496.614510] sdhci-pci 0000:03:00.4: Will use DMA mode even though HW doesn't fully claim to support it.
[ 1497.798037] sdhci-pci 0000:03:00.4: Will use DMA mode even though HW doesn't fully claim to support it.
sdhci_pci 28672 0
27 фев 2018, 11:30
_DS_, проверяй, не отключен ли в БИОС. У тебя загружен только драйвер хоста, нет модулей sd, mmc.
Ещё -
lspci | egrep -i "sd|ricoh"
Если не увидишь периферию, то либо откл. питание, либо ядро не поддерживает. Ну или пипец физически. Хорошо бы, что питание просто откл.
_DS_
27 фев 2018, 13:19
В биосе ничего похожего не обнаружил. :-(
вставлена флеш
03:00.0 SD Host controller: Ricoh Co Ltd MMC/SD Host Controller
03:00.1 System peripheral: Ricoh Co Ltd R5U2xx (R5U230 / R5U231 / R5U241) [Memory Stick Host Controller]
03:00.4 SD Host controller: Ricoh Co Ltd MMC/SD Host Controller
Извлечена
Ещё, если карта вставлена то при загрузке системы вот так ругается:
[7.848850]mmc1: error -84 whilst initialising SD card
[9.044528]mmc1: error -84 whilst initialising SD card
[10.227501]mmc1: error -84 whilst initialising SD card
Scanning for Btrfs filesystems
[11.411522]mmc1: error -84 whilst initialising SD card
27 фев 2018, 13:36
_DS_, всё рабочая железка. Карта может кривая. В ФМ что-ли карточку не видишь, или в чем проблема? В утилите Диски посмотри.
_DS_
27 фев 2018, 13:41
Планшет карту видит без проблем.
Disks её тоже не определяет.
:sad: :dash2:
_DS_
27 фев 2018, 13:55
Раз железка рабочая.
Может попытаться примонтировать? По какому адресу искать?
Sander
Благодарил (а): 25 раз
27 фев 2018, 14:37
Не знаю, в тему или нет?
У меня usbишка вдруг перестала показываться в фм. На флшке индикатор мигает как обычно, звуки при всунуть-вынуть есть, а толку нет. В gipardet видна, форматирую- всё норм.
Записываю образ установочного диска, опять не видна, но загрузиться с неё можно.
Может быть минт после андроида брезгует? :joke:
_DS_
27 фев 2018, 15:10
Sander
Спасибо за попытку.
Посмотрел в гипарте поддерживаемые ФС системы. Вроде как-бы должен видеть.
