Wifi выключается
nico_bel
Wifi выключается
23 фев 2018, 13:26
Добрый день.
Подарили ноут lenovo ideapad 110 15acl
System:    Host: mint-Lenovo-ideapad-110-15ACL Kernel: 4.10.0-38-generic x86_64 (64 bit gcc: 5.4.0)
           Desktop: Cinnamon 3.6.6 (Gtk 3.18.9-1ubuntu3.3)
Machine:   System: LENOVO product: 80TJ v: Lenovo ideapad 110-15ACL
           Mobo: LENOVO model: Nano 5A8 v: SDK0M26038 WIN
           Bios: Lenovo v: 1QCN32WW date: 08/18/2016
CPU:       Quad core AMD A6-7310 APU with AMD Radeon R4 Graphics (-MCP-) cache: 8192 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm) bmips: 15969
           clock speeds: max: 2000 MHz 1: 1400 MHz 2: 1600 MHz 3: 1000 MHz
           4: 1000 MHz
Graphics:  Card-1: Advanced Micro Devices [AMD/ATI] Mullins [Radeon R4/R5 Graphics]
           bus-ID: 00:01.0
           Card-2: Advanced Micro Devices [AMD/ATI] Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330]
           bus-ID: 01:00.0
           Resolution: 1366x768@60.02hz
           GLX Renderer: Gallium 0.4 on AMD MULLINS (DRM 2.49.0 / 4.10.0-38-generic, LLVM 4.0.0)
Audio:     Card-1 Advanced Micro Devices [AMD] FCH Azalia Controller
           Card-2 Advanced Micro Devices [AMD/ATI] Kabini HDMI/DP Audio
           driver: snd_hda_intel bus-ID: 00:01.1
           Sound: Advanced Linux Sound Architecture v: k4.10.0-38-generic
Network:   Card-1: Realtek RTL8821AE 802.11ac PCIe Wireless Network Adapter
           driver: rtl8821ae port: 2000 bus-ID: 02:00.0
           IF: wlp2s0 state: down mac: <filter>
           Card-2: Realtek RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
           driver: r8169 v: 2.3LK-NAPI port: 1000 bus-ID: 03:00.0
Drives:    HDD Total Size: 500.1GB (2.5% used)
           ID-1: /dev/sda model: WDC_WD5000LPCX size: 500.1GB
Partition: ID-1: / size: 9.1G used: 5.6G (66%) fs: ext4 dev: /dev/sda1
           ID-2: /home size: 444G used: 532M (1%) fs: ext4 dev: /dev/sda6
           ID-3: swap-1 size: 6.00GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
Sensors:   System Temperatures: cpu: 40.1C mobo: N/A gpu: 39.0,N/A
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 214 Uptime: 54 min Memory: 1187.6/3352.7MB
стояла 10ка, поставил 7ку, но на 7ке не все оборудование распознается/
решил установить linux mint, все хорошо, но странно работает wifi, когда смотришь видео или серфишь, перестает подгружаться. выключаешь на ноуте wifi, опять включаешь, работает некоторое время, и опять не может загрузить страницы
Последний раз редактировалось пользователем 1 rogoznik; всего редактировалось раз: 23
Причина: BBcode
Wifi выключается
23 фев 2018, 13:38
nico_bel писал(а):
23 фев 2018, 13:26
nico_bel писал(а):
23 фев 2018, 13:26
Давай плясать от противного? Как бы... с самого наоборот.
Может дело не в самой карте, а... ну, скажем в настройках роутера? Ты уверен что там всё верно?
nico_bel
Wifi выключается
23 фев 2018, 13:41
на 7ке работало нормально.(этот ноутбук)
стоит еще комп, и планшеты-телефоны всякие, проблем с интернетом нет
nico_bel
Wifi выключается
23 фев 2018, 13:45
через кабель ethernet работает ноут
Wifi выключается
23 фев 2018, 13:47
nico_bel писал(а):
23 фев 2018, 13:41
Надо было сразу сказать.
Поехали дальше... wifi в mint из коробки завёлся или ты драйвер запирдолил?
nico_bel
Wifi выключается
23 фев 2018, 13:55
сразу завелся. сигнал 100 процентов.
у меня единственно в менеджере драйверов стоит amd64-microcode.
установил его. сначала-с ним, условно работал интернет 5 минут, без него-минут 10. но я думаю это ничего не значит
Wifi выключается
23 фев 2018, 14:09
nico_bel писал(а):
23 фев 2018, 13:55
ничего не значит
скорее всего
nico_bel, ну... как бы... есть вариант попробовать загрузиться на более новое ядро.
nico_bel
Wifi выключается
23 фев 2018, 14:11
какое?. это я за
Wifi выключается
23 фев 2018, 14:31
nico_bel писал(а):
23 фев 2018, 14:11
какое?. это я за
А это не поможет. У тебя и так драйвер установлен и лучше он не будет.
ОС установлена в УЕФИ или эмуляции БИОС?
Wifi выключается
23 фев 2018, 14:39
Unborn писал(а):
23 фев 2018, 14:31
Почему? dkms должен смочь пересобрать его под новые реали.
nico_bel
Wifi выключается
23 фев 2018, 14:44
Unborn писал(а):
23 фев 2018, 14:31
не могу сказать.
скачал дистрибутив и через программу rufus записал, загрузился с флэхи на рабочий линукса, нажал instal linux
Wifi выключается
23 фев 2018, 14:50
vir0id писал(а):
23 фев 2018, 14:39
Под какие реалии? Там карта просто спать ложится, вот и всё.
nico_bel писал(а):
23 фев 2018, 14:44
не могу сказать.
тогда вывод
sudo fdisk -l
nico_bel
Wifi выключается
23 фев 2018, 14:53
Disk /dev/sda: 465,8 GiB, 500107862016 bytes, 976773168 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: dos
Disk identifier: 0x098ea7c3
Device     Boot    Start       End   Sectors   Size Id Type
/dev/sda1  *        2048  19531775  19529728   9,3G 83 Linux
/dev/sda2       19533822 976771071 957237250 456,5G  5 Extended
/dev/sda5       19533824  31250431  11716608   5,6G 82 Linux swap / Solaris
/dev/sda6       31252480 976771071 945518592 450,9G 83 Linux
Partition 2 does not start on physical sector boundary.
Причина: BBcode
nico_bel
Wifi выключается
23 фев 2018, 14:56
после перезагрузки немного поработал интернет, и опять перестал. Но заработал опять спустя время без манипуляций
Wifi выключается
23 фев 2018, 15:00
Unborn писал(а):
23 фев 2018, 14:50
Не могу не согласиться. :-D
nico_bel писал(а):
23 фев 2018, 14:56
Unborn, так ведь сама просыпается, местами, падлюка
nico_bel
Wifi выключается
23 фев 2018, 15:03
на минуту отходишь от него, потом обновляешь страницу, долго думает, но секунд через 20 опять начинает работать
Wifi выключается
23 фев 2018, 15:08
nico_bel писал(а):
23 фев 2018, 14:56
Ну так и должно быть, у нее своя жизнь, потому что УЕФИ без нормального взаимодействия с ОС работает. В УЕФИ нужно было Минт устанавливать, у тебя не древнее железо, забудь про БИОС, Легаси и прочую хрень.
Попробуй еще
sudo iwconfig (какое имя интерфейса в системе) power off
Wifi выключается
23 фев 2018, 15:12
nico_bel, засунь под спойлер вывод
grep -i networkmanager /var/log/syslog
Wifi выключается
23 фев 2018, 15:14
nico_bel, давай еще и
sudo efibootmgr
в студию
nico_bel
Wifi выключается
23 фев 2018, 17:42
sudo iwconfig
wlp2s0    IEEE 802.11  ESSID:"qwerty"
          Mode:Managed  Frequency:2.427 GHz  Access Point: C4:6E:1F:70:9D:4C
          Bit Rate=150 Mb/s   Tx-Power=20 dBm
          Retry short limit:7   RTS thr=2347 B   Fragment thr:off
          Encryption key:off
          Power Management:off
          Link Quality=70/70  Signal level=-30 dBm
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:0   Missed beacon:0
lo        no wireless extensions.
enp3s0    no wireless extensions.
Последний раз редактировалось пользователем 1 Dja; всего редактировалось раз: 24
Причина: BB-codes
Сейчас этот форум просматривают: Google [Bot] и 2 гостя
