pip install pyTelegramBotAPI
GasMan
17 фев 2018, 20:21
Всем привет, пытаюсь добавить библиотеку в питон, но что бы не пытался ничего не выходит, поискав в интернете найти решений не смог
17 фев 2018, 20:38
pip3
GasMan
17 фев 2018, 20:41
etamax, тоже самое, пробовал(
17 фев 2018, 20:56
apt install python-pip
apt install python-setuptools
sudo pip install pyTelegramBotAPI
The directory '/home/msuser/.cache/pip/http' or its parent directory is not owned by the current user and the cache has been disabled. Please check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
The directory '/home/msuser/.cache/pip' or its parent directory is not owned by the current user and caching wheels has been disabled. check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
Collecting pyTelegramBotAPI
Downloading pyTelegramBotAPI-3.5.2.tar.gz (51kB)
100% |████████████████████████████████| 61kB 323kB/s
Collecting requests (from pyTelegramBotAPI)
Downloading requests-2.18.4-py2.py3-none-any.whl (88kB)
100% |████████████████████████████████| 92kB 469kB/s
Requirement already satisfied: six in /usr/lib/python2.7/dist-packages (from pyTelegramBotAPI)
Collecting certifi>=2017.4.17 (from requests->pyTelegramBotAPI)
Downloading certifi-2018.1.18-py2.py3-none-any.whl (151kB)
100% |████████████████████████████████| 153kB 383kB/s
Collecting chardet<3.1.0,>=3.0.2 (from requests->pyTelegramBotAPI)
Downloading chardet-3.0.4-py2.py3-none-any.whl (133kB)
100% |████████████████████████████████| 143kB 357kB/s
Collecting idna<2.7,>=2.5 (from requests->pyTelegramBotAPI)
Downloading idna-2.6-py2.py3-none-any.whl (56kB)
100% |████████████████████████████████| 61kB 285kB/s
Collecting urllib3<1.23,>=1.21.1 (from requests->pyTelegramBotAPI)
Downloading urllib3-1.22-py2.py3-none-any.whl (132kB)
100% |████████████████████████████████| 133kB 221kB/s
Installing collected packages: certifi, chardet, idna, urllib3, requests, pyTelegramBotAPI
Found existing installation: chardet 2.3.0
Uninstalling chardet-2.3.0:
Successfully uninstalled chardet-2.3.0
Found existing installation: idna 2.0
Uninstalling idna-2.0:
Successfully uninstalled idna-2.0
Running setup.py install for pyTelegramBotAPI ... done
Successfully installed certifi-2018.1.18 chardet-3.0.4 idna-2
https://kostya.co/create-first-telegram-bot/
GasMan
17 фев 2018, 21:04
etamax, опять, 2 пункт установил, а вот с 3 те же самые проблемы, и с ресурса того же делал по инструкции
17 фев 2018, 21:09
pip -V
pip 9.0.1 from /home/msuser/.local/lib/python2.7/site-packages (python 2.7)
для этого
pip install --upgrade pip
GasMan
17 фев 2018, 21:31
etamax,
17 фев 2018, 21:34
Так он же тебе написал
"Может быть вы имели ввиду install"
А у тебя написано intsall. Чувствуешь разницу.
GasMan
17 фев 2018, 21:36
darkfenix, букву пропустил, ниже на скрине правильно написал же
17 фев 2018, 21:40
GasMan, не увидел.
Только что
darkfenix@darkfenix  ~  pip install --upgrade pip
Collecting pip
  Downloading pip-9.0.1-py2.py3-none-any.whl (1.3MB)
    100% |████████████████████████████████| 1.3MB 837kB/s
Installing collected packages: pip
Successfully installed pip-8.1.1
You are using pip version 8.1.1, however version 9.0.1 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
 darkfenix@darkfenix  ~  inxi -S
System:    Host: darkfenix Kernel: 4.14.17-041417-generic x86_64 (64 bit) Desktop: Cinnamon 3.6.7
Покажи вывод inxi -S
GasMan
17 фев 2018, 21:46
darkfenix, inxi -S
System: Host: Brokoly Kernel: 4.10.0-42-generic x86_64 (64 bit)
Desktop: Cinnamon 3.4.6 Distro: Linux Mint 18.2 Sonya
17 фев 2018, 21:58
Вот сейчас в лайв-сессии
Что-то ты где-то сломал.
GasMan
17 фев 2018, 22:00
Есть какие-то предположения?)) Ядро не так давно откатывал, звук не работал, сейчас висит обновление ядра 4.13.0
17 фев 2018, 22:04
Тут не в ядре дело. В питоне не силен. Подождем мож подскажет кто куда копать.
17 фев 2018, 22:08
17 фев 2018, 21:58
Не корректный пример , пакет не поставился , не хватает -
4.4.0-112-generic ))
17 фев 2018, 22:11
etamax писал(а):
17 фев 2018, 22:08
Что в нем не так. pip то обновился. А целью поставить туда pyTelegramBotApi я не задавался. Я всего лишь показал что pip обновляется и пытается установить пакет на версии 18.2.
GasMan
18 фев 2018, 02:31
etamax, а что-нибудь решить то удастся?)
18 фев 2018, 02:53
GasMan, да можно все руками развернуть.
setuptools:
wget https://pypi.python.org/packages/6c/54/f7e9cea6897636a04e74c3954f0d8335cc38f7d01e27eec98026b049a300/setuptools-38.5.1.zip
unzip setuptools-38.5.1.zip
cd setuptools-38.5.1
sudo python setup.py install
pip:
wget https://pypi.python.org/packages/11/b6/abcb525026a4be042b486df43905d6893fb04f05aac21c32c638e939e447/pip-9.0.1.tar.gz
tar -xzvf pip-9.0.1.tar.gz
cd pip-9.0.1
▶ pip -V
pip 9.0.1 from /usr/local/lib/python2.7/dist-packages/pip-9.0.1-py2.7.egg (python 2.7)
Ну и следуя этой логике - с тем же успехом можно скачать и сам искомый модуль pyTelegramBotAPI и развернуть вручную без pip :)
GasMan
18 фев 2018, 03:08
~/Документы/pyTelegramBotAPI $ sudo python setup.py install
[sudo] пароль для selderey:
running install
running bdist_egg
running egg_info
writing requirements to pyTelegramBotAPI.egg-info/requires.txt
writing pyTelegramBotAPI.egg-info/PKG-INFO
writing top-level names to pyTelegramBotAPI.egg-info/top_level.txt
writing dependency_links to pyTelegramBotAPI.egg-info/dependency_links.txt
reading manifest file 'pyTelegramBotAPI.egg-info/SOURCES.txt'
writing manifest file 'pyTelegramBotAPI.egg-info/SOURCES.txt'
installing library code to build/bdist.linux-x86_64/egg
running install_lib
running build_py
creating build/lib.linux-x86_64-2.7
creating build/lib.linux-x86_64-2.7/telebot
copying telebot/apihelper.py -> build/lib.linux-x86_64-2.7/telebot
copying telebot/__init__.py -> build/lib.linux-x86_64-2.7/telebot
copying telebot/util.py -> build/lib.linux-x86_64-2.7/telebot
copying telebot/types.py -> build/lib.linux-x86_64-2.7/telebot
creating build/bdist.linux-x86_64/egg
creating build/bdist.linux-x86_64/egg/telebot
copying build/lib.linux-x86_64-2.7/telebot/apihelper.py -> build/bdist.linux-x86_64/egg/telebot
copying build/lib.linux-x86_64-2.7/telebot/__init__.py -> build/bdist.linux-x86_64/egg/telebot
copying build/lib.linux-x86_64-2.7/telebot/util.py -> build/bdist.linux-x86_64/egg/telebot
copying build/lib.linux-x86_64-2.7/telebot/types.py -> build/bdist.linux-x86_64/egg/telebot
byte-compiling build/bdist.linux-x86_64/egg/telebot/apihelper.py to apihelper.pyc
byte-compiling build/bdist.linux-x86_64/egg/telebot/__init__.py to __init__.pyc
byte-compiling build/bdist.linux-x86_64/egg/telebot/util.py to util.pyc
byte-compiling build/bdist.linux-x86_64/egg/telebot/types.py to types.pyc
creating build/bdist.linux-x86_64/egg/EGG-INFO
copying pyTelegramBotAPI.egg-info/PKG-INFO -> build/bdist.linux-x86_64/egg/EGG-INFO
copying pyTelegramBotAPI.egg-info/SOURCES.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
copying pyTelegramBotAPI.egg-info/dependency_links.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
copying pyTelegramBotAPI.egg-info/requires.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
copying pyTelegramBotAPI.egg-info/top_level.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
zip_safe flag not set; analyzing archive contents...
creating 'dist/pyTelegramBotAPI-3.5.2-py2.7.egg' and adding 'build/bdist.linux-x86_64/egg' to it
removing 'build/bdist.linux-x86_64/egg' (and everything under it)
Processing pyTelegramBotAPI-3.5.2-py2.7.egg
Copying pyTelegramBotAPI-3.5.2-py2.7.egg to /usr/local/lib/python2.7/dist-packages
Adding pyTelegramBotAPI 3.5.2 to easy-install.pth file
Installed /usr/local/lib/python2.7/dist-packages/pyTelegramBotAPI-3.5.2-py2.7.egg
Processing dependencies for pyTelegramBotAPI==3.5.2
Searching for requests
Reading https://pypi.python.org/simple/requests/
Download error on https://pypi.python.org/simple/requests/: unknown error (_ssl.c:2831) -- Some packages may not be found!
Couldn't find index page for 'requests' (maybe misspelled?)
Scanning index of all packages (this may take a while)
Download error on https://pypi.python.org/simple/: unknown error (_ssl.c:2831) -- Some packages may not be found!
No local packages or working download links found for requests
error: Could not find suitable distribution for Requirement.parse('requests')
все шло хорошо, пока не начал сам следовать логике :-D вот что вышло когда попытался присоединить модуль без pip
Последний раз редактировалось пользователем 1 rogoznik; всего редактировалось раз: 18
Причина: BBcode
18 фев 2018, 03:12
GasMan писал(а):
18 фев 2018, 03:08
('requests')
Не хватает еще одного зависимого модуля, о чем он тебе и говорит
https://pypi.python.org/pypi/requests
