При запуске самой инсталяции видает такую ошибку
Supported adapter detected.
Check if system has the tools required for installation.
fglrx installation requires that the system have kernel headers. /lib/modules/4.10.0-38-generic/build/include/linux/version.h cannot be found on this system.
One or more tools required for installation cannot be found on the system. Install the required tools before installing the fglrx driver.
Optionally, run the installer with --force option to install without the tools.
Forcing install will disable AMD hardware acceleration and may make your system unstable. Not recommended.
Не могу утановить драйвер видеокарти AMD Radeon на Linux Mint 18.3
Вывод
inix -Fxz
покажи. И почитай Панель форматирования текста в темах/ответахНе могу утановить драйвер видеокарти AMD Radeon на Linux Mint 18.3
darkfenix, дискретная карта греется как атомный реактор
$ inxi -Fxz
System: Host: HP Kernel: 4.10.0-38-generic x86_64 (64 bit gcc: 5.4.0)
Desktop: KDE Plasma 5.8.8 (Qt 5.6.1)
Machine: System: Hewlett-Packard (portable) product: HP 2000 Notebook PC v: 088A130000305910000610100
Mobo: Hewlett-Packard model: 1855 v: 64.2A
Bios: Insyde v: F.3C date: 10/11/2013
CPU: Dual core Intel Pentium 2020M (-MCP-) cache: 2048 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 9578
clock speeds: max: 2400 MHz 1: 1200 MHz 2: 1200 MHz
Graphics: Card-1: Intel 3rd Gen Core processor Graphics Controller
bus-ID: 00:02.0
Card-2: Advanced Micro Devices [AMD/ATI] Seymour [Radeon HD 6400M/7400M Series]
bus-ID: 01:00.0
Display Server: X.Org 1.18.4 drivers: ati,radeon,intel (unloaded: fbdev,vesa)
Resolution: 1366x768@60.07hz
GLX Renderer: Mesa DRI Intel Ivybridge Mobile
Audio: Card Intel 7 Series/C210 Series Family High Definition Audio Controller
Sound: Advanced Linux Sound Architecture v: k4.10.0-38-generic
Network: Card-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
driver: ath9k bus-ID: 07:00.0
Card-2: Realtek RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
driver: r8169 v: 2.3LK-NAPI port: 2000 bus-ID: 0e:00.0
IF: eno1 state: down mac: <filter>
Card-3: Atheros usb-ID: 001-005
IF: null-if-id state: N/A speed: N/A duplex: N/A mac: N/A
Последний раз редактировалось пользователем 1 vishenman; всего редактировалось раз: 7
- Решено: 15
Jigorua, У нас тут есть инструкция от чокобо. А вообще, тебе предлагают установить форсированно, без доп. пакета утилит. А ты уверен, что тот самый драйвер устанавливаешь?
