Ошибка useradd
Oxotnik26
Ошибка useradd
10 янв 2018, 01:37
Linux Mit 18.3 x64 mate.
administrator@1C-Server ~ $ inxi -Fxz
System: Host: 1C-Server Kernel: 4.10.0-38-generic x86_64 (64 bit gcc: 5.4.0)
Desktop: MATE 1.18.0 (Gtk 3.18.9-1ubuntu3.3)
Machine: Mobo: Gigabyte model: P85-D3 v: x.x
Bios: American Megatrends v: FD date: 08/18/2014
CPU: Quad core Intel Core i7-4790 (-HT-MCP-) cache: 8192 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 28734
clock speeds: max: 4000 MHz 1: 2524 MHz 2: 3544 MHz 3: 2590 MHz
4: 2858 MHz 5: 2502 MHz 6: 2519 MHz 7: 3967 MHz 8: 3006 MHz
Graphics: Card: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics Controller
bus-ID: 00:02.0
Resolution: 1680x1050@59.95hz
GLX Renderer: Mesa DRI Intel Haswell Desktop
Audio: Card-1 Intel 8 Series/C220 Series High Definition Audio Controller
Card-2 Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio Controller
driver: snd_hda_intel bus-ID: 00:03.0
Sound: Advanced Linux Sound Architecture v: k4.10.0-38-generic
Network: Card: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
driver: r8169 v: 2.3LK-NAPI port: e000 bus-ID: 02:00.0
Drives: HDD Total Size: 755.7GB (8.4% used)
ID-1: /dev/sda model: KINGSTON_SH103S3 size: 240.1GB temp: 25C
ID-2: /dev/sdb model: WDC_WD2500AAJS size: 250.1GB temp: 43C
ID-3: /dev/sdc model: WDC_WD2500AAJS size: 250.1GB temp: 44C
ID-4: USB /dev/sdd model: SanDisk_Ultra size: 15.5GB temp: 0C
Partition: ID-1: / size: 204G used: 41G (21%) fs: ext4 dev: /dev/sda2
ID-2: swap-1 size: 17.04GB used: 0.00GB (0%) fs: swap dev: /dev/sda3
Sensors: System Temperatures: cpu: 29.8C mobo: 27.8C
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 233 Uptime: 39 min Memory: 1299.6/15916.1MB
При попытке добавить пользователя через команду sudo useradd система никак не реагирует.
administrator@1C-Server ~ $ sudo useradd -D
sudo пароль для administrator:
administrator@1C-Server ~ $ useradd -D
administrator@1C-Server ~ $ sudo useradd -m db2fenc1
В файлы пользователя и группы ничего не заносится. Папка в хом не создаётся(с соотв-ей командой). На useradd -D тоже не реагирует. С groupadd та же история.
Но при попытке поставить ssh выскакивает такая ошибка.
 openssh-server
Ошибка при установке пакета. Попытка восстановления:
Настраивается пакет openssh-server (1:7.2p2-4ubuntu2.2) …
adduser: Работа «/usr/sbin/useradd -d /var/run/sshd -g nogroup -s /usr/sbin/nologin -u 123 sshd» завершилась с кодом ошибки 1. Завершение работы.
На опеннет узнал что это "не удалось изменить файл паролей".
administrator@1C-Server /etc $ ls -al
итого 1360
drwxr-xr-x   2 root root     4096 ноя 24 17:25 groff
-rw-rw-rw-   1 root root     1128 янв  9 23:58 group
-rw-------   1 root root     1091 янв  2 13:42 group-
drwxr-xr-x   2 root root     4096 ноя 24 17:31 grub.d
-rw-r-----   1 root shadow    949 янв  9 23:51 gshadow
-rw-------   1 root root      921 янв  2 13:42 gshadow-
drwxr-xr-x   3 root root     4096 ноя 24 17:06 gss
-rw-r--r--   1 root root        3 янв  2 13:25 papersize
-rw-r--r--   1 root root     2505 янв 10 00:05 passwd
-rw-r--r--   1 root root     2506 янв  9 23:58 passwd-
drwxr-xr-x   2 root root     4096 ноя 24 17:26 pcmcia
drwxr-xr-x   4 root root     4096 ноя 24 17:31 sgml
-rw-r-----   1 root shadow   1459 янв  9 23:50 shadow
-rw-------   1 root root     1332 янв  9 22:53 shadow-
-rw-r--r--   1 root root       96 янв  9 13:06 shells
Все команды делаются из под рута, файлов блокировок нет.
До этого ставил 1с и апач всё прошло нормально. После этого пошли проблемы не смог поставить ssh, но решил забить на него. А тут начал ставить IBM DB2 и такая засада.
Oxotnik26
Ошибка useradd
10 янв 2018, 03:40
Проблема решена. Похоже я случайно удалил пакет "login". :dash2:
Может мой косяк позволит кому то исправить его проблему.
