На недавно приобретённом ноутбуке после установки Linux Mint 18.3 столкнулся с проблемой, что нет звука. А точнее, иногда он появляется после работы в Windows 10, которая стоит параллельно на диске.
Чип Realtek ALC295.
Может подсказать, как решить проблему?
Некоторая информация:
lsb_release -rd
Description: Linux Mint 18.3 Sylvia
Release: 18.3
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC295 Analog [ALC295 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
00:00.0 Host bridge [0600]: Intel Corporation Device [8086:5910] (rev 05)
Subsystem: ASUSTeK Computer Inc. Device [1043:1bc0]
Flags: bus master, fast devsel, latency 0
Capabilities: <access denied>
00:01.0 PCI bridge [0604]: Intel Corporation Sky Lake PCIe Controller (x16) [8086:1901] (rev 05) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 121
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000e000-0000efff
Memory behind bridge: de000000-df0fffff
Prefetchable memory behind bridge: 00000000c0000000-00000000d1ffffff
Kernel driver in use: pcieport
Kernel modules: shpchp
00:08.0 System peripheral [0880]: Intel Corporation Sky Lake Gaussian Mixture Model [8086:1911]
Subsystem: ASUSTeK Computer Inc. Skylake Gaussian Mixture Model [1043:1bc0]
Flags: fast devsel, IRQ 11
Memory at df430000 (64-bit, non-prefetchable) [disabled] [size=4K]
00:14.0 USB controller [0c03]: Intel Corporation Sunrise Point-H USB 3.0 xHCI Controller [8086:a12f] (rev 31) (prog-if 30 [XHCI])
Subsystem: ASUSTeK Computer Inc. Sunrise Point-H USB 3.0 xHCI Controller [1043:201f]
Flags: bus master, medium devsel, latency 0, IRQ 125
Memory at df410000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: xhci_hcd
00:14.2 Signal processing controller [1180]: Intel Corporation Sunrise Point-H Thermal subsystem [8086:a131] (rev 31)
Subsystem: ASUSTeK Computer Inc. Sunrise Point-H Thermal subsystem [1043:1bc0]
Flags: fast devsel, IRQ 18
Memory at df42f000 (64-bit, non-prefetchable) [size=4K]
Kernel driver in use: intel_pch_thermal
Kernel modules: intel_pch_thermal
00:15.0 Signal processing controller [1180]: Intel Corporation Sunrise Point-H LPSS I2C Controller #0 [8086:a160] (rev 31)
Subsystem: ASUSTeK Computer Inc. Sunrise Point-H Serial IO I2C Controller [1043:1bc0]
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at df42e000 (64-bit, non-prefetchable) [size=4K]
Kernel driver in use: intel-lpss
Kernel modules: intel_lpss_pci
00:16.0 Communication controller [0780]: Intel Corporation Sunrise Point-H CSME HECI #1 [8086:a13a] (rev 31)
Subsystem: ASUSTeK Computer Inc. Sunrise Point-H CSME HECI [1043:1bc0]
Flags: bus master, fast devsel, latency 0, IRQ 321
Memory at df42d000 (64-bit, non-prefetchable) [size=4K]
Kernel driver in use: mei_me
Kernel modules: mei_me
00:17.0 RAID bus controller [0104]: Intel Corporation 82801 Mobile SATA Controller [RAID mode] [8086:282a] (rev 31)
Subsystem: ASUSTeK Computer Inc. 82801 Mobile SATA Controller [RAID mode] [1043:1bc0]
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 319
Memory at df428000 (32-bit, non-prefetchable) [size=8K]
Memory at df42c000 (32-bit, non-prefetchable) [size=256]
I/O ports at f050 [size=8]
I/O ports at f040 [size=4]
I/O ports at f020 [size=32]
Memory at df42b000 (32-bit, non-prefetchable) [size=2K]
Kernel driver in use: ahci
Kernel modules: ahci
00:1c.0 PCI bridge [0604]: Intel Corporation Sunrise Point-H PCI Express Root Port #5 [8086:a114] (rev f1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 122
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 0000d000-0000dfff
Memory behind bridge: df300000-df3fffff
00:1c.5 PCI bridge [0604]: Intel Corporation Sunrise Point-H PCI Express Root Port #6 [8086:a115] (rev f1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 123
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
Memory behind bridge: df200000-df2fffff
00:1c.6 PCI bridge [0604]: Intel Corporation Sunrise Point-H PCI Express Root Port #7 [8086:a116] (rev f1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 124
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
Memory behind bridge: df100000-df1fffff
00:1f.0 ISA bridge [0601]: Intel Corporation Sunrise Point-H LPC Controller [8086:a152] (rev 31)
Subsystem: ASUSTeK Computer Inc. Sunrise Point-H LPC Controller [1043:1bc0]
00:1f.2 Memory controller [0580]: Intel Corporation Sunrise Point-H PMC [8086:a121] (rev 31)
Subsystem: ASUSTeK Computer Inc. Sunrise Point-H PMC [1043:1bc0]
Flags: fast devsel
Memory at df424000 (32-bit, non-prefetchable) [disabled] [size=16K]
00:1f.3 Audio device [0403]: Intel Corporation Device [8086:a171] (rev 31)
Flags: bus master, fast devsel, latency 32, IRQ 324
Memory at df420000 (64-bit, non-prefetchable) [size=16K]
Memory at df400000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
00:1f.4 SMBus [0c05]: Intel Corporation Sunrise Point-H SMBus [8086:a123] (rev 31)
Subsystem: ASUSTeK Computer Inc. Sunrise Point-H SMBus [1043:1bc0]
Flags: medium devsel, IRQ 11
Memory at df42a000 (64-bit, non-prefetchable) [size=256]
I/O ports at f000 [size=32]
Kernel modules: i2c_i801
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation Device [10de:1c20] (rev a1) (prog-if 00 [VGA controller])
Subsystem: ASUSTeK Computer Inc. Device [1043:156e]
Flags: bus master, fast devsel, latency 0, IRQ 323
Memory at de000000 (32-bit, non-prefetchable) [size=16M]
Memory at c0000000 (64-bit, prefetchable) [size=256M]
Memory at d0000000 (64-bit, prefetchable) [size=32M]
I/O ports at e000 [size=128]
Expansion ROM at 000c0000 [disabled] [size=128K]
Kernel driver in use: nouveau
Kernel modules: nvidiafb, nouveau, nvidia_384_drm, nvidia_384
02:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 15)
Subsystem: ASUSTeK Computer Inc. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [1043:200f]
Flags: bus master, fast devsel, latency 0, IRQ 320
I/O ports at d000 [size=256]
Memory at df304000 (64-bit, non-prefetchable) [size=4K]
Memory at df300000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: r8169
Kernel modules: r8169
03:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5229 PCI Express Card Reader [10ec:5229] (rev 01)
Subsystem: ASUSTeK Computer Inc. RTS5229 PCI Express Card Reader [1043:202f]
Flags: bus master, fast devsel, latency 0, IRQ 318
Memory at df200000 (32-bit, non-prefetchable) [size=4K]
Kernel driver in use: rtsx_pci
Kernel modules: rtsx_pci
04:00.0 Network controller [0280]: Intel Corporation Device [8086:24fd] (rev 78)
Subsystem: Intel Corporation Device [8086:0010]
Flags: bus master, fast devsel, latency 0, IRQ 322
Memory at df100000 (64-bit, non-prefetchable) [size=8K]
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
System: Host: ASUS-ROG Kernel: 4.10.0-42-generic x86_64 (64 bit gcc: 5.4.0)
Desktop: Cinnamon 3.6.6 (Gtk 3.18.9-1ubuntu3.3) Distro: Linux Mint 18.3 Sylvia
Machine: Mobo: ASUSTeK model: GL703VM v: 1.0 Bios: American Megatrends v: GL703VM.306 date: 10/03/2017
CPU: Quad core Intel Core i7-7700HQ (-HT-MCP-) cache: 6144 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 22464
clock speeds: max: 3800 MHz 1: 3408 MHz 2: 3426 MHz 3: 3430 MHz 4: 3413 MHz 5: 3491 MHz 6: 3402 MHz
7: 3401 MHz 8: 3438 MHz
Graphics: Card: NVIDIA Device 1c20 bus-ID: 01:00.0
Display Server: X.Org 1.18.4 drivers: (unloaded: fbdev,vesa) FAILED: nouveau
Resolution: 1920x1080@60.02hz
GLX Renderer: llvmpipe (LLVM 5.0, 256 bits) GLX Version: 3.0 Mesa 17.3.0 Direct Rendering: Yes
Audio: Card Intel Device a171 driver: snd_hda_intel bus-ID: 00:1f.3 Sound: ALSA v: k4.10.0-42-generic
driver: r8169 v: 2.3LK-NAPI port: d000 bus-ID: 02:00.0
IF: enp2s0 state: down mac: 10:7b:44:b9:ca:fd
Card-2: Intel Device 24fd driver: iwlwifi bus-ID: 04:00.0
IF: wlp4s0 state: up speed: N/A duplex: N/A mac: f8:34:41:84:78:99
Drives: HDD Total Size: 1256.3GB (56.1% used) ID-1: /dev/sda model: HFS256G39TND size: 256.1GB
ID-2: /dev/sdb model: HGST_HTS721010A9 size: 1000.2GB
Partition: ID-1: / size: 24G used: 11G (47%) fs: ext4 dev: /dev/sda4
ID-2: /home size: 56G used: 15G (28%) fs: ext4 dev: /dev/sda6
Sensors: System Temperatures: cpu: 53.5C mobo: N/A
Fan Speeds (in rpm): cpu: 0
Info: Processes: 281 Uptime: 10 min Memory: 2473.1/32125.6MB Init: systemd runlevel: 5 Gcc sys: 5.4.0
