Не работает звук через HDMI Nvidia 1060
Xaket
10 дек 2017, 19:26
Не воспроизводит звук через HDMI, через аудио джеки звук работает. Помогите настроить звук через HDMI. Установил проприетарный драйвер.
Resolution: 1920x1080@60.00hz, 1920x1080@50.00hz
           GLX Renderer: GeForce GTX 1060 6GB/PCIe/SSE2
           GLX Version: 4.5.0 NVIDIA 384.90 Direct Rendering: Yes
Audio:     Card-1 Advanced Micro Devices [AMD] Device 1457
           driver: snd_hda_intel bus-ID: 22:00.3
           Card-2 NVIDIA Device 10f1 driver: snd_hda_intel bus-ID: 20:00.1
           Sound: Advanced Linux Sound Architecture v: k4.10.0-42-generic
pacmd list-sinks
2 sink(s) available.
* index: 12
driver: <module-alsa-card.c>
flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: IDLE
suspend cause:
priority: 9059
volume: front-left: 66290 / 101% / 0,30 dB, front-right: 66290 / 101% / 0,30 dB
balance 0,00
base volume: 65536 / 100% / 0,00 dB
volume steps: 65537
muted: no
current latency: 37,28 ms
max request: 6 KiB
max rewind: 64 KiB
monitor source: 13
sample spec: s16le 2-канальный 4410
channel map: front-left,front-right
Стерео
used by: 0
linked by: 1
configured latency: 40,00 ms; range is 0,50 .. 371,52 ms
card: 1 <alsa_card.pci-0000_22_00.3>
module: 7
properties:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "ALC892 Analog"
alsa.id = "ALC892 Analog"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "1"
alsa.card_name = "HD-Audio Generic"
alsa.long_card_name = "HD-Audio Generic at 0xfd700000 irq 242"
alsa.driver_name = "snd_hda_intel"
device.bus_path = "pci-0000:22:00.3"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:22:00.3/sound/card1"
device.bus = "pci"
device.vendor.id = "1022"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD]"
device.product.id = "1457"
device.string = "front:1"
device.buffering.buffer_size = "65536"
device.buffering.fragment_size = "32768"
device.access_mode = "mmap+timer"
device.profile.name = "analog-stereo"
device.profile.description = "Аналоговый стерео"
device.description = "HD-Audio Generic Аналоговый стерео"
alsa.mixer_name = "Realtek ALC892"
alsa.components = "HDA:10ec0892,1462fa37,00100302"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
ports:
analog-output-lineout: Линейный выход (priority 9900, latency offset 0 usec, available: yes)
properties:
analog-output-headphones: Аналоговые наушники (priority 9000, latency offset 0 usec, available: no)
properties:
device.icon_name = "audio-headphones"
active port: <analog-output-headphones>
index: 45
flags: HARDWARE DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: IDLE
suspend cause:
priority: 9050
volume: front-left: 65536 / 100% / 0,00 dB, front-right: 65536 / 100% / 0,00 dB
balance 0,00
volume steps: 65537
muted: no
current latency: 39,96 ms
max request: 6 KiB
max rewind: 64 KiB
monitor source: 46
Стерео
used by: 0
linked by: 1
card: 0 <alsa_card.pci-0000_20_00.1>
module: 6
properties:
device.api = "alsa"
alsa.name = "HDMI 0"
alsa.id = "HDMI 0"
alsa.device = "3"
alsa.card = "0"
alsa.card_name = "HDA NVidia"
alsa.long_card_name = "HDA NVidia at 0xfd080000 irq 240"
device.bus_path = "pci-0000:20:00.1"
sysfs.path = "/devices/pci0000:00/0000:00:03.1/0000:20:00.1/sound/card0"
device.bus = "pci"
device.vendor.id = "10de"
device.vendor.name = "NVIDIA Corporation"
device.product.id = "10f1"
device.string = "hdmi:0"
device.profile.name = "hdmi-stereo"
device.profile.description = "Digital Stereo (HDMI)"
device.description = "HDA NVidia Digital Stereo (HDMI)"
alsa.mixer_name = "Nvidia Generic HDMI"
alsa.components = "HDA:10de0084,1458371a,00100100"
ports:
hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: yes)
properties:
device.icon_name = "video-display"
device.product.name = "C27F390"
active port: <hdmi-output-0>
Последний раз редактировалось пользователем 1 Dja; всего редактировалось раз: 10
Причина: BB-code
Вернуться в «Видеокарты»
