System: Host: svit-HP-Laptop-15-bs0xx Kernel: 4.10.0-38-generic x86_64 (64 bit gcc: 5.4.0) Desktop: Xfce 4.12.3 (Gtk 2.24.28) Distro: Linux Mint 18.3 Sylvia Machine: System: HP product: HP Laptop 15-bs0xx v: Type1ProductConfigId Mobo: HP model: 832D v: 25.30 Bios: Insyde v: F.21 date: 07/07/2017 CPU: Quad core Intel Pentium N3710 (-MCP-) cache: 1024 KB flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 12800 clock speeds: max: 2560 MHz 1: 2312 MHz 2: 1848 MHz 3: 1781 MHz 4: 1912 MHz Graphics: Card-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Integrated Graphics Controller bus-ID: 00:02.0 Card-2: Advanced Micro Devices [AMD/ATI] Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430] bus-ID: 01:00.0 Display Server: X.Org 1.18.4 drivers: vesa,intel (unloaded: fbdev) Resolution: 1368x768@0.00hz GLX Renderer: Gallium 0.4 on llvmpipe (LLVM 4.0, 128 bits) GLX Version: 3.0 Mesa 17.0.7 Direct Rendering: Yes Audio: Card Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series High Definition Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0 Sound: Advanced Linux Sound Architecture v: k4.10.0-38-generic Network: Card-1: Realtek Device d723 port: 2000 bus-ID: 02:00.0 IF: N/A state: N/A speed: N/A duplex: N/A mac: N/A Card-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller driver: r8169 v: 2.3LK-NAPI port: 1000 bus-ID: 03:00.0 IF: eno1 state: up speed: 100 Mbps duplex: full mac: <filter> Drives: HDD Total Size: 500.1GB (3.2% used) ID-1: /dev/sda model: TOSHIBA_MQ01ABF0 size: 500.1GB Partition: ID-1: / size: 48G used: 12G (25%) fs: ext4 dev: /dev/sda1 ID-2: swap-1 size: 4.19GB used: 0.00GB (0%) fs: swap dev: /dev/sda5 RAID: No RAID devices: /proc/mdstat, md_mod kernel module present Sensors: System Temperatures: cpu: 40.0C mobo: 27.8C Fan Speeds (in rpm): cpu: N/A Info: Processes: 217 Uptime: 18 min Memory: 1305.5/3855.8MB Init: systemd runlevel: 5 Gcc sys: 5.4.0 Client: Shell (bash 4.3.481) inxi: 2.2.35
Темный экран после выбора загрузки
Автор темы - Сообщения: 12
В общем пользовался тулзой катулин для установки репозиториев кали на Минт. Все шло неплохо но потом были ошибки с несколькими пакетами, решил перезапустить ноут, после чего обнаружил темный экран после того как выбрал загрузку минта. Номодесет и рекавери работают исправно, но нужно же это все исправлять. Linux Mint 18.3 XFCE beta
ngix был пакетом который ошибочно установился, ну недосутановился. Какая разница для чего? Это все равно не поможет решению проблемы. Попробовал все варианты какпочинить. Ничего не помогало. Залез в рекавери и с помощью функции починки починил пакеет. Казалось бы уже все можно перезапускать, но перезапуск был теаким же. Экран с курсором.
Ставил же на минт, темболее уверен что скорее не в этом дело
просто для информации добавил, чтобы было от чего оттолкнутся. Но походу дело в дровах. Обновлял с помощью менеджера - не помогло
Svit, какой минт? У тебя что только не стояло. Разберись с выбором дистриба для начала и не юзай всякие шлако-репозитории.
Я поставил минт и все. прошу вот помочь разобратся а вы меня посылаете)
Dja, Katoolin - это приложуха для кулцхакеров. Она и на минте может работать.
Но дурнаааяяя)
вообще дело не в ней а в дровах длявидео. Не надо было ее упоминать)
- Решено: 8
незнаю у меня обычно при загрузки по экрану бегут строки загрузки. когда какойто-диск отсоединен (например дом.директория или /var он показывает черный экран. Это БАГ минта. Он должен в любом случае отображать ход загрузки
Ivanov_k, юзатель неделю назад узнал о существовании nano, но еще раньше уже начал проявлять нездоровый интерес ко всяким калям с торами
- Решено: 217
Svit, а где подробности, чтоб начать по теме?
Прыгни в tty или чрутнись с лайва, стащи логи или сними hw-probe хотя бы, для отправной точки
