Помогите пожалуйста с WiFi
Skrabus
10 ноя 2017, 17:39
Доброго времени суток всем....
Помогите пожалуйста не работает WiFi Intel Centrino Wireless-N 1000 [Condor Peak]
Драйвера стоят iwlwifi-1000-5.ucode и iwlwifi-1000-3.ucode. А все равно не видит сети....
$ inxi -Fxz
System:    Host: ksp-Lenovo-IdeaPad-Y570 Kernel: 4.10.0-38-generic i686 (32 bit gcc: 5.4.0)
           Desktop: Cinnamon 3.4.6 (Gtk 3.18.9-1ubuntu3.3)
           Distro: Linux Mint 18.2 Sonya
Machine:   System: LENOVO product: 0862 v: Lenovo IdeaPad Y570
           Mobo: LENOVO model: N/A
           Bios: LENOVO v: 47CN31WW(V2.09) date: 10/28/2011
CPU:       Quad core Intel Core i7-2670QM (-HT-MCP-) cache: 6144 KB
           flags: (lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 17561
           clock speeds: max: 3100 MHz 1: 799 MHz 2: 799 MHz 3: 799 MHz
           4: 799 MHz 5: 799 MHz 6: 799 MHz 7: 799 MHz 8: 799 MHz
Graphics:  Card-1: Intel 2nd Generation Core Processor Family Integrated Graphics Controller
           bus-ID: 00:02.0
           Card-2: NVIDIA GF108M [GeForce GT 555M] bus-ID: 01:00.0
           Display Server: X.Org 1.18.4 driver: nvidia
           Resolution: 1366x768@60.00hz
           GLX Renderer: GeForce GT 555M/PCIe/SSE2
           GLX Version: 4.5.0 NVIDIA 384.90 Direct Rendering: Yes
Audio:     Card Intel 6 Series/C200 Series Family High Definition Audio Controller
           Sound: Advanced Linux Sound Architecture v: k4.10.0-38-generic
Network:   Card-1: Broadcom NetLink BCM57781 Gigabit Ethernet PCIe
           driver: tg3 v: 3.137 bus-ID: 07:00.0
           IF: enp7s0 state: up speed: 100 Mbps duplex: full mac: <filter>
           Card-2: Intel Centrino Wireless-N 1000 [Condor Peak]
           driver: iwlwifi bus-ID: 08:00.0
           IF: wlp8s0f0 state: down mac: <filter>
Drives:    HDD Total Size: 1000.2GB (11.4% used)
           ID-1: /dev/sda model: HGST_HTS541010A9 size: 1000.2GB
Partition: ID-1: / size: 46G used: 7.0G (16%) fs: ext4 dev: /dev/sda1
           ID-2: /home size: 862G used: 91G (12%) fs: ext4 dev: /dev/sda5
           ID-3: swap-1 size: 10.00GB used: 0.00GB (0%) fs: swap dev: /dev/sda6
Sensors:   System Temperatures: cpu: 82.0C mobo: N/A gpu: 0.0:85C
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 253 Uptime: 36 min Memory: 963.1/8040.4MB
0: ideapad_wlan: Wireless LAN
Soft blocked: no
Hard blocked: no
1: ideapad_bluetooth: Bluetooth
Soft blocked: no
Hard blocked: no
2: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
3: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
Последний раз редактировалось пользователем 1 Dja; всего редактировалось раз: 11
Skrabus
10 ноя 2017, 22:15
Ivanov_k
Решено: 8
Благодарил (а): 12 раз
10 ноя 2017, 22:32
А при установки системы он видел сеть?
Skrabus
10 ноя 2017, 22:34
Нет он пытался но при установке использовал провод... До этого пробывал без инета WiFiне подхватывает...
Ivanov_k
Решено: 8
10 ноя 2017, 22:35
А когда у вас был виндовс,какие драйверы вы ставили на WLan ?
Skrabus
10 ноя 2017, 22:37
Винда атоматом ставила Вафлю.... Пробывал через Установщик драйверов для Винды поставить ...Не определяет устройство...хоть тресни....
Ivanov_k
Решено: 8
10 ноя 2017, 22:39
Skrabus
10 ноя 2017, 22:42
А как их в Минт то воткнуть .exe .... через драйвер Виндоуз... пишет нет файла .inf, а те что нашел не включаются все равно....
Ivanov_k
Решено: 8
10 ноя 2017, 22:44
А утилита минта по поиску драйверов находит что-то?
Skrabus
10 ноя 2017, 22:48
в firmware Драйвера стоят iwlwifi-1000-5.ucode и iwlwifi-1000-3.ucode. А все равно не видит сети....
Skrabus
10 ноя 2017, 22:56
Ivanov_k
Решено: 8
10 ноя 2017, 22:57
apt-cache search слово_поиска
apt-get install имя_пакета
например apt search Centrino Wireless и тп либо синаптиком
предварительно сделай бекап системы.
Skrabus
10 ноя 2017, 23:13
ksp-Lenovo-IdeaPad-Y570 Загрузки # apt-get install linux-firmware-bf04291309d3169c0ad3b8db52564235bbd08e30
E: Не удалось найти пакет linux-firmware-bf04291309d3169c0ad3b8db52564235bbd08e30
Причина: spoil
Skrabus
10 ноя 2017, 23:14
Что я не так делаю.... :sad:
Ivanov_k
Решено: 8
10 ноя 2017, 23:31
поищите в репозитариях командой которую я дал пакет с подходящим названием под модель вашей Wlan карт
Skrabus
10 ноя 2017, 23:56
ksp@ksp-Lenovo-IdeaPad-Y570:~$ apt-cache search Intel Centrino Wireless-N 1000 [Condor Peak]
E: Regex compilation error
amtterm - Serial-over-lan (sol) client for Intel AMT, console version
ksp@ksp-Lenovo-IdeaPad-Y570:~$ apt-cache search Intel Centrino amtterm
ksp@ksp-Lenovo-IdeaPad-Y570:~$ amtterm
Программа 'amtterm' на данный момент не установлена. Вы можете установить её, выполнив:
sudo apt install amtterm
ksp@ksp-Lenovo-IdeaPad-Y570:~$ sudo apt install amtterm
[sudo] пароль для ksp:
Рекомендуемые пакеты:
libsoap-lite-perl
amtterm
обновлено 0, установлено 1 новых пакетов, для удаления отмечено 0 пакетов, и 0 пакетов не обновлено.
Необходимо скачать 19,7 kБ архивов.
После данной операции, объём занятого дискового пространства возрастёт на 59,4 kB.
Пол:1 http://mirror.yandex.ru/ubuntu xenial/universe i386 amtterm i386 1.4-1 [19,7 kB]
Получено 19,7 kБ за 0с (298 kБ/c)
Выбор ранее не выбранного пакета amtterm.
(Чтение базы данных … на данный момент установлено 277846 файлов и каталогов.)
Подготовка к распаковке …/amtterm_1.4-1_i386.deb …
Распаковывается amtterm (1.4-1) …
Обрабатываются триггеры для man-db (2.7.5-1) …
Настраивается пакет amtterm (1.4-1) …
ksp@ksp-Lenovo-IdeaPad-Y570:~$ sudo amtterm
This is amtterm, release 1.4, I'll establish
serial-over-lan (sol) connections to your Intel AMT boxes.
usage: amtterm [options] host [port]
options:
-h print this text
-v verbose (default)
-q quiet
-u user username (default: admin)
-p pass password (default: $AMT_PASSWORD)
By default port 16994 is used.
If no password is given amtterm will ask for one.
(c) 2007 Gerd Hoffmann <kraxel@redhat.com>
А дальше что... ??????
 ! Сообщение из: Dja
А вот криком Вы себе не поможете
Причина: spoil
11 ноя 2017, 00:07
Skrabus писал(а):
10 ноя 2017, 23:56
Оно тут совсем не причем, можешь удалять обратно)
Skrabus
11 ноя 2017, 00:10
ksp@ksp-Lenovo-IdeaPad-Y570:~$ sudo amtterm -u 16994
options:
-h print this text
-q quiet
ksp@ksp-Lenovo-IdeaPad-Y570:~$ sudo amtterm -v 16994
AMT password for host 16994:
amtterm: NONE -> CONNECT (connection to host)
ipv4 16994 [0.0.66.98] 16994 connect: Invalid argument
amtterm: CONNECT -> ERROR (failure)
amtterm: ERROR:
ВВожу пароль $AMT_PASSWORD и тничего.... ?????
 ! Сообщение из: Dja
Еще раз. Кричать не стоит. Предупреждение. Пока устное.
Причина: spoil
Skrabus
11 ноя 2017, 00:11
ksp@ksp-Lenovo-IdeaPad-Y570:~$ sudo apt-get remove amtterm
Пакеты, которые будут УДАЛЕНЫ:
amtterm
обновлено 0, установлено 0 новых пакетов, для удаления отмечено 1 пакетов, и 0 пакетов не обновлено.
После данной операции, объём занятого дискового пространства уменьшится на 59,4 kB.
Хотите продолжить? [Д/н] д
(Чтение базы данных … на данный момент установлено 277855 файлов и каталогов.)
Удаляется amtterm (1.4-1) …
Причина: spoil
11 ноя 2017, 00:14
Skrabus писал(а):
10 ноя 2017, 23:14
прежде всего не читаешь правила
