Радеон 530 не могу установить драйвер
VaisVitaly
13 сен 2017, 13:35
Добрый день всем! Помогите установить нужный драйвер, что-то видимо руки пока крабоподобные самостоятельно не могу
VaisVitaly
13 сен 2017, 13:37
System:    Host: vitaly-HP-Laptop Kernel: 4.10.0-33-generic x86_64 (64 bit gcc: 5.4.0)
           Desktop: Cinnamon 3.4.6 (Gtk 3.18.9-1ubuntu3.3)
           Distro: Linux Mint 18.2 Sonya
Machine:   System: HP product: HP Laptop 15-bw0xx v: Type1ProductConfigId
           Mobo: HP model: 8333 v: 28.24 Bios: Insyde v: F.10 date: 05/11/2017
CPU:       Quad core AMD A10-9620P RADEON R5 10 COMPUTE CORES 4C+6G (-MCP-) cache: 4096 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm) bmips: 19962
           clock speeds: max: 2500 MHz 1: 1600 MHz 2: 1300 MHz 3: 1600 MHz
           4: 1600 MHz
Graphics:  Card-1: Advanced Micro Devices [AMD/ATI] Carrizo bus-ID: 00:01.0
           Card-2: Advanced Micro Devices [AMD/ATI] Topaz XT [Radeon R7 M260/M265]
           bus-ID: 05:00.0
           Display Server: X.Org 1.18.4 drivers: ati,amdgpu (unloaded: fbdev,vesa,radeon)
           Resolution: 1920x1080@60.01hz
           GLX Renderer: Gallium 0.4 on AMD CARRIZO (DRM 3.9.0 / 4.10.0-33-generic, LLVM 4.0.0)
Audio:     Card-1 Advanced Micro Devices [AMD] Device 157a
           driver: snd_hda_intel bus-ID: 00:09.2
           Card-2 Advanced Micro Devices [AMD/ATI] Kabini HDMI/DP Audio
           driver: snd_hda_intel bus-ID: 00:01.1
           Sound: Advanced Linux Sound Architecture v: k4.10.0-33-generic
Network:   Card-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
           driver: r8169 v: 2.3LK-NAPI port: 4000 bus-ID: 01:00.0
           IF: enp1s0 state: down mac: f4:30:b9:3c:9f:6a
           Card-2: Realtek RTL8723BE PCIe Wireless Network Adapter
           driver: rtl8723be port: 3000 bus-ID: 02:00.0
           IF: wlo1 state: up mac: 3c:95:09:ee:fc:a7
           WAN IP: 83.246.215.162
           IF: wlo1 ip-v4: 192.168.0.100 ip-v6: fe80::7783:6428:6a08:669b
           IF: enp1s0 ip-v4: N/A ip-v6: N/A
Drives:    HDD Total Size: 500.1GB (2.8% used)
           ID-1: /dev/sda model: ST500LT012 size: 500.1GB
Partition: ID-1: / size: 185G used: 6.0G (4%) fs: ext4 dev: /dev/sda6
           ID-2: swap-1 size: 8.02GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
Sensors:   System Temperatures: cpu: 20.0C mobo: 0.0C
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 228 Uptime: 19 min Memory: 1482.1/7443.8MB
Последний раз редактировалось пользователем 1 Dja; всего редактировалось раз: 13
Причина: spoil
Filin
Благодарил (а): 55 раз
13 сен 2017, 16:54
Так вы драйвер принудительно поставили? Из за чего? Пожалуйста смотивируйте. Свободный драйвер не пошёл?
VaisVitaly
13 сен 2017, 19:21
Установка методом как было описано в теме Установка видеодрайвера AMD (fglrx) в Linux Mint 18 (18.1 / 18.2) не помогла
VaisVitaly
13 сен 2017, 19:23
           Display Server: X.Org 1.17.3 driver: N/A
Причина: spoil
13 сен 2017, 19:25
lspci -k посмотри, что там сейчас про видеоадаптеры
VaisVitaly
13 сен 2017, 19:27
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 1576
	Subsystem: Hewlett-Packard Company Device 8333
00:01.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Carrizo (rev ca)
	DeviceName: ATI EG BROADWAY
	Subsystem: Hewlett-Packard Company Carrizo
	Kernel driver in use: amdgpu
	Kernel modules: amdgpu, fglrx
00:01.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Kabini HDMI/DP Audio
	Subsystem: Hewlett-Packard Company Kabini HDMI/DP Audio
	Kernel driver in use: snd_hda_intel
	Kernel modules: snd_hda_intel
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 157b
00:02.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 157c
	Kernel driver in use: pcieport
	Kernel modules: shpchp
00:02.4 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 157c
00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 157b
00:03.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 157c
00:08.0 Encryption controller: Advanced Micro Devices, Inc. [AMD] Device 1578
00:09.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 157d
00:09.2 Audio device: Advanced Micro Devices, Inc. [AMD] Device 157a
00:10.0 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB XHCI Controller (rev 20)
	Subsystem: Hewlett-Packard Company FCH USB XHCI Controller
	Kernel driver in use: xhci_hcd
00:11.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 49)
	Subsystem: Hewlett-Packard Company FCH SATA Controller [AHCI mode]
	Kernel driver in use: ahci
	Kernel modules: ahci
00:12.0 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB EHCI Controller (rev 49)
	Subsystem: Hewlett-Packard Company FCH USB EHCI Controller
	Kernel driver in use: ehci-pci
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 4a)
	Subsystem: Hewlett-Packard Company FCH SMBus Controller
	Kernel driver in use: piix4_smbus
	Kernel modules: i2c_piix4, sp5100_tco
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 11)
	Subsystem: Hewlett-Packard Company FCH LPC Bridge
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 1570
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 1571
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 1572
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 1573
	Kernel driver in use: k10temp
	Kernel modules: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 1574
	Kernel driver in use: fam15h_power
	Kernel modules: fam15h_power
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 1575
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
	Subsystem: Hewlett-Packard Company RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
	Kernel driver in use: r8169
	Kernel modules: r8169
02:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8723BE PCIe Wireless Network Adapter
	DeviceName:
	Subsystem: Hewlett-Packard Company RTL8723BE PCIe Wireless Network Adapter
	Kernel driver in use: rtl8723be
	Kernel modules: rtl8723be
05:00.0 Display controller: Advanced Micro Devices, Inc. [AMD/ATI] Topaz XT [Radeon R7 M260/M265] (rev ff)
Причина: spoil
13 сен 2017, 19:28
Блеклистить amdgpu, там же было в инструкции
VaisVitaly
13 сен 2017, 19:31
Извините чет не вижу
Благодарил (а): 794 раза
13 сен 2017, 19:36
13 сен 2017, 19:36
modprobe.blacklist=radeon modprobe.blacklist=amdgpu
добавить в /etc/default/grub к значению в строке GRUB_CMDLINE_LINUX_DEFAULT и затем выполнить sudo update-grub
darkfenix, Опередил)
13 сен 2017, 19:42
Chocobo, :blum:
VaisVitaly
13 сен 2017, 19:44
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash" сюда?
VaisVitaly
13 сен 2017, 19:51
Вот еще что вылезло sudo update-grub
/usr/sbin/grub-mkconfig: 11: /etc/default/grub: modprobe.blacklist=radeon: not found
13 сен 2017, 20:03
Сделай как на скриншоте, обрати внимание на кавычки. Скорей всего мимо написал
VaisVitaly
13 сен 2017, 20:08
Сделал, и все таки я смог, упал мой линукс минт
13 сен 2017, 20:10
Корица не взлетела? в /etc/environment переменные вносил?
VaisVitaly
13 сен 2017, 20:11
Теперь завтра буду переустанвливать
VaisVitaly
13 сен 2017, 20:12
Да добавлял
13 сен 2017, 21:50
на этапе меню GRUB можешь нажать e и выпилить строчку после которой перестал грузиться.
Вернуться в «Видеокарты»
