VirtualBox не пробрасывает флешки
15 авг 2017, 09:16
Собственно вопрос в заголовке. В настройках виртуальной машины пытаюсь добавить подключенную флешку, а машина попросту ее не видит. Плагин установлен. Дополнения в гостевой ОС установлены.
~$ virtualbox --help
Oracle VM VirtualBox Manager 5.1.26
(C) 2005-2017 Oracle Corporation
All rights reserved.
~$ inxi -Fxz
System:    Host: nikita Kernel: 4.10.0-32-generic x86_64 (64 bit gcc: 5.4.0)
           Desktop: Cinnamon 3.4.6 (Gtk 3.18.9-1ubuntu3.3) Distro: Linux Mint 18.2 Sonya
Machine:   System: Hewlett-Packard product: HP Compaq 6200 Pro MT PC
           Mobo: Hewlett-Packard model: 1497 Bios: Hewlett-Packard v: J01 v02.15 date: 11/10/2011
CPU:       Quad core Intel Core i5-2400 (-MCP-) cache: 6144 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 24743
           clock speeds: max: 3400 MHz 1: 1771 MHz 2: 1603 MHz 3: 1626 MHz 4: 1709 MHz
Graphics:  Card-1: Intel 2nd Generation Core Processor Family Integrated Graphics Controller
           bus-ID: 00:02.0
           Card-2: NVIDIA GF106GL [Quadro 2000] bus-ID: 01:00.0
           Display Server: X.Org 1.18.4 drivers: nouveau (unloaded: fbdev,vesa) FAILED: intel
           Resolution: 1440x900@59.89hz, 1440x900@59.89hz
           GLX Renderer: Gallium 0.4 on NVC3 GLX Version: 3.0 Mesa 17.0.7 Direct Rendering: Yes
Audio:     Card-1 NVIDIA GF106 High Definition Audio Controller
           Card-2 Intel 6 Series/C200 Series Family High Definition Audio Controller
           Sound: Advanced Linux Sound Architecture v: k4.10.0-32-generic
Network:   Card-1: Intel 82579LM Gigabit Network Connection
           driver: e1000e v: 3.2.6-k port: f080 bus-ID: 00:19.0
           Card-2: 3Com 3c905C-TX/TX-M [Tornado] driver: 3c59x port: d000 bus-ID: 06:00.0
           IF: enp6s0 state: unknown speed: 100 Mbps duplex: full mac: <filter>
Drives:    HDD Total Size: 515.9GB (61.8% used) ID-1: /dev/sda model: ST3500413AS size: 500.1GB
           ID-2: USB /dev/sdb model: Transcend_16GB size: 15.8GB
Partition: ID-1: / size: 44G used: 13G (31%) fs: ext4 dev: /dev/sda1
           ID-2: /home size: 411G used: 268G (69%) fs: ext4 dev: /dev/sda5
           ID-3: swap-1 size: 4.19GB used: 0.01GB (0%) fs: swap dev: /dev/sda2
Sensors:   System Temperatures: cpu: 36.0C mobo: N/A gpu: 61.0
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 222 Uptime: 3:17 Memory: 3487.1/5853.7MB
           Init: systemd runlevel: 5 Gcc sys: 5.4.0 Client: Shell (bash 4.3.481) inxi: 2.2.35
Решение rogoznik » 15 авг 2017, 09:28
di_mok писал(а): А если запустить через sudo?
Не пробовал. Но думаю пробросилось бы. Т.к. удалось решить так sudo usermod -a -G vboxusers $USER
15 авг 2017, 09:24
15 авг 2017, 09:28
Filin
Благодарил (а): 55 раз
15 авг 2017, 11:52
Чуточку от темы. В Windows подразумеваю разделы NTFS Linux видит всё. Можно даже принудить его писать там нужное тебе но он вписывает свою корзину. Файл в общем то понятный даже ребёнку но в майкрософте принуждают к заголовку что система якобы повреждена. Он видит корзину Linux но демонстративно показывает это как ошибку в разбивке диска. Спорить не буду но на флешках если перепрыгиваешь с Linux на Windows спотыкаюсь бесконечно на сообщение. Консультации не прошу просто как комментарий вставил А корзину убирать не хочу. Я таки на Linux сидю. :smile:
AlexelA
Благодарил (а): 110 раз
15 авг 2017, 19:04
Проверить, обнаруживаются ли USB устройства, можно с помощью команды: VBoxManage list usbhost...
